Trenger hjelp til å lage cs map
Hmm.. For meg var det der gresk.
hlcsg v3.2.1 rel 3.2.1 Final (Apr  3 2005)
Zoner's Half-Life Compilation Tools 3.2.1 For Half Life 1
Based on code modifications by Sean `Zoner' Cavanaugh.
Based on Valve's version, modified with permission.
Submit detailed bug reports to amckern at [email protected]
If you have a Compile error with this stage of compile, please check
http://www.zhlt.info or the Mods Mapping Forum 'Search Function'.
-----  BEGIN  hlcsg -----
Command line: C:\Valve\CSBANE~1\ZHLT\hlcsg.exe C:\Valve\Steam\SteamApps\luzifer_loff\counter-strike\cstrike\maps\test
Entering C:\Valve\Steam\SteamApps\luzifer_loff\counter-strike\cstrike\maps\test.map
Current hlcsg Settings
Name                |  Setting  |  Default
threads              [      1 ] [  Varies ]
verbose              [    off ] [    off ]
log                  [      on ] [      on ]
developer            [      0 ] [      0 ]
chart                [    off ] [    off ]
estimate              [    off ] [    off ]
max texture memory    [ 4194304 ] [ 4194304 ]
max lighting memory  [ 6291456 ] [ 6291456 ]
priority              [  Normal ] [  Normal ]
noclip                [    off ] [    off ]
null texture stripping[      on ] [      on ]
clipnode economy mode [      on ] [      on ]
clip hull type        [  legacy ] [  legacy ]
onlyents              [    off ] [    off ]
wadtextures          [      on ] [      on ]
skyclip              [      on ] [      on ]
hullfile              [    None ] [    None ]
nullfile              [    None ] [    None ]
min surface area      [  0.500 ] [  0.500 ]
brush union threshold [  0.000 ] [  0.000 ]
Using mapfile wad configuration
Wadinclude list :
[zhlt.wad]
0 brushes (totalling 0 sides) discarded from clipping hulls
CreateBrush:
(0.00 seconds)
SetModelCenters:
(0.00 seconds)
CSGBrush:
(0.02 seconds)
Including Wadfile: \valve\cs baner\zhlt\zhlt.wad
- Contains 0 used textures, 0.00 percent of map (8 textures in wad)
Using Wadfile: \valve\cs baner\map textures\as_armageddon.wad
- Contains 1 used texture, 100.00 percent of map (9 textures in wad)
Texture usage is at 0.08 mb (of 4.00 mb MAX)
0.03 seconds elapsed
-----  END  hlcsg -----
hlbsp v3.2.1 rel 3.2.1 Final (Apr  3 2005)
-----  BEGIN  hlbsp -----
Command line: C:\Valve\CSBANE~1\ZHLT\hlbsp.exe C:\Valve\Steam\SteamApps\luzifer_loff\counter-strike\cstrike\maps\test
Current hlbsp Settings
log                [      on ] [      on ]
nofill              [    off ] [    off ]
noopt              [    off ] [    off ]
null tex. stripping [      on ] [      on ]
notjunc            [    off ] [    off ]
subdivide size      [    240 ] [    240 ] (Min 64) (Max 512)
max node size      [    1024 ] [    1024 ] (Min 64) (Max 8192)
SolidBSP [hull 0] 47 (0.02 seconds)
Warning: === LEAK in hull 0 ===
Entity light_environment @ (-202, 192,  64)
Error:
  A LEAK is a hole in the map, where the inside of it is exposed to the
(unwanted) outside region.  The entity listed in the error is just a helpful
indication of where the beginning of the leak pointfile starts, so the
beginning of the line can be quickly found and traced to until reaching the
outside. Unless this entity is accidentally on the outside of the map, it
probably should not be deleted.  Some complex rotating objects entities need
their origins outside the map.  To deal with these, just enclose the origin
brush with a solid world brush
Leak pointfile generated
SolidBSP [hull 1] 65 (0.00 seconds)
Warning: No entities exist in hull 1, no filling performed for this hull
SolidBSP [hull 2] 65 (0.02 seconds)
Warning: No entities exist in hull 2, no filling performed for this hull
SolidBSP [hull 3] 69 (0.00 seconds)
Warning: No entities exist in hull 3, no filling performed for this hull
0.11 seconds elapsed
-----  END  hlbsp -----
hlvis v3.2.1 rel 3.2.1 Final (Apr  3 2005)
-----  BEGIN  hlvis -----
Command line: C:\Valve\CSBANE~1\ZHLT\hlvis.exe C:\Valve\Steam\SteamApps\luzifer_loff\counter-strike\cstrike\maps\test
>> There was a problem compiling the map.
>> Check the file C:\Valve\Steam\SteamApps\luzifer_loff\counter-strike\cstrike\maps\test.log for the cause.
-----  END  hlvis -----
hlrad v3.2.1 rel 3.2.1 Final (Apr  3 2005)
-----  BEGIN  hlrad -----
Command line: C:\Valve\CSBANE~1\ZHLT\hlrad.exe C:\Valve\Steam\SteamApps\luzifer_loff\counter-strike\cstrike\maps\test
-----  END  hlrad -----
:hmm:
test.bsp
Ja, du har en så kallt leak:
Error:
Error:
En lekasje? Det vil si en åpning elns en plass? Jeg aner ikke. :blush:
Men hvis det er det, så kan du jo se på fila jeg la ved. Jeg kan ikke se noe "lekasje!
Ja. Mappet ditt må være helt tett. Mange bruker å lage en skybox rundt hele mapet for å gjøre det tett. Det kan være ganske småe hull i mapet ditt. Så det er litt pirkearbeid. Av og til vanskelig å finne.
Men du kan sjekke etter feil før du kjører mapet, noe som er ganske lurt. Da finner du fort ut om det finnes leaks i mapet ditt, og hvor de befinner seg.
Hvordan lager man en slik skybox? Jeg regner med det blir brukt mange steder siden mange map har fri himmel.
Om du har leak i mappe er point fila god å ha. Load den inn og følg den røde linja.
Husker ikke helt men mener det var tools->load pointfile.
Skal du ha sky anbefaler jeg ikke en boks rundt hele brette med sky på. Gir sinnsyk høy count på brette. Har sett mange som har brukt denne løsningen. Forsegle heller brette der det skal være sky med sky og ikke lag en boks rundt hele brette.
Vet det ikke er lett i starten men er mye lettere å vende seg til det med en gang slik at du ikke får problemer med det når du blir flinkere med designe.
Hvor finner jeg den da?
Edit: Åpnet cs og valgte banen på lokal game. Da fikk jeg opp en feilmelding som sa at den ikke kunne åpne en .wad-fil som trengtes.
Endret av Luzifer
