Warcraft 3 Patch 1.14
  WARCRAFT III: THE FROZEN THRONE VERSION HISTORY
- PATCH 1.14
FIXES
- Fixed an issue with custom save games from version 1.12 (including those
  from Orc Act I) so Hero Agility is recognized properly. Attack speeds
  will now be correct when loading from a previous save game.
- Fixed an issue that caused Scroll of Town Portal to always place your
  units to the lower right side of your town hall instead of the location
  you clicked.
- Fixed an issue with the Skeletal Mage upgrade that prevented the Raise
  Dead skill from working on the corpses inside Meat Wagons.
- Fixed an issue that caused a unit to permanently lose 75% of its attack
  speed if it was Polymorphed or Hexed while under the effects of Unholy
  Frenzy.
- Fixed an issue with Spirit Link in which, if one of the linked units was
  a Troll Berserker with the Berserk ability active, all units linked with
  that Troll would take the increased damage penalty associated with the
  Berserk ability.
- Fixed an issue in which, if a unit casting a channeling spell died from
  Mana Flare, the channeled spell would linger in the area permanently.
- Fixed an issue that caused the Call to Arms command not to work if you
  clicked the button an EVEN number of times.
- Fixed an issue with Hero and unit ability orders in which, under certain
  conditions, ability orders would not be dispatched properly, causing
  "lag" or unresponsiveness.
- Fixed an issue that caused Glaive Throwers to lose damage when the
  Vorpal Blades upgrade was researched.
BALANCE CHANGES
Undead
- Anti-magic Shell cost reduced to 100 from 150, and hit points absorbed
  reduced to 300 from 350.
Night Elf
- Mana Flare area-of-effect damage radius reduced to 200 from 250.
Neutral Units and Heroes
- Nerubian Webspinners now cost 200/35/3, up from 175/25/2.
- Stampede damage reduced from 80 per beast to 60 per beast.
- The Beastmaster bear's Bash ability now stuns Heroes for 1 second instead
  of 2 seconds.
- Summoned Treants no longer give large gold bounties.
NOTES: Replays are incompatible between major game revisions (1.13 replays
cannot be viewed with the 1.14 version of Warcraft III).
