Media program henger seg
Ok, det kan hende du bruker en eldre versjon av ALSA eller MPlayer.
Legg til dette i ~/.mplayer/config:
ao=alsa
Hvis ikke det fungerer så skal dette fungere:
ao=alsa:device=dmix
Du kan prøve det ut først med å skrive:
mplayer -ao alsa foobar.mpg
eller:
mplayer -ao alsa:device=dmix foobar.mpg
Endret av olear
prøv "mplayer -ao esd -vo xv <fil>"
(også "mplayer -ao help" og "mplayer -vo help" for å se liste over valgene. Når du har funne beste kombinasjonen ligger du dem inn i ~/.mplayer/config )
Jeg la inn "ao=alsa:device=dmix" i den config fila, og prøvde en vanelig film i mplayer, men fortsatt funka det ikke. trur jeg får samme meldingen:
$ mplayer halloween.mpeg
MPlayer 1.0pre6-3.3.5 © 2000-2004 MPlayer Team
CPU: Intel Celeron 2/Pentium III Coppermine,Geyserville (Family: 6, Stepping: 10)
Detected cache-line size is 32 bytes
CPUflags:  MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 0
Compiled for Debian.
Linux RTC init error in ioctl (rtc_irqp_set 1024): Permission denied
Try adding "echo 1024 > /proc/sys/dev/rtc/max-user-freq" to your system startup scripts.
Opening joystick device /dev/input/js0
Can't open joystick device /dev/input/js0 : No such file or directory
Can't init input joystick
Setting up LIRC support...
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support.
You will not be able to use your remote control.
Playing halloween.mpeg.
MPEG-PS file format detected.
VIDEO:  MPEG1  640x480  (aspect 1)  25.000 fps    0.0 kbps ( 0.0 kbyte/s)
Trying to force audio codec driver family libmad...
Opening audio decoder: [libmad] libmad mpeg audio decoder
AUDIO: 32000 Hz, 1 ch, 16 bit (0x10), ratio: 8000->64000 (64.0 kbit)
Selected audio codec: [mad] afm:libmad (libMAD MPEG layer 1-2-3)
vo: X11 running at 1024x768 with depth 24 and 32 bpp (":0.0" => local display)
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 640 x 480 (preferred csp: Mpeg PES)
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
The selected video_out device is incompatible with this codec.
VDecoder init failed :(
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG 1 or 2 (libmpeg2))
Checking audio filter chain for 32000Hz/1ch/16bit -> 32000Hz/2ch/16bit...
AF_pre: af format: 2 bps, 1 ch, 32000 hz, little endian signed int
AF_pre: 32000Hz 1ch Signed 16-bit (Little-Endian)
alsa-init: soundcard set to dmix
Terrasque  Skrevet 18/04/2005 : 08:12
funka med mplayer -ao esd <fil>, men ikke med det du skrev. skal jeg bare legge til 'mplayer -ao esd' i /.mplayer/config da?
Hadde hvert flott om det hadde funka i Totem også ;)
Står da i første innlegg at dette er en laptop, jeg anbefaler at trådstarter tar en titt på lydkort databasen til alsa-project.org og sjekker om kortet faktisk støtter HW-mixing før man starter på no heftig debugging av dmix ;)
Regel nr.1 er: Har du integrert lydkort så trenger du SW-mikser.
BTW: Står ingenting i databasen til ALSA om kort har HW-mikser.
Endret av olear
Ok.:) Er SW-mikser en pakke jeg kan instalere?
Du har dem allerede.
Det finnes tre miksere til Linux: ESD (GNOME), aRts (KDE) og dmix (ALSA)
EDIT:
dmix skal fungere perfekt med deg, sikkert på at det ikke er noe tull med .asoundrc filen?
Endret av olear
Jaok. men hvordan skal jeg gjøre så MPlayer eller Totem bruker ESD mikseren uten og måtte skrive masse rart i terminal a?
Endret av SaiMANN
Du fikk jo beskrivelse av meg i går hvordan du gjørt dette ;)
~/.mplayer/config
ao=esd
EDIT:
Totem bruker Gstreamer, du finner noe med media .... under instillinger i GNOME.
Endret av olear
Den sto på esd fra før. Men Totem vil jo fortsatt ikke funke som det skal :/
EDIT:
mplayer funker nå fra terminal men ikke med grafisk
Endret av SaiMANN
Hva mener du med grafisk?
gmplayer?
Åpne mplayer med nautilus?
Åpne mplayer med konqueror?
Kjør denne i en terminal:
yes lydtest > /dev/dsp
Hvis den gir lyd så bruker du ikke en softwaremikser, men alsa eller oss.
Endret av ratix
Sikker på at han har en .asoundrc fil?
Jeg ba han opprette den i går, så hvis han gjorde det rett så skal alt fungere.
Endret av olear
Da starter vi xmms og venter på at han skal lage den.. :p
Jaha?
(3) Hardware mixing supported
Om kortet har (3) under notes...
Ok, så ikke det.
Du glemmer jackd og mas, samt at den siste utgaven av oss har sw-mixer.
Om SaiMANN kjører esd over "oss-emulering" kan kanskje det skape problemer. Jeg forseslår å prøve dmix igjen, men å drepe esd først.
killall -9 esd
(Dersom prosessen heter esd, da).
lsof /dev/dsp
kan også være en idè, for å se hvilke prosesser som bruke dsp.
