Landkrabben Skrevet 6. september 2006 Skrevet 6. september 2006 Hei!! Noen som erfaring med Autocad her?? [/u]Jeg skulle legge inn noen symboler i autocad, altså disse her: ""How to load the Piping Symbols Library v1.1 in AutoCAD or AutoCAD LT 2006 or 2007 Note:This menu will only function with the version of the Piping Symbols Library purchased after August 2004. Contact us to receive instructions for your Piping Symbols Library that you purchased before August 2004. Step 1: Download the latest menus for the library. These menus are in .zip format. You'll need WinZip (or similar) to open them. Extract the menus to your computer's "Piping" folder where the Piping Symbols Library is located. Step 2: Load The New Menu File Into AutoCAD's Menu Bar A.) Open AutoCAD or AutoCAD LT B.) Type MENULOAD in the command line, press the Enter button. C.) When the "Load/Unload Customizations" dialog box appears, click on the "Browse" button. Browse to the folder "Piping" that you previously created on your computer and look for the following menu files: Hint: Make sure the "Files of type" drop-down box reads "Customized User Information (*.cui)". * For AutoCad: PIPE06.cui (for Imperial units) MPIPE06.cui (for metric units) * For AutoCad LT: PIPELT06.cui (for Imperial units) MPIPELT06.cui (for metric units) D.) Select the menu, then click "Load". Allow a few seconds for AutoCad to load the menu. You will see "PIPE" (imperial units) or “MPIPE” (metric units) in the "Loaded Customization Groups" list when it is complete. Click the "Close" button. "Piping Library" will now appear in AutoCad's menu bar. Step 3: Modify AutoCAD's Support File Search Path A.) In AutoCAD's command line, type OPTIONS then press Enter. B.) Under the "Files" tab, click on the plus symbol next to "Support File Search Path". C.) Click on the "Add" button, then click on "Browse" and search for the "Piping" folder on your computer. Select it. Click on "OK". The Piping Symbols Library for AutoCAD 2006 or 2007 is now ready to use."" Men dette fungerte ikkje i Autocad 2006.. Står at det mangler "ikoner".. Noen som har vore borti det samme?
