hører jeg et skjermkortprob?
jeg formaterte pcn i går.. har installert de nyeste driverne til nvidia, lastet ned nyeste adobe flash.. og den sliter fortsatt med å spille av trailere etc. hvis jeg ser på en video på youtube hakker den å bare sånn.. "brrbrr" i gjentagelse av lyden liksom, hvis dere forstår.. hehe
jeg vet ikke hvordan jeg skal fikse det, noen som kan hjelpe?:s
System Information
Time of this report: 7/16/2008, 19:27:09
Machine name: DIEMACHINEN
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp.080413-2111)
Language: Norwegian (Bokmål) (Regional Setting: Norwegian (Bokmål))
System Manufacturer: NVIDIA
System Model: AWRDACPI
BIOS: Award Modular BIOS v6.00PG
Processor: AMD Athlon 64 Processor 3500+, MMX, 3DNow, ~2.1GHz
Memory: 1024MB RAM
Page File: 294MB used, 2166MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
Display Devices
Card name: NVIDIA GeForce 6600 GT
Chip type: GeForce 6600 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0140&SUBSYS_31251458&REV_A2
Display Memory: 128.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Plug and Play-skjerm
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.7519 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 5/16/2008 14:01:00, 6108928 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: i/t
Mini VDD: nv4_mini.sys
Mini VDD Date: 5/16/2008 14:01:00, 6557408 bytes
Device Identifier: {D7B71E3E-4200-11CF-B76A-2E1103C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0140
SubSys ID: 0x31251458
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek AC97 Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_10DE&DEV_0059&SUBSYS_AE011458&REV_A2
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ALCXWDM.SYS
Driver Version: 5.10.0000.5770 (English)
WHQL Logo'd: Yes
Date and Size: 12/22/2004 11:07:12, 2304320 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 192000
Static/Strm HW Mix Bufs: 26, 25
Static/Strm HW 3D Bufs: 26, 25
HW Memory: 0
Voice Management: No
EAX 2.0 Listen/Src: Yes, Yes
I3DL2 Listen/Src: Yes, Yes
Sensaura ZoomFX: No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
Endret av Latskap
For meg virker det som om du har glemt å innstallere drivere av et eller annet slag.
Har du lastet ned alle oppdateringer FØR du la inn SP3?
Har du noen gule trekanter i Enhetsbehandlig?
Det tyder isåfall på at du har glemt å innstallere noen drivere.
Spiller det noen rolle om det var før eller etter?
det som er rart er at det bare plutselig har skjedd, det var jo ikke sånn før.
Pcn henger seg sånn litt hele tiden noe som er grusomt plagsomt
