Forelenge skjermsignal via CAT5?
Denne burde vel passe?
Artikkelnummer: LV-420-EU
Artikkelnavn: LongView Multimedia
Din pris: Kr 5 200,00
På lager Ikke disponibel på lager.
LongView Multimedia har støtte for Lyd og RS-232 , Se Detaljer
* Max .150 meter ved 1024x768/75Hz
* Max. 60 meter ved 1600x1200/75Hz
http://www.letsshop.no/
samme link som over
Fant litt erfaringer på Slashdot:
http://slashdot.org/articles/02/08/02/0333224.shtml?tid=137
We have over 100 KVM switches in our building. in 30 different labs. Some are for SUN, some HP, most for PCs, and none of them ever give us problems. However, while we are not using the top of the line matrix KVMs, we are not using the SOHO crap that the artical rates. Our switches are setup to handle more than one user, 2 or 4, and control 8 to 32 machines. I am looking for a cheep way to buy one of these monsters for my home. The cheapest 4 user by 16 port system I have found is $3999. All of the switches we have can handle 1600x1200, and allow for PS/2 | DINN | serial style keyboard/mouse connections. All of them have on screen display, however none of them have USB or sound support. If you as a reader are looking into KVM switches, but don't want the sound of humming boxes under your desk, check out the longview extenders from [cybex.com]. You can put this bad boy 200ft away from your kvm switch, and still view your screen at 1600x1200. We play FPS'ers via these titans all the time, with no loss of res, or screen update speed.
  Also, while VNC (slow screen updates), is by far the greatest free tool of it's kind I have ever seen, there are cases where you really really want to be at the console, and yet still keep your boxes in a controled environment.
Ser ut som om Longview kan være en løsning.
