Kjell-arne Skrevet 20. juni 2008 Skrevet 20. juni 2008 Ja da har dagen endelig kommet, 2K har fjernet Installasjonsbegrensningen fra BioShock. Dette vil da si at du kan installere det så mange ganger du vil på så mange datamaskiner du vil. For å sitere direkte: "As promised, all activation restrictions, including install limits, have been removed from BioShock PC as of today." http://forums.2kgames.com/forums/showthrea...6125#post296125 ----- Og nei, de har ikke fjernet SecuROM fra spillet ennå. "Our other methods of copy protection remain. You will still have to activate your copy, and you will still need to keep the disc in the drive. SecuROM has not been removed -- just the activation limits on number of installs and number of computers you can install BioShock on simultaneously. As I promised that the activation limits would go away, I can promise that if we ever stop supporting BioShock in the ways you speak of, we will release a patch so that the game is still playable."
Gjest Slettet-aNZFa3 Skrevet 23. juni 2008 Skrevet 23. juni 2008 Nydelig! Da kan jeg installere Bioshock igjen da
