Splinter Cell double agent
har en pentium 4 - 3.2 ghz
1024ram
xfx nvidia 7950GT 512mb agp 8x
lurer på om jeg kan kjøre det spillet rent uten lagg/hakking og problemer?
takker for svar.
1 gb ram til hadde ikke vært å forakte. Her er hvert fall system kravene til spillet.
Splinter Cell Double Agent Download Minimum System Requirements
Supported OS: Windows® XP (only)
Processor: 3 Ghz Pentium® 4 or AMD Athlon™ 3000 (3.5 Ghz Pentium 4 or Athlon 3500 recommended). Game optimized for Dual-processor-enabled computers.
RAM: 1 GB
Video Card: DirectX® 9.0c-compliant, Shader 3.0-enabled 128 MB video card (256 MB recommended) (see supported list*)
Sound Card: DirectX® 9.0c-compatible (EAX" recommended) - PC audio solution containing Dolby® Digital Live required for Dolby Digital audio.
DirectX Version: 9.0c or higher
Hard Drive Space: 8 GB
Peripherals Supported: Mouse, keyboard
Multiplay: Broadband connection with 128 kbps upstream or faster
*Supported Video Cards at Time of Release
ATI® X1600/X1800/X1900 NVidia® 6600 /6800/7300/7600/7800/7900
Laptop versions of these cards may work but are NOT supported.
