Half-Life: City 17: Tid og sted.
HL1 tok vel sted i 1999 om jeg husker rett. Grunnen til at vi ikke får vite noe årstall i HL2 er fordi Valve ville gjøre deg like forvirret som det Gordon Freeman var. Derfor er det også lite detaljer om hvilket land du er i osv.
Jeg tror ikke Valve direkte valgte et land som de gikk ut i fra i spillet, mulig det er en russisk provins eller var det tidligere. Å finne navnet på landet blir litt av en nøtt.
Endret av TCi
  • 7 måneder senere...
HL1 tok plass i 2000-2009, det ser man om man ser på kalendere i det spillet, da ser man tydelig at årstallet er "200-", som betyr at det er uvisst hvilket år det er, men at det er en plass i 2000-2009.
  • 1 år senere...
Mulig dette blir en überbump, men here goes:
Beliggenheten:
Other speculated locations from with City 17 is inspired include:
Riga, Latvia. This is based again on the strong similarities between the game and the city. Interestingly, part of Riga, known as "Old Riga" is strongly reminiscent of Ravenholm (though one should note Ravenholm is not part of City 17, but a distinct community). Riga is also a coastal city with a coastline that closely matches that shown in Raising the Bar. Its skyline is dotted with many buildings of a similar style and colour as seen in City 17, and the area is famous for its Art Nouveau influences. Old Riga is an area that is also dotted with tramlines and churches, any of which would fit with Father Grigori's character. Most interestingly, however, is the number of spires on the skyline (especially the suspension bridge) and Riga Castle - all of which cluster around "Citadale Street" - a possible inspiration for the Citadel in Half-Life 2.
Vilnius, Lithuania, as the streets in HL2 are similar to the ones in Vilnius. The difference is City 17's addition of the canals.
Belgrade, Serbia, based on the nearly identical resemblance between the Parliament of Serbia building and the Overwatch Nexus in City 17.
City 17's name itself, which is thought to be a reference to the Soviet practice of numbering secret closed cities rather than naming them, as in Arzamas-16, Krasnoyarsk-26, Tomsk-7 and numerous others.
St. Petersburg, Russia. This could explain the abundance of canals and an ever-present chain of Café Baltic shops. St. Petersburg also has a large street called Nevsky Prospekt, which phonetically resembles Nova Prospekt, the ex-prison turned into a Combine facility.
Odesa, Ukraine, capital of the Odessa Oblast. Close to a large body of water, with similar architectural styles and heritage, and the same name as that of the character of Odessa Cubbage, and the resistance hideout in which he and a group of rebels live, called New Little Odessa, it could certainly apply for candidacy.
However, in addition to incorporating Eastern European elements, examples of Norwegian, Italian, Polish, Finnish and French influences also exist, suggesting that the setting is something of a montage of European locations.
MAO: City 17 er en blanding av mange europeiske byer!
2: Nightshotet over C17 som vle vist på første side er et bilde over New York City på kvelden:
Dette var bare for å klare opp, så ikke gi warn pga bump.
Endret av Acolyt3
EDIT: jeg så at Acolyt3 hadde den samme infoen i posten sin
La meg sjekke nerdebibelen RTB ....jeg fant det ikke ut, men jeg fant noe annet interesant.Han som gir rpg'en i HL2 heter Odessa,Odessa er et også et sted sør-øst Ukraina
Endret av Campin carl
7574975[/snapback]
Som også står i min post :p
-Half-Life 2 skulle egentlig starte på en isbryterbåt. De klimatiske forholdene ved det Kaspiske Hav gjør at det ville vært meningsløst med en isbryter ettersom det ikke finnes is der.
3423601[/snapback]
Satt og så på National geograpic channel en dag, de skulle bygge en enorm bro sør i europa, tror det var ved middelhavet.
Nå pilarene ble støpt( veldig store beist), så sank dem etterhvert de ble høyere, da brukte dem en Isbryter båt fra Norge til å taue den lengre ut, slik at dem kunne bygge dem høyere.
Tog du an? Point being at dem brukes til mye annet en isbryting, bla seismiske undersøkelser.
Ps: Det skal legges til at kommentatoren sa at en isbryterbåt fikk innbyggerene der nede til å heve øyenbrynene ;)
Endret av guttorm
en ting jeg lurer på..Gman er med i hl1 ja?
i såfall...er det han?
Klikk for å se/fjerne innholdet nedenfor
Endret av xitto
Off-Topic
startet akkurat på HL1 igjen for å shape historia litt før jeg bynner på HL2..
Jeg snoket rundt i garderoben og såg på alle navn på garderobe skapene
(hvor jeg foresten såg navnet bond)
Jeg fant et skap hvor det sto freeman på, så jeg tenkte jeg skulle prøve å se om den kunne opnes..jada, det kunne den..og her er hva som var inni..(vis ingen andre har sett det fra før da :p )
Jeg la merke til et lite bilde av en bebi oppe i høyre jørnet...kansje Freeman er far :ohmy: eller kansje det er han som gutt:)
tror nesten jeg må starte med HL1, og jobbe meg opp. Spilte HL2 en stund, uten å ha rørt 1'ern så her må d litt historieundervisning til ;p
