Ikke trådløst nettverk i Ubuntu 9.04
Hei. Jeg har nettopp installert Ubuntu 9.04 på min nye selvbygde PC. Det er det eneste OSet jeg har installert. Men jeg mangler trådløst nettverk. Jeg har vært borti dette før, men da var det vare å reinstallere driveren i "Hardware Drivers". Nå finner den ikke noen andre drivere i "Hardware Drivers" enn Skjermkortet. Noen som kan hjelpe meg?
ifconfig:
eth0 Link encap:Ethernet HWaddr 00:24:8c:a1:df:ee
inet addr:10.0.0.1 Bcast:10.0.0.255 Mask:255.255.255.0
inet6 addr: fe80::224:8cff:fea1:dfee/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2794 errors:0 dropped:0 overruns:0 frame:0
TX packets:2695 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1458728 (1.4 MB) TX bytes:463533 (463.5 KB)
Interrupt:18
eth1 Link encap:Ethernet HWaddr 00:24:8c:a1:df:ed
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:17
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:24 errors:0 dropped:0 overruns:0 frame:0
TX packets:24 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1632 (1.6 KB) TX bytes:1632 (1.6 KB)
iwconfig:
lo no wireless extensions.
eth0 no wireless extensions.
eth1 no wireless extensions.
pan0 no wireless extensions.
lspci:
00:00.0 Host bridge: Intel Corporation X58 I/O Hub to ESI Port (rev 12)
00:01.0 PCI bridge: Intel Corporation X58 I/O Hub PCI Express Root Port 1 (rev 12)
00:03.0 PCI bridge: Intel Corporation X58 I/O Hub PCI Express Root Port 3 (rev 12)
00:07.0 PCI bridge: Intel Corporation X58 I/O Hub PCI Express Root Port 7 (rev 12)
00:10.0 PIC: Intel Corporation X58 Physical and Link Layer Registers Port 0 (rev 12)
00:10.1 PIC: Intel Corporation X58 Routing and Protocol Layer Registers Port 0 (rev 12)
00:14.0 PIC: Intel Corporation X58 I/O Hub System Management Registers (rev 12)
00:14.1 PIC: Intel Corporation X58 I/O Hub GPIO and Scratch Pad Registers (rev 12)
00:14.2 PIC: Intel Corporation X58 I/O Hub Control Status and RAS Registers (rev 12)
00:14.3 PIC: Intel Corporation X58 I/O Hub Throttle Registers (rev 12)
00:1a.0 USB Controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4
00:1a.1 USB Controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5
00:1a.2 USB Controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6
00:1a.7 USB Controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2
00:1b.0 Audio device: Intel Corporation 82801JI (ICH10 Family) HD Audio Controller
00:1c.0 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Port 1
00:1c.2 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Port 3
00:1c.4 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Port 5
00:1c.5 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Port 6
00:1d.0 USB Controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1
00:1d.1 USB Controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2
00:1d.2 USB Controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3
00:1d.7 USB Controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 90)
00:1f.0 ISA bridge: Intel Corporation 82801JIR (ICH10R) LPC Interface Controller
00:1f.2 IDE interface: Intel Corporation 82801JI (ICH10 Family) 4 port SATA IDE Controller
00:1f.3 SMBus: Intel Corporation 82801JI (ICH10 Family) SMBus Controller
00:1f.5 IDE interface: Intel Corporation 82801JI (ICH10 Family) 2 port SATA IDE Controller
02:00.0 VGA compatible controller: ATI Technologies Inc Device 9460
02:00.1 Audio device: ATI Technologies Inc HD48x0 audio
04:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8056 PCI-E Gigabit Ethernet Controller (rev 12)
05:00.0 IDE interface: Marvell Technology Group Ltd. 88SE6121 SATA II Controller (rev b2)
06:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8056 PCI-E Gigabit Ethernet Controller (rev 12)
08:02.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306 Fire II IEEE 1394 OHCI Link Layer Controller (rev c0)
lshw -C network:
WARNING: you should run this program as super-user.
*-network
description: Ethernet interface
product: 88E8056 PCI-E Gigabit Ethernet Controller
vendor: Marvell Technology Group Ltd.
physical id: 0
bus info: pci@0000:06:00.0
logical name: eth0
version: 12
serial: 00:24:8c:a1:df:ee
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical
configuration: broadcast=yes driver=sky2 driverversion=1.22 firmware=N/A ip=10.0.0.1 latency=0 module=sky2 multicast=yes
*-network
physical id: 0
bus info: pci@0000:04:00.0
logical name: eth1
version: 12
serial: 00:24:8c:a1:df:ed
width: 64 bits
clock: 33MHz
configuration: broadcast=yes driver=sky2 driverversion=1.22 firmware=N/A latency=0 module=sky2 multicast=yes
*-network DISABLED
physical id: 1
logical name: pan0
serial: e2:73:bc:c1:5d:81
capabilities: ethernet physical
configuration: broadcast=yes driver=bridge driverversion=2.3 firmware=N/A multicast=yes
Hvis du trenger mer informasjon er det bare å spørre!
Takker for alle svar!
Er det et PCI-kort? I så fall virker det som om det ikke blir oppdaget. Kan være HW-feil, eller at det ikke er satt inn rett. Ville ha prøvd med Windows hvis du har muligheten, for å feilsøke om det er et OS-problem eller et HW-problem.
Ubuntu fungerer ikke med Broadcom (leste ikke hele innlegget)
Gjør det vel. Hvis det ikke funker ut av boksen så er det mest sannsynlig en måte å fikse det på.
atriC, joda, det gjør det, men driverne Broadcom lirer av seg er crap.. Og de reverse-engineerede er også litt ustabile. Nå har jeg ikke fulgt med på Broadcom i det siste, men mener å huske det var prat om at de skulle åpne kildekoden til en del brikker.
Dessuten er det vel ganske irrelevant å nevne broadcom når problemet er at maskina ikke oppdager wlan-kortet i det hele tatt?
Har ikke så god greie på dette, men har han to ethernetporter?
Flott å se trådstarter som gir all relevant info :thumbup:
Enig med tamarin her, kortet oppdages ikke fra Bios. Enten er det defekt, eller du har ikke montert det, eller det er avslått. Det aller meste av trådløst funker i 9.04, ikke sett mye klager på trådløst der ennå.
Kommer til å tenke på det så har det generelt vært svært lite snakk om trådløst siden 9.04 kom ut. Kan det være at problemer med trådløst nå er forsvinnende lite på linux?
Endret av Del
