Taxman Skrevet 13. august 2005 Skrevet 13. august 2005 Oppgraderet til siste catalyst, og reagerte på at jeg fikk en økning i antall prossesser som snurret og gikk. Det snurrer og går ti cli.exe, begge starter av bruker (dvs ikke system eller local service). Begge cli filene er bruker sånn ca samme mengde minne. Skal det være slik? Har reinstallert driver med restart i mellom, men fremdeles 2 cli'er. Lastet rett ned fra ATI's sider. Noen andre som har siste catalyst som har det samme "problemet"?
MistaPi Skrevet 13. august 2005 Skrevet 13. august 2005 Ja det skal være slik. Slår du på "system tray icon" får du 3 cli.exe prosesser. Q: Why does the Catalyst™ Control Center require 3 “CLI.exe” files as well a “Preview.exe” file? A: The Catalyst™ Control Center has been separated into different components (a unique instance of CLI.exe per component) because it allows us to tune the characteristics of the process instance to the type of component. One component is called the “Runtime”, which acts as a server to all of the other client components. The two other client components are the “User-Interface” and the “System Tray”. The client “CLI.exe”s are tuned differently to enhance performance; the “User-Interface” client is optimized to run for short periods of time, whereas the “System Tray” client is designed to run for long periods of time. The “preview.exe” file (used for the 3D preview) is a based on the Win32 process (whereas the rest of the Catalyst™ Control Center is based on the .NET framework), and is strictly an OpenGL application. Note that the preview “preview.exe” process is used only when the “User-Interface” is operating, and is ended as soon as the Catalyst™ Control Center is closed. - Catalyst Control Center FAQ
Freak627 Skrevet 13. august 2005 Skrevet 13. august 2005 huff det er jo bare D***! bruker mer system ram osv... holder mg til Nvidia jeg
KusaRS Skrevet 15. august 2005 Skrevet 15. august 2005 huff det er jo bare D***! bruker mer system ram osv... holder mg til Nvidia jeg Ja det å bruke 20MB av minnet er jo forferdelig...
Gjest Slettet+6132 Skrevet 15. august 2005 Skrevet 15. august 2005 huff det er jo bare D***! bruker mer system ram osv... holder mg til Nvidia jeg Ja det å bruke 20MB av minnet er jo forferdelig... En godt kodet driver/UI skal *ikke* bruke 20MB.. helst ikke 1MB en gang.. ATI Catalyst/Control-center basert på .NET er forøvrig en tragisk app.. omtrent som ett glorete reklame-innslag på TV2.. Men det er sikkert bare jeg som synes det...
Ostepølsa Skrevet 15. august 2005 Skrevet 15. august 2005 Selv synes jeg Control Center bare er tull, jeg holder meg til control panel jeg.
MistaPi Skrevet 17. august 2005 Skrevet 17. august 2005 Med Catalyst 5.8 har dem gått ned til en CLI.exe prosess uten "system tray icon" som ligger på 2-3MB. Jeg syns også CCC har blitt raskere.
