oppdatert rogue review, 1.12
http://forums.worldofwarcraft.com/thread.a...p=1#post1337254
We have been continuing to work on the review since the 'First Glimpse' post, the talent calculator unveiling, and we have been building upon those initial changes. After our own discussions and testing, as well as reviewing the player feedback we have received, we are planning to make the below additional changes to the rogue talents for patch 1.12.
Please keep in mind that these changes, as well as the review as a whole, are not final, and are still subject to change. We are moving closer to the launch of the Public Test Realms for 1.12 and we will be continuing to evaluate the changes throughout the testing process.
The 'First Glimpse' post and talent calculator can be viewed from the links below.
http://forums.worldofwarcraft.com/thread.a...e&t=1271292&p=1
http://www.worldofwarcraft.com/info/classe...s2/talents.html
# Murder has been changed to increase damage caused against Humanoid, Giant, Beast, and Dragonkin by 1%/2%.
# Remorseless Attacks has been reduced to 2 ranks, with the new effectiveness being 20% and 40%.
# Endurance has been changed to reduce the cooldown of your Sprint and Evasion abilities by 45 sec/1.5 min. It no longer increases the duration of Evasion.
# Weapon Expertise will now increases your skill with Fist, Dagger, and Sword weapons. It will no longer affect Maces, and this change is being followed up by
# Mace Specialization will now also add 1-5 weapon skill with Maces, in addition to the stun effect the talent already provides.
# Adrenaline Rush now has a reduced cooldown of 5 min.
# Elusiveness has been reduced to a 2 point talent and now reduces the cooldown of Vanish and Blind by 45 sec/1.5 min. It no longer reduces the cooldown for Evasion.
# Opportunity is being moved to a tier 1 talent, swapping places with Camouflage.
# Ghostly Strike has been reverted back to the previous 125% weapon damage, but retains its new Energy cost of 40.
# Setup will now also provide combo points if you fully resist an attackers spell.
# Improved Rupture, Improved Cheap Shot, and Improved Garrote have been removed.
# New talent 'Serrated Blades' is a tier 4 talent in the Subtlety tree, causes your attacks to ignore X of your targets Armor, and increases the damage dealt by your Rupture ability. The amount of Armor reduced increases with your level. At level 60, the ranks will reduce target Armor by 100/200/300 respectively.
# New talent 'Dirty Deeds' replaces the Improved Cheap Shot talent, reducing the Energy cost of both the Cheap Shot and Garrote abilities by 10/20.
# Garrote, Eviscerate, and Rupture now all scale with Attack Power. The previously announced Eviscerate book will still be made available in an undisclosed location. While we had always planned to scale these abilites at a point in the future, we felt that the rank upgrade for Eviscerate and damage increase for Garotte would provide a well needed boost in the current game and carry these abilities until the scaling mechanic was implemented. Our ultimate goal to scale the abilities in a future update was decided to be moved ahead, and the current plan is to implement scaling for these abilities in 1.12, instead of in a later update.
Again, please keep in mind that any of the above changes are subject to revision, reversal, or removal. We'll be continuing to evaluate these changes, and the review as a whole. Neither the talent calculator, nor these forum posts should be considered final word on the review.
Thanks for reading.
Haha! Yes!
Endelig hørte de på oss! Det tok bare omtrent 4000 mennesker som sa at de ville slutte å spille hvis de ikke fikset rogues! :p
Scaling = win!
Haha! Yes!
Scaling = win!
6485846[/snapback]
Skulle ønske det samme funket for oss warriors :( Påtide å geare up rogue alten min da
Å inni he**vette!!! :D :D :D
Jeg er så glad nå at jeg ikke veit hvor jeg skal gjøre av meg! :D Scalet Eviscerate! :D Og opportunity som Tier1 Talent! :D og.. og.. OG! :D :D :D
Åh herre! :D
Endelig hørte de på alle sammen! <3
Fortsatt ingen Fan of Knives. Kastekniver er tøffe, hadde vært greit dersom det var noen gode kastekniver på høy level, og om du kunne kaste en haug av gangen i alle mulige retninger om du følte for det.
"Scalet" Eviscerate kan godt bety at du med det aller beste utstyret tilgjengelig vil gjøre like mye skade som du gjør nå, og at du uten det aller beste utstyret vil gjøre langt mindre skade. Ikke fyr løs med champagne helt enda.
Endret av Pycnopodia
Jess, gleder meg til å fylle opp meg selv med combopoints når roguer resister "new and improved" demoshout/piercing med 30% resist, og å bli oneshotted av crusaderpowered eviscerate. Jaja, er jeg heldig får warrior ny tooltip. i burning crusade.
Ville gjerne sett imp sprint bytte plass med sleight of hand, er da helt klart et pve talent som passer bedre der.
Og imp S&D bytte med impBS, kunne blitt noen gode builds ut av det.
Men utenom det så ser det helt greit ut. Er rimelig fornøyd.
Endret av GhsotFace
6486344[/snapback]
Du har jo nesten ikke gjort annet enn å gråte over warrior nerfs det siste året. Du er en værre whiner en fjortissene på wow-europe forumet.
Det har enda ikke blitt klart hvordan eviscerate skal scale med gear, er ikke sikkert det blir den helt store dmg-buffen. At du fyller deg selv opp med combopoints gjør vel egentlig ikke så mye, da 5cp evis critter ikke over 1000 på plate uansett. Blir du oneshottet av det så er du naken med ressurection sickness.
PS: Gråter du IRL eller?
6486344[/snapback]
6486648[/snapback]
:roll:
PS: lyst på warn pga personangrep eller?
:roll:
6486731[/snapback]
Var ikke ment som noe personangrep, men et forsøk på å få deg til å droppe whinemachine holdningen. Les ditt eget inlegg en gang til. Når du gjentatte ganger kommer med slite uttalelser, går det på nervene løs.
Haha! Yes!
Scaling = win!
6485846[/snapback]
6485893[/snapback]
Huh?!
Denne patchen ble laget fordi warriors scaler med gear, og derfor gjør så SYKT mye skade nå! Hvor har du vært?
Jeg driter egentlig i hvor mye eviscerate scaler.. jeg kan godt gjøre like mye skade på eviscerate som jeg gjør nå (selv om det er tåpelig), så lenge ikke en som nettopp har blitt lvl 60 og har blue gear, skal gjøre like mye skade som meg i fullt epic.. :)
Var på tide at de satte opp scaling på rogues også. :p
Sånn det har vært nå, har jeg samlet gear etter hvordan det har sett ut, ikke pga stats, for det har ikke hatt noe annet å si enn hvor lenge jeg kan leve (stamina).. :)
Haha! Yes!
Scaling = win!
6485846[/snapback]
6485893[/snapback]
Huh?!
6486935[/snapback]
Han mener sikkert execute
Stilig... Er rimelig lei av combat atm, så tror jeg skal respecce til Hemo... 16/3/32 eller noe sånt. Ghostly Strike har jo også blitt veldig aktuelt nå når den bare koster 40 energy og gjør 125% wep dmg (+15% dodge i 7s).
Blir spennende å se hvordan de har tenkt å la evisc/etc scale med gear tho.
