COD 4 multiplayer funker ikke =(
singleplayern funker helt fint, men da jeg forsøker å starte multiplayeren får jeg en feilmelding om at "iw3mp.exe har sluttet å virke"
Hva er galt? kan noen hjelpe meg?
M.V.H moi ;)
Prøv å reinstallere spillet.
Spiller du på winXP eller VISTA 64bit eller 32bit?
jeg kjører vista 32 bit
har det noe å si da?
For Guds skyld, nei ikke avinnstaler spillet
Bare plugg inn en mic, så funker spillet igjen(gjorde det i allefall for meg, og har hørt det har funket for mange andre)
Det trenger vel ikke å være tilfellet. Du mistenker en crack, men sannheten er jo at den har samme filnavnet som originalen. Tvilen kommer alltid tiltalte til gode så klapp igjen.
Prøv reinnstall? /Reg mech? :D
Problem #6 : iw3mp.exe error in Call of Duty 4 Multiplayer
Solution A : rename mssmp3.asi to mssmp3.bak.(from Elem3nt and franjo)
Solution B : From activision(do this only if Solution A doesnt fix it)
There are some issues running CoD 4 multiplayer on some onboard sound cards. If you have a RealTek onboard sound card and Windows® Vista you should try removing your sound card drivers and allow Windows Vista to install it’s default sound drivers. Please make note of the make and model of your sound card prior to removing it in order to aid in reinstallation at a later date.
To remove your sound card drivers do the following:
Open the control panel link from the start menu
Check the programs and features tool to see if your sound card drivers are listed here
If they are not open the system tool in the control panel
Click on the device manager task on the left
Locate your sound card in the list, it should be in the sound, video, and game controllers section
Right-click on the sound card name and select Uninstall.
If you have a Sigmatel® onboard sound card you will need to install all Windows® Vista updates, and the latest Sigmatel drivers from www.dell.com. Please navigate from the dell homepage to support, your make and model computer, and look for a sound card update.
If you are running the game from a secondary partition, download the latest BIOS updates from your motherboard manufacturer in addition to following the above instructions.
Gjest Slettet-oVjeg2q2Tk
La meg omformulere meg da.
Du kan prøve å erstatte den aktuelle filen med en identisk fil, denne filen har jeg ikke fundert på hvordan du kan skaffe deg, men en søketure rundt på nettet hadde nok ikke vært så dumt, tolk det hvordan du vil.
Endret av Slettet-oVjeg2q2Tk
