Macroer for alt
Her kan alle poste de macroene de mener for jobben gjort.
Dette kan være alt fra ta på seg armor til grinding av proff. macroer.
Når jeg kommer meg hjem idag skal jeg poste en Ch grinding macro som er utrolig effektiv.
Laterz Peeps
Har to macroer til medic grinding:
1: Macro name: tumbling
/tumbletostanding;
/macro tumbling
2: Macro name: Healing (target må være på tumbleren)
/healdamage;
/pause 5; (kan byttes ut med tall op til 10 avhengig av hvor mye du healer pr. stim)
/macro healing
Til slutt en fin macro for å stå utenfor theed og drepe sommerfugler:
Macro name: Autokill
/ui action targetSelf;
/ui action cycleTargetOutward;
/attack;
/pause 10; (alt ettersom hvor lang tid det tar å drepe et dyr for deg)
/macro autokill
(trykk gjerne ctrl+shift+S for å rotere field of wiev sånn at du ikke bare tar dyrene rett foran deg)
:w00t:
How to Grind Master Musician/Dancer:
Prerequisite: Not much
Cost: Training (if you can't find people on site to train you)
Time: God knows too long... most an afk job
Simple setup for this grind. Use the following macro for either dancer or entertainer:
/join;
/ui action toolbarSlot10;
/flourish 1;
/pause 15;
/flourish 2;
/pause 15;
/flourish 3;
/pause 15;
/flourish 4;
/pause 15;
/flourish 5;
/pause 15;
/flourish 6;
/pause 15;
/flourish 7;
/pause 15;
/flourish 8;
/ui action toolbarSlot11;
Place in F12 slot. Place the highest skill "begin playing/dancing" macro that you have in F11 slot. This macro will auto accept group invitations (because being in a group is crucial for gaining experience). You'll want to go to Theed cantina to do this. Once you train up in a specfic skill you'll want to play the newer type song/dance. Musician will take much longer than dancing because they will always be forced to play low level songs for incoming newbies who want to be part of the band (it's why there are Star Wars songs you've never heard in the cantina before, lol)
:w00t:
How to Grind Surveying Experience:
/survey;
/pause 5;
/sit;
/stand;
Place in F12. You'll have to have a resource pre-selected from your scanning tool before you start this. Adjust the timer if you wish
:w00t:
Macro Name: ClearCache
Purpose: clear cache, effektivt hvis du har en litt gammel pc. Denne macroen vil flushe grafikk kortet hvert 10 min.
Macro:
/flushGraphicsResources fullReset;
/pause 600;
/macro ClearCache;
:w00t:
Endret av The_Firm
Center Of Being
Makro navn: CoB
/ui action clearCombatQueue;
/CenterOfBeing;
/pause XX;
/macro CoB
XX = Sjekk CenterOfBeing Modifier du har for det våpenet du bruker, denne +1 er tallet som skal stå her
Heal
/healDamage Self
For PvP
Lag makroer for alle specials du bruker, avslutt med /deathblow. Riflemen avslutter med /snipershot.
Intimidate
/Intimidate1;
Bruk Intimidate2 hvis du er Master Brawler.
Hvordan Grinde Image Designer:
ETA: 1.5 hours +
Prerequisite: Requires partner
Cost: Training only (145k credits)
The grinder goes and gets novice entertainer, and writes the following macro for themself, and places the macro in the F12 toolbar slot.
/im;
/imagedesignSetValue eyeshadow 1;
:w00t:
Virker ikke nå når timeren har kommet
Creture Handler Grind:
/ui action untarget;
/tellpet attack;
/pause 6;
/macro CHGrind
Denne er veldig effektiv, pleier å afk i Theed ved siden av fossen..
Dette er noe av det samme som orcblood har skrevet før bare med en pet.
:w00t:
Das Schtimt!! :thumbup: Hvor er Geo Cave? Hvilken planet ? WP?
Har kun grindet i Squill Cave.. :roll:
En annen ting; Jeg har nettopp fåt AV-21 schemeticsen, men på hvilken corvette finner jeg powerplaneten som gjør det mulig å bygge opp en AV-21??
Endret av The_Firm
du kan finne powerplant på en hvilken som helst corvette, i armory tror jeg, men det er ikke alltid den i det hele tatt er og finne.
Geo cave (Geonosian Research Facility) er på Yavin IV, husker dog ikke wp
Endret av Eurofighter
Om jeg ikke tar helt feil så ligger Geo Caven ved WP -6494 -413 på Yavin
Endret av DataChild
Nice!! Takk for det..
Ps: her bilder fra corvetten, hvor hoved elementene er plassert.. :w00t:
ETA: 1.5 hours +
/im;
:w00t:
Denne macroen fungerer ikke lenger, etter at ID ble nerfet/revampet.
/im;
:w00t:
Yepps I know, skal fjerne den! ;)
Denne macroen her liker jeg som TKM og MDoc :)
/curepoison;
/curedisease;
/healstate;
/firstaid;
/reviveplayer
Har en knapp som automatisk targeter meg selv for PvP:
/curepoison self;
/curedisease self;
/healstate self;
/firstaid self;
Også har jeg bindet /heal til INSERT knappen og /ui action clearCombatQueue; til HOME. Blir litt lettere da...
Alle special inneholder /loot; for PvE og /deathblow for PvP ;).
Når jeg tumbler med alten min så bruker jeg en "trick" macro :D. Har ikke Marksman så jeg bruker denne macroen:
/tellpet trick;
/macro trick;
(bare kall macroen trick og call en pet med trick kommandoen)
Endret av John Abrahamsen
