lazy weapon innstilling
trur det har noko med kor mykje våpenet ditt beveger seg. svinger frå side til side når du går/står/ligger.
Ja...ser ut som om du er inne på noe. Fant dette...:
Lazy Weapon: The Lazy weapon slider determines how much your character's gun "lags" onscreen. The further to the right the slider, the more your gun lags with movements, which may look more realistic to some people. Note however that while a high Lazy Weapon setting may make the gun appear to lag, your targeting cursor should never lag regardless of this setting. A lagging cursor is due to low FPS and is also affected by your Mouse settings under Control Options menu (see below).
...her:
http://www.tweakguides.com/Farcry_5.html
Merker ikke særlig forskjell jeg!!
  • 2 uker senere...
