Tribes 2 - Nå gratis, la oss spille online!
Denne artikkelen er tatt fra http://www.tribalwars.com, ser nok ut til at Sierra has stopped masterserverne og noen har laget sin egen versjon av masterserver som ikke krever autentifikasjon (altså, ingen cd-key), godt å vite at Tribes 2 også ligger gratis på nettet, lovlig! Ser ganske lovende ut dette her, diskutèr!
As some of you may already know, Sierra has shutted down master servers for 21 games 1st November, 2008. So some dedicated Tribes 2 members has made their own master server which uses no authentication, which means EVERYONE can play online, totally legal and awesome. This is known as one of the best multiplayer games ever created, so grab it folks!
Download the client from here: http://www.tribesnext.com/downloads/tribes2gsi
High-res textures:
http://files.filefront.com/hrsa+T2exe/;123...;/fileinfo.html
UPDATE:
The Alternate Master Server is now 100% Tribes2 script, and is also Compatable with Defense Turret. It acts just like the official master server now, automatically registering hosted servers/auto refreshing server list!
I made a Master Server for T2 6 months ago, but it was limited to a really old T2 version, and couldn't update the server list with new servers, but all that has changed . Now the Latest version is supported, along with any varient/mod, and you can dynamically add your server to the list as long as it is running in -nologin mode.
I would appreciate any servers that run it.
Allowing for online play even without a cd key
DOWNLOAD (1.8mb)
Installation:
1. Unzip to you main Tribes2 Folder (C:/Dynamix/Tribes2) and overwrite all files if asked.
2. Launch the "Tribes 2 Online - Alternate Master Server.bat" file inside your Tribes2 folder to start playing.
Instructions
1. About
2. Requirements
3. Using the Master Server for play
4. Hosting a Server
5. Credits
1. About
This Alternate Master Server was created for a few reasons:
- To allow Tribes2 players an alternate Master Server to connect to, incase the official one crashes or is shutdown forever.
- To allows players without CD keys to connect and play online, to help the dropping player population.
- (Visit tribes2.servegame.com for more info and updates)
2. Requirements
- Latest Version of Tribes2
- Game must be started in -nologin mode(LAN Mode)
- Start the 'Tribes 2 Online - Alternate Master Server.bat' file in your Tribes2 folder, or just simply Start Tribes in -nologin mode.
4. Hosting a Server
- Replace your Tribes2.exe with the one in the 'GameData/AlternateMasterPatch', this will ensure you will be able to accept connections from the internet. Start a server normally, but be sure you are in -nologin mode. You will automatically register with the master server.
5. Credits
- Created by Morrow36/Worrom. Thanks krash123 for the T2 Script help.
See you online folks! :thumbup:
Endret av evilleader360
Tråd oppdatert, er mer enn klar til å spille Tribes 2, noen som blir med :D?
Hvordan starter man spillet i LAN mode hvis man bruker bat filen til å spille >.<?
X:\Dynamix\Tribes2 - X: er din HDD, let etter gallkaabo.jpg;)
