Tips til noen LAN-spill ?
Jeg lurer på om noen har forslag til et eller flere bra Lan-spill ?
Jeg liker Lan-spill som ; Wc3, Diablo 2, og Heroes of Might And Magic-serien.
Gjest Slettet-aNZFa3
Stemmer for Swat 4 jeg også.
Også har du ArmA 2 med coop oppdraget Cipher.
* 'Cipher' is playable in SP mode as well as in MP coop mode (just copy the mission into your respective Arma2 folder).
* Each time you start the mission over, you start at a unique location anywhere on Chernarus.
* Each time you start the mission over, the primary objective is located somewhere else.
* You need to search for the main objective and after successfully completing the required tasks, call for extraction and leave Chernarus.
* While on mission, you will encounter 'living' AI, easily implemented thanks to the new BIS modules, as well as scripted civilian population roving around the whole map, mostly by car.
* Dynamically acting hostile forces, using choppers and armored vehicles, initially randomly patrolling around the target area, and dynamically reacting to encounters - eventually flanking your position and supporting each other.
* random time start (at daylight), selectable daytime emphasis per option.
* full dynamic weather
* no Addons needed
* Since version 1.22 the mission is also playable in a second play mode 'SpecOP', since 1.28 there is a 'SpecOp light' mode too.
http://armaholic.com/page.php?id=6768
Silent Hunter 3-5. Mye morsommere enn et ubåtspill kan virke som, selv om det krever litt innsikt i styremekanismene i spillet (3-eren har lavest systemkrav og antagelig den enkleste betjeningen). Mener å huske at fireren gir deg mulighet til å ha spillere både som ubåter og overflateskip.
