Når kommer DC 0.8?
Siden .8 ikke vil være en offisiell release så er det litt vanskelig å si når det blir sluppet, men vi får håpe at det kommer når alle bugsa er borte =)
1. Is this announcement concerning the next release of Desert Combat
Yes and no. This release has the help of the DC devs and includes material donated by testers. It is the size and compilation of the next DC release. It is however not "Desert Combat".
2. Is this the last release of Desert Combat
Yes and no. Officially: .7 was the last release. "DC Final" is an unofficial release created by some very dedicated DC developers (off the clock) and testers. Unfortunately Trauma studios is unable to continue Desert Combat as their schedules simply cannot handle it. Speculation about contracts is pure speculation and I cannot answer any questions about it.
3. Will work continue on this unofficial continuation mod for Desert Combat?
That is to be foreseen. It depends on how well this release is recieved. Although this is not official by Trauma studios, this is what the testers call the "next Desert Combat release". There's not a tester that doesn't disagree. This release is worthy of being called .8 - despite that it can't be
4. What will be in this unofficial release?
Well obviously some bug fixes. We are working with a skeleton crew and we can't get to every little thing on every map. But I think we got most of the big stuff.
Also some balancing things. The hummer is obviously fixed. I can't post the changelist. The bulk of the changes are cosmetic. The explosion effects have been revamped. There's a couple of new animations. The sounds are WAY cooler. The smoke trails for certain things have been revamped. Some new vehicle varients. A couple of innovative weapons for sure. New maps of course. We're still not sure what maps will make it - so I'm not going to list it.
It will be an AWESOME release. There are SOOO many refinements that it makes the game feel like modern combat. The old releases (to me) felt like a BF42 mod. Now its a whole new game.
5. When's it going to be released
Can't say. We are ramping up testing and are going to push it through quick - but we want to make sure we get all the bugs out
Les her: http://www.ucfclan.com/modules.php?name=Ne...e=article&sid=7
Patriot Missile launcher for the allies - this baby will be able to defend against scud attacks. In real life they intercept the scud and blow it up, that might be a bit hard in DC - lets see how it goes!
F117 Stealth Fighter will hopefully be added to DC .8 as well !!
BTW: nå er jo Trauma Studios (DC) kjøpt opp av DICE (BF) - vi kan nok vente oss noen GODE produkter fra den kanten! :)
http://desertcombat.com
DC-forum
Endret av Croyfer
Lurer på når 0.8 kommer, så annonse for 0.8 for 4 måneder sia, så burde vel komme snart nå?
Bl.a. Stealth fly skal være med :)
Er det ikke snakk om første offiselle release av dc nå og ikke en beta? I så fall blir det vel DC 1.0.
Den releasen som kommer nå vil hete DC Final - dette vil da være "DC 0.8"
DC Final utvikles ikke a Trauma studios slik som alle de foregående releasene har blitt. Siden Trauma jobber med EA på Battlefield2 er DC Final blitt utviklet av communitiet istedenfor.
Det er litt vanskelig å si når DC Final vil bli sluppet, men hvis du leser intervjuet overnfor så finner man ut at det ikke er så mange dagene/ukene igjen til vi får DC Final rett i fanget !
[iC' date=10/09/2004 : 15:35]
Når kommer DC 0.8?
Spørsmålet er egentlig ikke NÅR det kommer, men OM det kommer!
Hvordan kan du stille det spørsmålet når vi har screenshots, demos og at de faktisk driver med final testing i dette øyeblikk...
DC Final (0.8) vil komme !
[iC,10/09/2004 : 15:35]
Når kommer DC 0.8?
0.8 kommer om ett par dager ! litt for dumt sagt ! ) TOK VELDIG FEIL DER ! SORRY)
Endret av Lucas
Når kommer DC 0.8?
Man vet ALDRI noe for sikkert... :roll:
EDIT: Bortsett fra når det ER helt sikkert da :p
Endret av MeTa][iC
  • 2 uker senere...
Jeg trodde battlfield 2 skulle erstatte dc jeg?
Battlefield 2 blir ett helt nytt spill i Battlefield serien, ikke en mod (modifikasjon)
Battlefeild 2 blir vel det siste spillet EA kommer til å lage i Battlefield serien (vill gjetting)
DC 0.8 Final er ventet ut om ikke så alt for lenge siden de er langt inne i Beta testingen !
Den gjettninga blir nok litt for vill, for det er DICE som utvikler (eller "lager" som du liker å kalle det) BF spillene!
EA gir bare ut spillene og lager cover bilder og manual osv...
Hvem lager DC 0.8? Ikke Trauma Studios er det vel? I så fall blir det en offesiell patch?
