Liestöl Skrevet 14. oktober 2004 Skrevet 14. oktober 2004 http://www.pointofexistence.com Ny patch. Laster ned nå... Har noen testa det? btw Gleder meg til DC 0.8
Croyfer Skrevet 14. oktober 2004 Skrevet 14. oktober 2004 (endret) For å komme med litt mer info: Point of Existence Version .1.5 (542 MB) ftp://poe1:[email protected]/PoEv0.1.5_Full.exe ftp://poe1:[email protected]/PoEv0.1.5_Full.exe ftp://poe1:[email protected]/PoEv0.1.5_Full.exe ftp://poe1:[email protected]/PoEv0.1.5_Full.exe http://www.fileplanet.com/download.aspx?f=144757 Point of Existence Version .0.1 - .1.5 (299 MB) ftp://poe1:[email protected]/PoEv0.1_.1.5_incremental.exe ftp://poe1:[email protected]/PoEv0.1_.1.5_incremental.exe ftp://poe1:[email protected]/PoEv0.1_.1.5_incremental.exe ftp://poe1:[email protected]/PoEv0.1_.1.5_incremental.exe http://www.fileplanet.com/download.aspx?f=146656 Point of Existence Version .1.5 Server (45,5 MB) ftp://poe1:[email protected]/PoE.1.5_Server.zip ftp://poe1:[email protected]/PoE.1.5_Server.zip ftp://poe1:[email protected]/PoE.1.5_Server.zip ftp://poe1:[email protected]/PoE.1.5_Server.zip ****************CHANGE LOG********************* Added: ====== •Sounds - Sounds, Sounds, and more sounds has been added to most of the content in previous versions, thanks to Wookie, our awesome new sound engineer •New versions of the M4A1; un-scoped, silenced, reflex •AK-74M - We've listened to you, and this has been given to the Russians •XM-109 - Another community suggestion, this experimental 25mm Anti-Material has been added to a spawn able kit for the USA •AT4 - a new Anti-Tank weapon has been added for the US side, found in a spawn kit •MP5A4 - a new SMG for the US forces •RPG-22 - new Anti-Tank weapon for the Russians •RPG29 - Russian Heavy Anti-Tank weapon found in spawn kit •Mk23 SOCOM - Silenced handgun for US •US Player Skins •Music! - Menu/load music •Custom Vehicle Icons •New scope textures on m8, m4a1 and the Sniper Rifles Tweaked: ======== •T90 vs. M1A2 - the issue with the T90 being more resilient to hits has been resolved, making for more balanced tank combat •Helicopter Yaw slightly increased •Plane Acceleration slightly increased •HeliMG's- Added Splash damage vs. infantry •Increased Velocity On Airplane/Heli MG's •Mara - This map has been given a new facelift by GreyJedi •BFV1.2 maps converted to PoE (Defense_of_Con_Thien, Fall_of_Saigon, Saigon68, and Operation_Cedar_Falls) •Improved AI Endret 15. oktober 2004 av Croyfer
Sjefern Skrevet 15. oktober 2004 Skrevet 15. oktober 2004 jessssssssss! Gleder meg! *pust pes!!* *laste ned*
Hr. Jenssen Skrevet 15. oktober 2004 Skrevet 15. oktober 2004 (endret) http://www.pointofexistence.com Ny patch. Laster ned nå... Har noen testa det? btw Gleder meg til DC 0.8 Jeg fikk en "fin" liten melding da jeg åpna linken din: DB function failed with error number 1016Can't open file: 'mos_session.MYI'. (errno: 145) SQL=SELECT session_id FROM mos_session WHERE session_id=MD5('7b848e153c7c1a884f9e401d595487e9') SQL = SELECT session_id FROM mos_session WHERE session_id=MD5('7b848e153c7c1a884f9e401d595487e9') Noen som kan linke til en annen high speed server for å laste ned? (helst ingen kø-drit) EDIT: ****************CHANGE LOG********************* Added: ====== •Sounds - Sounds, Sounds, and more sounds has been added to most of the content in previous versions, thanks to Wookie, our awesome new sound engineer •New versions of the M4A1; un-scoped, silenced, reflex •AK-74M - We've listened to you, and this has been given to the Russians •XM-109 - Another community suggestion, this experimental 25mm Anti-Material has been added to a spawn able kit for the USA •AT4 - a new Anti-Tank weapon has been added for the US side, found in a spawn kit •MP5A4 - a new SMG for the US forces •RPG-22 - new Anti-Tank weapon for the Russians •RPG29 - Russian Heavy Anti-Tank weapon found in spawn kit •Mk23 SOCOM - Silenced handgun for US •US Player Skins •Music! - Menu/load music •Custom Vehicle Icons •New scope textures on m8, m4a1 and the Sniper Rifles Tweaked: ======== •T90 vs. M1A2 - the issue with the T90 being more resilient to hits has been resolved, making for more balanced tank combat •Helicopter Yaw slightly increased •Plane Acceleration slightly increased •HeliMG's- Added Splash damage vs. infantry •Increased Velocity On Airplane/Heli MG's •Mara - This map has been given a new facelift by GreyJedi •BFV1.2 maps converted to PoE (Defense_of_Con_Thien, Fall_of_Saigon, Saigon68, and Operation_Cedar_Falls) •Improved AI Heh, høres ut som at PoE er raskere til å oppdatere ting enn DC var, da de var "fersk"! Har ikke noe imot det! Gleder meg skikkelig! BTW: Esker å krype rundt i gresset med en SVD, på det afrikanse savanne-brettet! Endret 15. oktober 2004 av MeTa][iC
Sjefern Skrevet 16. oktober 2004 Skrevet 16. oktober 2004 tysk nettsted Jeg hadde samme problemet men så fant jeg dette stedet. Kreveer at du registerer deg men det var ikke vanskelig. (selv uten så mye som en eneste tysk-time i mitt liv. Litt Derrek har det vel blitt for mange år siden men det er alt )
vorbis Skrevet 16. oktober 2004 Skrevet 16. oktober 2004 Lastet den ned igår, og synes det var en veldig bra forbedring i forhold til de tidligerer versjonene. Nye lyder på alle våpnene gir et litt annen "feeling", ikke den *dette er jo bf:v med andre skins på våpnene* Og så likte jeg den nye RPG-29, den ødela en m1a1 Abraham på et skudd, men du må sitte på huk eller prone for og skyte, ellers treffer du ikke.
janfredrik Skrevet 17. oktober 2004 Skrevet 17. oktober 2004 Er ny på dette greiene her... Har BF:V og vil ha dette her, har aldri hatt det før.. ¤Hva må jeg laste ned? ¤Hva gjør den med BF? ¤Har det noe å si for internett spilling? :?:
Hr. Jenssen Skrevet 17. oktober 2004 Skrevet 17. oktober 2004 Er ny på dette greiene her... Har BF:V og vil ha dette her, har aldri hatt det før.. ¤Hva må jeg laste ned? ¤Hva gjør den med BF? ¤Har det noe å si for internett spilling? :?: Jeg kan i allefall svare på de to siste spørsmålene dine: PoE (Point of Existence) er en mod til bf:v, som gjør spillet om til en slags nåtid, med Russere vs. Amerikanere. Det vil si at det er nye maps, nåtidens våpen og kjøretøy, + diverse andre duppedingser. For det andre: Du kan spille på nett med denne modden, men det er ikke slik at du MÅ spille denne modden når du først har installert den! Når du starter BF:V så går du inn på "custom game", og der kan du bestemme om du vil spille klassisk BF:V, PoE, eller eventuelt andre mods som du har installert.
Croyfer Skrevet 17. oktober 2004 Skrevet 17. oktober 2004 ¤Hva må jeg laste ned? PoEv0.1.5_Full.exe Se i min post helt øverst etter linker!
MemorY Skrevet 17. oktober 2004 Skrevet 17. oktober 2004 ¤Hva må jeg laste ned? må vel ha BF:V 1.2 og.. er det ikke 1.2 som er den nyeste versonen a??
Hr. Jenssen Skrevet 17. oktober 2004 Skrevet 17. oktober 2004 ¤Hva må jeg laste ned? må vel ha BF:V 1.2 og.. er det ikke 1.2 som er den nyeste versonen a?? jo
janfredrik Skrevet 19. oktober 2004 Skrevet 19. oktober 2004 Nå har jeg innstallert Poe, men jeg ser ikke noe valg for og velge dette jeg.. :|
Hr. Jenssen Skrevet 19. oktober 2004 Skrevet 19. oktober 2004 Nå har jeg innstallert Poe, men jeg ser ikke noe valg for og velge dette jeg.. :| Du kan enten velge å starte PoE fra snarveien som vanligvis blir satt på skrivebordet ditt, eller du går inn på CUSTOM GAME, hvor du finner valg av forskjellige mods som kan spilles.
