bakgrunn borte ved fullskjerm i sdl
Den er forandret og forenklet litt, men her er den:
// "Graphics with SDL" turorial series Lesson 2
// by Marius Andra (http;//cone3d.gamedev.net/)
// NOTE: don't be alarmed if running this from
// Dev-C++ turns up a black screen. Compile it and then
// run it from the sources folder.
#include <stdio.h>
#include <stdlib.h>
#include <SDL/SDL.h>
SDL_Surface *back;
SDL_Surface *screen;
int xpos=0,ypos=0;
void Slock(SDL_Surface *screen)
 if ( SDL_MUSTLOCK(screen) )
   if ( SDL_LockSurface(screen) < 0 )
     return;
void Sulock(SDL_Surface *screen)
   SDL_UnlockSurface(screen);
void DrawIMG(SDL_Surface *img, int x, int y)
 SDL_Rect dest;
 dest.x = x;
 dest.y = y;
 SDL_BlitSurface(img, NULL, screen, &dest);
void DrawIMG(SDL_Surface *img, int x, int y, int w, int h, int x2, int y2)
 SDL_Rect dest;
 dest.x = x;
 dest.y = y;
 SDL_Rect dest2;
 dest2.x = x2;
 dest2.y = y2;
 dest2.w = w;
 dest2.h = h;
 SDL_BlitSurface(img, &dest2, screen, &dest);
void DrawBG()
 Slock(screen);
 DrawIMG(back, 0, 0);
 Sulock(screen);
void DrawScene()
 Slock(screen);
 DrawIMG(back, xpos-2, ypos-2, 132, 132, xpos-2, ypos-2);
 SDL_Flip(screen);
 Sulock(screen);
int main(int argc, char *argv[])
 Uint8* keys;
 SDL_Init(SDL_INIT_AUDIO|SDL_INIT_VIDEO);
 atexit(SDL_Quit);
 screen=SDL_SetVideoMode(640,480,32,SDL_HWSURFACE|SDL_DOUBLEBUF|SDL_FULLSCREEN); // det er her problemene begynner!
 back = SDL_LoadBMP("bg.bmp");
 DrawBG();
 int done=0;
 while(done == 0)
   SDL_Event event;
   while ( SDL_PollEvent(&event) )
     if ( event.type == SDL_QUIT )  {  done = 1;  }
     if ( event.type == SDL_KEYDOWN )
       if ( event.key.keysym.sym == SDLK_ESCAPE ) { done = 1; }
   DrawScene();
 return 0;
