Resette instillinger i spillet, uten å gi inn?
Kjører PCen fra en 37" TV som ikke klarer å kjøre nåværende oppløsning i HL.
Hvordan kan jeg resette/endre det uten å gå inn i spillet?
How do I set the autoconfig launch option?
The -autoconfig launch option will allow Steam to configure the game with the best settings for use on your machine.
Open Steam
Go to the "My Games" tab
Right-click the game which needs to be reconfigured
Select "Properties" from the menu
Click the "Set launch options..." button
Add -autoconfig at the end of the line, be sure to include a space before the " - " and anything before it.
How do I reset the video settings?
If the -autoconfig launch option does not resolve the issue, use the links below to reset the video settings to their defaults (low resolution, highest refresh rate) and launch a game:
Source-engine Games
Half-Life 2
Counter-Strike: Source
Half-Life: Source
Day of Defeat: Source
Half-Life 2: Deathmatch
Half-Life Deathmatch: Source
Half-Life 2: Episode One
SiN Episodes: Emergence
GoldSrc-engine Games
Counter-Strike
Team Fortress Classic
Day of Defeat
Deathmatch Classic
Opposing Force
Ricochet
Half-Life
Condition Zero
Half-Life: Blue Shift
How do I force a working DirectX level and video mode?
If the game fails to load with the default settings, you will need to test for a working DirectX level and video mode.
Force a DirectX level
This process may help with some older video cards - some users report the game will run faster, as well:
Open Steam
Add one of the DirectX level launch options specified below - be sure to include a space before the " - " and anything before it.
DirectX Level Launch Options
-dxlevel 90 (DirectX v9.0)
-dxlevel 81 (DirectX v8.1)
-dxlevel 80 (DirectX v8.0)
-dxlevel 70 (DirectX v7.0)
Force a Video Mode
Follow these instructions to configure your video mode and resolution before launching a game:
Important:
If you are forcing a refresh rate on your system (this is not recommended), you will need to ensure that you specify the forced refresh rate in the launch options.
Open Steam
Add -gl at the end of the line, be sure to include a space before the " - " and anything before it.
Specify the appropriate Video Mode and Video Option switches from the lists below
Video Mode Launch Options
Use the -w # switch (where " # " is a number from the list below) to specify the display resolution:
640 (640x480) GoldSource Only
720 (720x576)
800 (800x600)
1024 (1024x768) - This mode offers the best performance for most cards
1152 (1152x864)
1280 (1280x1024) - This mode is optimal for high-end cards
1600 (1600x1200) - This mode requires a high-end monitor and a high-performance card
https://support.steampowered.com/kb_article...=1216-JMTZ-0860
