Hvordan bli attuned til Karazhan
1. Gjør ferdig to quester utenfor Karazhan. (Drep x mobs / finn to steder rett nedenfor Karazhan og bruk et item på dem)
2. Dra til Dalaran.
3. Snakk med Khadgar i Shattrath.
4. Dra til Shadow Labyrinth.
5. Dra til Arcatraz i Tempest Keep og Steam Vaults i Coilfang Reservoir.
1. Hit 70 and grab a flying mount
2. Go to Karazhan and do 2 quests (which are soloable I've been told)
3. Go to the Shadow Labyrinth, defeat Murmur and loot the key next to him.
4. Go to the Steam vault, defeat the 1st boss and loot the key nearby.
5. Fly to Arcatraz, defeat the the 1st boss and loot the key nearby.
6. Complete Old Hillsbrad to gain access to the Black Morass instance.
7. Complete the Black Morass instance and speak to Medivh.
Fra guildforumet :)
Hva er old hillbrad? En instance?
Og hva sier Medivh?
Old Hillsbrad er den første instancen i Caverns of Time. Caverns of Time finner du for øvrig i Tanaris, og er en samling instancer der du drar tilbake i tid for å hjelpe helter i Warcraft-historien.
7917829[/snapback]
Befrir Thrall :love:
Elsker den instancen, hjelpe Thrall å greier :dribble:
Jeg skrev denne på guildforumet for en stund siden, den er kanskje litt overdrevent beskrevet til tider men det skader vel ingen
Starting the questline!
Quest 1:
Quest: Arcane Disturbances
Starts at NPC: Archmage Alturus
Location: Outside the instance of Karazhan. Cords: 50,80 Deadwind pass
Basically what you need to do here is go down to a cellar located in a nearby house (entrance at 47,78)
Just run around there until you see the pond, very easy to spot. Now right click the crystal and go back out of the cellar.
Then do the well, the well is in another cellar located just next to the other one (entrance at 48,78)
This is where the
Just go straight down the hallway, be careful as there are mobs at both sides. When you reach the room with the hole in it you go to the right and follow that hallway until the next room, the well is then on the right. Right click the crystal in your inventory when standing next to it.
Now go back to the quest giver.
Quest 2:
Quest: Contact from Dalaran
Now you need to go to Hillsbrad Foothills, Southshore then move to Dalaran. You will find Archmage Cedric at cords 15,54.
Quest 3:
Quest: Khadgar
Starts at NPC: Archmage Cedric
Now go to Shattrath and visit Khadgar in the middle of the Terrace of Light (the center of Shattrath)
Quest 4:
Quest: Entry Into Karazhan
Starts at NPC: Khadgar
This key fragment is in a small vase next to Murmur!
Tip: If more than 5 needs the attunement, he can join the party after they have killed Murmur and run in and pick it up!
Quest 4:
Quest: The Second and Third Fragment
Ok, here you need to enter The Steamvault in Coilfang Resevoirs, the key fragment is in some chest.
For the third fragment you need to go to Arcatraz, in order to enter there you need a flying mount and one person in your party with the key. The fragment is also in some chest somewhere!
Quest 5:
Quest: The Master's Touch
Need to goto Caverns of Time (CoT) and finish the quest Opening of the Dark Portal. Before u can enter this part of CoT, you need to finish the following questline first:
- To the Master's Lair, starts: dragon at the entrence of CoT (note: dismount first ;P)
- Caverns of Time, starts: Andormu (z.Z)
- Old Hillsbrad, starts: Andormu
- Teretha's Diversion, starts: Erozion
- Escape from Durnholde, starts: Thrall (Thrall is in the basement of the keep)
- Return to Andormu
- The Black Morass, starts: Andormu
- The opening of the Dark Portal, starts: Sa'at
Endret av thomas_c24
2. Dra til Dalaran.
7915702[/snapback]
Takk takk, da var eg på god vei :thumbup:
Til thomas_c24: Fin guide spiller på silvermoon selv :thumbup:
Endret av albions
