Patch 1.05 til BF2142 er ute
Då er patch 1.05 for Battlefield 2142 ute. Den kan lastast ned herifrå:
http://battlefield.ea.com/battlefield/bf/B...ews_112106.aspx
Her er lista over det som vart fiksa:
Klikk for å se/fjerne innholdet nedenfor
Fixed Ground Defense kills to properly count towards the Ground Base Defense Ribbon
Fixed an exploit with using the Air Transport to gain points at an unnatural rate
Fixed a issue that caused scores and ranks to be improperly displayed in the front end
The Silver Titan Destruction Badge will now be properly awarded when the core is destroyed
The PAC Duty Ribbon will no longer be awarded randomly when a player enters a server
Single player End of Round screen will now display round stats properly
Enemy Squad Leader Spawn Beacon is now visible on the 3d-map
Crouch may now be bound to the same key for both common use and land vehicles (Battlewalkers)
Fixed an issue which allowed the Titan guns to be re-supplied for points
Players may no longer repeatedly spam a squad leader with requests to join a locked squad
Accept and Reject prompts will no longer be displayed in the debug console
Titan Survival pin will now be correctly rewarded to players who safely escape a titan after the core is destroyed
Fixed the issue that prevented players from reviving team mates in a moving Titan
Fixed an exploit that allows players to use tanks to enter building geometry
Players may now play single player offline mode when EA master servers are down
Fixed issues with Battle Recorder Playback and Camera control
Fixed the issue that caused missile silos to appear in the wrong locations on players’ HUDs.
Fixed the issue that caused the Squad Leader Spawn Beacon to not be usable after map and round rotations.
Added the proper game information to the Swedish install for when a mutiny occurs against the commander
2142 will no longer show up as Battlefield 2 in the Windows Firewall Exception List
Altered some player collision inside the Titan. This should improve many of the Player / Titan interactions
Adjusted the Deviation per bullet on the Assault Rifles. This will allow the AR weapons to be more effective in medium to short range fire fights.
Titans will stop moving once the Titan shield go down
Battlefield 2142 will now close after a player selects “OK” in the patch prompt.
Added additional support during map load to prevent EA Master Server disconnects during map load times
Client Version is now displayed at the Login Screen
Fint å sjå at dei har fått fjerna det "fenomenet" som gjorde at ein kunne gje forsyningar til kanonene på titanen for å få poeng, i alle fall - den har vore flittig brukt på dei serverane eg har vore på... :)
Endret av Garegaupa
Angåenede CTD: tatt fra BF.no sitt forum
MEN! VIKTIG! Angående CTD:
Dice har opplevd dette problemet under testing og isolert det til grafikkortsdriverne.
Følgende opplyses:
Except for one person running NVIDIA drivers more than a year old all CTD’s are on NVIDIA drivers 93.71 and ATi drivers 6.11.
Men CTD oppleves også på andre drivere. Oppfølging til dette var:
This is not 100%, but has helped a good number of people.
Please delete your cache in the My Documents\Battlefield 2142\mods folder and the file icontent.cache.  This may help some and NVIDIA driver version 91.31 is confirmed to run with out crashing after clearing your cache.  Please roll back to version 91.31. You can download this driver here: http://download.nvidia.com/Windows/91.31/9...nglish_whql.exe
Så prøv dette dere som opplever CTD. Gi gjerne tilbakemelding om det funker, så skal
jeg bringe det videre.
Edit: Les også her: http://www.battlefield.no/forum/index.php?...dpost&p=1639153
Endret av Markaren
Jeg opplever at laggen er betydligere mer tilstede med denne patchen :hmm:
7344055[/snapback]
O B S ! :scared::scared:
Ny patch 1.06 er allerede ute.............fixer noen 1.05 bugger.
7344055[/snapback]
7351418[/snapback]
Hæ? Er dette sant? Kom ikke 1.05 for ett par dager siden? Og nå 1.06?
Makan til tull!
