834HF42F242 Skrevet 27. juli 2005 Skrevet 27. juli 2005 (endret) Som den lovlydige borger jeg er, kjøper jeg mine spill. Men det er ikke dermed sagt at jeg liker å måtte sette i original-cd'en hver gang jeg skal spille. Tidligere var det veldig enkelt. Man kunne laste ned en cracket exe-fil, og visp; man kunne spille uten original-CD i drevet. Jeg har skaffet meg GTR FIA GT, og ønsker å spille dette uten å måtte ha CD'en i. Jeg fant følgende prosedyre på nettet, men før jeg tester det ut, vil jeg høre med dere her. Har noen andre prøvd dette tidligere, og vil det fungere? Eller er den siterte teksten ren humbug? GTR - Real Racing - Alcohol ------------------------------- No-CD method: In order to play without swapping the original CD-Rom all the time you need to do the following... 1. Make sure you have the latest version of Alcohol 120% or Daemon Tools installed. 2. Install GTR. 3. Shut down your computer and disconnect all your cd/dvd drives. 4. Start up your computer. 5. Open your Computer Management then go to> Device Manager> System Devices. If you have Alcohol installed you should see "Plug and Play BIOS Extension" and if you have Daemon Tools you should see "PnP BIOS Extension". If you have both installed you have to do the following for both. 6. Right click "Plug and Play BIOS Extension" or "PnP BIOS Extension" and go to Properties. 7. On the Details tab you can select "Device Instance ID". Looks like ROOT\SYSTEM\0003. Remember or write down the last numbers. 8. Now you go to> Start> Run> Now you type: regedit WARNING! You are now about to edit the registry. Errors in the registry can cause errors in your system. If you do exactly what's described here it won't go wrong. You are responsible for your own actions. 9. On the left side you go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\R oot\SYSTEM 10. Under the system folder you see the number(s) as you found in step 7. 11. Right click the number(s) and select "Permissions" 12. Click on the System group and set "Read" to "Deny" 13. Close regedit 14. Mount the .mds from this package 15. Start the game and use this serial: xxxx-xxxx-xxxx-xxxx-xxxx NOTE: This serial will only work with the .mds included. 16. Start the game and enjoy! When you update Alcohol or Daemon you need to follow these steps again. ------------------------------------ Thanks Simbin for making an excellent game!! When GTR comes available in your country make sure you buy your legal copy! This will invest in future titles. ------------------------------------ Sjediek Endret 27. juli 2005 av anth
Goophy Skrevet 27. juli 2005 Skrevet 27. juli 2005 Oj, det var en knotete metode. Det skal holde å lage et klon-image av CD-en og mounte det virtuelt.
834HF42F242 Skrevet 27. juli 2005 Forfatter Skrevet 27. juli 2005 (endret) Nope, det går ikke! Flere nye spill hvor det ikke lenger går. Verken å mounte et image eller en klon-cd i drevet. Endret 27. juli 2005 av anth
KayAU Skrevet 28. juli 2005 Skrevet 28. juli 2005 Som den lovlydige borger jeg er, kjøper jeg mine spill. Men det er ikke dermed sagt at jeg liker å måtte sette i original-cd'en hver gang jeg skal spille. Må berre få seie at eg er heilt utruleg einig. Heilt enormt, fenomenalt, sensasjonelt einig. Eg er so utruleg dritlei å måtte leite fram og sette inn ein CD kvar gong eg vil spele eit spel. Det er tungvindt. Det fører til unødvendig slitasje. Sidan eg har laptop, medfører det ein god del ekstra støy. Og det verste av alt er at eg kan ikkje forstå at det har nokon vesentleg begrensande effekt på piratkopiering i det heile. Det er liksom berre ei straff for oss som faktisk betalar for ting vi skaffar oss. Eg bruker vanlegvis å gå til gamecopyworld.com og leite etter ein patch etter å ha kjøpt eit nytt spel, men det er ikkje alltid eg finn ein, eller so kan den eg finn vere ustabil. Har irritert meg over situasjonen i lengre tid no. Kay
834HF42F242 Skrevet 28. juli 2005 Forfatter Skrevet 28. juli 2005 No-CD Cracks? Prøv med et nyere spill, som for eksempel Colin Mc Rae 5. Last ned en No-CD-crack og fortelle meg om det fungerer uten original-CD i. Svaret er nei... De har kommet et nytt beskyttelsessystem som gjør det umulig å få til med gamlemetoden. Les for øvrig startinnlegget!
