Problemer med DVD Brenning
Hei.
Får feil ved brenning av Cd'er med Nero 7, har prøvd 3 ganger nå og får samme feilen. Når jeg prøver simulering går alt fint, men når jeg brenner får jeg feil på sluten av brenninga. Jeg har lagt ved log'en.
Noen som vet hva feilen kan være, så jeg slipper å ødelegge flere DVD plater ved feilbrenning.
SNK
Ofp
5C80001080000000005666878691
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02.11.2004 13:54:32
NT-SPTI used
Nero Version: 7.0.0.0
Recorder: <SONY DVD RW DW-D23A> Version: CYS1 - HA 1 TA 0 - 7.0.0.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <SONY DVD RW DW-D23A >Version: CYS1 - HA 1 TA 0 - 7.0.0.0
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD800JB-00ETA0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD2500JB-00GVC0 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : SONY DVD RW DW-D23A atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
SONY DVD RW DW-D23A G: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1047788kB)
Free physical memory: 694MB (710684kB)
Memory in use : 32 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
21.11.2006
ISO-kompilasjon
19:11:24 #1 Text 0 File Isodoc.cpp, Line 6410
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
19:11:24 #2 Text 0 File ThreadedTransfer.cpp, Line 525
ReadBuffer-Pipe got 81920KB of Memory
19:11:24 #3 Text 0 File Reader.cpp, Line 124
Reader running
19:11:24 #4 Text 0 File Writer.cpp, Line 113
Writer G: SONY DVD RW DW-D23A running
19:11:24 #5 ISO9660GEN -11 File Geniso.cpp, Line 3304
First writeable address = 0 (0x00000000)
19:11:24 #6 Text 0 File Burncd.cpp, Line 3301
Turn on Disc-At-Once, using DVD media
19:11:24 #7 Text 0 File DlgWaitCD.cpp, Line 277
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2099103 (466:28.03, 4099MB)
19:11:24 #8 Text 0 File DlgWaitCD.cpp, Line 289
Write in overburning mode: NO (enabled: CD)
19:11:24 #9 Text 0 File DlgWaitCD.cpp, Line 2568
Recorder: SONY DVD RW DW-D23A, Media type: DVD-R
Disc Manufacturer: AN32 -
Disc Application Code: 64, Disc Physical Code: 193
19:11:24 #10 Text 0 File DlgWaitCD.cpp, Line 456
>>> Protocol of DlgWaitCD activities: <<<
19:11:24 #11 Text 0 File ThreadedTransferInterface.cpp, Line 846
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2099104 (2099104) = #2099104/466:28.4
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2099104 blocks [G: SONY DVD RW DW-D23A]
19:11:24 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1058
Prepare recorder [G: SONY DVD RW DW-D23A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4298964992, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2099104 | lead-out | 1 | 0x41 | 0x00
19:11:24 #13 Text 0 File SCSIPassThrough.cpp, Line 34
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
19:11:24 #14 Phase 24 File dlgbrnst.cpp, Line 1724
Caching of files started
19:11:24 #15 Text 0 File Burncd.cpp, Line 4129
Cache writing successful.
19:11:24 #16 Phase 25 File dlgbrnst.cpp, Line 1724
Caching of files completed
19:11:24 #17 Phase 36 File dlgbrnst.cpp, Line 1724
Burn process started at 4x (5 540 KB/s)
19:11:24 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2669
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
19:11:24 #19 Text 0 File DVDR.cpp, Line 2469
Recording mode: Sequential Recording Mode for Multisession
19:11:24 #20 Text 0 File MMC.cpp, Line 21541
Set BUFE: Power-Burn -> ON , Adapt writespeed to disc : ON
19:11:24 #21 Text 0 File DVDR.cpp, Line 2624
Start write address at LBA 0
DVD high compatibility mode: Yes
19:11:24 #22 Text 0 File Cdrdrv.cpp, Line 8385
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
19:13:01 #23 SPTI -500 File SCSIPassThrough.cpp, Line 306
CdRom0: SCSIStatus(x00) WinError(1117) NeroError(-500)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x5C 00 00 00 00 00 00 00 0C 00 00 00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
Buffer x038ea600: Len xc
19:13:17 #24 SPTI -500 File SCSIPassThrough.cpp, Line 306
Sense Code: 0x00
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 00 20 00 00 20 00 00 00
Buffer x033d0000: Len x10000
0x20 53 74 61 72 20 5B 72 6C 5D 2E 61 76 69 80 00
0x00 00 00 50 58 05 02 00 00 00 00 00 1F EA E1 CD
0x05 C7 01 00 A7 4D 5C 66 07 C7 01 80 8E DE 17 98
19:13:17 #25 SPTI -1114 File SCSIPassThrough.cpp, Line 306
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1114)
Sense Key: 0x06 (KEY_UNIT_ATTENTION)
Sense Code: 0x29
Sense Qual: 0x00
Sense Area: 0x70 00 06 00 00 00 00 0A 00 00 00 00 29
Buffer x047c5000: Len x10000
19:13:17 #26 CDR -1114 File Writer.cpp, Line 302
Reset occurred
19:13:17 #27 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
19:13:17 #28 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
19:13:17 #29 Text 0 File DVDR.cpp, Line 2866
EndDAO: Last written address was 31
19:13:17 #30 Phase 133 File dlgbrnst.cpp, Line 1724
Writing short lead-out
19:13:17 #31 Phase 38 File dlgbrnst.cpp, Line 1724
Burn process failed at 4x (5 540 KB/s)
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
hadde samme feil med nero 7. La inn nero 6 fungerte utmerket.
Altså mitt tips er prøv med en annen versjon eller et annet program.
