Mage build for PvP/grind og Instance
som det står i topic :)
men jeg lurer på om hvordan build som er bra for dette og hva jeg bør starte med?
har nettop starta en mage og er lvl 16atm
takker for svar etc på forhond :)
Endret av AltuZ
Selvom mange sier Fire er bra så er Frost egentlig (min mening) best på grinding/pvp og instances. Min måte og grinde på er:
frostbolt+frostbolt+frostbolt+frostnova+løpe litt vekk+frostbolt(crit)+CoC(crit)+død mob. omtrent ingen nedetid.
Bare du får deg evocation og instant arcane explosion så er jeg fornøyd.
Mitt build:
Class: Mage
Level: 60
Arcane Talents (18 points)
Improved Arcane Missiles - 5/5 points
Gives you a 100% chance to avoid interruption caused by damage while channeling Arcane Missiles.
Arcane Concentration - 5/5 points
Gives you a 10% chance of entering a Clearcasting state after any damage spell hits a target. The Clearcasting state reduces the mana cost of your next damage spell by 100%.
Improved Arcane Explosion - 5/5 points
Reduces the casting time of your Arcane Explosion by 1.5 seconds.
Evocation - 1/1 point
While channeling this spell, your mana regeneration is active and increased by 1500%. Lasts 8 seconds.
Improved Counterspell - 2/2 points
Gives your Counterspell a 100% chance to silence the target for 4 seconds.
Frost Talents (33 points)
Improved Frostbolt - 5/5 points
Reduces the casting time of your Frostbolt spell by 0.5 seconds.
Winter's Chill - 3/3 points
Increases the power of your chill effects by slowing the target's movement by an additional 10%.
Improved Frost Nova - 2/2 points
Reduces the cooldown of your Frost Nova spell by 4 seconds.
Ice Shards - 5/5 points
Increases the critical strike damage bonus of your Frost spells by 100%.
Cold Snap - 1/1 point
When activated, this spell finishes the cooldown on all of your frost spells.
Arctic Reach - 2/2 points
Increases the range of your Frostbolt spell and the radius of your Frost Nova and Cone of Cold spells by 20%.
Frost Channeling - 3/3 points
Reduces the mana cost of your frost spells by 15%.
Shatter - 5/5 points
Increases the critical strike chance of your frost spells against frozen targets by 50%.
Improved Cone of Cold - 3/3 points
Increases the damage dealt by your Cone of Cold spell by 35%.
Ice Block - 1/1 point
You become encased in a block of ice, protecting you from all physical attacks and spells for 10 seconds, but during that time you cannot attack, move, or cast spells.
Frostbite - 2/5 points
Gives your chill effects a 6% chance to freeze the target for 5 seconds.
Ice Barrier - 1/1 point
Instantly shields you, absorbing 455 damage. Lasts 1 minute. While the shield holds, spells will not be interrupted.
Level 40: 549 damage absorbed
Level 52: 678 damage absorbed
Level 58: 818 damage absorbed
Endret av Smeagoldfish
fire fra level 10 og respecc på level 24 til arcane med instant AE.
nei. clearcasting som du får ganske tidlig er såpass bra at det er verdt og ta den med en gang
okok :p
men de 5 første er de verste, satte mine på mindre resist sjanse, arcane missiles er blææææ :p
Jeg bruker helt samme build som Smeagold... 18arcane 33frost, Dette er et kjempe godt build.. Tok nettop en lvl 56elite (jeg er 55) uten å miste 1 eneste HP...
Angående Arcane Missiles, vil jeg si at Improved AM er et absolutt must..
Disse er ekstremt kjekke å ha når du har litt lite HP å stresser med å få drepe en mob som står helt intill deg, han kan ikke interrupte deg. Jeg har vertfall hatt kjempe mye nytte av de siden lvl 15.
Var Fire specced helt til lvl 50, var litt morro å få alle de gode frost talentene på en gang. Men Fire funket bra til da, men ikke like bra i PvE. Da brukte jeg 31arcane 20fire
I pvp er fire ubrukelig til alt annet enn ganking av lvl58 noobs.
Med en frost build har du nok ikke nok burst dps til å ta livet av en healer i pvp.
Pve, så er vel frostbolt (AM på CC) og blizzard de eneste offansive spellsa man bruker etter man er kommet over UBRS stadiet.
Etter min meining så kan du ikkje ha god build for både pvp og instance. Enten spesialisere seg på pvp (mykje burst damage) eller instance (mana effektiv). Eg ser så ofta at mages med typiske pvp build er tom for mana mens eg har 60-70% av min mana tilgjengeleg fortsatt.
Her er min (instance build):
Arcane talents (28 points)
Arcane Meditation - 5/5 points
Allows 15% of your Mana regeneration to continue while casting. <-- Bruker ein mage armor saman med denne vil ein ha 45% mana regeneration.
Presence of Mind - 1/1 point
When activated, your next Mage spell with a casting time less than 10 seconds becomes an instant cast spell.
Arcane Mind - 4/4 points
Increases your maximum Mana by 8%.
Frost Talents (23 points)
Permafrost - 1/5 points
Increases the duration of your chill effects by 1 seconds.
When activated, this spell finishes the cooldown on all of your cold spells.
Improved Blizzard - 3/3 points
Adds a chill effect to your Blizzard spell. This effect lowers the target's movement speed to 35% of normal. Lasts 1.50 seconds.
Improved Cone of Cold 2/3 points
Increases the damage dealt by your Cone of Cold spell by 25%.
Endret av fenris1911
Jeg kjører en fire/arcane build (30 fire/21 arcane)
Mot en mob gjør jeg følgende:
1) Fireball
2) Så mange scorch jeg rekker før mob'en er helt nærme
3) Fireblast
4) Frost nova
5) Fireball
6) Scorch til den er død
I PvP har jeg mest problemer mot:
1) Shadow priest
2) Druid (for få druids på min server så jeg får ikke øvd meg :p )
3) Shaman
4) Warlock
5) Rogue
6) Paladin
7) Warrior
EDIT: Et par leifer..
Endret av Rodney Mullen
Joa, det blir en del drikking, men har funka greit for meg hittil :)
Har det ikke så travelt, jeg valgte fire fordi jeg _trodde_ det var veldig bra i pvp (noe det ikke er), men jeg har blitt glad i det og vil fortsette med det.. Tror jeg :p
1) Fireball
3) Fireblast
4) Frost nova
5) Fireball
1) Shadow priest
3) Shaman
4) Warlock
5) Rogue
6) Paladin
7) Warrior
Så hunters tar du uten problemer? :hmm:
Må si jeg tviler. På huntern min så kan jeg drepe en mage før den rekker å se hva som angrep den. (Hvis jeg er heldig)
Aimed shot (crit ~2000dmg)+Multishot(600) da har ikke en mage lenge igjen og leve for å si det slik.
1) Fireball
3) Fireblast
4) Frost nova
5) Fireball
1) Shadow priest
3) Shaman
4) Warlock
5) Rogue
6) Paladin
7) Warrior
Hvilke elendige mager har du spilt mot? :o
