[Sluppet] WLM 8.1 (8.1.0178.00) Støtte for Vista
Last ned her (norsk)
Da er Windows Live Messenger 8.1 ute av beta, med build 178 som final. Div. bug-fikser, samt bedre støtte for Vista.
Se Inside Messenger-bloggen for mer informasjon.
Vista Flash Crash Improvement
Klikk for å se/fjerne innholdet nedenfor
As you may recall if you have an old version of flash, Vista and Messenger 8.1 Beta the client was prone to crash. I still highly recommend you update your flash player if you haven't already. But if not we have put in and an extra safety measure (disable features that use flash and provide you a way to upgrade) to eliminate the flash crash.
What does Vista have to do with Messenger 8.1?
Messenger 8.1 was updated to work well with Vista.
What is new since the Messenger 8.0 (in case you didn't use the Beta)?
Roaming Identity - Your display name follows you any place you sign into. Now your display picture and personal message will follow you too. If you would prefer they stayed in place you can turn this off (Tools->Options->General -> Sign In -> "Use the same display picture....")
Contact Card - The contact card has gotten a updated look. Instead of a flip it does a slide to toggle between the Spaces and Contact information. Also no more squinting at an icon and trying to figure out what it means the actions on the card are now listed out plain and simple.
Emoticons, Winks, Backgrounds, Display Pictures - The menus have gotten an updated look. They include a recently used list and easy access to featured content so you can get new emoticons, winks, background and display pictures to use. hint: typcially in the featured section the first 4 are free.
SMS Phone Book - You now have a quick way to send SMS to a phone number or add phone numbers for your contacts. Just click the cell phone icon in them main window for a good time.
New Contact Emotion - In 8.0 all our icons got an update but we forgot a very important one. The contact emoticon. Type (M) to send it.
Status Menu includes Sign Out - We noticed people look in the status menu to sign out and so ta-da now you can sign out from the status menu.
Report abuse - Here is something you will hopefully never need to use, but it is there just in case in the help menus.
Vista Presentation Mode - When you are in Presentation Mode on Vista Messenger will change your status to busy so you can avoid the embarrassing situation of everyone reading your IMs! Don't worry if you want to show Messenger in your presentation you can turn this off (Tools->Options-> Personal-> My Status -> Show me as "Busy"...).
Behind the scenes changes - This release also includes changes to the "guts" of some of the features. The goal is for these changes to improve your experience. Please let us know if that is not the case.
Personal Invitation - When you add a new contact you can add a message so they know who you are. Especially helpful if your email address is something like ILoveMessenger(at)emaildomain.com - since there are so many of us out there.
