Loeb Skrevet 12. juni 2005 Skrevet 12. juni 2005 Sliter noe sinnsykt med dette oppdraget. Hvor man skal skyte ned 4 folk fra toget. Noen som har noen tips, har prøvd alt av tips som står på nettet
tjalla Skrevet 12. juni 2005 Skrevet 12. juni 2005 (endret) Det beste er vel å stå skrått bak, til høyre for dem Endret 12. juni 2005 av tjalla
genser Skrevet 13. juni 2005 Skrevet 13. juni 2005 (endret) Slet veldig mye med denne på PS2, men på PC gikk det av en eller annen grunn mye lettere. Du ser selv litt når skytteren treffer personene og når han treffer toget. Er du for nærme så bommer han og treffer toget, men hvis du holder litt avstand og gjerne litt bak dem så treffer han bedre. Bør bare være å posisjonere seg greit nok så bør det gå fint. edit: Kanskje dette hjelper This is what I would consider to be the first somewhat difficult mission in the game, and while it isn't particuarly hard by any means, it definitely has the potential to be frustration. Drive Smoke's car to Unity Station for your next set of instructions. After the scene hop onto the dirt bike with Smoke. What you need to do is keep up with the train and take out the four guys on top. Now you have to not only adjust your speed so you stay right beside them, but you also have to adjust your distance so that you aren't too close to the train. Being right beside the train the whole time will just lead Big Smoke to hit the train itself with every shot, the best location is on the right side of the train, and on the right side of the outer tracks. As you keep going you'll see a car in the distance, don't be too close to the front of the train when you approach it because it explodes when the train hits it. Next danger is when you approach the tunnel, watch out for the oncoming train, you should be safe if you're sticking with the right side of the tracks. In the next area you need to ride up the dirt path on the side and stay close to the edge of the cliff while Smoke fires upon the gangsters. Cross the bridge to the other side and drive down the hill in front of the train so you have the chance to get back on the right side. Now at this point the train speeds up, and around the next bend is the last chance you have to finish them off otherwise it disappears forever, so do what you can. When they're dead just drive Big Smoke back to his house to get some well earned respect. Endret 13. juni 2005 av arehei
Loeb Skrevet 13. juni 2005 Forfatter Skrevet 13. juni 2005 YES klarte det endelig!! Fant en M4, hoppa på toget og klarte å skyte ned alle sammen før jeg kom til den lave brua. Ved hjelp av denne guiden: However, I found a completely new way to do this mission. Get on the Sanchez as quickly as possible and speed off WITHOUT letting Big Smoke on. That's right, leave him behind. The first thing you will notice is that you are going much faster without him riding with you so you can zip ahead of the train. However, if you get too far ahead you will fail the mission. But I am not going very far ahead anyway. Follow the track and go through the long left turn. Right after the turn is a road crossing. Just to the left is a small ramp. This goes up to an elevated walkway then to a wide bridge railing. After climinbg that, you will see another small ramp that will lead you to the top of the 24 Hour Motel in Idlewood. Once you are on top of the Motel, get off the bike. From here you can jump on top of the train as it passes. Don't get too close to the edge of the roof though, you might jump over the train and land on the ground instead. If you make it to the top of the train, switch to your M4 then target and shoot the Vagos. The Vagos are pretty tough (they will quite a few shots to take down) but, because you are on top of the train instead of on the bike, they may just stand there making it a bit easier to kill them. Then M4 is easily the best weapon to take out the Vagos. It is powerful and fast. And you do need to kill them quickly while on the train. Why? Because if you don't kill them quickly you will be knocked off the train by a low hanging pedestrian bridge in East Los Santos. It should be noted that you can't use explosive weapons on the Vagos (even the Rocket Launcher).
Mats1988 Skrevet 13. juni 2005 Skrevet 13. juni 2005 Den hadde jeg også problemer med, jeg kjørte oppå den andre togskinne, men det er vist ikke helt "rett". Da jeg prøvde å kjøre på siden av den andre skinna, fikk jeg til det ganske fort.
Sovietpig Skrevet 13. juni 2005 Skrevet 13. juni 2005 jeg bare fulgte etter toget jeg... tok siste karn rett før den veisperringa
Fredrik Larsen Skrevet 13. juni 2005 Skrevet 13. juni 2005 Er bare å holde seg litt til siden og ikke så nært i bredden GTA:SA er dritdigg!
aklla Skrevet 17. juni 2005 Skrevet 17. juni 2005 det var vansklig ja, prøvde sikkert 10 ganger før jeg fant ut at jeg skulle hoppe med sykkelen opp på toget, da funka det fett
