Har så lyst på Druidium
Addonen Druidium eeeeer bare så fet!! Men jeg får den bare ikke til å virke! Noen som har den som kan forklare meg GRUNDIG! Det var mange ting jeg ikke skjønte helt på guiden... burde vært en film guide på den :D Men please hjelp meg, folks!
Kan noen PLEASE lage en film guide? :w00t:
Druidium:http://www.curse-gaming.com/mod.php?addid=2266
Endret av Vaag1991
Det står veldig grundig beskrevet på curse-gaming.com
Du må laste ned alle andre addsons som står på lista der i tillegg til DiscordArt modden og themen.
som det står i guiden:
Extract the rar file into a safe location (all but the wow folder)
- Do not copy the files yet
Hvilke filer er dette? Jeg kan poste hele guiden og så kan folk få forklare hvis de helst vil
Druidium install guide.
- Warning !-
Installing this addon is at own risk. If you lose data (macro’s etc) it is your own fault.
This guide simply tells you how to install this addon taking into consideration that it’s
the first addon pack being installed on your pc. Following this guide is not a guarantee
to 100% success and it might be possible you have to do some tweaking of your own.
If you are using different settings then noted in this guide it might be possible you will
not get the same result as shown on my screenshots. BUT this does not mean the ui does not
work with different settings.
Install guide:
Part1:
- Backup your Interface + WTF folder.
* F:\games\World of Warcraft\Interface (example)
* F:\games\World of Warcraft\WTF (example)
- Remove all content from your interface folder (don’t worry you can add your own addons later)
- Remove all content from the Saved variable map from your account
(don’t worry you can copy data from specific addons later if you want)
*F:\games\World of Warcraft\WTF\Account\SARCOPHILUS\SavedVariables (example)
- Extract the rar file into a safe location (all but the wow folder)
- Run WoW 1 time without any addons installed.
- Login with the character you want to setup the addon with first
- go to video options and set video resolution to 1280/1024 And turn ui scaling on and set it to 0.64 (far left)
If your system does not support this resolution use 1024/768 (or for some 1600/1200) but you might need
tweaking of your own when not using my default settings. Further down the guide will be explained hot to do this.
- If you are using any action bars provided by wow itself (left actionbar etc) turn them off!
go to interface options and at the bottom turn all action bar settings off.
- quit the game
Part2:
- go to the location you extracted the compilation
- go into the WTF/Account
- change the folder named ‘YOUR ACCOUNT NAME HERE’ to your account name.
- after that go into the folder and rename the map ‘YOUR CHAR NAME HER’ into your character name
( this is the character the ui will be created for the first time).
- Go into the SavedVariables folder (Account\youraccountname\Savedvariables\)
Part3:
You need to edit several files manually.
The files named below contain 2 words that need to be replaced with the correct info:
Yourcharnamehere
Yourrealmnamehere
Replace these with the desired info.
The character name is the char you setup the ui for the first time.
edit the following files:
- Confab.lua
- CT_MasterMod.lua
- eCastingBar.lua
- sct.lua
- Titan.lua
- Wardrobe.lua
Make sure you have replaced all 'Yourcharnamehere' 'Yourrealmnamehere'
for these files and saved them.
Part4:
- Copy the Interface + Addons folder into your World of Warcraft folder.
Make 100% sure you maintain the correct structure.
Part5:
- Run the game
All grafix + unitframe info should be in the correct location. Now to fix the action bars
- type '/DAB' in the chat window
- Go to MISC OPTIONS
- click load custom settings
- your done
Extra parts:
If you want to alter things yourself now this is what you need
/dart ( contains all settings for the grafix )
/dab ( contains all settings for the action bars )
/duf ( contains all settings for unit frames )
If you are using widescreen resolution you will need to move the art yourself by going into /dart.
And scale everything untill you get the result you desire.
Some goes for moving around unit frame info edit that by going into /duf.
For additional help with these addons go to the author page located here:
www.discordmods.com
Action bars.
Getting those to work for Stances/stealth/shapeshifting.
This is quite easy go trough the following steps.
- at options set a main bar ( this will be the main bar that will change when you change stances go stealth or shapeshift)
the bars that contain the buttons for the actual stance (standard you can change them)
- go to their options and at the bottom say for what stance/form the bar is and what to do
- select change with main bar at the bottom.
For more help with this addon go to www.discordmods.com
End.
I tillegg må du ha disse mods :
Chronos
CleanMinimap
Confab
CT_MasterMod
CT_RaidAssist
CT_Viewport
DiscordActionBars
DiscordArt
DiscordLibrary
DiscordUnitFrames
eCastingBar
GroupButtons
LS_Chat
MoveAnything
myModel
myTargetModel
sct
Sea
Titan
TitanDPS
TitanRegen
Wardrobe
