AoC: Nytt PvP rulesett annonsert: Culture PvP Ruleset
Fra det off. forumet.
As part of celebrating the release of Age of Conan we are happy to unravel a brand new PvP ruleset that has not previously been disclosed: The Culture PvP ruleset! Note that this new PvP server type is experimental and players on these servers must expect an ongoing change to the ruleset.
The goal of this PvP server-type is to stimulate war behind the three cultures of Cimmeria, Aquilonia and Stygia. As a player on a Culture PvP server, you are shielded from lone travelers of your own culture, however you may still group with any culture and form a group and attack anyone.
The Culture PvP ruleset is an evolving ruleset that will be tweaked and polished based on player-feedback in the months to come. Although it is, at least currently, possible to make guilds across cultures, pure culture groups and guilds will be endorsed on this server, and as such players on the Culture PvP servers must prepare that the future will hold continued changes to the ruleset.
We have changed to ruleset on two servers that were previously flagged as full PvP. The homes for the Culture PvP servers are:
Bane (US)
Twilight (EU)
With best regards,
Funcom
Edit:
Litt spent på hvordan dette blir å funke. Er det ikke slik at noen classes er rase spesifikk?
Endret av Konamixx
Går vel mer ut på at du ikke kan angripe de du er fra samme land som.
Lurer på hvordan dette blir, litt overraskende at de annonserer dette dagen spillet "kommer ut".
Endret av tineyoghurt
jeg synes det høres bra ut,men det er nesten som å spille på en beta server.De kommer til å bytte masse og til slutt så blir det ingenting he he.
