Zirion Skrevet 13. april 2008 Del Skrevet 13. april 2008 Fikk nylig denne mailen av Blizzard brukerstøtte som sa meg hva jeg skulle gjøre for å fikse et problem: Klikk for å se/fjerne innholdet nedenfor Hello Christian, Thank you for your reply concerning the error #132 in World of Warcraft. We reviewed the system diagnostic files you sent us and noticed that your motherboard and Ethernet adapter are missing drivers: Name: Standard Dual Channel PCI IDE Controller Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.00.6000.16632 (English), 2/14/2008 Name: Standard Universal PCI to USB Host Controller Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.00.6000.16553 (English), 2/14/2008 Name: SM-busskontroller Driver: n/a Name: Ethernet-kontroller Driver: n/a Please make sure to download updated drivers for your Dell computer. Also, download and install the latest System Firmware (BIOS). Please note that making any changes in your BIOS is an advanced step and should only be undertaken by a Computer Technician. Once updated drivers are installed, please reset the game to default settings by deleting the Cache, Interface and WTF folders located in the World of Warcraft directory; then make sure to run World of Warcraft with administrator rights: 1. Open the folder that contains your World of Warcraft installation. 2. Right-click the Launcher.exe file and left-click Properties 3. On the new window, click the Compatibility tab 4. Tick the option that reads 'Run this program as an administrator' 5. Click OK to save the change 6. Repeat steps 2 - 5 for the Wow.exe file, found in the same location If the issue continues, please try removing one RAM module from your computer. Furthermore, please confirm you ran the Prime95 Torture test overnight. Should you need further technical assistance, please do not hesitate to contact us again. Best regards, Blizzard Entertainment Europe Mario D. Technical Support http://eu.blizzard.com/support If you reply to this email, please include all previous replies and files. Customer satisfaction is a top priority here at Blizzard Entertainment, and we would like your feedback on the level of service you have received. Please feel free to provide such feedback at the following web address: http://eu.blizzard.com/support/[email protected] Den siste delen av dette forstår jeg, men aner ikke hvordan jeg skal finne de riktige driverne til Ethernet kontroller osv. Noen som kan hjelpe meg med dette og kanskje poste en link til der jeg kan laste ned driverne? Jeg har en Dell inspiron 530 PC med vista 32 bit. Legger ved msinfo også hvis det skulle være nødvendig. MSINFO: Klikk for å se/fjerne innholdet nedenfor Systeminformasjonsrapport skrevet: 04/08/08 17:01:27 Systemnavn: TANZ [systemsammendrag] Element Verdi OS-navn Microsoft® Windows Vista™ Home Premium Versjon 6.0.6000 Build 6000 Annen OS-beskrivelse Ikke tilgjengelig OS-produsent Microsoft Corporation Systemnavn TANZ Systemprodusent Dell Inc. Systemmodell Inspiron 530 Systemtype X86-based PC Prosessor Intel® Core2 Duo CPU E6550 @ 2.33GHz, 2331 Mhz, 2 kjerne®, 2 logiske prosessor(er) BIOS-versjon/-dato Dell Inc. 1.0.3, 12.07.2007 SMBIOS-versjon 2.5 Windows-mappe C:\Windows Systemmappe C:\Windows\system32 Oppstartsenhet \Device\HarddiskVolume2 Nasjonal innstilling Norge Hardware Abstraction Layer Versjon = "6.0.6000.20500" Brukernavn TANZ\Tanz Tidssone Vest-Europa (sommertid) Fysisk minne totalt 3 069,56 MB Fysisk minne tilgjengelig 662,11 MB Virtuelt minne totalt 6,19 GB Virtuelt minne tilgjengelig 3,52 GB Plass for sidevekslingsfil 3,29 GB Sidevekslingsfil C:\pagefile.sys [Maskinvareressurser] [Konflikter/deling] Ressurs Enhet I/U-port 0x00000000-0x00000CF7 PCI bus I/U-port 0x00000000-0x00000CF7 Direct memory access controller I/U-port 0x000003C0-0x000003DF PCI standard PCI-to-PCI bridge I/U-port 0x000003C0-0x000003DF ATI Radeon HD 2600 XT IRQ 23 Standard Universal PCI to USB Host Controller IRQ 23 Standard Enhanced PCI to USB Host Controller Minneadresse 0xFED00000-0xFED003FF High precision event timer Minneadresse 0xFED00000-0xFED003FF System board IRQ 16 PCI standard PCI-to-PCI bridge IRQ 16 Standard Universal PCI to USB Host Controller Minneadresse 0xD0000000-0xDFFFFFFF PCI standard PCI-to-PCI bridge Minneadresse 0xD0000000-0xDFFFFFFF ATI Radeon HD 2600 XT IRQ 18 Standard Enhanced PCI to USB Host Controller IRQ 18 Standard Universal PCI to USB Host Controller IRQ 19 Standard Universal PCI to USB Host Controller IRQ 19 Standard Universal PCI to USB Host Controller IRQ 19 Standard Dual Channel PCI IDE Controller IRQ 19 Standard Dual Channel PCI IDE Controller Minneadresse 0xBFF00000-0xFEBFFFFF PCI bus Minneadresse 0xBFF00000-0xFEBFFFFF System board Minneadresse 0xA0000-0xBFFFF PCI bus Minneadresse 0xA0000-0xBFFFF PCI standard PCI-to-PCI bridge Minneadresse 0xA0000-0xBFFFF ATI Radeon HD 2600 XT I/U-port 0x000003B0-0x000003BB PCI standard PCI-to-PCI bridge I/U-port 0x000003B0-0x000003BB ATI Radeon HD 2600 XT [DMA] Ressurs Enhet Status Channel 4 Direct memory access controller OK Channel 2 Standard diskettkontroller OK [Tvungen maskinvare] Enhet PNP-enhets-ID [i/U] Ressurs Enhet Status 0x00000000-0x00000CF7 PCI bus OK 0x00000000-0x00000CF7 Direct memory access controller OK 0x00000D00-0x0000FFFF PCI bus OK 0x0000C000-0x0000CFFF PCI standard PCI-to-PCI bridge OK 0x000003B0-0x000003BB PCI standard PCI-to-PCI bridge OK 0x000003B0-0x000003BB ATI Radeon HD 2600 XT OK 0x000003C0-0x000003DF PCI standard PCI-to-PCI bridge OK 0x000003C0-0x000003DF ATI Radeon HD 2600 XT OK 0x0000CE00-0x0000CEFF ATI Radeon HD 2600 XT OK 0x0000FF00-0x0000FF1F Ethernet-kontroller OK 0x0000FE00-0x0000FE1F Standard Universal PCI to USB Host Controller OK 0x0000FD00-0x0000FD1F Standard Universal PCI to USB Host Controller OK 0x0000FC00-0x0000FC1F Standard Universal PCI to USB Host Controller OK 0x0000FB00-0x0000FB1F Standard Universal PCI to USB Host Controller OK 0x0000FA00-0x0000FA1F Standard Universal PCI to USB Host Controller OK 0x0000F900-0x0000F91F Standard Universal PCI to USB Host Controller OK 0x0000D000-0x0000DFFF Intel® 82801 PCI Bridge - 244E OK 0x00000010-0x0000001F Motherboard resources OK 0x00000022-0x0000003F Motherboard resources OK 0x00000044-0x0000005F Motherboard resources OK 0x00000060-0x00000060 Motherboard resources OK 0x00000064-0x00000064 Motherboard resources OK 0x00000062-0x00000063 Motherboard resources OK 0x00000065-0x0000006F Motherboard resources OK 0x00000074-0x0000007F Motherboard resources OK 0x00000091-0x00000093 Motherboard resources OK 0x000000A2-0x000000BF Motherboard resources OK 0x000000E0-0x000000EF Motherboard resources OK 0x000004D0-0x000004D1 Motherboard resources OK 0x00000800-0x0000087F Motherboard resources OK 0x00000290-0x00000297 Motherboard resources OK 0x00000880-0x0000088F Motherboard resources OK 0x00000020-0x00000021 Programmable interrupt controller OK 0x000000A0-0x000000A1 Programmable interrupt controller OK 0x00000080-0x00000090 Direct memory access controller OK 0x00000094-0x0000009F Direct memory access controller OK 0x000000C0-0x000000DF Direct memory access controller OK 0x00000040-0x00000043 System timer OK 0x00000070-0x00000073 System CMOS/real time clock OK 0x00000061-0x00000061 System speaker OK 0x000000F0-0x000000FF Numeric data processor OK 0x000003F0-0x000003F5 Standard diskettkontroller OK 0x000003F7-0x000003F7 Standard diskettkontroller OK 0x00000400-0x000004BF Motherboard resources OK 0x0000F800-0x0000F807 Standard Dual Channel PCI IDE Controller OK 0x0000F700-0x0000F703 Standard Dual Channel PCI IDE Controller OK 0x0000F600-0x0000F607 Standard Dual Channel PCI IDE Controller OK 0x0000F500-0x0000F503 Standard Dual Channel PCI IDE Controller OK 0x0000F400-0x0000F40F Standard Dual Channel PCI IDE Controller OK 0x0000F300-0x0000F30F Standard Dual Channel PCI IDE Controller OK 0x00000500-0x0000051F SM-busskontroller OK 0x0000F100-0x0000F107 Standard Dual Channel PCI IDE Controller OK 0x0000F000-0x0000F003 Standard Dual Channel PCI IDE Controller OK 0x0000EF00-0x0000EF07 Standard Dual Channel PCI IDE Controller OK 0x0000EE00-0x0000EE03 Standard Dual Channel PCI IDE Controller OK 0x0000ED00-0x0000ED0F Standard Dual Channel PCI IDE Controller OK 0x0000EC00-0x0000EC0F Standard Dual Channel PCI IDE Controller OK 0x0000FFE0-0x0000FFEF SCSI/RAID Host Controller OK [iRQer] Ressurs Enhet Status IRQ 80 Microsoft ACPI-kompatibelt system OK IRQ 81 Microsoft ACPI-kompatibelt system OK IRQ 82 Microsoft ACPI-kompatibelt system OK IRQ 83 Microsoft ACPI-kompatibelt system OK IRQ 84 Microsoft ACPI-kompatibelt system OK IRQ 85 Microsoft ACPI-kompatibelt system OK IRQ 86 Microsoft ACPI-kompatibelt system OK IRQ 87 Microsoft ACPI-kompatibelt system OK IRQ 88 Microsoft ACPI-kompatibelt system OK IRQ 89 Microsoft ACPI-kompatibelt system OK IRQ 90 Microsoft ACPI-kompatibelt system OK IRQ 91 Microsoft ACPI-kompatibelt system OK IRQ 92 Microsoft ACPI-kompatibelt system OK IRQ 93 Microsoft ACPI-kompatibelt system OK IRQ 94 Microsoft ACPI-kompatibelt system OK IRQ 95 Microsoft ACPI-kompatibelt system OK IRQ 96 Microsoft ACPI-kompatibelt system OK IRQ 97 Microsoft ACPI-kompatibelt system OK IRQ 98 Microsoft ACPI-kompatibelt system OK IRQ 99 Microsoft ACPI-kompatibelt system OK IRQ 100 Microsoft ACPI-kompatibelt system OK IRQ 101 Microsoft ACPI-kompatibelt system OK IRQ 102 Microsoft ACPI-kompatibelt system OK IRQ 103 Microsoft ACPI-kompatibelt system OK IRQ 104 Microsoft ACPI-kompatibelt system OK IRQ 105 Microsoft ACPI-kompatibelt system OK IRQ 106 Microsoft ACPI-kompatibelt system OK IRQ 107 Microsoft ACPI-kompatibelt system OK IRQ 108 Microsoft ACPI-kompatibelt system OK IRQ 109 Microsoft ACPI-kompatibelt system OK IRQ 110 Microsoft ACPI-kompatibelt system OK IRQ 111 Microsoft ACPI-kompatibelt system OK IRQ 112 Microsoft ACPI-kompatibelt system OK IRQ 113 Microsoft ACPI-kompatibelt system OK IRQ 114 Microsoft ACPI-kompatibelt system OK IRQ 115 Microsoft ACPI-kompatibelt system OK IRQ 116 Microsoft ACPI-kompatibelt system OK IRQ 117 Microsoft ACPI-kompatibelt system OK IRQ 118 Microsoft ACPI-kompatibelt system OK IRQ 119 Microsoft ACPI-kompatibelt system OK IRQ 120 Microsoft ACPI-kompatibelt system OK IRQ 121 Microsoft ACPI-kompatibelt system OK IRQ 122 Microsoft ACPI-kompatibelt system OK IRQ 123 Microsoft ACPI-kompatibelt system OK IRQ 124 Microsoft ACPI-kompatibelt system OK IRQ 125 Microsoft ACPI-kompatibelt system OK IRQ 126 Microsoft ACPI-kompatibelt system OK IRQ 127 Microsoft ACPI-kompatibelt system OK IRQ 128 Microsoft ACPI-kompatibelt system OK IRQ 129 Microsoft ACPI-kompatibelt system OK IRQ 130 Microsoft ACPI-kompatibelt system OK IRQ 131 Microsoft ACPI-kompatibelt system OK IRQ 132 Microsoft ACPI-kompatibelt system OK IRQ 133 Microsoft ACPI-kompatibelt system OK IRQ 134 Microsoft ACPI-kompatibelt system OK IRQ 135 Microsoft ACPI-kompatibelt system OK IRQ 136 Microsoft ACPI-kompatibelt system OK IRQ 137 Microsoft ACPI-kompatibelt system OK IRQ 138 Microsoft ACPI-kompatibelt system OK IRQ 139 Microsoft ACPI-kompatibelt system OK IRQ 140 Microsoft ACPI-kompatibelt system OK IRQ 141 Microsoft ACPI-kompatibelt system OK IRQ 142 Microsoft ACPI-kompatibelt system OK IRQ 143 Microsoft ACPI-kompatibelt system OK IRQ 144 Microsoft ACPI-kompatibelt system OK IRQ 145 Microsoft ACPI-kompatibelt system OK IRQ 146 Microsoft ACPI-kompatibelt system OK IRQ 147 Microsoft ACPI-kompatibelt system OK IRQ 148 Microsoft ACPI-kompatibelt system OK IRQ 149 Microsoft ACPI-kompatibelt system OK IRQ 150 Microsoft ACPI-kompatibelt system OK IRQ 151 Microsoft ACPI-kompatibelt system OK IRQ 152 Microsoft ACPI-kompatibelt system OK IRQ 153 Microsoft ACPI-kompatibelt system OK IRQ 154 Microsoft ACPI-kompatibelt system OK IRQ 155 Microsoft ACPI-kompatibelt system OK IRQ 156 Microsoft ACPI-kompatibelt system OK IRQ 157 Microsoft ACPI-kompatibelt system OK IRQ 158 Microsoft ACPI-kompatibelt system OK IRQ 159 Microsoft ACPI-kompatibelt system OK IRQ 160 Microsoft ACPI-kompatibelt system OK IRQ 161 Microsoft ACPI-kompatibelt system OK IRQ 162 Microsoft ACPI-kompatibelt system OK IRQ 163 Microsoft ACPI-kompatibelt system OK IRQ 164 Microsoft ACPI-kompatibelt system OK IRQ 165 Microsoft ACPI-kompatibelt system OK IRQ 166 Microsoft ACPI-kompatibelt system OK IRQ 167 Microsoft ACPI-kompatibelt system OK IRQ 168 Microsoft ACPI-kompatibelt system OK IRQ 169 Microsoft ACPI-kompatibelt system OK IRQ 170 Microsoft ACPI-kompatibelt system OK IRQ 171 Microsoft ACPI-kompatibelt system OK IRQ 172 Microsoft ACPI-kompatibelt system OK IRQ 173 Microsoft ACPI-kompatibelt system OK IRQ 174 Microsoft ACPI-kompatibelt system OK IRQ 175 Microsoft ACPI-kompatibelt system OK IRQ 176 Microsoft ACPI-kompatibelt system OK IRQ 177 Microsoft ACPI-kompatibelt system OK IRQ 178 Microsoft ACPI-kompatibelt system OK IRQ 179 Microsoft ACPI-kompatibelt system OK IRQ 180 Microsoft ACPI-kompatibelt system OK IRQ 181 Microsoft ACPI-kompatibelt system OK IRQ 182 Microsoft ACPI-kompatibelt system OK IRQ 183 Microsoft ACPI-kompatibelt system OK IRQ 184 Microsoft ACPI-kompatibelt system OK IRQ 185 Microsoft ACPI-kompatibelt system OK IRQ 186 Microsoft ACPI-kompatibelt system OK IRQ 187 Microsoft ACPI-kompatibelt system OK IRQ 188 Microsoft ACPI-kompatibelt system OK IRQ 189 Microsoft ACPI-kompatibelt system OK IRQ 190 Microsoft ACPI-kompatibelt system OK IRQ 16 PCI standard PCI-to-PCI bridge OK IRQ 16 Standard Universal PCI to USB Host Controller OK IRQ 4294967294 ATI Radeon HD 2600 XT OK IRQ 17 High Definition Audio-kontroller OK IRQ 10 Ethernet-kontroller OK IRQ 21 Standard Universal PCI to USB Host Controller OK IRQ 19 Standard Universal PCI to USB Host Controller OK IRQ 19 Standard Universal PCI to USB Host Controller OK IRQ 19 Standard Dual Channel PCI IDE Controller OK IRQ 19 Standard Dual Channel PCI IDE Controller OK IRQ 18 Standard Enhanced PCI to USB Host Controller OK IRQ 18 Standard Universal PCI to USB Host Controller OK IRQ 22 High Definition Audio-kontroller OK IRQ 23 Standard Universal PCI to USB Host Controller OK IRQ 23 Standard Enhanced PCI to USB Host Controller OK IRQ 0 High precision event timer OK IRQ 8 High precision event timer OK IRQ 13 Numeric data processor OK IRQ 6 Standard diskettkontroller OK IRQ 11 SM-busskontroller OK IRQ 9 SCSI/RAID Host Controller OK [Minne] Ressurs Enhet Status 0xA0000-0xBFFFF PCI bus OK 0xA0000-0xBFFFF PCI standard PCI-to-PCI bridge OK 0xA0000-0xBFFFF ATI Radeon HD 2600 XT OK 0xC0000-0xDFFFF PCI bus OK 0xBFF00000-0xFEBFFFFF PCI bus OK 0xBFF00000-0xFEBFFFFF System board OK 0xFDD00000-0xFDDFFFFF PCI standard PCI-to-PCI bridge OK 0xD0000000-0xDFFFFFFF PCI standard PCI-to-PCI bridge OK 0xD0000000-0xDFFFFFFF ATI Radeon HD 2600 XT OK 0xFDDE0000-0xFDDEFFFF ATI Radeon HD 2600 XT OK 0xFDDFC000-0xFDDFFFFF High Definition Audio-kontroller OK 0xFDFC0000-0xFDFDFFFF Ethernet-kontroller OK 0xFDFFF000-0xFDFFFFFF Ethernet-kontroller OK 0xFDFFE000-0xFDFFE3FF Standard Enhanced PCI to USB Host Controller OK 0xFDFF4000-0xFDFF7FFF High Definition Audio-kontroller OK 0xFDFFD000-0xFDFFD3FF Standard Enhanced PCI to USB Host Controller OK 0xFDC00000-0xFDCFFFFF Intel® 82801 PCI Bridge - 244E OK 0xFDE00000-0xFDEFFFFF Intel® 82801 PCI Bridge - 244E OK 0xFED00000-0xFED003FF High precision event timer OK 0xFED00000-0xFED003FF System board OK 0xFFB80000-0xFFBFFFFF Intel® 82802 Firmware Hub Device OK 0xFDFFC000-0xFDFFC0FF SM-busskontroller OK 0xE0000000-0xEFFFFFFF Motherboard resources OK 0xF0000-0xFFFFF System board OK 0xBFE90000-0xBFEFFFFF System board OK 0x0000-0x9FFFF System board OK 0x100000-0xBFE8FFFF System board OK 0xFEC00000-0xFEC00FFF System board OK 0xFED14000-0xFED1DFFF System board OK 0xFED20000-0xFED9FFFF System board OK 0xFEE00000-0xFEE00FFF System board OK 0xFFB00000-0xFFB7FFFF System board OK 0xFFF00000-0xFFFFFFFF System board OK 0xE0000-0xEFFFF System board OK [Komponenter] [Multimedia] [Lydkodeker] Kodek Produsent Beskrivelse Status Fil Versjon Størrelse Opprettelsesdato c:\windows\system32\msgsm32.acm Microsoft Corporation OK C:\Windows\system32\MSGSM32.ACM 6.0.6000.16386 22,50 kB (23 040 byte) 02.11.2006 10:03 c:\windows\system32\msg711.acm Microsoft Corporation OK C:\Windows\system32\MSG711.ACM 6.0.6000.16386 12,00 kB (12 288 byte) 02.11.2006 10:03 c:\windows\system32\msadp32.acm Microsoft Corporation OK C:\Windows\system32\MSADP32.ACM 6.0.6000.16386 17,00 kB (17 408 byte) 02.11.2006 10:03 c:\windows\system32\imaadp32.acm Microsoft Corporation OK C:\Windows\system32\IMAADP32.ACM 6.0.6000.16386 17,00 kB (17 408 byte) 02.11.2006 10:03 c:\windows\system32\sirenacm.dll Microsoft Corporation Messenger Audio Codec OK C:\Windows\system32\SIRENACM.DLL 8.5.1302.1018 50,02 kB (51 224 byte) 18.10.2007 12:31 c:\windows\system32\l3codeca.acm Fraunhofer Institut Integrierte Schaltungen IIS Fraunhofer IIS MPEG Layer-3 Codec OK C:\Windows\system32\L3CODECA.ACM 1.9.0.401 61,00 kB (62 464 byte) 02.11.2006 13:35 c:\windows\system32\lhacm.acm Microsoft Corporation lhacm.acm OK C:\Windows\system32\LHACM.ACM 4.4.0.3385 33,27 kB (34 064 byte) 02.03.2008 14:37 [Videokodeker] Kodek Produsent Beskrivelse Status Fil Versjon Størrelse Opprettelsesdato c:\windows\system32\iyuv_32.dll Microsoft Corporation OK C:\Windows\system32\IYUV_32.DLL 6.0.6000.16386 48,50 kB (49 664 byte) 02.11.2006 09:55 c:\windows\system32\msyuv.dll Microsoft Corporation OK C:\Windows\system32\MSYUV.DLL 6.0.6000.16386 22,00 kB (22 528 byte) 02.11.2006 09:55 c:\windows\system32\msvidc32.dll Microsoft Corporation OK C:\Windows\system32\MSVIDC32.DLL 6.0.6000.16513 30,50 kB (31 232 byte) 14.02.2008 15:35 c:\windows\system32\msrle32.dll Microsoft Corporation OK C:\Windows\system32\MSRLE32.DLL 6.0.6000.16513 12,50 kB (12 800 byte) 14.02.2008 15:35 c:\windows\system32\tsbyuv.dll Microsoft Corporation OK C:\Windows\system32\TSBYUV.DLL 6.0.6000.16386 11,50 kB (11 776 byte) 02.11.2006 09:55 c:\windows\system32\frapsvid.dll Beepa P/L Fraps Video Decompressor OK C:\Windows\system32\FRAPSVID.DLL 2.9.4.7039 80,00 kB (81 920 byte) 14.01.2008 13:52 c:\windows\system32\iccvid.dll Radius Inc. OK C:\Windows\system32\ICCVID.DLL 1.10.0.12 80,00 kB (81 920 byte) 02.11.2006 13:34 [CD-ROM] Element Verdi Stasjon D: Beskrivelse CD-ROM-stasjon Innlastet medium Nei Medietype UNKNOWN Navn TSSTcorp DVD+-RW TS-H653B ATA Device Produsent (Standard CD-ROM-stasjoner) Status OK Overføringshastighet -1.00 kB/s SCSI-mål-ID 0 PNP-enhets-ID IDE\CDROMTSSTCORP_DVD+-RW_TS-H653B_______________D200____\5&2F6B6D99&0&0.0.0 Driver c:\windows\system32\drivers\cdrom.sys (6.0.6000.16386, 65,50 kB (67 072 byte), 02.11.2006 09:51) Stasjon J: Beskrivelse CD-ROM-stasjon Innlastet medium Nei Medietype UNKNOWN Navn TA2251U FGE477C SCSI CdRom Device Produsent (Standard CD-ROM-stasjoner) Status OK Overføringshastighet -1.00 kB/s SCSI-mål-ID 0 PNP-enhets-ID SCSI\CDROM&VEN_TA2251U&PROD_FGE477C&REV_1.0\5&36E5972&0&000000 Driver c:\windows\system32\drivers\cdrom.sys (6.0.6000.16386, 65,50 kB (67 072 byte), 02.11.2006 09:51) [Lydenhet] Element Verdi Navn High Definition Audio-enhet Produsent Microsoft Status OK Enhets-ID for PNP HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1000\5&37ADDC76&0&0001 Driver c:\windows\system32\drivers\hdaudio.sys (6.0.5840.16387, 230,00 kB (235 520 byte), 02.11.2006 11:25) Navn High Definition Audio-enhet Produsent Microsoft Status OK Enhets-ID for PNP HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_1028020D&REV_1000\4&18CA5B6A&0&0201 Driver c:\windows\system32\drivers\hdaudio.sys (6.0.5840.16387, 230,00 kB (235 520 byte), 02.11.2006 11:25) [skjerm] Element Verdi Navn ATI Radeon HD 2600 XT ID for PNP-enhet PCI\VEN_1002&DEV_9588&SUBSYS_25421028&REV_00\4&22F4F1A2&0&0008 Korttype ATI Radeon Graphics Processor (0x9588), ATI Technologies Inc.-kompatibelt Kortbeskrivelse ATI Radeon HD 2600 XT RAM på kortet 256,00 MB (268 435 456 byte) Installerte drivere atidxx32.dll,atidxx64,atiumdag.dll,atiumdva.dat,atiumd64,atiumd6a,atitmm64 Driverversjon 7.01.01.747 INF-fil oem9.inf (ati2mtag_RV630-avsnitt) Fargenivåer Ikke tilgjengelig Fargetabelloppføringer 4294967296 Oppløsning 1440 x 900 x 59 hertz Biter/piksel 32 Minneadresse 0xD0000000-0xDFFFFFFF Minneadresse 0xFDDE0000-0xFDDEFFFF I/U-port 0x0000CE00-0x0000CEFF IRQ-kanal IRQ 4294967294 I/U-port 0x000003B0-0x000003BB I/U-port 0x000003C0-0x000003DF Minneadresse 0xA0000-0xBFFFF Driver c:\windows\system32\drivers\atikmdag.sys (7.1.1.747, 3,36 MB (3 520 512 byte), 26.02.2008 06:53) [infrarød] Element Verdi [inndata] [Tastatur] Element Verdi Beskrivelse USB-enhet for menneskelig grensesnitt Navn Enhanced (101- or 102-key) Oppsett 00000414 PNP-enhets-ID USB\VID_413C&PID_2003\5&2BEB6C46&0&2 Antall funksjonstaster 12 Driver c:\windows\system32\drivers\hidusb.sys (6.0.6000.16386, 12,00 kB (12 288 byte), 02.11.2006 09:55) [Pekeenhet] Element Verdi Maskinvaretype USB-enhet for menneskelig grensesnitt Antall knapper 0 Status OK PNP-enhets-ID USB\VID_046D&PID_C50E\5&2BEB6C46&0&1 Strømstyring støttes Nei Terskel for dobbeltklikk Ikke tilgjengelig Høyre-/venstrehendt Ikke tilgjengelig Driver c:\windows\system32\drivers\hidusb.sys (6.0.6000.16386, 12,00 kB (12 288 byte), 02.11.2006 09:55) [Modem] Element Verdi [Nettverk] [Kort] Element Verdi Navn [00000000] WAN-miniport (L2TP) Korttype Ikke tilgjengelig Produkttype WAN-miniport (L2TP) Installert Ja ID for PNP-enhet ROOT\MS_L2TPMINIPORT000 Sist tilbakestilt 08.04.2008 06:58 Indeks 0 Tjenestenavn Rasl2tp IP-adresse Ikke tilgjengelig IP-nettverk Ikke tilgjengelig Standard IP-gateway Ikke tilgjengelig DHCP-aktivert Nei DHCP-server Ikke tilgjengelig DHCP-leie utløper Ikke tilgjengelig DHCP-leie inngått Ikke tilgjengelig MAC-adresse Ikke tilgjengelig Driver c:\windows\system32\drivers\rasl2tp.sys (6.0.6000.16386, 74,00 kB (75 776 byte), 02.11.2006 09:58) Navn [00000001] WAN-miniport (PPTP) Korttype Wide Area Network (WAN) Produkttype WAN-miniport (PPTP) Installert Ja ID for PNP-enhet ROOT\MS_PPTPMINIPORT000 Sist tilbakestilt 08.04.2008 06:58 Indeks 1 Tjenestenavn PptpMiniport IP-adresse Ikke tilgjengelig IP-nettverk Ikke tilgjengelig Standard IP-gateway Ikke tilgjengelig DHCP-aktivert Nei DHCP-server Ikke tilgjengelig DHCP-leie utløper Ikke tilgjengelig DHCP-leie inngått Ikke tilgjengelig MAC-adresse 50:50:54:50:30:30 Driver c:\windows\system32\drivers\raspptp.sys (6.0.6000.16386, 60,00 kB (61 440 byte), 02.11.2006 09:58) Navn [00000002] WAN-miniport (PPPOE) Korttype Wide Area Network (WAN) Produkttype WAN-miniport (PPPOE) Installert Ja ID for PNP-enhet ROOT\MS_PPPOEMINIPORT000 Sist tilbakestilt 08.04.2008 06:58 Indeks 2 Tjenestenavn RasPppoe IP-adresse Ikke tilgjengelig IP-nettverk Ikke tilgjengelig Standard IP-gateway Ikke tilgjengelig DHCP-aktivert Nei DHCP-server Ikke tilgjengelig DHCP-leie utløper Ikke tilgjengelig DHCP-leie inngått Ikke tilgjengelig MAC-adresse 33:50:6F:45:30:30 Driver c:\windows\system32\drivers\raspppoe.sys (6.0.6000.16386, 40,50 kB (41 472 byte), 02.11.2006 09:58) Navn [00000003] WAN-miniport (IPv6) Korttype Ikke tilgjengelig Produkttype WAN-miniport (IPv6) Installert Ja ID for PNP-enhet ROOT\MS_NDISWANIPV6000 Sist tilbakestilt 08.04.2008 06:58 Indeks 3 Tjenestenavn NdisWan IP-adresse Ikke tilgjengelig IP-nettverk Ikke tilgjengelig Standard IP-gateway Ikke tilgjengelig DHCP-aktivert Nei DHCP-server Ikke tilgjengelig DHCP-leie utløper Ikke tilgjengelig DHCP-leie inngått Ikke tilgjengelig MAC-adresse Ikke tilgjengelig Driver c:\windows\system32\drivers\ndiswan.sys (6.0.6000.16386, 116,00 kB (118 784 byte), 02.11.2006 09:58) Navn [00000004] Jensen Air:Link 85300 Korttype Ikke tilgjengelig Produkttype Jensen Air:Link 85300 Installert Ja ID for PNP-enhet Ikke tilgjengelig Sist tilbakestilt 08.04.2008 06:58 Indeks 4 Tjenestenavn netr28u IP-adresse Ikke tilgjengelig IP-nettverk Ikke tilgjengelig Standard IP-gateway Ikke tilgjengelig DHCP-aktivert Nei DHCP-server Ikke tilgjengelig DHCP-leie utløper Ikke tilgjengelig DHCP-leie inngått Ikke tilgjengelig MAC-adresse Ikke tilgjengelig Navn [00000005] Jensen Air:Link 85300 Korttype Ikke tilgjengelig Produkttype Jensen Air:Link 85300 Installert Ja ID for PNP-enhet Ikke tilgjengelig Sist tilbakestilt 08.04.2008 06:58 Indeks 5 Tjenestenavn netr28u IP-adresse Ikke tilgjengelig IP-nettverk Ikke tilgjengelig Standard IP-gateway Ikke tilgjengelig DHCP-aktivert Ja DHCP-server Ikke tilgjengelig DHCP-leie utløper Ikke tilgjengelig DHCP-leie inngått Ikke tilgjengelig MAC-adresse Ikke tilgjengelig Navn [00000006] WAN-miniport (IP) Korttype Ikke tilgjengelig Produkttype WAN-miniport (IP) Installert Ja ID for PNP-enhet ROOT\MS_NDISWANIP000 Sist tilbakestilt 08.04.2008 06:58 Indeks 6 Tjenestenavn NdisWan IP-adresse Ikke tilgjengelig IP-nettverk Ikke tilgjengelig Standard IP-gateway Ikke tilgjengelig DHCP-aktivert Nei DHCP-server Ikke tilgjengelig DHCP-leie utløper Ikke tilgjengelig DHCP-leie inngått Ikke tilgjengelig MAC-adresse Ikke tilgjengelig Driver c:\windows\system32\drivers\ndiswan.sys (6.0.6000.16386, 116,00 kB (118 784 byte), 02.11.2006 09:58) Navn [00000007] Microsoft Tun Miniport Adapter Korttype Ethernet 802.3 Produkttype Microsoft Tun Miniport Adapter Installert Ja ID for PNP-enhet ROOT\*TUNMP000 Sist tilbakestilt 08.04.2008 06:58 Indeks 7 Tjenestenavn tunmp IP-adresse Ikke tilgjengelig IP-nettverk Ikke tilgjengelig Standard IP-gateway Ikke tilgjengelig DHCP-aktivert Nei DHCP-server Ikke tilgjengelig DHCP-leie utløper Ikke tilgjengelig DHCP-leie inngått Ikke tilgjengelig MAC-adresse 02:00:54:55:4E:01 Driver c:\windows\system32\drivers\tunmp.sys (6.0.6000.16501, 15,00 kB (15 360 byte), 07.02.2008 16:55) Navn [00000009] RAS Async-kort Korttype Ikke tilgjengelig Produkttype RAS Async-kort Installert Ja ID for PNP-enhet Ikke tilgjengelig Sist tilbakestilt 08.04.2008 06:58 Indeks 9 Tjenestenavn AsyncMac IP-adresse Ikke tilgjengelig IP-nettverk Ikke tilgjengelig Standard IP-gateway Ikke tilgjengelig DHCP-aktivert Nei DHCP-server Ikke tilgjengelig DHCP-leie utløper Ikke tilgjengelig DHCP-leie inngått Ikke tilgjengelig MAC-adresse Ikke tilgjengelig Navn [00000010] Jensen Air:Link 85300 Korttype Ikke tilgjengelig Produkttype Jensen Air:Link 85300 Installert Ja ID for PNP-enhet Ikke tilgjengelig Sist tilbakestilt 08.04.2008 06:58 Indeks 10 Tjenestenavn netr28u IP-adresse Ikke tilgjengelig IP-nettverk Ikke tilgjengelig Standard IP-gateway Ikke tilgjengelig DHCP-aktivert Ja DHCP-server Ikke tilgjengelig DHCP-leie utløper Ikke tilgjengelig DHCP-leie inngått Ikke tilgjengelig MAC-adresse Ikke tilgjengelig Navn [00000011] Jensen Air:Link 85300 Korttype Ethernet 802.3 Produkttype Jensen Air:Link 85300 Installert Ja ID for PNP-enhet USB\VID_148F&PID_2870\5&26712E48&0&3 Sist tilbakestilt 08.04.2008 06:58 Indeks 11 Tjenestenavn netr28u IP-adresse 192.168.1.2, fe80::481f:5b6b:5ea8:af45 IP-nettverk 255.255.255.0, 64 Standard IP-gateway 192.168.1.1 DHCP-aktivert Ja DHCP-server 192.168.1.1 DHCP-leie utløper 08.04.2008 17:31 DHCP-leie inngått 08.04.2008 16:31 MAC-adresse 00:0E:2E:E9:E2:CB Driver c:\windows\system32\drivers\netr28u.sys (1.0.3.0, 325,00 kB (332 800 byte), 07.02.2008 16:30) Navn [00000012] Microsoft ISATAP Adapter Korttype Tunnel Produkttype Microsoft ISATAP Adapter Installert Ja ID for PNP-enhet ROOT\*ISATAP002 Sist tilbakestilt 08.04.2008 06:58 Indeks 12 Tjenestenavn tunnel IP-adresse Ikke tilgjengelig IP-nettverk Ikke tilgjengelig Standard IP-gateway Ikke tilgjengelig DHCP-aktivert Nei DHCP-server Ikke tilgjengelig DHCP-leie utløper Ikke tilgjengelig DHCP-leie inngått Ikke tilgjengelig MAC-adresse Ikke tilgjengelig Driver c:\windows\system32\drivers\tunnel.sys (6.0.6000.16501, 22,50 kB (23 040 byte), 07.02.2008 16:55) [Protokoll] Element Verdi Navn MSAFD Tcpip [TCP/IP] Tjeneste uten forbindelse Nei Garanterer levering Ja Garanterer sekvens Ja Maksimal adressestørrelse 16 byte Maksimal meldingsstørrelse 0 byte Meldingsorientert Nei Minimal adressestørrelse 16 byte Pseudo-dataflytorientert Nei Støtter kringkasting Nei Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Ja Støtter stilfull lukking Ja Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD Tcpip [uDP/IP] Tjeneste uten forbindelse Ja Garanterer levering Nei Garanterer sekvens Nei Maksimal adressestørrelse 16 byte Maksimal meldingsstørrelse 63,99 kB (65 527 byte) Meldingsorientert Ja Minimal adressestørrelse 16 byte Pseudo-dataflytorientert Nei Støtter kringkasting Ja Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Ja Navn MSAFD Tcpip [TCP/IPv6] Tjeneste uten forbindelse Nei Garanterer levering Ja Garanterer sekvens Ja Maksimal adressestørrelse 28 byte Maksimal meldingsstørrelse 0 byte Meldingsorientert Nei Minimal adressestørrelse 28 byte Pseudo-dataflytorientert Nei Støtter kringkasting Nei Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Ja Støtter stilfull lukking Ja Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD Tcpip [uDP/IPv6] Tjeneste uten forbindelse Ja Garanterer levering Nei Garanterer sekvens Nei Maksimal adressestørrelse 28 byte Maksimal meldingsstørrelse 63,99 kB (65 527 byte) Meldingsorientert Ja Minimal adressestørrelse 28 byte Pseudo-dataflytorientert Nei Støtter kringkasting Ja Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Ja Navn RSVP TCPv6-tjenesteleverandør Tjeneste uten forbindelse Nei Garanterer levering Ja Garanterer sekvens Ja Maksimal adressestørrelse 28 byte Maksimal meldingsstørrelse 0 byte Meldingsorientert Nei Minimal adressestørrelse 28 byte Pseudo-dataflytorientert Nei Støtter kringkasting Nei Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Ja Støtter fremskutte data Ja Støtter stilfull lukking Ja Støtter garantert båndbredde Nei Støtter multikasting Nei Navn RSVP TCP-tjenesteleverandør Tjeneste uten forbindelse Nei Garanterer levering Ja Garanterer sekvens Ja Maksimal adressestørrelse 16 byte Maksimal meldingsstørrelse 0 byte Meldingsorientert Nei Minimal adressestørrelse 16 byte Pseudo-dataflytorientert Nei Støtter kringkasting Nei Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Ja Støtter fremskutte data Ja Støtter stilfull lukking Ja Støtter garantert båndbredde Nei Støtter multikasting Nei Navn RSVP UDPv6-tjenesteleverandør Tjeneste uten forbindelse Ja Garanterer levering Nei Garanterer sekvens Nei Maksimal adressestørrelse 28 byte Maksimal meldingsstørrelse 63,99 kB (65 527 byte) Meldingsorientert Ja Minimal adressestørrelse 28 byte Pseudo-dataflytorientert Nei Støtter kringkasting Ja Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Ja Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Ja Navn RSVP UDP-tjenesteleverandør Tjeneste uten forbindelse Ja Garanterer levering Nei Garanterer sekvens Nei Maksimal adressestørrelse 16 byte Maksimal meldingsstørrelse 63,99 kB (65 527 byte) Meldingsorientert Ja Minimal adressestørrelse 16 byte Pseudo-dataflytorientert Nei Støtter kringkasting Ja Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Ja Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Ja Navn MSAFD NetBIOS [\Device\NetBT_Tcpip_{54353B49-19FC-4440-A8FC-31F8473A4D5B}] SEQPACKET 6 Tjeneste uten forbindelse Nei Garanterer levering Ja Garanterer sekvens Ja Maksimal adressestørrelse 20 byte Maksimal meldingsstørrelse 62,50 kB (64 000 byte) Meldingsorientert Ja Minimal adressestørrelse 20 byte Pseudo-dataflytorientert Nei Støtter kringkasting Nei Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD NetBIOS [\Device\NetBT_Tcpip_{54353B49-19FC-4440-A8FC-31F8473A4D5B}] DATAGRAM 6 Tjeneste uten forbindelse Ja Garanterer levering Nei Garanterer sekvens Nei Maksimal adressestørrelse 20 byte Maksimal meldingsstørrelse 62,50 kB (64 000 byte) Meldingsorientert Ja Minimal adressestørrelse 20 byte Pseudo-dataflytorientert Nei Støtter kringkasting Ja Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD NetBIOS [\Device\NetBT_Tcpip_{8C94CAA2-64FF-4D9F-BC40-D951162D5271}] SEQPACKET 2 Tjeneste uten forbindelse Nei Garanterer levering Ja Garanterer sekvens Ja Maksimal adressestørrelse 20 byte Maksimal meldingsstørrelse 62,50 kB (64 000 byte) Meldingsorientert Ja Minimal adressestørrelse 20 byte Pseudo-dataflytorientert Nei Støtter kringkasting Nei Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD NetBIOS [\Device\NetBT_Tcpip_{8C94CAA2-64FF-4D9F-BC40-D951162D5271}] DATAGRAM 2 Tjeneste uten forbindelse Ja Garanterer levering Nei Garanterer sekvens Nei Maksimal adressestørrelse 20 byte Maksimal meldingsstørrelse 62,50 kB (64 000 byte) Meldingsorientert Ja Minimal adressestørrelse 20 byte Pseudo-dataflytorientert Nei Støtter kringkasting Ja Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD NetBIOS [\Device\NetBT_Tcpip_{901F1A42-7CA9-4A34-B933-FD8EF5EB8FA9}] SEQPACKET 0 Tjeneste uten forbindelse Nei Garanterer levering Ja Garanterer sekvens Ja Maksimal adressestørrelse 20 byte Maksimal meldingsstørrelse 62,50 kB (64 000 byte) Meldingsorientert Ja Minimal adressestørrelse 20 byte Pseudo-dataflytorientert Nei Støtter kringkasting Nei Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD NetBIOS [\Device\NetBT_Tcpip_{901F1A42-7CA9-4A34-B933-FD8EF5EB8FA9}] DATAGRAM 0 Tjeneste uten forbindelse Ja Garanterer levering Nei Garanterer sekvens Nei Maksimal adressestørrelse 20 byte Maksimal meldingsstørrelse 62,50 kB (64 000 byte) Meldingsorientert Ja Minimal adressestørrelse 20 byte Pseudo-dataflytorientert Nei Støtter kringkasting Ja Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD NetBIOS [\Device\NetBT_Tcpip_{39093A4B-AA13-4DBF-AD1F-E62080A911C6}] SEQPACKET 4 Tjeneste uten forbindelse Nei Garanterer levering Ja Garanterer sekvens Ja Maksimal adressestørrelse 20 byte Maksimal meldingsstørrelse 62,50 kB (64 000 byte) Meldingsorientert Ja Minimal adressestørrelse 20 byte Pseudo-dataflytorientert Nei Støtter kringkasting Nei Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD NetBIOS [\Device\NetBT_Tcpip_{39093A4B-AA13-4DBF-AD1F-E62080A911C6}] DATAGRAM 4 Tjeneste uten forbindelse Ja Garanterer levering Nei Garanterer sekvens Nei Maksimal adressestørrelse 20 byte Maksimal meldingsstørrelse 62,50 kB (64 000 byte) Meldingsorientert Ja Minimal adressestørrelse 20 byte Pseudo-dataflytorientert Nei Støtter kringkasting Ja Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD NetBIOS [\Device\NetBT_Tcpip6_{54353B49-19FC-4440-A8FC-31F8473A4D5B}] SEQPACKET 7 Tjeneste uten forbindelse Nei Garanterer levering Ja Garanterer sekvens Ja Maksimal adressestørrelse 20 byte Maksimal meldingsstørrelse 62,50 kB (64 000 byte) Meldingsorientert Ja Minimal adressestørrelse 20 byte Pseudo-dataflytorientert Nei Støtter kringkasting Nei Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD NetBIOS [\Device\NetBT_Tcpip6_{54353B49-19FC-4440-A8FC-31F8473A4D5B}] DATAGRAM 7 Tjeneste uten forbindelse Ja Garanterer levering Nei Garanterer sekvens Nei Maksimal adressestørrelse 20 byte Maksimal meldingsstørrelse 62,50 kB (64 000 byte) Meldingsorientert Ja Minimal adressestørrelse 20 byte Pseudo-dataflytorientert Nei Støtter kringkasting Ja Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD NetBIOS [\Device\NetBT_Tcpip6_{8C94CAA2-64FF-4D9F-BC40-D951162D5271}] SEQPACKET 3 Tjeneste uten forbindelse Nei Garanterer levering Ja Garanterer sekvens Ja Maksimal adressestørrelse 20 byte Maksimal meldingsstørrelse 62,50 kB (64 000 byte) Meldingsorientert Ja Minimal adressestørrelse 20 byte Pseudo-dataflytorientert Nei Støtter kringkasting Nei Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD NetBIOS [\Device\NetBT_Tcpip6_{8C94CAA2-64FF-4D9F-BC40-D951162D5271}] DATAGRAM 3 Tjeneste uten forbindelse Ja Garanterer levering Nei Garanterer sekvens Nei Maksimal adressestørrelse 20 byte Maksimal meldingsstørrelse 62,50 kB (64 000 byte) Meldingsorientert Ja Minimal adressestørrelse 20 byte Pseudo-dataflytorientert Nei Støtter kringkasting Ja Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD NetBIOS [\Device\NetBT_Tcpip6_{901F1A42-7CA9-4A34-B933-FD8EF5EB8FA9}] SEQPACKET 1 Tjeneste uten forbindelse Nei Garanterer levering Ja Garanterer sekvens Ja Maksimal adressestørrelse 20 byte Maksimal meldingsstørrelse 62,50 kB (64 000 byte) Meldingsorientert Ja Minimal adressestørrelse 20 byte Pseudo-dataflytorientert Nei Støtter kringkasting Nei Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD NetBIOS [\Device\NetBT_Tcpip6_{901F1A42-7CA9-4A34-B933-FD8EF5EB8FA9}] DATAGRAM 1 Tjeneste uten forbindelse Ja Garanterer levering Nei Garanterer sekvens Nei Maksimal adressestørrelse 20 byte Maksimal meldingsstørrelse 62,50 kB (64 000 byte) Meldingsorientert Ja Minimal adressestørrelse 20 byte Pseudo-dataflytorientert Nei Støtter kringkasting Ja Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD NetBIOS [\Device\NetBT_Tcpip6_{39093A4B-AA13-4DBF-AD1F-E62080A911C6}] SEQPACKET 5 Tjeneste uten forbindelse Nei Garanterer levering Ja Garanterer sekvens Ja Maksimal adressestørrelse 20 byte Maksimal meldingsstørrelse 62,50 kB (64 000 byte) Meldingsorientert Ja Minimal adressestørrelse 20 byte Pseudo-dataflytorientert Nei Støtter kringkasting Nei Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Nei Navn MSAFD NetBIOS [\Device\NetBT_Tcpip6_{39093A4B-AA13-4DBF-AD1F-E62080A911C6}] DATAGRAM 5 Tjeneste uten forbindelse Ja Garanterer levering Nei Garanterer sekvens Nei Maksimal adressestørrelse 20 byte Maksimal meldingsstørrelse 62,50 kB (64 000 byte) Meldingsorientert Ja Minimal adressestørrelse 20 byte Pseudo-dataflytorientert Nei Støtter kringkasting Ja Støtter datasammenkobling Nei Støtter datafrakobling Nei Støtter kryptering Nei Støtter fremskutte data Nei Støtter stilfull lukking Nei Støtter garantert båndbredde Nei Støtter multikasting Nei [WinSock] Element Verdi Fil c:\windows\system32\winsock.dll Størrelse 2,80 kB (2 864 byte) Versjon 3.10.0.103 Fil c:\windows\system32\wsock32.dll Størrelse 14,50 kB (14 848 byte) Versjon 6.0.6000.16386 [Porter] [serielle] Element Verdi [Parallelle] Element Verdi [Lagringsplass] [stasjoner] Element Verdi Stasjon C: Beskrivelse Local Fixed Disk Komprimert Nei Filsystem NTFS Størrelse 232,83 GB (249 997 291 520 byte) Ledig plass 90,92 GB (97 625 030 656 byte) Volumnavn Volumserienummer E2154412 Stasjon D: Beskrivelse CD-ROM Disc Stasjon E: Beskrivelse Local Fixed Disk Komprimert Nei Filsystem NTFS Størrelse 232,83 GB (249 997 291 520 byte) Ledig plass 69,24 GB (74 345 713 664 byte) Volumnavn Volumserienummer 660BEFAF Stasjon G: Beskrivelse Removable Disk Stasjon H: Beskrivelse Removable Disk Stasjon I: Beskrivelse Removable Disk Stasjon J: Beskrivelse CD-ROM Disc Stasjon K: Beskrivelse Removable Disk [Disker] Element Verdi Beskrivelse Diskstasjon Produsent (Standard diskstasjoner) Modell ST3250820AS ATA Device Byte/sektor 512 Medier lastet inn Ja Medietype Fixed hard disk Partisjoner 1 SCSI-buss 0 Logisk enhet for SCSI 0 SCSI-port 0 Mål-ID for SCSI 0 Sektorer/spor 63 Størrelse 232,83 GB (249 999 160 320 byte) Totalt antall sylindre 30 394 Totalt antall sektorer 488 279 610 Totalt antall spor 7 750 470 Spor/sylinder 255 Partisjon Disk #0, Partition #0 Partisjonstørrelse 232,83 GB (249 997 295 616 byte) Startforskyvning for partisjon 1 048 576 byte Beskrivelse Diskstasjon Produsent (Standard diskstasjoner) Modell WDC WD2500JS-75NCB3 ATA Device Byte/sektor 512 Medier lastet inn Ja Medietype Fixed hard disk Partisjoner 1 SCSI-buss 1 Logisk enhet for SCSI 0 SCSI-port 1 Mål-ID for SCSI 0 Sektorer/spor 63 Størrelse 232,83 GB (249 999 160 320 byte) Totalt antall sylindre 30 394 Totalt antall sektorer 488 279 610 Totalt antall spor 7 750 470 Spor/sylinder 255 Partisjon Disk #1, Partition #0 Partisjonstørrelse 232,83 GB (249 997 295 616 byte) Startforskyvning for partisjon 1 048 576 byte Beskrivelse Diskstasjon Produsent (Standard diskstasjoner) Modell TEAC USB HS-CF Card USB Device Byte/sektor Ikke tilgjengelig Medier lastet inn Ja Medietype Ikke tilgjengelig Partisjoner 0 SCSI-buss Ikke tilgjengelig Logisk enhet for SCSI Ikke tilgjengelig SCSI-port Ikke tilgjengelig Mål-ID for SCSI Ikke tilgjengelig Sektorer/spor Ikke tilgjengelig Størrelse Ikke tilgjengelig Totalt antall sylindre Ikke tilgjengelig Totalt antall sektorer Ikke tilgjengelig Totalt antall spor Ikke tilgjengelig Spor/sylinder Ikke tilgjengelig Beskrivelse Diskstasjon Produsent (Standard diskstasjoner) Modell TEAC USB HS-MS Card USB Device Byte/sektor Ikke tilgjengelig Medier lastet inn Ja Medietype Ikke tilgjengelig Partisjoner 0 SCSI-buss Ikke tilgjengelig Logisk enhet for SCSI Ikke tilgjengelig SCSI-port Ikke tilgjengelig Mål-ID for SCSI Ikke tilgjengelig Sektorer/spor Ikke tilgjengelig Størrelse Ikke tilgjengelig Totalt antall sylindre Ikke tilgjengelig Totalt antall sektorer Ikke tilgjengelig Totalt antall spor Ikke tilgjengelig Spor/sylinder Ikke tilgjengelig Beskrivelse Diskstasjon Produsent (Standard diskstasjoner) Modell TEAC USB HS-SD Card USB Device Byte/sektor Ikke tilgjengelig Medier lastet inn Ja Medietype Ikke tilgjengelig Partisjoner 0 SCSI-buss Ikke tilgjengelig Logisk enhet for SCSI Ikke tilgjengelig SCSI-port Ikke tilgjengelig Mål-ID for SCSI Ikke tilgjengelig Sektorer/spor Ikke tilgjengelig Størrelse Ikke tilgjengelig Totalt antall sylindre Ikke tilgjengelig Totalt antall sektorer Ikke tilgjengelig Totalt antall spor Ikke tilgjengelig Spor/sylinder Ikke tilgjengelig Beskrivelse Diskstasjon Produsent (Standard diskstasjoner) Modell TEAC USB HS-xD/SM USB Device Byte/sektor Ikke tilgjengelig Medier lastet inn Ja Medietype Ikke tilgjengelig Partisjoner 0 SCSI-buss Ikke tilgjengelig Logisk enhet for SCSI Ikke tilgjengelig SCSI-port Ikke tilgjengelig Mål-ID for SCSI Ikke tilgjengelig Sektorer/spor Ikke tilgjengelig Størrelse Ikke tilgjengelig Totalt antall sylindre Ikke tilgjengelig Totalt antall sektorer Ikke tilgjengelig Totalt antall spor Ikke tilgjengelig Spor/sylinder Ikke tilgjengelig [sCSI] Element Verdi Navn SCSI/RAID Host Controller Produsent (Standard mass storage controllers) Status OK Enhets-ID for PNP ACPI\PNPA000\4&5D18F2DF&0 I/U-port 0x0000FFE0-0x0000FFEF IRQ-kanal IRQ 9 Navn Microsoft iSCSI Initiator Produsent Microsoft Status OK Enhets-ID for PNP ROOT\ISCSIPRT000 Driver c:\windows\system32\drivers\msiscsi.sys (6.0.6000.16386, 164,60 kB (168 552 byte), 02.11.2006 09:52) [iDE] Element Verdi Navn Standard Dual Channel PCI IDE Controller Produsent (Standard IDE ATA/ATAPI-kontrollere) Status OK Enhets-ID for PNP PCI\VEN_8086&DEV_2920&SUBSYS_020D1028&REV_02\3&2411E6FE&0&FA I/U-port 0x0000F800-0x0000F807 I/U-port 0x0000F700-0x0000F703 I/U-port 0x0000F600-0x0000F607 I/U-port 0x0000F500-0x0000F503 I/U-port 0x0000F400-0x0000F40F I/U-port 0x0000F300-0x0000F30F IRQ-kanal IRQ 19 Driver c:\windows\system32\drivers\pciide.sys (6.0.6000.16632, 15,55 kB (15 928 byte), 14.02.2008 17:06) Navn IDE-kanal Produsent (Standard IDE ATA/ATAPI-kontrollere) Status OK Enhets-ID for PNP PCIIDE\IDECHANNEL\4&1C8E8B0D&0&0 Driver c:\windows\system32\drivers\atapi.sys (6.0.6000.16632, 21,05 kB (21 560 byte), 14.02.2008 17:06) Navn IDE-kanal Produsent (Standard IDE ATA/ATAPI-kontrollere) Status OK Enhets-ID for PNP PCIIDE\IDECHANNEL\4&1C8E8B0D&0&1 Driver c:\windows\system32\drivers\atapi.sys (6.0.6000.16632, 21,05 kB (21 560 byte), 14.02.2008 17:06) Navn Standard Dual Channel PCI IDE Controller Produsent (Standard IDE ATA/ATAPI-kontrollere) Status OK Enhets-ID for PNP PCI\VEN_8086&DEV_2926&SUBSYS_020D1028&REV_02\3&2411E6FE&0&FD I/U-port 0x0000F100-0x0000F107 I/U-port 0x0000F000-0x0000F003 I/U-port 0x0000EF00-0x0000EF07 I/U-port 0x0000EE00-0x0000EE03 I/U-port 0x0000ED00-0x0000ED0F I/U-port 0x0000EC00-0x0000EC0F IRQ-kanal IRQ 19 Driver c:\windows\system32\drivers\pciide.sys (6.0.6000.16632, 15,55 kB (15 928 byte), 14.02.2008 17:06) Navn IDE-kanal Produsent (Standard IDE ATA/ATAPI-kontrollere) Status OK Enhets-ID for PNP PCIIDE\IDECHANNEL\4&39BFD449&0&0 Driver c:\windows\system32\drivers\atapi.sys (6.0.6000.16632, 21,05 kB (21 560 byte), 14.02.2008 17:06) Navn IDE-kanal Produsent (Standard IDE ATA/ATAPI-kontrollere) Status OK Enhets-ID for PNP PCIIDE\IDECHANNEL\4&39BFD449&0&1 Driver c:\windows\system32\drivers\atapi.sys (6.0.6000.16632, 21,05 kB (21 560 byte), 14.02.2008 17:06) [utskrift] Navn Driver Portnavn Servernavn Send To OneNote 2007 Send To Microsoft OneNote Driver Send To Microsoft OneNote Port: Microsoft XPS Document Writer Microsoft XPS Document Writer XPSPort: Adobe PDF Adobe PDF Converter Documents\*.pdf \\Jostein\HP DeskJet 930C/932C/935C HP DeskJet 930C/932C/935C LPT1: [Problemenheter] Enhet PNP-enhets-ID Feilkode Ethernet-kontroller PCI\VEN_8086&DEV_10C0&SUBSYS_020D1028&REV_02\3&2411E6FE&0&C8 The drivers for this device are not installed. SM-busskontroller PCI\VEN_8086&DEV_2930&SUBSYS_020D1028&REV_02\3&2411E6FE&0&FB The drivers for this device are not installed. [uSB] Enhet PNP-enhets-ID Standard Universal PCI to USB Host Controller PCI\VEN_8086&DEV_2937&SUBSYS_020D1028&REV_02\3&2411E6FE&0&D0 Standard Universal PCI to USB Host Controller PCI\VEN_8086&DEV_2938&SUBSYS_020D1028&REV_02\3&2411E6FE&0&D1 Standard Universal PCI to USB Host Controller PCI\VEN_8086&DEV_2939&SUBSYS_020D1028&REV_02\3&2411E6FE&0&D2 Standard Enhanced PCI to USB Host Controller PCI\VEN_8086&DEV_293C&SUBSYS_020D1028&REV_02\3&2411E6FE&0&D7 Standard Universal PCI to USB Host Controller PCI\VEN_8086&DEV_2934&SUBSYS_020D1028&REV_02\3&2411E6FE&0&E8 Standard Universal PCI to USB Host Controller PCI\VEN_8086&DEV_2935&SUBSYS_020D1028&REV_02\3&2411E6FE&0&E9 Standard Universal PCI to USB Host Controller PCI\VEN_8086&DEV_2936&SUBSYS_020D1028&REV_02\3&2411E6FE&0&EA Standard Enhanced PCI to USB Host Controller PCI\VEN_8086&DEV_293A&SUBSYS_020D1028&REV_02\3&2411E6FE&0&EF [Programvaremiljø] [systemdrivere] Navn Beskrivelse Fil Type Startet Startmodus Tilstand Status Feilkontroll Godta pause Godta stopp acpi Microsoft ACPI-driver c:\windows\system32\drivers\acpi.sys Kernel Driver Ja Boot Running OK Critical Nei Ja adp94xx adp94xx c:\windows\system32\drivers\adp94xx.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei adpahci adpahci c:\windows\system32\drivers\adpahci.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei adpu160m adpu160m c:\windows\system32\drivers\adpu160m.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei adpu320 adpu320 c:\windows\system32\drivers\adpu320.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei afd Ancilliary Function Driver for Winsock c:\windows\system32\drivers\afd.sys Kernel Driver Ja System Running OK Normal Nei Ja agp440 Intel AGP Bus Filter c:\windows\system32\drivers\agp440.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei aic78xx aic78xx c:\windows\system32\drivers\djsvs.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei aliide aliide c:\windows\system32\drivers\aliide.sys Kernel Driver Nei Disabled Stopped OK Critical Nei Nei amdagp AMD AGP Bus Filter Driver c:\windows\system32\drivers\amdagp.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei amdide amdide c:\windows\system32\drivers\amdide.sys Kernel Driver Nei Disabled Stopped OK Critical Nei Nei amdk7 AMD K7 Processor Driver c:\windows\system32\drivers\amdk7.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei amdk8 AMD K8 Processor Driver c:\windows\system32\drivers\amdk8.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei arc arc c:\windows\system32\drivers\arc.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei arcsas arcsas c:\windows\system32\drivers\arcsas.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei asyncmac RAS asynkron mediedriver c:\windows\system32\drivers\asyncmac.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei atapi IDE-kanal c:\windows\system32\drivers\atapi.sys Kernel Driver Ja Boot Running OK Critical Nei Ja atikmdag atikmdag c:\windows\system32\drivers\atikmdag.sys Kernel Driver Ja Manual Running OK Ignore Nei Ja beep Beep c:\windows\system32\drivers\beep.sys Kernel Driver Ja System Running OK Normal Nei Ja bowser Bowser c:\windows\system32\drivers\bowser.sys File System Driver Ja Manual Running OK Normal Nei Ja brfiltlo Brother USB Mass-Storage Lower Filter Driver c:\windows\system32\drivers\brfiltlo.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei brfiltup Brother USB Mass-Storage Upper Filter Driver c:\windows\system32\drivers\brfiltup.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei brserid Brother MFC Serial Port Interface Driver (WDM) c:\windows\system32\drivers\brserid.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei brserwdm Brother WDM Serial driver c:\windows\system32\drivers\brserwdm.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei brusbmdm Brother MFC USB Fax Only Modem c:\windows\system32\drivers\brusbmdm.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei brusbser Brother MFC USB Serial WDM Driver c:\windows\system32\drivers\brusbser.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei bthmodem Bluetooth Serial Communications Driver c:\windows\system32\drivers\bthmodem.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei cdfs CD/DVD File System Reader c:\windows\system32\drivers\cdfs.sys File System Driver Ja Disabled Running OK Normal Nei Ja cdrom CD-ROM-driver c:\windows\system32\drivers\cdrom.sys Kernel Driver Ja System Running OK Normal Nei Ja circlass Consumer IR Devices c:\windows\system32\drivers\circlass.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei clfs Common Log (CLFS) c:\windows\system32\clfs.sys Kernel Driver Ja Boot Running OK Critical Nei Ja cmdide cmdide c:\windows\system32\drivers\cmdide.sys Kernel Driver Nei Disabled Stopped OK Critical Nei Nei compbatt Microsoft Composite Battery Driver c:\windows\system32\drivers\compbatt.sys Kernel Driver Nei Disabled Stopped OK Critical Nei Nei crcdisk Crcdisk Filter Driver c:\windows\system32\drivers\crcdisk.sys Kernel Driver Ja Boot Running OK Normal Nei Ja crusoe Transmeta Crusoe Processor Driver c:\windows\system32\drivers\crusoe.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei dfsc Dfs Client Driver c:\windows\system32\drivers\dfsc.sys File System Driver Ja System Running OK Normal Nei Ja disk Diskdriver c:\windows\system32\drivers\disk.sys Kernel Driver Ja Boot Running OK Normal Nei Ja drmkaud Microsoft Kernel DRM Audio Descrambler c:\windows\system32\drivers\drmkaud.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei dxgkrnl LDDM Graphics Subsystem c:\windows\system32\drivers\dxgkrnl.sys Kernel Driver Ja Manual Running OK Ignore Nei Ja e1g60 Intel® PRO/1000 NDIS 6 Adapter Driver c:\windows\system32\drivers\e1g60i32.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei ecache ReadyBoost Caching Driver c:\windows\system32\drivers\ecache.sys Kernel Driver Ja Boot Running OK Critical Nei Ja elxstor elxstor c:\windows\system32\drivers\elxstor.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei fastfat FAT12/16/32 File System Driver c:\windows\system32\drivers\fastfat.sys File System Driver Nei Manual Stopped OK Normal Nei Nei fdc Driver for diskettkontroller c:\windows\system32\drivers\fdc.sys Kernel Driver Ja Manual Running OK Normal Nei Ja fileinfo File Information FS MiniFilter c:\windows\system32\drivers\fileinfo.sys File System Driver Ja Boot Running OK Normal Nei Ja filetrace FileTrace c:\windows\system32\drivers\filetrace.sys File System Driver Nei Manual Stopped OK Normal Nei Nei flpydisk Floppy Disk Driver c:\windows\system32\drivers\flpydisk.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei fltmgr FltMgr c:\windows\system32\drivers\fltmgr.sys File System Driver Ja Boot Running OK Critical Nei Ja gagp30kx Microsoft Generic AGPv3.0 Filter for K8 Processor Platforms c:\windows\system32\drivers\gagp30kx.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei hdaudaddservice Microsoft 1.1 UAA Function Driver for High Definition Audio Service c:\windows\system32\drivers\hdaudio.sys Kernel Driver Ja Manual Running OK Normal Nei Ja hdaudbus Microsoft UAA Bus Driver for High Definition Audio c:\windows\system32\drivers\hdaudbus.sys Kernel Driver Ja Manual Running OK Normal Nei Ja hidbth Microsoft Bluetooth HID Miniport c:\windows\system32\drivers\hidbth.sys Kernel Driver Nei Disabled Stopped OK Ignore Nei Nei hidir Microsoft Infrared HID Driver c:\windows\system32\drivers\hidir.sys Kernel Driver Nei Disabled Stopped OK Ignore Nei Nei hidusb Microsoft HID-klassedriver c:\windows\system32\drivers\hidusb.sys Kernel Driver Ja Manual Running OK Ignore Nei Ja hpcisss HpCISSs c:\windows\system32\drivers\hpcisss.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei http HTTP c:\windows\system32\drivers\http.sys Kernel Driver Ja Manual Running OK Normal Nei Ja i2omp i2omp c:\windows\system32\drivers\i2omp.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei i8042prt i8042 Keyboard and PS/2 Mouse Port Driver c:\windows\system32\drivers\i8042prt.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei iastorv Intel RAID Controller Vista c:\windows\system32\drivers\iastorv.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei iirsp iirsp c:\windows\system32\drivers\iirsp.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei intelide intelide c:\windows\system32\drivers\intelide.sys Kernel Driver Nei Disabled Stopped OK Critical Nei Nei intelppm Intel Processor Driver c:\windows\system32\drivers\intelppm.sys Kernel Driver Ja Manual Running OK Normal Nei Ja ipfilterdriver IP Traffic Filter Driver c:\windows\system32\drivers\ipfltdrv.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei ipmidrv IPMIDRV c:\windows\system32\drivers\ipmidrv.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei ipnat IP Network Address Translator c:\windows\system32\drivers\ipnat.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei irenum IR Bus Enumerator c:\windows\system32\drivers\irenum.sys Kernel Driver Nei Manual Stopped OK Ignore Nei Nei isapnp PnP ISA/EISA Bus Driver c:\windows\system32\drivers\isapnp.sys Kernel Driver Nei Disabled Stopped OK Critical Nei Nei iscsiprt iScsiPort-driver c:\windows\system32\drivers\msiscsi.sys Kernel Driver Ja Manual Running OK Normal Nei Ja iteatapi ITEATAPI_Service_Install c:\windows\system32\drivers\iteatapi.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei iteraid ITERAID_Service_Install c:\windows\system32\drivers\iteraid.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei kbdclass Keyboard Class Driver c:\windows\system32\drivers\kbdclass.sys Kernel Driver Ja System Running OK Normal Nei Ja kbdhid Keyboard HID Driver c:\windows\system32\drivers\kbdhid.sys Kernel Driver Ja System Running OK Ignore Nei Ja ksecdd KSecDD c:\windows\system32\drivers\ksecdd.sys Kernel Driver Ja Boot Running OK Critical Nei Ja lltdio Link-Layer Topology Discovery Mapper I/O Driver c:\windows\system32\drivers\lltdio.sys Kernel Driver Ja Auto Running OK Normal Nei Ja lsi_fc LSI_FC c:\windows\system32\drivers\lsi_fc.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei lsi_sas LSI_SAS c:\windows\system32\drivers\lsi_sas.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei lsi_scsi LSI_SCSI c:\windows\system32\drivers\lsi_scsi.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei luafv UAC File Virtualization c:\windows\system32\drivers\luafv.sys File System Driver Ja Auto Running OK Normal Nei Ja megasas megasas c:\windows\system32\drivers\megasas.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei modem Modem c:\windows\system32\drivers\modem.sys Kernel Driver Nei Manual Stopped OK Ignore Nei Nei monitor Microsoft Monitor Class Function Driver Service c:\windows\system32\drivers\monitor.sys Kernel Driver Ja Manual Running OK Normal Nei Ja mouclass Museklassedriver c:\windows\system32\drivers\mouclass.sys Kernel Driver Ja System Running OK Normal Nei Ja mouhid Muse-HID-driver c:\windows\system32\drivers\mouhid.sys Kernel Driver Ja Manual Running OK Ignore Nei Ja mountmgr Mount Point Manager c:\windows\system32\drivers\mountmgr.sys Kernel Driver Ja Boot Running OK Critical Nei Ja mpio Microsoft Multi-Path Bus Driver c:\windows\system32\drivers\mpio.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei mpsdrv Driver for Windows-brannmurgodkjenning c:\windows\system32\drivers\mpsdrv.sys Kernel Driver Ja Manual Running OK Normal Nei Ja mraid35x Mraid35x c:\windows\system32\drivers\mraid35x.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei mrxdav WebDav Client Redirector Driver c:\windows\system32\drivers\mrxdav.sys File System Driver Ja Manual Running OK Normal Nei Ja mrxsmb SMB MiniRedirector Wrapper and Engine c:\windows\system32\drivers\mrxsmb.sys File System Driver Ja Manual Running OK Normal Nei Ja mrxsmb10 SMB 1.x MiniRedirector c:\windows\system32\drivers\mrxsmb10.sys File System Driver Ja Manual Running OK Normal Nei Ja mrxsmb20 SMB 2.0 MiniRedirector c:\windows\system32\drivers\mrxsmb20.sys File System Driver Ja Manual Running OK Normal Nei Ja msahci msahci c:\windows\system32\drivers\msahci.sys Kernel Driver Nei Disabled Stopped OK Critical Nei Nei msdsm Microsoft Multi-Path Device Specific Module c:\windows\system32\drivers\msdsm.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei msfs Msfs c:\windows\system32\drivers\msfs.sys File System Driver Ja System Running OK Normal Nei Ja msisadrv ISA/EISA Class Driver c:\windows\system32\drivers\msisadrv.sys Kernel Driver Ja Boot Running OK Critical Nei Ja mskssrv Tjenesteproxy for Microsoft Streaming c:\windows\system32\drivers\mskssrv.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei mspclock Klokkeproxy for Microsoft Streaming c:\windows\system32\drivers\mspclock.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei mspqm Kvalitetsbehandlingsproxy for Microsoft Streaming c:\windows\system32\drivers\mspqm.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei msrpc MsRPC c:\windows\system32\drivers\msrpc.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei mssmbios Microsoft System Management BIOS Driver c:\windows\system32\drivers\mssmbios.sys Kernel Driver Ja Manual Running OK Normal Nei Ja mstee Tee/Sink-to-Sink-konverterer for Microsoft Streaming c:\windows\system32\drivers\mstee.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei mup Mup c:\windows\system32\drivers\mup.sys File System Driver Ja Boot Running OK Normal Nei Ja nativewifip NativeWiFi Filter c:\windows\system32\drivers\nwifi.sys Kernel Driver Ja Manual Running OK Normal Nei Ja ndis NDIS System Driver c:\windows\system32\drivers\ndis.sys Kernel Driver Ja Boot Running OK Critical Nei Ja ndistapi NDIS TAPI-driver for ekstern pålogging c:\windows\system32\drivers\ndistapi.sys Kernel Driver Ja Manual Running OK Normal Nei Ja ndisuio NDIS Usermode I/O Protocol c:\windows\system32\drivers\ndisuio.sys Kernel Driver Ja Manual Running OK Normal Nei Ja ndiswan NDIS WAN-driver for ekstern pålogging c:\windows\system32\drivers\ndiswan.sys Kernel Driver Ja Manual Running OK Normal Nei Ja ndproxy NDIS Proxy c:\windows\system32\drivers\ndproxy.sys Kernel Driver Ja Manual Running OK Normal Nei Ja netbios NetBIOS Interface c:\windows\system32\drivers\netbios.sys File System Driver Ja System Running OK Normal Nei Ja netbt NETBT c:\windows\system32\drivers\netbt.sys Kernel Driver Ja System Running OK Normal Nei Ja netr28u Jensen USB Wireless LAN Card Driver for Vista c:\windows\system32\drivers\netr28u.sys Kernel Driver Ja Manual Running OK Normal Nei Ja nfrd960 nfrd960 c:\windows\system32\drivers\nfrd960.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei npfs Npfs c:\windows\system32\drivers\npfs.sys File System Driver Ja System Running OK Normal Nei Ja nsiproxy NSI proxy service c:\windows\system32\drivers\nsiproxy.sys Kernel Driver Ja System Running OK Normal Nei Ja ntfs Ntfs c:\windows\system32\drivers\ntfs.sys File System Driver Ja Manual Running OK Normal Nei Ja ntrigdigi N-trig HID Tablet Driver c:\windows\system32\drivers\ntrigdigi.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei null Null c:\windows\system32\drivers\null.sys Kernel Driver Ja System Running OK Normal Nei Ja nvraid NVIDIA nForce RAID Class Driver c:\windows\system32\drivers\nvraid.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei nvstor nvstor c:\windows\system32\drivers\nvstor.sys Kernel Driver Nei Disabled Stopped OK Critical Nei Nei nv_agp NVIDIA nForce AGP Bus Filter c:\windows\system32\drivers\nv_agp.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei ohci1394 NEC FireWarden OHCI Compliant IEEE 1394 Host Controller c:\windows\system32\drivers\ohci1394.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei parport Parallel port driver c:\windows\system32\drivers\parport.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei partmgr Partition Manager c:\windows\system32\drivers\partmgr.sys Kernel Driver Ja Boot Running OK Critical Nei Ja parvdm Parvdm c:\windows\system32\drivers\parvdm.sys Kernel Driver Nei Auto Stopped OK Ignore Nei Nei pci PCI Bus Driver c:\windows\system32\drivers\pci.sys Kernel Driver Ja Boot Running OK Critical Nei Ja pciide pciide c:\windows\system32\drivers\pciide.sys Kernel Driver Ja Boot Running OK Critical Nei Ja pcmcia pcmcia c:\windows\system32\drivers\pcmcia.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei peauth PEAUTH c:\windows\system32\drivers\peauth.sys Kernel Driver Ja Auto Running OK Normal Nei Ja pptpminiport WAN-miniport (PPTP) c:\windows\system32\drivers\raspptp.sys Kernel Driver Ja Manual Running OK Normal Nei Ja processor Processor Driver c:\windows\system32\drivers\processr.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei psched QoS-pakkeplanlegger c:\windows\system32\drivers\pacer.sys Kernel Driver Ja System Running OK Normal Nei Ja pxhelp20 PxHelp20 c:\windows\system32\drivers\pxhelp20.sys Kernel Driver Ja Boot Running OK Normal Nei Ja ql2300 QLogic Fibre Channel Miniport Driver c:\windows\system32\drivers\ql2300.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei ql40xx QLogic iSCSI Miniport Driver c:\windows\system32\drivers\ql40xx.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei qwavedrv QWAVE-driver c:\windows\system32\drivers\qwavedrv.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei rasacd Remote Access Auto Connection Driver c:\windows\system32\drivers\rasacd.sys Kernel Driver Ja System Running OK Normal Nei Ja rasl2tp WAN-miniport (L2TP) c:\windows\system32\drivers\rasl2tp.sys Kernel Driver Ja Manual Running OK Normal Nei Ja raspppoe PPPOE-driver for ekstern tilgang c:\windows\system32\drivers\raspppoe.sys Kernel Driver Ja Manual Running OK Normal Nei Ja rdbss Redirected Buffering Sub Sysytem c:\windows\system32\drivers\rdbss.sys File System Driver Ja System Running OK Normal Nei Ja rdpcdd RDPCDD c:\windows\system32\drivers\rdpcdd.sys Kernel Driver Ja System Running OK Ignore Nei Ja rdpdr Terminal Server Device Redirector Driver c:\windows\system32\drivers\rdpdr.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei rdpencdd RDP Encoder Mirror Driver c:\windows\system32\drivers\rdpencdd.sys Kernel Driver Ja System Running OK Ignore Nei Ja rdpwd RDP Winstation Driver c:\windows\system32\drivers\rdpwd.sys Kernel Driver Nei Manual Stopped OK Ignore Nei Nei rspndr Link-Layer Topology Discovery Responder c:\windows\system32\drivers\rspndr.sys Kernel Driver Ja Auto Running OK Normal Nei Ja sbp2port SBP-2 Transport/Protocol Bus Driver c:\windows\system32\drivers\sbp2port.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei secdrv Security Driver c:\windows\system32\drivers\secdrv.sys Kernel Driver Ja Auto Running OK Normal Nei Ja serenum Serenum Filter Driver c:\windows\system32\drivers\serenum.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei serial Serial Port Driver c:\windows\system32\drivers\serial.sys Kernel Driver Nei Disabled Stopped OK Ignore Nei Nei sermouse Serial Mouse Driver c:\windows\system32\drivers\sermouse.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei sffdisk SFF Storage Class Driver c:\windows\system32\drivers\sffdisk.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei sffp_mmc SFF Storage Protocol Driver for MMC c:\windows\system32\drivers\sffp_mmc.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei sffp_sd SFF Storage Protocol Driver for SDBus c:\windows\system32\drivers\sffp_sd.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei sfloppy High-Capacity Floppy Disk Drive c:\windows\system32\drivers\sfloppy.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei sisagp SIS AGP Bus Filter c:\windows\system32\drivers\sisagp.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei sisraid2 SiSRaid2 c:\windows\system32\drivers\sisraid2.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei sisraid4 SiSRaid4 c:\windows\system32\drivers\sisraid4.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei smb Meldingsorientert TCP/IP- og TCP/IPv6-protokoll (SMB-økt) c:\windows\system32\drivers\smb.sys Kernel Driver Ja System Running OK Normal Nei Ja spldr Security Processor Loader Driver c:\windows\system32\drivers\spldr.sys Kernel Driver Ja Boot Running OK Critical Nei Ja srv srv c:\windows\system32\drivers\srv.sys File System Driver Ja Manual Running OK Normal Nei Ja srv2 srv2 c:\windows\system32\drivers\srv2.sys File System Driver Ja Manual Running OK Normal Nei Ja srvnet srvnet c:\windows\system32\drivers\srvnet.sys File System Driver Ja Manual Running OK Normal Nei Ja swenum Software Bus Driver c:\windows\system32\drivers\swenum.sys Kernel Driver Ja Manual Running OK Normal Nei Ja symc8xx Symc8xx c:\windows\system32\drivers\symc8xx.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei sym_hi Sym_hi c:\windows\system32\drivers\sym_hi.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei sym_u3 Sym_u3 c:\windows\system32\drivers\sym_u3.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei tcpip Driver for TCP/IP-protokoll c:\windows\system32\drivers\tcpip.sys Kernel Driver Ja System Running OK Normal Nei Ja tcpip6 Microsoft IPv6 Protocol Driver c:\windows\system32\drivers\tcpip.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei tcpipreg TCP/IP Registry Compatibility c:\windows\system32\drivers\tcpipreg.sys Kernel Driver Ja Auto Running OK Normal Nei Ja tdpipe TDPIPE c:\windows\system32\drivers\tdpipe.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei tdtcp TDTCP c:\windows\system32\drivers\tdtcp.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei tdx TDI-støttedriver for eldre NetIO c:\windows\system32\drivers\tdx.sys Kernel Driver Ja System Running OK Normal Nei Ja termdd Terminal Device Driver c:\windows\system32\drivers\termdd.sys Kernel Driver Ja System Running OK Normal Nei Ja tssecsrv Terminal Services Security Filter Driver c:\windows\system32\drivers\tssecsrv.sys Kernel Driver Nei Manual Stopped OK Ignore Nei Nei tunmp Microsoft Tun Miniport Adapter Driver c:\windows\system32\drivers\tunmp.sys Kernel Driver Ja Manual Running OK Normal Nei Ja tunnel Microsoft IPv6 Tunnel Miniport Adapter Driver c:\windows\system32\drivers\tunnel.sys Kernel Driver Ja Manual Running OK Normal Nei Ja uagp35 Microsoft AGPv3.5 Filter c:\windows\system32\drivers\uagp35.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei udfs udfs c:\windows\system32\drivers\udfs.sys File System Driver Nei Disabled Stopped OK Normal Nei Nei uliagpkx Uli AGP Bus Filter c:\windows\system32\drivers\uliagpkx.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei uliahci uliahci c:\windows\system32\drivers\uliahci.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei ulsata UlSata c:\windows\system32\drivers\ulsata.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei ulsata2 ulsata2 c:\windows\system32\drivers\ulsata2.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei umbus UMBus Enumerator Driver c:\windows\system32\drivers\umbus.sys Kernel Driver Ja Manual Running OK Normal Nei Ja usbccgp Microsoft USB Generic Parent Driver c:\windows\system32\drivers\usbccgp.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei usbcir eHome Infrared Receiver (USBCIR) c:\windows\system32\drivers\usbcir.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei usbehci Microsoft USB 2.0 Enhanced Host Controller Miniport Driver c:\windows\system32\drivers\usbehci.sys Kernel Driver Ja Manual Running OK Normal Nei Ja usbhub USB2 Enabled Hub c:\windows\system32\drivers\usbhub.sys Kernel Driver Ja Manual Running OK Normal Nei Ja usbohci Microsoft USB Open Host Controller Miniport Driver c:\windows\system32\drivers\usbohci.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei usbprint Microsoft USB PRINTER Class c:\windows\system32\drivers\usbprint.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei usbstor USB Mass Storage Driver c:\windows\system32\drivers\usbstor.sys Kernel Driver Ja Manual Running OK Normal Nei Ja usbuhci Microsoft USB Universal Host Controller Miniport Driver c:\windows\system32\drivers\usbuhci.sys Kernel Driver Ja Manual Running OK Normal Nei Ja vga vga c:\windows\system32\drivers\vgapnp.sys Kernel Driver Nei Manual Stopped OK Ignore Nei Nei vgasave VgaSave c:\windows\system32\drivers\vga.sys Kernel Driver Ja System Running OK Ignore Nei Ja viaagp VIA AGP Bus Filter c:\windows\system32\drivers\viaagp.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei viac7 VIA C7 Processor Driver c:\windows\system32\drivers\viac7.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei viaide viaide c:\windows\system32\drivers\viaide.sys Kernel Driver Nei Disabled Stopped OK Critical Nei Nei volmgr Volume Manager Driver c:\windows\system32\drivers\volmgr.sys Kernel Driver Ja Boot Running OK Critical Nei Ja volmgrx Dynamic Volume Manager c:\windows\system32\drivers\volmgrx.sys Kernel Driver Ja Boot Running OK Critical Nei Ja volsnap Lagringsvolumer c:\windows\system32\drivers\volsnap.sys Kernel Driver Ja Boot Running OK Critical Nei Ja vsmraid vsmraid c:\windows\system32\drivers\vsmraid.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei wacompen Wacom Serial Pen HID Driver c:\windows\system32\drivers\wacompen.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei wanarp Remote Access IP ARP Driver c:\windows\system32\drivers\wanarp.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei wanarpv6 Remote Access IPv6 ARP Driver c:\windows\system32\drivers\wanarp.sys Kernel Driver Ja System Running OK Normal Nei Ja wd Microsoft Watchdog Timer Driver c:\windows\system32\drivers\wd.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei wdf01000 Kernel Mode Driver Frameworks service c:\windows\system32\drivers\wdf01000.sys Kernel Driver Ja Boot Running OK Normal Nei Ja wmiacpi Microsoft Windows Management Interface for ACPI c:\windows\system32\drivers\wmiacpi.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei wpdusb WpdUsb c:\windows\system32\drivers\wpdusb.sys Kernel Driver Nei Manual Stopped OK Normal Nei Nei ws2ifsl Winsock IFS driver c:\windows\system32\drivers\ws2ifsl.sys Kernel Driver Nei Disabled Stopped OK Normal Nei Nei wudfrd WUDFRd c:\windows\system32\drivers\wudfrd.sys Kernel Driver Ja Manual Running OK Normal Nei Ja xpadfl02 XPAD Filter Service 02 c:\windows\system32\drivers\xpadfl02.sys Kernel Driver Nei Manual Stopped OK Ignore Nei Nei [signerte drivere] Enhetsnavn Signert Enhetsklasse Driverversjon Driverdato Produsent INF-navn Drivernavn Enhets-ID Generisk volum Ja VOLUME 6.0.6000.16586 21.06.2006 Microsoft volume.inf Ikke tilgjengelig STORAGE\VOLUME\1&19F7E59C&0&_??_USBSTOR#DISK&VEN_TEAC&PROD_USB___HS-SD_CARD&REV_4.08#000006023F25&3#{53F56307-B6BF-11D0-94F2-00A0C91EFB8B} Generisk volum Ja VOLUME 6.0.6000.16586 21.06.2006 Microsoft volume.inf Ikke tilgjengelig STORAGE\VOLUME\1&19F7E59C&0&_??_USBSTOR#DISK&VEN_TEAC&PROD_USB___HS-MS_CARD&REV_4.08#000006023F25&2#{53F56307-B6BF-11D0-94F2-00A0C91EFB8B} Generisk volum Ja VOLUME 6.0.6000.16586 21.06.2006 Microsoft volume.inf Ikke tilgjengelig STORAGE\VOLUME\1&19F7E59C&0&_??_USBSTOR#DISK&VEN_TEAC&PROD_USB___HS-XD#SM&REV_4.08#000006023F25&1#{53F56307-B6BF-11D0-94F2-00A0C91EFB8B} Generisk volum Ja VOLUME 6.0.6000.16586 21.06.2006 Microsoft volume.inf Ikke tilgjengelig STORAGE\VOLUME\1&19F7E59C&0&_??_USBSTOR#DISK&VEN_TEAC&PROD_USB___HS-CF_CARD&REV_4.08#000006023F25&0#{53F56307-B6BF-11D0-94F2-00A0C91EFB8B} Generisk volumskyggekopi Ja VOLUMESNAPSHOT 6.0.6000.16386 21.06.2006 Microsoft volsnap.inf Ikke tilgjengelig STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT20 Generisk volumskyggekopi Ja VOLUMESNAPSHOT 6.0.6000.16386 21.06.2006 Microsoft volsnap.inf Ikke tilgjengelig STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT19 Generisk volumskyggekopi Ja VOLUMESNAPSHOT 6.0.6000.16386 21.06.2006 Microsoft volsnap.inf Ikke tilgjengelig STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT18 Generisk volumskyggekopi Ja VOLUMESNAPSHOT 6.0.6000.16386 21.06.2006 Microsoft volsnap.inf Ikke tilgjengelig STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT17 Generisk volumskyggekopi Ja VOLUMESNAPSHOT 6.0.6000.16386 21.06.2006 Microsoft volsnap.inf Ikke tilgjengelig STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT16 Generisk volumskyggekopi Ja VOLUMESNAPSHOT 6.0.6000.16386 21.06.2006 Microsoft volsnap.inf Ikke tilgjengelig STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT15 Generisk volumskyggekopi Ja VOLUMESNAPSHOT 6.0.6000.16386 21.06.2006 Microsoft volsnap.inf Ikke tilgjengelig STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT14 Generisk volumskyggekopi Ja VOLUMESNAPSHOT 6.0.6000.16386 21.06.2006 Microsoft volsnap.inf Ikke tilgjengelig STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT13 Generisk volumskyggekopi Ja VOLUMESNAPSHOT 6.0.6000.16386 21.06.2006 Microsoft volsnap.inf Ikke tilgjengelig STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT12 Generisk volumskyggekopi Ja VOLUMESNAPSHOT 6.0.6000.16386 21.06.2006 Microsoft volsnap.inf Ikke tilgjengelig STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT11 Generisk volumskyggekopi Ja VOLUMESNAPSHOT 6.0.6000.16386 21.06.2006 Microsoft volsnap.inf Ikke tilgjengelig STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT10 Generisk volumskyggekopi Ja VOLUMESNAPSHOT 6.0.6000.16386 21.06.2006 Microsoft volsnap.inf Ikke tilgjengelig STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT9 Generisk volumskyggekopi Ja VOLUMESNAPSHOT 6.0.6000.16386 21.06.2006 Microsoft volsnap.inf Ikke tilgjengelig STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT8 Generisk volumskyggekopi Ja VOLUMESNAPSHOT 6.0.6000.16386 21.06.2006 Microsoft volsnap.inf Ikke tilgjengelig STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT7 Generisk volumskyggekopi Ja VOLUMESNAPSHOT 6.0.6000.16386 21.06.2006 Microsoft volsnap.inf Ikke tilgjengelig STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT6 Generisk volumskyggekopi Ja VOLUMESNAPSHOT 6.0.6000.16386 21.06.2006 Microsoft volsnap.inf Ikke tilgjengelig STORAGE\VOLUMESNAPSHOT\HARDDISKVOLUMESNAPSHOT5 Generisk volum Ja VOLUME 6.0.6000.16586 21.06.2006 Microsoft volume.inf Ikke tilgjengelig STORAGE\VOLUME\1&19F7E59C&0&SIGNATURE22300763OFFSET100000LENGTH3A35000000 Generisk volum Ja VOLUME 6.0.6000.16586 21.06.2006 Microsoft volume.inf Ikke tilgjengelig STORAGE\VOLUME\1&19F7E59C&0&SIGNATURE22300766OFFSET100000LENGTH3A35000000 Volume Manager Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ROOT\VOLMGR000 USB HS-xD/SM Ja WPD 6.0.6000.16386 21.06.2006 TEAC wpdfs.inf Ikke tilgjengelig WPDBUSENUMROOT\UMB\2&37C186B&0&STORAGE#VOLUME#1&19F7E59C&0&_??_USBSTOR#DISK&VEN_TEAC&PROD_USB___HS-XD#SM&REV_4.08#000006023F25&1# USB HS-SD Card Ja WPD 6.0.6000.16386 21.06.2006 TEAC wpdfs.inf Ikke tilgjengelig WPDBUSENUMROOT\UMB\2&37C186B&0&STORAGE#VOLUME#1&19F7E59C&0&_??_USBSTOR#DISK&VEN_TEAC&PROD_USB___HS-SD_CARD&REV_4.08#000006023F25&3# USB HS-MS Card Ja WPD 6.0.6000.16386 21.06.2006 TEAC wpdfs.inf Ikke tilgjengelig WPDBUSENUMROOT\UMB\2&37C186B&0&STORAGE#VOLUME#1&19F7E59C&0&_??_USBSTOR#DISK&VEN_TEAC&PROD_USB___HS-MS_CARD&REV_4.08#000006023F25&2# USB HS-CF Card Ja WPD 6.0.6000.16386 21.06.2006 TEAC wpdfs.inf Ikke tilgjengelig WPDBUSENUMROOT\UMB\2&37C186B&0&STORAGE#VOLUME#1&19F7E59C&0&_??_USBSTOR#DISK&VEN_TEAC&PROD_USB___HS-CF_CARD&REV_4.08#000006023F25&0# UMBus Enumerator Ja SYSTEM 6.0.6000.16386 21.06.2006 Microsoft umbus.inf Ikke tilgjengelig UMB\UMB\1&841921D&0&WPDBUSENUMROOT UMBus Enumerator Ja SYSTEM 6.0.6000.16386 21.06.2006 Microsoft umbus.inf Ikke tilgjengelig UMB\UMB\1&841921D&0&PRINTERBUSENUMERATOR UMBus Root Bus Enumerator Ja SYSTEM 6.0.6000.16386 21.06.2006 Microsoft umbus.inf Ikke tilgjengelig ROOT\UMBUS000 Microsoft System Management BIOS Driver Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ROOT\SYSTEM002 Plug and Play Software Device Enumerator Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ROOT\SYSTEM000 Terminal Server Mouse Driver Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ROOT\RDP_MOU000 Terminal Server Keyboard Driver Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ROOT\RDP_KBD000 WAN-miniport (PPTP) Ja NET 6.0.6000.16386 21.06.2006 Microsoft netrasa.inf Ikke tilgjengelig ROOT\MS_PPTPMINIPORT000 WAN-miniport (PPPOE) Ja NET 6.0.6000.16386 21.06.2006 Microsoft netrasa.inf Ikke tilgjengelig ROOT\MS_PPPOEMINIPORT000 WAN-miniport (IPv6) Ja NET 6.0.6000.16386 21.06.2006 Microsoft netrasa.inf Ikke tilgjengelig ROOT\MS_NDISWANIPV6000 WAN-miniport (IP) Ja NET 6.0.6000.16386 21.06.2006 Microsoft netrasa.inf Ikke tilgjengelig ROOT\MS_NDISWANIP000 WAN-miniport (L2TP) Ja NET 6.0.6000.16386 21.06.2006 Microsoft netrasa.inf Ikke tilgjengelig ROOT\MS_L2TPMINIPORT000 Kernel Mode Driver Frameworks service Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_WDF01000000 Remote Access IPv6 ARP Driver Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_WANARPV6000 Lagringsvolumer Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_VOLSNAP000 Dynamic Volume Manager Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_VOLMGRX000 VgaSave Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_VGASAVE000 TDI-støttedriver for eldre NetIO Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_TDX000 TCP/IP Registry Compatibility Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_TCPIPREG000 Driver for TCP/IP-protokoll Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_TCPIP000 sptd Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_SPTD000 Security Processor Loader Driver Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_SPLDR000 Meldingsorientert TCP/IP- og TCP/IPv6-protokoll (SMB-økt) Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_SMB000 Security Driver Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_SECDRV000 Link-Layer Topology Discovery Responder Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_RSPNDR000 RDP Encoder Mirror Driver Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_RDPENCDD000 RDPCDD Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_RDPCDD000 Remote Access Auto Connection Driver Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_RASACD000 QoS-pakkeplanlegger Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_PSCHED000 PEAUTH Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_PEAUTH000 Null Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_NULL000 NSI proxy service Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_NSIPROXY000 NETBT Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_NETBT000 NDProxy Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_NDPROXY000 NDIS Usermode I/O Protocol Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_NDISUIO000 NDIS System Driver Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_NDIS000 NativeWiFi Filter Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_NATIVEWIFIP000 ISA/EISA Class Driver Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_MSISADRV000 Driver for Windows-brannmurgodkjenning Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_MPSDRV000 Mount Point Manager Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_MOUNTMGR000 Link-Layer Topology Discovery Mapper I/O Driver Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_LLTDIO000 KSecDD Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_KSECDD000 HTTP Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_HTTP000 LDDM Graphics Subsystem Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_DXGKRNL000 Crcdisk Filter Driver Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_CRCDISK000 Common Log (CLFS) Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_CLFS000 Beep Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_BEEP000 Ancilliary Function Driver for Winsock Ikke tilgjengelig LEGACYDRIVER Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig ROOT\LEGACY_AFD000 Microsoft iSCSI Initiator Ja SCSIADAPTER 6.0.6000.16386 21.06.2006 Microsoft iscsi.inf Ikke tilgjengelig ROOT\ISCSIPRT000 ACPI Fixed Feature Button Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\FIXEDBUTTON\2&DABA3FF&1 ACPI Thermal Zone Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\THERMALZONE\THRM ACPI Fan Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\PNP0C0B\2&DABA3FF&1 System board Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\PNP0C01\2&DABA3FF&1 Motherboard resources Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\PNP0C02\4 CD-ROM-stasjon Ja CDROM 6.0.6000.16386 21.06.2006 (Standard CD-ROM-stasjoner) cdrom.inf Ikke tilgjengelig SCSI\CDROM&VEN_TA2251U&PROD_FGE477C&REV_1.0\5&36E5972&0&000000 SCSI/RAID Host Controller Ikke tilgjengelig SCSIADAPTER Ikke tilgjengelig Ikke tilgjengelig (Standard mass storage controllers) Ikke tilgjengelig Ikke tilgjengelig ACPI\PNPA000\4&5D18F2DF&0 Extended IO Bus Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\PNP0A06\3&473F1A46&0 IDE-kanal Ja HDC 6.0.6000.16632 21.06.2006 (Standard IDE ATA/ATAPI-kontrollere) mshdc.inf Ikke tilgjengelig PCIIDE\IDECHANNEL\4&39BFD449&0&1 CD-ROM-stasjon Ja CDROM 6.0.6000.16386 21.06.2006 (Standard CD-ROM-stasjoner) cdrom.inf Ikke tilgjengelig IDE\CDROMTSSTCORP_DVD+-RW_TS-H653B_______________D200____\5&2F6B6D99&0&0.0.0 IDE-kanal Ja HDC 6.0.6000.16632 21.06.2006 (Standard IDE ATA/ATAPI-kontrollere) mshdc.inf Ikke tilgjengelig PCIIDE\IDECHANNEL\4&39BFD449&0&0 Standard Dual Channel PCI IDE Controller Ja HDC 6.0.6000.16632 21.06.2006 (Standard IDE ATA/ATAPI-kontrollere) mshdc.inf Ikke tilgjengelig PCI\VEN_8086&DEV_2926&SUBSYS_020D1028&REV_02\3&2411E6FE&0&FD SM-busskontroller Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig PCI\VEN_8086&DEV_2930&SUBSYS_020D1028&REV_02\3&2411E6FE&0&FB Diskstasjon Ja DISKDRIVE 6.0.6000.16386 21.06.2006 (Standard diskstasjoner) disk.inf Ikke tilgjengelig IDE\DISKWDC_WD2500JS-75NCB3_____________________10.02E04\5&384A886&0&1.0.0 IDE-kanal Ja HDC 6.0.6000.16632 21.06.2006 (Standard IDE ATA/ATAPI-kontrollere) mshdc.inf Ikke tilgjengelig PCIIDE\IDECHANNEL\4&1C8E8B0D&0&1 Diskstasjon Ja DISKDRIVE 6.0.6000.16386 21.06.2006 (Standard diskstasjoner) disk.inf Ikke tilgjengelig IDE\DISKST3250820AS_____________________________3.ADG___\5&163E592B&0&0.0.0 IDE-kanal Ja HDC 6.0.6000.16632 21.06.2006 (Standard IDE ATA/ATAPI-kontrollere) mshdc.inf Ikke tilgjengelig PCIIDE\IDECHANNEL\4&1C8E8B0D&0&0 Standard Dual Channel PCI IDE Controller Ja HDC 6.0.6000.16632 21.06.2006 (Standard IDE ATA/ATAPI-kontrollere) mshdc.inf Ikke tilgjengelig PCI\VEN_8086&DEV_2920&SUBSYS_020D1028&REV_02\3&2411E6FE&0&FA Intel® 82802 Firmware Hub Device Ja SYSTEM 6.0.6000.16386 21.06.2006 Intel machine.inf Ikke tilgjengelig ACPI\INT0800\4&E75F1&0 Motherboard resources Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\PNP0C02\2 Standard diskettkontroller Ja FDC 6.0.6000.16386 21.06.2006 (Standard diskettkontrollere) fdc.inf Ikke tilgjengelig ACPI\PNP0700\4&E75F1&0 Numeric data processor Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\PNP0C04\4&E75F1&0 System speaker Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\PNP0800\4&E75F1&0 System CMOS/real time clock Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\PNP0B00\4&E75F1&0 High precision event timer Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\PNP0103\4&E75F1&0 System timer Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\PNP0100\4&E75F1&0 Direct memory access controller Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\PNP0200\4&E75F1&0 Programmable interrupt controller Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\PNP0000\4&E75F1&0 Motherboard resources Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\PNP0C02\1 PCI standard ISA bridge Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig PCI\VEN_8086&DEV_2916&SUBSYS_020D1028&REV_02\3&2411E6FE&0&F8 Intel® 82801 PCI Bridge - 244E Ja SYSTEM 6.0.6000.16386 21.06.2006 Intel machine.inf Ikke tilgjengelig PCI\VEN_8086&DEV_244E&SUBSYS_020D1028&REV_92\3&2411E6FE&0&F0 Diskstasjon Ja DISKDRIVE 6.0.6000.16386 21.06.2006 (Standard diskstasjoner) disk.inf Ikke tilgjengelig USBSTOR\DISK&VEN_TEAC&PROD_USB___HS-SD_CARD&REV_4.0800006023F25&3 Diskstasjon Ja DISKDRIVE 6.0.6000.16386 21.06.2006 (Standard diskstasjoner) disk.inf Ikke tilgjengelig USBSTOR\DISK&VEN_TEAC&PROD_USB___HS-MS_CARD&REV_4.0800006023F25&2 Diskstasjon Ja DISKDRIVE 6.0.6000.16386 21.06.2006 (Standard diskstasjoner) disk.inf Ikke tilgjengelig USBSTOR\DISK&VEN_TEAC&PROD_USB___HS-XD/SM&REV_4.0800006023F25&1 Diskstasjon Ja DISKDRIVE 6.0.6000.16386 21.06.2006 (Standard diskstasjoner) disk.inf Ikke tilgjengelig USBSTOR\DISK&VEN_TEAC&PROD_USB___HS-CF_CARD&REV_4.0800006023F25&0 USB Mass Storage Device Ja USB 6.0.6000.16478 21.06.2006 Compatible USB storage device usbstor.inf Ikke tilgjengelig USB\VID_0644&PID_020000006023F25 Jensen Air:Link 85300 Nei NET 1.0.3.0 30.04.2007 Jensen Scandinavia AS. oem3.inf Ikke tilgjengelig USB\VID_148F&PID_2870\5&26712E48&0&3 USB Root Hub Ja USB 6.0.6000.16386 21.06.2006 (Standard USB Host Controller) usbport.inf Ikke tilgjengelig USB\ROOT_HUB20\4&A57E816&0 Standard Enhanced PCI to USB Host Controller Ja USB 6.0.6000.16386 21.06.2006 (Standard USB Host Controller) usbport.inf Ikke tilgjengelig PCI\VEN_8086&DEV_293A&SUBSYS_020D1028&REV_02\3&2411E6FE&0&EF USB Root Hub Ja USB 6.0.6000.16386 21.06.2006 (Standard USB Host Controller) usbport.inf Ikke tilgjengelig USB\ROOT_HUB\4&1E8EF8FA&0 Standard Universal PCI to USB Host Controller Ja USB 6.0.6000.16553 21.06.2006 (Standard USB Host Controller) usbport.inf Ikke tilgjengelig PCI\VEN_8086&DEV_2936&SUBSYS_020D1028&REV_02\3&2411E6FE&0&EA USB Root Hub Ja USB 6.0.6000.16386 21.06.2006 (Standard USB Host Controller) usbport.inf Ikke tilgjengelig USB\ROOT_HUB\4&14FDF0FC&0 Standard Universal PCI to USB Host Controller Ja USB 6.0.6000.16553 21.06.2006 (Standard USB Host Controller) usbport.inf Ikke tilgjengelig PCI\VEN_8086&DEV_2935&SUBSYS_020D1028&REV_02\3&2411E6FE&0&E9 USB Root Hub Ja USB 6.0.6000.16386 21.06.2006 (Standard USB Host Controller) usbport.inf Ikke tilgjengelig USB\ROOT_HUB\4&715777&0 Standard Universal PCI to USB Host Controller Ja USB 6.0.6000.16553 21.06.2006 (Standard USB Host Controller) usbport.inf Ikke tilgjengelig PCI\VEN_8086&DEV_2934&SUBSYS_020D1028&REV_02\3&2411E6FE&0&E8 High Definition Audio-enhet Ja MEDIA 6.0.6000.16386 21.06.2006 Microsoft hdaudio.inf HdAudio.sys HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_1028020D&REV_1000\4&18CA5B6A&0&0201 High Definition Audio-kontroller Ja SYSTEM 6.0.6000.16481 21.06.2006 Microsoft hdaudbus.inf Ikke tilgjengelig PCI\VEN_8086&DEV_293E&SUBSYS_020D1028&REV_02\3&2411E6FE&0&D8 USB Root Hub Ja USB 6.0.6000.16386 21.06.2006 (Standard USB Host Controller) usbport.inf Ikke tilgjengelig USB\ROOT_HUB20\4&24CDE621&0 Standard Enhanced PCI to USB Host Controller Ja USB 6.0.6000.16386 21.06.2006 (Standard USB Host Controller) usbport.inf Ikke tilgjengelig PCI\VEN_8086&DEV_293C&SUBSYS_020D1028&REV_02\3&2411E6FE&0&D7 HID Keyboard Device Ja KEYBOARD 6.0.6000.16609 21.06.2006 (Standard tastaturer) keyboard.inf Ikke tilgjengelig HID\VID_413C&PID_2003\6&5299367&0&0000 USB-enhet for menneskelig grensesnitt Ja HIDCLASS 6.0.6000.16386 21.06.2006 (Standard systemenheter) input.inf Ikke tilgjengelig USB\VID_413C&PID_2003\5&2BEB6C46&0&2 HID-compliant mouse Ja MOUSE 6.0.6000.16609 21.06.2006 Microsoft msmouse.inf Ikke tilgjengelig HID\VID_046D&PID_C50E\6&3B8B19A8&0&0000 USB-enhet for menneskelig grensesnitt Ja HIDCLASS 6.0.6000.16386 21.06.2006 (Standard systemenheter) input.inf Ikke tilgjengelig USB\VID_046D&PID_C50E\5&2BEB6C46&0&1 USB Root Hub Ja USB 6.0.6000.16386 21.06.2006 (Standard USB Host Controller) usbport.inf Ikke tilgjengelig USB\ROOT_HUB\4&179223DB&0 Standard Universal PCI to USB Host Controller Ja USB 6.0.6000.16386 21.06.2006 (Standard USB Host Controller) usbport.inf Ikke tilgjengelig PCI\VEN_8086&DEV_2939&SUBSYS_020D1028&REV_02\3&2411E6FE&0&D2 USB Root Hub Ja USB 6.0.6000.16386 21.06.2006 (Standard USB Host Controller) usbport.inf Ikke tilgjengelig USB\ROOT_HUB\4&3977EE9F&0 Standard Universal PCI to USB Host Controller Ja USB 6.0.6000.16553 21.06.2006 (Standard USB Host Controller) usbport.inf Ikke tilgjengelig PCI\VEN_8086&DEV_2938&SUBSYS_020D1028&REV_02\3&2411E6FE&0&D1 USB Root Hub Ja USB 6.0.6000.16386 21.06.2006 (Standard USB Host Controller) usbport.inf Ikke tilgjengelig USB\ROOT_HUB\4&39E334E0&0 Standard Universal PCI to USB Host Controller Ja USB 6.0.6000.16553 21.06.2006 (Standard USB Host Controller) usbport.inf Ikke tilgjengelig PCI\VEN_8086&DEV_2937&SUBSYS_020D1028&REV_02\3&2411E6FE&0&D0 Ethernet-kontroller Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig PCI\VEN_8086&DEV_10C0&SUBSYS_020D1028&REV_02\3&2411E6FE&0&C8 High Definition Audio-enhet Ja MEDIA 6.0.6000.16386 21.06.2006 Microsoft hdaudio.inf HdAudio.sys HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1000\5&37ADDC76&0&0001 High Definition Audio-kontroller Ja SYSTEM 6.0.6000.16481 21.06.2006 Microsoft hdaudbus.inf Ikke tilgjengelig PCI\VEN_1002&DEV_AA08&SUBSYS_AA081028&REV_00\4&22F4F1A2&0&0108 Dell SE198WFP(Digital) Ja MONITOR 1.0.0.0 21.12.2006 Dell Inc. oem7.inf Ikke tilgjengelig DISPLAY\DELF004\5&31D0A865&1&UID268435459 ATI Radeon HD 2600 XT Ja DISPLAY 8.471.0.0 25.02.2008 ATI Technologies Inc. oem9.inf Ikke tilgjengelig PCI\VEN_1002&DEV_9588&SUBSYS_25421028&REV_00\4&22F4F1A2&0&0008 PCI standard PCI-to-PCI bridge Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig PCI\VEN_8086&DEV_29C1&SUBSYS_020D1028&REV_02\3&2411E6FE&0&08 PCI standard host CPU bridge Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig PCI\VEN_8086&DEV_29C0&SUBSYS_020D1028&REV_02\3&2411E6FE&0&00 PCI bus Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\PNP0A08\1 ACPI Power Button Ja SYSTEM 6.0.6000.16386 21.06.2006 (Standard systemenheter) machine.inf Ikke tilgjengelig ACPI\PNP0C0C\2&DABA3FF&1 Intel Processor Ja PROCESSOR 6.0.6000.16386 21.06.2006 Intel cpu.inf Ikke tilgjengelig ACPI\GENUINEINTEL_-_X86_FAMILY_6_MODEL_15\_1 Intel Processor Ja PROCESSOR 6.0.6000.16386 21.06.2006 Intel cpu.inf Ikke tilgjengelig ACPI\GENUINEINTEL_-_X86_FAMILY_6_MODEL_15\_0 Microsoft ACPI-kompatibelt system Ja SYSTEM 6.0.6000.16553 21.06.2006 Microsoft acpi.inf Ikke tilgjengelig ACPI_HAL\PNP0C08 ACPI x86-basert PC Ja COMPUTER 6.0.6000.20500 21.06.2006 (Standarddatamaskiner) hal.inf Ikke tilgjengelig ROOT\ACPI_HAL000 Microsoft Tun Miniport Adapter Ja NET 6.0.6000.16386 21.06.2006 Microsoft nettun.inf Ikke tilgjengelig ROOT\*TUNMP000 Microsoft ISATAP Adapter Ja NET 6.0.6000.16386 21.06.2006 Microsoft nettun.inf Ikke tilgjengelig ROOT\*ISATAP002 Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig HTREE\ROOT Ikke tilgjengelig Ja Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Send To OneNote 2007 Ikke tilgjengelig Ja Ikke tilgjengelig 2:6.0 Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Microsoft XPS Document Writer Ikke tilgjengelig Ja Ikke tilgjengelig 2:6.0 Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Adobe PDF Ikke tilgjengelig Ja Ikke tilgjengelig 2:6.0 Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig \\Jostein\HP DeskJet 930C/932C/935C [Miljøvariabler] Variabel Verdi Brukernavn ComSpec %SystemRoot%\system32\cmd.exe <SYSTEM> FP_NO_HOST_CHECK NO <SYSTEM> OS Windows_NT <SYSTEM> Path %SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Roxio Shared\9.0\DLLShared\ <SYSTEM> PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC <SYSTEM> PROCESSOR_ARCHITECTURE x86 <SYSTEM> TEMP %SystemRoot%\TEMP <SYSTEM> TMP %SystemRoot%\TEMP <SYSTEM> USERNAME SYSTEM <SYSTEM> windir %SystemRoot% <SYSTEM> PROCESSOR_LEVEL 6 <SYSTEM> PROCESSOR_IDENTIFIER x86 Family 6 Model 15 Stepping 11, GenuineIntel <SYSTEM> PROCESSOR_REVISION 0f0b <SYSTEM> NUMBER_OF_PROCESSORS 2 <SYSTEM> RoxioCentral C:\Program Files\Common Files\Roxio Shared\9.0\Roxio Central33\ <SYSTEM> TEMP %USERPROFILE%\AppData\Local\Temp NT-MYNDIGHET\SYSTEM TMP %USERPROFILE%\AppData\Local\Temp NT-MYNDIGHET\SYSTEM TEMP %USERPROFILE%\AppData\Local\Temp NT-MYNDIGHET\LOKAL TJENESTE TMP %USERPROFILE%\AppData\Local\Temp NT-MYNDIGHET\LOKAL TJENESTE TEMP %USERPROFILE%\AppData\Local\Temp NT-MYNDIGHET\NETTVERKSTJENESTE TMP %USERPROFILE%\AppData\Local\Temp NT-MYNDIGHET\NETTVERKSTJENESTE TEMP %USERPROFILE%\AppData\Local\Temp TANZ\Tanz TMP %USERPROFILE%\AppData\Local\Temp TANZ\Tanz [utskriftsjobber] Dokument Størrelse Eier Varsle Status Tidspunkt sendt Starttidspunkt Inntil klokkeslett Brukt tid Sider skrevet ut Jobb-ID Prioritet Parametere Driver Utskriftsprosessor Vær vert for utskriftskø Datatype Navn [Nettverkstilkoblinger] Lokalt navn Eksternt navn Type Status Brukernavn [Kjørende oppgaver] Navn Bane Prosess-ID Prioritet Minimalt arbeidssett Maksimalt arbeidssett Starttidspunkt Versjon Størrelse Fildato system idle process Ikke tilgjengelig 0 0 Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig system Ikke tilgjengelig 4 8 Ikke tilgjengelig Ikke tilgjengelig 08.04.2008 06:58 Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig smss.exe Ikke tilgjengelig 360 11 204800 1413120 08.04.2008 06:58 Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig csrss.exe c:\windows\system32\csrss.exe 500 13 204800 1413120 08.04.2008 06:58 6.0.6000.16386 7,50 kB (7 680 byte) 02.11.2006 09:33 wininit.exe c:\windows\system32\wininit.exe 556 13 204800 1413120 08.04.2008 06:58 6.0.6000.16386 93,50 kB (95 744 byte) 02.11.2006 09:44 csrss.exe c:\windows\system32\csrss.exe 568 13 204800 1413120 08.04.2008 06:58 6.0.6000.16386 7,50 kB (7 680 byte) 02.11.2006 09:33 services.exe c:\windows\system32\services.exe 600 9 204800 1413120 08.04.2008 06:58 6.0.6000.16386 273,00 kB (279 552 byte) 02.11.2006 09:35 lsass.exe c:\windows\system32\lsass.exe 612 9 204800 1413120 08.04.2008 06:58 6.0.6000.16386 7,50 kB (7 680 byte) 02.11.2006 09:43 lsm.exe c:\windows\system32\lsm.exe 620 8 204800 1413120 08.04.2008 06:58 6.0.6000.16386 206,00 kB (210 944 byte) 02.11.2006 10:02 winlogon.exe c:\windows\system32\winlogon.exe 764 13 204800 1413120 08.04.2008 06:58 6.0.6000.16386 301,00 kB (308 224 byte) 02.11.2006 09:44 svchost.exe c:\windows\system32\svchost.exe 788 8 204800 1413120 08.04.2008 06:58 6.0.6000.16386 21,50 kB (22 016 byte) 02.11.2006 09:35 svchost.exe c:\windows\system32\svchost.exe 848 8 204800 1413120 08.04.2008 06:58 6.0.6000.16386 21,50 kB (22 016 byte) 02.11.2006 09:35 svchost.exe c:\windows\system32\svchost.exe 896 8 204800 1413120 08.04.2008 06:58 6.0.6000.16386 21,50 kB (22 016 byte) 02.11.2006 09:35 ati2evxx.exe c:\windows\system32\ati2evxx.exe 964 8 204800 1413120 08.04.2008 06:58 6.14.10.4190 640,00 kB (655 360 byte) 13.11.2007 10:16 svchost.exe c:\windows\system32\svchost.exe 980 8 204800 1413120 08.04.2008 06:58 6.0.6000.16386 21,50 kB (22 016 byte) 02.11.2006 09:35 svchost.exe c:\windows\system32\svchost.exe 1008 8 204800 1413120 08.04.2008 06:58 6.0.6000.16386 21,50 kB (22 016 byte) 02.11.2006 09:35 svchost.exe c:\windows\system32\svchost.exe 1024 8 204800 1413120 08.04.2008 06:58 6.0.6000.16386 21,50 kB (22 016 byte) 02.11.2006 09:35 audiodg.exe Ikke tilgjengelig 1192 8 Ikke tilgjengelig Ikke tilgjengelig 08.04.2008 06:58 Ikke tilgjengelig Ikke tilgjengelig Ikke tilgjengelig slsvc.exe c:\windows\system32\slsvc.exe 1228 8 204800 1413120 08.04.2008 06:58 6.0.6000.16509 2,48 MB (2 605 568 byte) 14.02.2008 17:04 svchost.exe c:\windows\system32\svchost.exe 1288 8 204800 1413120 08.04.2008 06:58 6.0.6000.16386 21,50 kB (22 016 byte) 02.11.2006 09:35 svchost.exe c:\windows\system32\svchost.exe 1428 8 204800 1413120 08.04.2008 06:58 6.0.6000.16386 21,50 kB (22 016 byte) 02.11.2006 09:35 ati2evxx.exe c:\windows\system32\ati2evxx.exe 1544 8 204800 1413120 08.04.2008 06:58 6.14.10.4190 640,00 kB (655 360 byte) 13.11.2007 10:16 dwm.exe c:\windows\system32\dwm.exe 1796 13 52428800 2147418112 08.04.2008 06:58 6.0.6000.16386 81,50 kB (83 456 byte) 02.11.2006 09:39 spoolsv.exe c:\windows\system32\spoolsv.exe 1840 8 204800 1413120 08.04.2008 06:58 6.0.6000.16386 122,00 kB (124 928 byte) 02.11.2006 10:15 svchost.exe c:\windows\system32\svchost.exe 1880 8 204800 1413120 08.04.2008 06:58 6.0.6000.16386 21,50 kB (22 016 byte) 02.11.2006 09:35 taskeng.exe c:\windows\system32\taskeng.exe 1888 8 204800 1413120 08.04.2008 06:58 6.0.6000.16386 162,50 kB (166 400 byte) 02.11.2006 09:41 explorer.exe c:\windows\explorer.exe 1980 8 60309504 62423040 08.04.2008 06:58 6.0.6000.16549 2,79 MB (2 923 520 byte) 14.02.2008 17:07 msascui.exe c:\program files\windows defender\msascui.exe 1732 8 204800 1413120 08.04.2008 06:59 1.1.1505.0 982,68 kB (1 006 264 byte) 14.02.2008 14:39 acrotray.exe c:\program files\adobe\acrobat 8.0\acrobat\acrotray.exe 1988 8 204800 1413120 08.04.2008 06:59 8.0.137.0 609,62 kB (624 248 byte) 08.02.2008 16:36 jusched.exe c:\program files\java\jre1.6.0_03\bin\jusched.exe 488 8 204800 1413120 08.04.2008 06:59 6.0.30.5 129,39 kB (132 496 byte) 24.02.2008 00:49 msnmsgr.exe c:\program files\windows live\messenger\msnmsgr.exe 656 8 65355776 67469312 08.04.2008 06:59 8.5.1302.1018 5,46 MB (5 724 184 byte) 18.10.2007 12:34 jensenui.exe c:\program files\jensen\common\jensenui.exe 1640 8 204800 1413120 08.04.2008 06:59 1.0.10.0 892,00 kB (913 408 byte) 07.02.2008 16:30 mom.exe c:\program files\ati technologies\ati.ace\core-static\mom.exe 1120 8 204800 1413120 08.04.2008 06:59 2.0.0.0 48,00 kB (49 152 byte) 01.06.2007 10:52 ccc.exe c:\program files\ati technologies\ati.ace\core-static\ccc.exe 1680 8 204800 1413120 08.04.2008 06:59 2.0.0.0 48,00 kB (49 152 byte) 01.06.2007 10:52 mdm.exe c:\program files\common files\microsoft shared\vs7debug\mdm.exe 2404 8 204800 1413120 08.04.2008 06:59 7.0.9466.0 314,57 kB (322 120 byte) 20.06.2003 00:25 svchost.exe c:\windows\system32\svchost.exe 2464 8 204800 1413120 08.04.2008 06:59 6.0.6000.16386 21,50 kB (22 016 byte) 02.11.2006 09:35 svchost.exe c:\windows\system32\svchost.exe 2500 8 204800 1413120 08.04.2008 06:59 6.0.6000.16386 21,50 kB (22 016 byte) 02.11.2006 09:35 svchost.exe c:\windows\system32\svchost.exe 2616 8 204800 1413120 08.04.2008 06:59 6.0.6000.16386 21,50 kB (22 016 byte) 02.11.2006 09:35 searchindexer.exe c:\windows\system32\searchindexer.exe 2660 8 204800 1413120 08.04.2008 06:59 6.0.6000.16386 281,00 kB (287 744 byte) 02.11.2006 13:34 wudfhost.exe c:\windows\system32\wudfhost.exe 2800 8 204800 1413120 08.04.2008 06:59 6.0.6000.16386 140,00 kB (143 360 byte) 02.11.2006 09:54 fnplicensingservice.exe c:\program files\common files\macrovision shared\flexnet publisher\fnplicensingservice.exe 3180 8 204800 1413120 08.04.2008 06:59 11.3.5.1 639,50 kB (654 848 byte) 08.02.2008 16:16 taskeng.exe c:\windows\system32\taskeng.exe 3948 6 204800 1413120 08.04.2008 06:59 6.0.6000.16386 162,50 kB (166 400 byte) 02.11.2006 09:41 wmpnetwk.exe c:\program files\windows media player\wmpnetwk.exe 832 8 204800 1413120 08.04.2008 07:01 11.0.6000.6324 874,50 kB (895 488 byte) 02.11.2006 13:36 wmpnscfg.exe c:\program files\windows media player\wmpnscfg.exe 2216 8 204800 1413120 08.04.2008 07:01 11.0.6000.6324 197,00 kB (201 728 byte) 02.11.2006 13:36 prime95.exe c:\users\tanz\downloads\p95v2414\prime95.exe 5004 4 204800 1413120 08.04.2008 11:05 24.14.1.0 4,13 MB (4 333 568 byte) 07.04.2008 15:16 firefox.exe c:\program files\mozilla firefox\firefox.exe 4084 8 204800 1413120 08.04.2008 16:54 1.8.20080.31114 7,31 MB (7 660 656 byte) 07.02.2008 18:20 wmiprvse.exe c:\windows\system32\wbem\wmiprvse.exe 3396 8 204800 1413120 08.04.2008 16:57 6.0.6000.16386 239,50 kB (245 248 byte) 02.11.2006 09:41 searchprotocolhost.exe c:\windows\system32\searchprotocolhost.exe 5664 4 204800 33554432 08.04.2008 16:58 6.0.6000.16386 199,50 kB (204 288 byte) 02.11.2006 13:34 searchfilterhost.exe c:\windows\system32\searchfilterhost.exe 1748 4 204800 33554432 08.04.2008 16:58 6.0.6000.16386 74,50 kB (76 288 byte) 02.11.2006 13:34 msinfo32.exe c:\windows\system32\msinfo32.exe 3924 8 204800 1413120 08.04.2008 16:58 6.0.6000.16386 398,00 kB (407 552 byte) 02.11.2006 09:35 wmiprvse.exe c:\windows\system32\wbem\wmiprvse.exe 3132 8 204800 1413120 08.04.2008 16:58 6.0.6000.16386 239,50 kB (245 248 byte) 02.11.2006 09:41 [innlastede moduler] Navn Versjon Størrelse Fildato Produsent Bane csrss 6.0.6000.16386 7,50 kB (7 680 byte) 02.11.2006 09:33 Microsoft Corporation c:\windows\system32\csrss.exe ntdll 6.0.6000.16386 1,11 MB (1 162 656 byte) 02.11.2006 09:31 Microsoft Corporation c:\windows\system32\ntdll.dll csrsrv 6.0.6000.16445 48,50 kB (49 664 byte) 07.02.2008 16:56 Microsoft Corporation c:\windows\system32\csrsrv.dll basesrv 6.0.6000.16386 67,00 kB (68 608 byte) 02.11.2006 09:33 Microsoft Corporation c:\windows\system32\basesrv.dll winsrv 6.0.6000.16445 367,50 kB (376 320 byte) 07.02.2008 16:56 Microsoft Corporation c:\windows\system32\winsrv.dll user32 6.0.6000.16438 619,00 kB (633 856 byte) 07.02.2008 16:53 Microsoft Corporation c:\windows\system32\user32.dll kernel32 6.0.6000.16386 854,00 kB (874 496 byte) 02.11.2006 09:33 Microsoft Corporation c:\windows\system32\kernel32.dll gdi32 6.0.6000.16386 289,50 kB (296 448 byte) 02.11.2006 09:38 Microsoft Corporation c:\windows\system32\gdi32.dll advapi32 6.0.6000.16386 752,00 kB (770 048 byte) 02.11.2006 10:16 Microsoft Corporation c:\windows\system32\advapi32.dll rpcrt4 6.0.6000.16525 770,50 kB (788 992 byte) 07.02.2008 16:53 Microsoft Corporation c:\windows\system32\rpcrt4.dll lpk 6.0.6000.16386 23,50 kB (24 064 byte) 02.11.2006 09:38 Microsoft Corporation c:\windows\system32\lpk.dll usp10 1.626.6000.16386 491,00 kB (502 784 byte) 02.11.2006 09:38 Microsoft Corporation c:\windows\system32\usp10.dll msvcrt 7.0.6000.16386 665,50 kB (681 472 byte) 02.11.2006 09:30 Microsoft Corporation c:\windows\system32\msvcrt.dll sxs 6.0.6000.16386 368,50 kB (377 344 byte) 02.11.2006 09:33 Microsoft Corporation c:\windows\system32\sxs.dll wininit 6.0.6000.16386 93,50 kB (95 744 byte) 02.11.2006 09:44 Microsoft Corporation c:\windows\system32\wininit.exe userenv 6.0.6000.16386 104,50 kB (107 008 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\userenv.dll secur32 6.0.6000.16386 71,00 kB (72 704 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\secur32.dll imm32 6.0.6000.16386 112,50 kB (115 200 byte) 02.11.2006 09:38 Microsoft Corporation c:\windows\system32\imm32.dll msctf 6.0.6000.16386 787,00 kB (805 888 byte) 02.11.2006 09:39 Microsoft Corporation c:\windows\system32\msctf.dll apphelp 6.0.6000.16386 167,00 kB (171 008 byte) 02.11.2006 09:30 Microsoft Corporation c:\windows\system32\apphelp.dll ws2_32 6.0.6000.16386 174,50 kB (178 688 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\ws2_32.dll nsi 6.0.6000.16386 10,00 kB (10 240 byte) 02.11.2006 09:57 Microsoft Corporation c:\windows\system32\nsi.dll mswsock 6.0.6000.16386 222,00 kB (227 328 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\mswsock.dll wshtcpip 6.0.6000.16386 11,00 kB (11 264 byte) 02.11.2006 09:57 Microsoft Corporation c:\windows\system32\wshtcpip.dll wship6 6.0.6000.16386 10,50 kB (10 752 byte) 02.11.2006 09:57 Microsoft Corporation c:\windows\system32\wship6.dll credssp 6.0.6000.16386 15,00 kB (15 360 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\credssp.dll crypt32 6.0.6000.16425 951,50 kB (974 336 byte) 14.02.2008 14:38 Microsoft Corporation c:\windows\system32\crypt32.dll msasn1 6.0.6000.16386 58,50 kB (59 904 byte) 02.11.2006 10:11 Microsoft Corporation c:\windows\system32\msasn1.dll schannel 6.0.6000.16508 263,50 kB (269 824 byte) 14.02.2008 15:35 Microsoft Corporation c:\windows\system32\schannel.dll netapi32 6.0.6000.16386 415,50 kB (425 472 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\netapi32.dll psapi 6.0.6000.16386 12,00 kB (12 288 byte) 02.11.2006 10:00 Microsoft Corporation c:\windows\system32\psapi.dll services 6.0.6000.16386 273,00 kB (279 552 byte) 02.11.2006 09:35 Microsoft Corporation c:\windows\system32\services.exe scesrv 6.0.6000.16386 298,50 kB (305 664 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\scesrv.dll authz 6.0.6000.16386 77,00 kB (78 848 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\authz.dll ncobjapi 6.0.6000.16386 47,00 kB (48 128 byte) 02.11.2006 09:41 Microsoft Corporation c:\windows\system32\ncobjapi.dll ntmarta 6.0.6000.16386 118,00 kB (120 832 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\ntmarta.dll wldap32 6.0.6000.16386 282,00 kB (288 768 byte) 02.11.2006 09:46 Microsoft Corporation c:\windows\system32\wldap32.dll samlib 6.0.6000.16386 55,00 kB (56 320 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\samlib.dll ole32 6.0.6000.16386 1,25 MB (1 314 816 byte) 02.11.2006 09:51 Microsoft Corporation c:\windows\system32\ole32.dll lsass 6.0.6000.16386 7,50 kB (7 680 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\lsass.exe lsasrv 6.0.6000.16386 1,18 MB (1 233 408 byte) 02.11.2006 09:44 Microsoft Corporation c:\windows\system32\lsasrv.dll samsrv 6.0.6000.16386 463,50 kB (474 624 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\samsrv.dll cryptdll 6.0.6000.16386 56,50 kB (57 856 byte) 02.11.2006 09:42 Microsoft Corporation c:\windows\system32\cryptdll.dll dnsapi 6.0.6000.16386 159,00 kB (162 816 byte) 02.11.2006 09:46 Microsoft Corporation c:\windows\system32\dnsapi.dll ntdsapi 6.0.6000.16386 85,50 kB (87 552 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\ntdsapi.dll feclient 6.0.6000.16386 52,50 kB (53 760 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\feclient.dll mpr 6.0.6000.16386 67,50 kB (69 120 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\mpr.dll slc 6.0.6000.16509 218,00 kB (223 232 byte) 14.02.2008 17:04 Microsoft Corporation c:\windows\system32\slc.dll sysntfy 6.0.6000.16386 15,00 kB (15 360 byte) 02.11.2006 09:44 Microsoft Corporation c:\windows\system32\sysntfy.dll wevtapi 6.0.6000.16386 239,00 kB (244 736 byte) 02.11.2006 09:41 Microsoft Corporation c:\windows\system32\wevtapi.dll iphlpapi 6.0.6000.16386 87,50 kB (89 600 byte) 02.11.2006 09:57 Microsoft Corporation c:\windows\system32\iphlpapi.dll dhcpcsvc 6.0.6000.16512 200,00 kB (204 800 byte) 14.02.2008 15:35 Microsoft Corporation c:\windows\system32\dhcpcsvc.dll winnsi 6.0.6000.16386 15,00 kB (15 360 byte) 02.11.2006 09:57 Microsoft Corporation c:\windows\system32\winnsi.dll dhcpcsvc6 6.0.6000.16512 117,50 kB (120 320 byte) 14.02.2008 15:35 Microsoft Corporation c:\windows\system32\dhcpcsvc6.dll cngaudit 6.0.6000.16386 11,50 kB (11 776 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\cngaudit.dll ncrypt 6.0.6000.16386 188,50 kB (193 024 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\ncrypt.dll bcrypt 6.0.6000.16386 259,50 kB (265 728 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\bcrypt.dll msprivs 6.0.6000.16386 2,00 kB (2 048 byte) 02.11.2006 08:18 Microsoft Corporation c:\windows\system32\msprivs.dll kerberos 6.0.6000.16386 481,50 kB (493 056 byte) 02.11.2006 09:44 Microsoft Corporation c:\windows\system32\kerberos.dll msv1_0 6.0.6000.16386 208,50 kB (213 504 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\msv1_0.dll netlogon 6.0.6000.16386 546,50 kB (559 616 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\netlogon.dll winbrand 6.0.6000.16386 849,00 kB (869 376 byte) 02.11.2006 09:34 Microsoft Corporation c:\windows\system32\winbrand.dll wdigest 6.0.6000.16386 164,50 kB (168 448 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\wdigest.dll rsaenh 6.0.6000.16386 223,60 kB (228 968 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\rsaenh.dll tspkg 6.0.6000.16386 60,00 kB (61 440 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\tspkg.dll gpapi 6.0.6000.16386 72,00 kB (73 728 byte) 02.11.2006 09:46 Microsoft Corporation c:\windows\system32\gpapi.dll scecli 6.0.6000.16386 172,50 kB (176 640 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\scecli.dll setupapi 6.0.6000.16609 1,51 MB (1 585 664 byte) 13.02.2008 22:45 Microsoft Corporation c:\windows\system32\setupapi.dll oleaut32 6.0.6000.16609 545,00 kB (558 080 byte) 13.02.2008 22:45 Microsoft Corporation c:\windows\system32\oleaut32.dll keyiso 6.0.6000.16386 18,50 kB (18 944 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\keyiso.dll dssenh 6.0.6000.16386 162,10 kB (165 992 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\dssenh.dll winsta 6.0.6000.16386 131,50 kB (134 656 byte) 02.11.2006 10:02 Microsoft Corporation c:\windows\system32\winsta.dll lsm 6.0.6000.16386 206,00 kB (210 944 byte) 02.11.2006 10:02 Microsoft Corporation c:\windows\system32\lsm.exe wmsgapi 6.0.6000.16386 10,50 kB (10 752 byte) 02.11.2006 09:44 Microsoft Corporation c:\windows\system32\wmsgapi.dll winlogon 6.0.6000.16386 301,00 kB (308 224 byte) 02.11.2006 09:44 Microsoft Corporation c:\windows\system32\winlogon.exe shsvcs 6.0.6000.16386 239,50 kB (245 248 byte) 02.11.2006 09:46 Microsoft Corporation c:\windows\system32\shsvcs.dll uxtheme 6.0.6000.16386 235,00 kB (240 640 byte) 02.11.2006 09:46 Microsoft Corporation c:\windows\system32\uxtheme.dll windowscodecs 6.0.6000.16493 695,50 kB (712 192 byte) 14.02.2008 15:35 Microsoft Corporation c:\windows\system32\windowscodecs.dll svchost 6.0.6000.16386 21,50 kB (22 016 byte) 02.11.2006 09:35 Microsoft Corporation c:\windows\system32\svchost.exe umpnpmgr 6.0.6000.16609 216,50 kB (221 696 byte) 13.02.2008 22:45 Microsoft Corporation c:\windows\system32\umpnpmgr.dll powrprof 6.0.6000.16386 94,50 kB (96 768 byte) 02.11.2006 09:48 Microsoft Corporation c:\windows\system32\powrprof.dll rpcss 6.0.6000.16386 533,00 kB (545 792 byte) 02.11.2006 09:50 Microsoft Corporation c:\windows\system32\rpcss.dll firewallapi 6.0.6000.16501 383,00 kB (392 192 byte) 07.02.2008 16:55 Microsoft Corporation c:\windows\system32\firewallapi.dll version 6.0.6000.16386 20,00 kB (20 480 byte) 02.11.2006 09:48 Microsoft Corporation c:\windows\system32\version.dll cabinet 6.0.6000.16386 67,00 kB (68 608 byte) 02.11.2006 09:48 Microsoft Corporation c:\windows\system32\cabinet.dll clbcatq 2001.12.6930.16386 511,50 kB (523 776 byte) 02.11.2006 09:51 Microsoft Corporation c:\windows\system32\clbcatq.dll wtsapi32 6.0.6000.16553 23,50 kB (24 064 byte) 14.02.2008 17:07 Microsoft Corporation c:\windows\system32\wtsapi32.dll fwpuclnt 6.0.6000.16386 530,50 kB (543 232 byte) 02.11.2006 09:57 Microsoft Corporation c:\windows\system32\fwpuclnt.dll mpsvc 1.1.1505.0 259,68 kB (265 912 byte) 14.02.2008 14:39 Microsoft Corporation c:\program files\windows defender\mpsvc.dll wintrust 6.0.6000.16386 167,50 kB (171 520 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\wintrust.dll imagehlp 6.0.6000.16470 149,00 kB (152 576 byte) 07.02.2008 16:53 Microsoft Corporation c:\windows\system32\imagehlp.dll mpclient 1.1.1505.0 304,68 kB (311 992 byte) 14.02.2008 14:39 Microsoft Corporation c:\program files\windows defender\mpclient.dll shell32 6.0.6000.16513 10,79 MB (11 315 200 byte) 14.02.2008 15:35 Microsoft Corporation c:\windows\system32\shell32.dll shlwapi 6.0.6000.16386 332,00 kB (339 968 byte) 02.11.2006 09:46 Microsoft Corporation c:\windows\system32\shlwapi.dll comctl32 6.10.6000.16386 1,57 MB (1 648 128 byte) 02.11.2006 09:47 Microsoft Corporation c:\windows\winsxs\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6000.16386_none_5d07289e07e1d100\comctl32.dll mpengine 1.1.3408.0 3,10 MB (3 251 280 byte) 07.04.2008 07:35 Microsoft Corporation c:\programdata\microsoft\windows defender\definition updates\{8add6e15-d0d9-4ccf-bc9b-a2b8ac92cd05}\mpengine.dll ktmw32 6.0.6000.16386 12,50 kB (12 800 byte) 02.11.2006 09:30 Microsoft Corporation c:\windows\system32\ktmw32.dll dbghelp 6.0.6000.16386 779,50 kB (798 208 byte) 02.11.2006 10:00 Microsoft Corporation c:\windows\system32\dbghelp.dll mprtplug 1.1.1505.0 57,18 kB (58 552 byte) 14.02.2008 14:39 Microsoft Corporation c:\program files\windows defender\mprtplug.dll tdh 6.0.6000.16386 402,00 kB (411 648 byte) 02.11.2006 09:35 Microsoft Corporation c:\windows\system32\tdh.dll ati2evxx 6.14.10.4190 640,00 kB (655 360 byte) 13.11.2007 10:16 ATI Technologies Inc. c:\windows\system32\ati2evxx.exe cfgmgr32 6.0.6000.16609 19,00 kB (19 456 byte) 13.02.2008 22:45 Microsoft Corporation c:\windows\system32\cfgmgr32.dll wevtsvc 6.0.6000.16386 966,50 kB (989 696 byte) 02.11.2006 09:42 Microsoft Corporation c:\windows\system32\wevtsvc.dll audiosrv 6.0.6000.16386 303,00 kB (310 272 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\audiosrv.dll mmdevapi 6.0.6000.16386 143,50 kB (146 944 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\mmdevapi.dll audioses 6.0.6000.16386 113,00 kB (115 712 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\audioses.dll audioeng 6.0.6000.16386 389,50 kB (398 848 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\audioeng.dll avrt 6.0.6000.16386 12,50 kB (12 800 byte) 02.11.2006 10:04 Microsoft Corporation c:\windows\system32\avrt.dll lmhsvc 6.0.6000.16386 18,50 kB (18 944 byte) 02.11.2006 09:57 Microsoft Corporation c:\windows\system32\lmhsvc.dll wscsvc 6.0.6000.16386 51,00 kB (52 224 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\wscsvc.dll wbemprox 6.0.6000.16386 29,50 kB (30 208 byte) 02.11.2006 09:41 Microsoft Corporation c:\windows\system32\wbem\wbemprox.dll wbemcomn 6.0.6000.16553 348,00 kB (356 352 byte) 14.02.2008 17:07 Microsoft Corporation c:\windows\system32\wbem\wbemcomn.dll wbemsvc 6.0.6000.16386 48,00 kB (49 152 byte) 02.11.2006 09:40 Microsoft Corporation c:\windows\system32\wbem\wbemsvc.dll fastprox 6.0.6000.16386 600,00 kB (614 400 byte) 02.11.2006 09:42 Microsoft Corporation c:\windows\system32\wbem\fastprox.dll wuapi 7.0.6000.381 536,84 kB (549 720 byte) 07.02.2008 16:34 Microsoft Corporation c:\windows\system32\wuapi.dll comctl32 5.82.6000.16386 524,50 kB (537 088 byte) 02.11.2006 09:46 Microsoft Corporation c:\windows\winsxs\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.6000.16386_none_87e0cb09378714f1\comctl32.dll WMALFXGFXDSP 11.0.6000.6324 1,25 MB (1 312 256 byte) 02.11.2006 11:25 Microsoft Corporation c:\windows\system32\wmalfxgfxdsp.dll mfplat 11.0.6000.6324 204,00 kB (208 896 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\mfplat.dll nlaapi 6.0.6000.16386 47,00 kB (48 128 byte) 02.11.2006 09:57 Microsoft Corporation c:\windows\system32\nlaapi.dll winrnr 6.0.6000.16386 19,50 kB (19 968 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\winrnr.dll napinsp 6.0.6000.16386 49,00 kB (50 176 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\napinsp.dll pnrpnsp 6.0.6000.16386 61,00 kB (62 464 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\pnrpnsp.dll rasadhlp 6.0.6000.16386 10,00 kB (10 240 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\rasadhlp.dll uxsms 6.0.6000.16386 28,00 kB (28 672 byte) 02.11.2006 09:39 Microsoft Corporation c:\windows\system32\uxsms.dll tabsvc 6.0.6000.16386 66,50 kB (68 096 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\tabsvc.dll hid 6.0.6000.16386 21,50 kB (22 016 byte) 02.11.2006 09:55 Microsoft Corporation c:\windows\system32\hid.dll wudfsvc 6.0.6000.16386 54,00 kB (55 296 byte) 02.11.2006 09:54 Microsoft Corporation c:\windows\system32\wudfsvc.dll wudfplatform 6.0.6000.16386 177,50 kB (181 760 byte) 02.11.2006 09:54 Microsoft Corporation c:\windows\system32\wudfplatform.dll wlansvc 6.0.6000.16551 491,00 kB (502 784 byte) 14.02.2008 17:07 Microsoft Corporation c:\windows\system32\wlansvc.dll wlanmsm 6.0.6000.16551 284,00 kB (290 816 byte) 14.02.2008 17:07 Microsoft Corporation c:\windows\system32\wlanmsm.dll wlansec 6.0.6000.16551 291,00 kB (297 984 byte) 14.02.2008 17:07 Microsoft Corporation c:\windows\system32\wlansec.dll onex 6.0.6000.16386 159,00 kB (162 816 byte) 02.11.2006 09:55 Microsoft Corporation c:\windows\system32\onex.dll eappprxy 6.0.6000.16386 40,00 kB (40 960 byte) 02.11.2006 09:59 Microsoft Corporation c:\windows\system32\eappprxy.dll eappcfg 6.0.6000.16386 148,50 kB (152 064 byte) 02.11.2006 09:59 Microsoft Corporation c:\windows\system32\eappcfg.dll wlgpclnt 6.0.6000.16386 77,00 kB (78 848 byte) 02.11.2006 09:55 Microsoft Corporation c:\windows\system32\wlgpclnt.dll l2gpstore 6.0.6000.16386 52,50 kB (53 760 byte) 02.11.2006 09:55 Microsoft Corporation c:\windows\system32\l2gpstore.dll wlanutil 6.0.6000.16386 8,00 kB (8 192 byte) 02.11.2006 09:55 Microsoft Corporation c:\windows\system32\wlanutil.dll msxml6 6.10.1200.0 1,27 MB (1 335 296 byte) 07.02.2008 16:54 Microsoft Corporation c:\windows\system32\msxml6.dll netcfgx 6.0.6000.16517 375,00 kB (384 000 byte) 14.02.2008 15:38 Microsoft Corporation c:\windows\system32\netcfgx.dll emdmgmt 6.0.6000.16386 547,50 kB (560 640 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\emdmgmt.dll wdscore 6.0.6000.16386 213,00 kB (218 112 byte) 02.11.2006 09:33 Microsoft Corporation c:\windows\system32\wdscore.dll slwga 6.0.6000.16386 12,00 kB (12 288 byte) 02.11.2006 09:44 Microsoft Corporation c:\windows\system32\slwga.dll urlmon 7.0.6000.16609 1,11 MB (1 159 680 byte) 13.02.2008 22:38 Microsoft Corporation c:\windows\system32\urlmon.dll iertutil 7.0.6000.16386 260,50 kB (266 752 byte) 02.11.2006 09:49 Microsoft Corporation c:\windows\system32\iertutil.dll pcasvc 6.0.6000.16386 37,00 kB (37 888 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\pcasvc.dll sysmain 6.0.6000.16551 530,00 kB (542 720 byte) 14.02.2008 17:07 Microsoft Corporation c:\windows\system32\sysmain.dll trkwks 6.0.6000.16386 73,50 kB (75 264 byte) 02.11.2006 09:50 Microsoft Corporation c:\windows\system32\trkwks.dll wpdbusenum 6.0.6000.16386 68,50 kB (70 144 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\wpdbusenum.dll portabledeviceapi 6.0.6000.16386 266,00 kB (272 384 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\portabledeviceapi.dll umb 6.0.6000.16386 48,00 kB (49 152 byte) 02.11.2006 09:37 Microsoft Corporation c:\windows\system32\umb.dll atl 3.5.2284.0 70,00 kB (71 680 byte) 02.11.2006 10:13 Microsoft Corporation c:\windows\system32\atl.dll netman 6.0.6000.16386 267,50 kB (273 920 byte) 02.11.2006 09:56 Microsoft Corporation c:\windows\system32\netman.dll rasapi32 6.0.6000.16386 273,50 kB (280 064 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\rasapi32.dll rasman 6.0.6000.16386 69,00 kB (70 656 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\rasman.dll tapi32 6.0.6000.16386 187,00 kB (191 488 byte) 02.11.2006 10:16 Microsoft Corporation c:\windows\system32\tapi32.dll rtutils 6.0.6000.16386 35,50 kB (36 352 byte) 02.11.2006 09:57 Microsoft Corporation c:\windows\system32\rtutils.dll winmm 6.0.6000.16386 188,50 kB (193 024 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\winmm.dll oleacc 4.2.5406.0 209,00 kB (214 016 byte) 02.11.2006 09:38 Microsoft Corporation c:\windows\system32\oleacc.dll netshell 6.0.6000.16386 3,03 MB (3 174 400 byte) 02.11.2006 09:56 Microsoft Corporation c:\windows\system32\netshell.dll wdi 6.0.6000.16386 72,50 kB (74 240 byte) 02.11.2006 09:35 Microsoft Corporation c:\windows\system32\wdi.dll pcadm 6.0.6000.16386 26,00 kB (26 624 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\pcadm.dll rasdlg 6.0.6000.16386 805,50 kB (824 832 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\rasdlg.dll mprapi 6.0.6000.16386 96,00 kB (98 304 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\mprapi.dll activeds 6.0.6000.16386 199,50 kB (204 288 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\activeds.dll adsldpc 6.0.6000.16386 194,00 kB (198 656 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\adsldpc.dll credui 6.0.6000.16386 174,00 kB (178 176 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\credui.dll hnetcfg 6.0.6000.16386 285,00 kB (291 840 byte) 02.11.2006 09:57 Microsoft Corporation c:\windows\system32\hnetcfg.dll winhttp 6.0.6000.16386 368,00 kB (376 832 byte) 02.11.2006 09:50 Microsoft Corporation c:\windows\system32\winhttp.dll upnp 6.0.6000.16386 191,00 kB (195 584 byte) 02.11.2006 09:59 Microsoft Corporation c:\windows\system32\upnp.dll ssdpapi 6.0.6000.16386 37,00 kB (37 888 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\ssdpapi.dll radardt 6.0.6000.16386 70,00 kB (71 680 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\radardt.dll mmcss 6.0.6000.16386 44,00 kB (45 056 byte) 02.11.2006 10:04 Microsoft Corporation c:\windows\system32\mmcss.dll profsvc 6.0.6000.16386 149,00 kB (152 576 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\profsvc.dll gpsvc 6.0.6000.16386 556,00 kB (569 344 byte) 02.11.2006 09:46 Microsoft Corporation c:\windows\system32\gpsvc.dll sens 6.0.6000.16386 46,00 kB (47 104 byte) 02.11.2006 09:50 Microsoft Corporation c:\windows\system32\sens.dll eapsvc 6.0.6000.16386 34,00 kB (34 816 byte) 02.11.2006 09:59 Microsoft Corporation c:\windows\system32\eapsvc.dll eapphost 6.0.6000.16386 195,00 kB (199 680 byte) 02.11.2006 09:59 Microsoft Corporation c:\windows\system32\eapphost.dll iscsiexe 6.0.6000.16386 108,50 kB (111 104 byte) 02.11.2006 09:52 Microsoft Corporation c:\windows\system32\iscsiexe.dll iscsium 6.0.6000.16386 28,00 kB (28 672 byte) 02.11.2006 09:52 Microsoft Corporation c:\windows\system32\iscsium.dll iscsied 6.0.6000.16386 7,50 kB (7 680 byte) 02.11.2006 09:52 Microsoft Corporation c:\windows\system32\iscsied.dll schedsvc 6.0.6000.16609 581,50 kB (595 456 byte) 13.02.2008 22:45 Microsoft Corporation c:\windows\system32\schedsvc.dll propsys 6.0.6000.16386 716,50 kB (733 696 byte) 02.11.2006 09:47 Microsoft Corporation c:\windows\system32\propsys.dll taskcomp 6.0.6000.16386 260,00 kB (266 240 byte) 02.11.2006 09:41 Microsoft Corporation c:\windows\system32\taskcomp.dll wiarpc 6.0.6000.16386 32,00 kB (32 768 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\wiarpc.dll tschannel 6.0.6000.16386 16,50 kB (16 896 byte) 02.11.2006 09:40 Microsoft Corporation c:\windows\system32\tschannel.dll srvsvc 6.0.6000.16386 118,50 kB (121 344 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\srvsvc.dll sscore 6.0.6000.16386 9,50 kB (9 728 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\sscore.dll clusapi 6.0.6000.16386 116,50 kB (119 296 byte) 02.11.2006 09:36 Microsoft Corporation c:\windows\system32\clusapi.dll resutils 6.0.6000.16386 64,50 kB (66 048 byte) 02.11.2006 09:36 Microsoft Corporation c:\windows\system32\resutils.dll winspool 6.0.6000.16386 249,50 kB (255 488 byte) 02.11.2006 10:15 Microsoft Corporation c:\windows\system32\winspool.drv browser 6.0.6000.16386 79,50 kB (81 408 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\browser.dll aelupsvc 6.0.6000.16386 24,00 kB (24 576 byte) 02.11.2006 09:29 Microsoft Corporation c:\windows\system32\aelupsvc.dll ikeext 6.0.6000.16386 407,00 kB (416 768 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\ikeext.dll seclogon 6.0.6000.16386 19,50 kB (19 968 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\seclogon.dll wmisvc 6.0.6000.16386 157,50 kB (161 280 byte) 02.11.2006 09:41 Microsoft Corporation c:\windows\system32\wbem\wmisvc.dll iphlpsvc 6.0.6000.16501 174,50 kB (178 688 byte) 07.02.2008 16:55 Microsoft Corporation c:\windows\system32\iphlpsvc.dll sqmapi 6.0.6000.16386 131,00 kB (134 144 byte) 02.11.2006 09:40 Microsoft Corporation c:\windows\system32\sqmapi.dll vssapi 6.0.6000.16386 971,50 kB (994 816 byte) 02.11.2006 09:52 Microsoft Corporation c:\windows\system32\vssapi.dll vsstrace 6.0.6000.16386 72,00 kB (73 728 byte) 02.11.2006 09:52 Microsoft Corporation c:\windows\system32\vsstrace.dll xmllite 1.1.1002.0 124,00 kB (126 976 byte) 02.11.2006 10:16 Microsoft Corporation c:\windows\system32\xmllite.dll wbemcore 6.0.6000.16386 723,50 kB (740 864 byte) 02.11.2006 09:41 Microsoft Corporation c:\windows\system32\wbem\wbemcore.dll esscli 6.0.6000.16386 260,50 kB (266 752 byte) 02.11.2006 09:41 Microsoft Corporation c:\windows\system32\wbem\esscli.dll wmiutils 6.0.6000.16386 82,50 kB (84 480 byte) 02.11.2006 09:41 Microsoft Corporation c:\windows\system32\wbem\wmiutils.dll repdrvfs 6.0.6000.16386 258,50 kB (264 704 byte) 02.11.2006 09:41 Microsoft Corporation c:\windows\system32\wbem\repdrvfs.dll wmiprvsd 6.0.6000.16386 474,50 kB (485 888 byte) 02.11.2006 09:42 Microsoft Corporation c:\windows\system32\wbem\wmiprvsd.dll wbemess 6.0.6000.16386 340,50 kB (348 672 byte) 02.11.2006 09:41 Microsoft Corporation c:\windows\system32\wbem\wbemess.dll ncprov 6.0.6000.16386 56,50 kB (57 856 byte) 02.11.2006 09:41 Microsoft Corporation c:\windows\system32\wbem\ncprov.dll qmgr 7.0.6000.16531 732,50 kB (750 080 byte) 07.02.2008 16:52 Microsoft Corporation c:\windows\system32\qmgr.dll shfolder 6.0.6000.16386 7,00 kB (7 168 byte) 02.11.2006 09:47 Microsoft Corporation c:\windows\system32\shfolder.dll bitsperf 7.0.6000.16386 17,50 kB (17 920 byte) 02.11.2006 09:40 Microsoft Corporation c:\windows\system32\bitsperf.dll bitsigd 7.0.6000.16386 31,00 kB (31 744 byte) 02.11.2006 09:40 Microsoft Corporation c:\windows\system32\bitsigd.dll wuaueng 7.0.6000.381 1,63 MB (1 712 984 byte) 07.02.2008 16:35 Microsoft Corporation c:\windows\system32\wuaueng.dll esent 6.0.6000.16386 1,39 MB (1 455 616 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\esent.dll mspatcha 6.0.6000.16386 34,50 kB (35 328 byte) 02.11.2006 09:36 Microsoft Corporation c:\windows\system32\mspatcha.dll rasmans 6.0.6000.16386 229,00 kB (234 496 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\rasmans.dll rastapi 6.0.6000.16386 65,50 kB (67 072 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\rastapi.dll rasppp 6.0.6000.16386 249,00 kB (254 976 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\rasppp.dll rasqec 6.0.6000.16386 65,50 kB (67 072 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\rasqec.dll qutil 6.0.6000.16386 77,00 kB (78 848 byte) 02.11.2006 09:56 Microsoft Corporation c:\windows\system32\qutil.dll raschap 6.0.6000.16386 268,00 kB (274 432 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\raschap.dll rastls 6.0.6000.16386 227,50 kB (232 960 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\rastls.dll cryptui 6.0.6000.16386 946,50 kB (969 216 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\cryptui.dll msimg32 6.0.6000.16386 4,50 kB (4 608 byte) 02.11.2006 09:38 Microsoft Corporation c:\windows\system32\msimg32.dll winscard 6.0.6000.16386 112,50 kB (115 200 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\winscard.dll wscapi 6.0.6000.16386 33,00 kB (33 792 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\wscapi.dll msxml3 8.90.1101.0 1,14 MB (1 191 936 byte) 07.02.2008 16:55 Microsoft Corporation c:\windows\system32\msxml3.dll msi 4.0.6000.16386 2,00 MB (2 095 616 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\msi.dll advpack 7.0.6000.16609 122,00 kB (124 928 byte) 13.02.2008 22:38 Microsoft Corporation c:\windows\system32\advpack.dll actxprxy 6.0.6000.16386 319,50 kB (327 168 byte) 02.11.2006 10:16 Microsoft Corporation c:\windows\system32\actxprxy.dll npmproxy 6.0.6000.16386 16,00 kB (16 384 byte) 02.11.2006 09:59 Microsoft Corporation c:\windows\system32\npmproxy.dll slsvc 6.0.6000.16509 2,48 MB (2 605 568 byte) 14.02.2008 17:04 Microsoft Corporation c:\windows\system32\slsvc.exe es 2001.12.6930.16386 253,50 kB (259 584 byte) 02.11.2006 09:51 Microsoft Corporation c:\windows\system32\es.dll nsisvc 6.0.6000.16386 18,00 kB (18 432 byte) 02.11.2006 09:57 Microsoft Corporation c:\windows\system32\nsisvc.dll webclnt 6.0.6000.16626 190,00 kB (194 560 byte) 13.02.2008 22:47 Microsoft Corporation c:\windows\system32\webclnt.dll wininet 7.0.6000.16609 805,50 kB (824 832 byte) 13.02.2008 22:38 Microsoft Corporation c:\windows\system32\wininet.dll normaliz 6.0.6000.16386 2,50 kB (2 560 byte) 02.11.2006 09:33 Microsoft Corporation c:\windows\system32\normaliz.dll wkssvc 6.0.6000.16386 152,50 kB (156 160 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\wkssvc.dll fdrespub 6.0.6000.16386 27,00 kB (27 648 byte) 02.11.2006 09:37 Microsoft Corporation c:\windows\system32\fdrespub.dll wsdapi 6.0.6000.16386 314,00 kB (321 536 byte) 02.11.2006 09:37 Microsoft Corporation c:\windows\system32\wsdapi.dll httpapi 6.0.6000.16386 30,00 kB (30 720 byte) 02.11.2006 09:56 Microsoft Corporation c:\windows\system32\httpapi.dll fundisc 6.0.6000.16386 143,00 kB (146 432 byte) 02.11.2006 09:37 Microsoft Corporation c:\windows\system32\fundisc.dll w32time 6.0.6000.16386 264,50 kB (270 848 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\w32time.dll netprofm 6.0.6000.16386 230,00 kB (235 520 byte) 02.11.2006 09:59 Microsoft Corporation c:\windows\system32\netprofm.dll fdphost 6.0.6000.16386 12,50 kB (12 800 byte) 02.11.2006 09:37 Microsoft Corporation c:\windows\system32\fdphost.dll fdwsd 6.0.6000.16386 63,50 kB (65 024 byte) 02.11.2006 09:37 Microsoft Corporation c:\windows\system32\fdwsd.dll mlang 6.0.6000.16386 183,50 kB (187 904 byte) 02.11.2006 09:47 Microsoft Corporation c:\windows\system32\mlang.dll fdssdp 6.0.6000.16386 65,00 kB (66 560 byte) 02.11.2006 09:37 Microsoft Corporation c:\windows\system32\fdssdp.dll fdproxy 6.0.6000.16386 20,50 kB (20 992 byte) 02.11.2006 09:37 Microsoft Corporation c:\windows\system32\fdproxy.dll ssdpsrv 6.0.6000.16386 151,50 kB (155 136 byte) 02.11.2006 09:59 Microsoft Corporation c:\windows\system32\ssdpsrv.dll upnphost 6.0.6000.16386 253,00 kB (259 072 byte) 02.11.2006 09:59 Microsoft Corporation c:\windows\system32\upnphost.dll dnsrslvr 6.0.6000.16386 82,00 kB (83 968 byte) 02.11.2006 09:46 Microsoft Corporation c:\windows\system32\dnsrslvr.dll cryptsvc 6.0.6000.16386 120,50 kB (123 392 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\cryptsvc.dll nlasvc 6.0.6000.16386 167,50 kB (171 520 byte) 02.11.2006 09:57 Microsoft Corporation c:\windows\system32\nlasvc.dll ncsi 6.0.6000.16386 89,50 kB (91 648 byte) 02.11.2006 09:56 Microsoft Corporation c:\windows\system32\ncsi.dll termsrv 6.0.6000.16386 417,50 kB (427 520 byte) 02.11.2006 10:02 Microsoft Corporation c:\windows\system32\termsrv.dll icaapi 6.0.6000.16386 15,50 kB (15 872 byte) 02.11.2006 10:02 Microsoft Corporation c:\windows\system32\icaapi.dll msdtckrm 2001.12.6930.16386 278,00 kB (284 672 byte) 02.11.2006 09:50 Microsoft Corporation c:\windows\system32\msdtckrm.dll tapisrv 6.0.6000.16386 237,00 kB (242 688 byte) 02.11.2006 10:16 Microsoft Corporation c:\windows\system32\tapisrv.dll unimdm 6.0.6000.16386 273,50 kB (280 064 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\unimdm.tsp uniplat 6.0.6000.16386 16,00 kB (16 384 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\uniplat.dll kmddsp 6.0.6000.16518 37,50 kB (38 400 byte) 14.02.2008 15:38 Microsoft Corporation c:\windows\system32\kmddsp.tsp ndptsp 6.0.6000.16518 48,50 kB (49 664 byte) 14.02.2008 15:38 Microsoft Corporation c:\windows\system32\ndptsp.tsp hidphone 6.0.6000.16386 31,00 kB (31 744 byte) 02.11.2006 10:16 Microsoft Corporation c:\windows\system32\hidphone.tsp vss_ps 6.0.6000.16386 24,50 kB (25 088 byte) 02.11.2006 09:52 Microsoft Corporation c:\windows\system32\vss_ps.dll ati2edxx 6.14.10.2513 42,50 kB (43 520 byte) 13.11.2007 10:16 ATI Technologies, Inc. c:\windows\system32\ati2edxx.dll atipdlxx 6.14.10.2530 308,00 kB (315 392 byte) 13.11.2007 10:16 ATI Technologies, Inc. c:\windows\system32\atipdlxx.dll ati2evxx 6.14.10.4176 248,00 kB (253 952 byte) 13.11.2007 10:16 ATI Technologies Inc. c:\windows\system32\ati2evxx.dll dwm 6.0.6000.16386 81,50 kB (83 456 byte) 02.11.2006 09:39 Microsoft Corporation c:\windows\system32\dwm.exe dwmredir 6.0.6000.16386 85,50 kB (87 552 byte) 02.11.2006 09:39 Microsoft Corporation c:\windows\system32\dwmredir.dll milcore 6.0.6000.16386 1,92 MB (2 014 720 byte) 02.11.2006 09:42 Microsoft Corporation c:\windows\system32\milcore.dll dwmapi 6.0.6000.16386 39,00 kB (39 936 byte) 02.11.2006 09:39 Microsoft Corporation c:\windows\system32\dwmapi.dll udwm 6.0.6000.16386 203,50 kB (208 384 byte) 02.11.2006 13:36 Microsoft Corporation c:\windows\system32\udwm.dll d3d9 6.0.6000.16386 1,71 MB (1 788 416 byte) 02.11.2006 10:04 Microsoft Corporation c:\windows\system32\d3d9.dll d3d8thk 6.0.6000.16386 11,00 kB (11 264 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\d3d8thk.dll atiumdag 7.14.10.567 2,93 MB (3 074 048 byte) 13.11.2007 10:16 ATI Technologies Inc. c:\windows\system32\atiumdag.dll atiumdva 7.14.10.182 3,90 MB (4 084 736 byte) 13.11.2007 10:16 ATI Technologies Inc. c:\windows\system32\atiumdva.dll spoolsv 6.0.6000.16386 122,00 kB (124 928 byte) 02.11.2006 10:15 Microsoft Corporation c:\windows\system32\spoolsv.exe spoolss 6.0.6000.16386 159,00 kB (162 816 byte) 02.11.2006 10:15 Microsoft Corporation c:\windows\system32\spoolss.dll localspl 6.0.6000.16515 678,50 kB (694 784 byte) 14.02.2008 15:38 Microsoft Corporation c:\windows\system32\localspl.dll sfc 6.0.6000.16386 4,50 kB (4 608 byte) 02.11.2006 09:33 Microsoft Corporation c:\windows\system32\sfc.dll adobepdf 8.1.0.0 28,59 kB (29 272 byte) 08.02.2008 16:38 Adobe Systems Incorporated. c:\windows\system32\adobepdf.dll msvcr80 8.0.50727.762 612,00 kB (626 688 byte) 12.02.2008 20:05 Microsoft Corporation c:\windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.762_none_10b2f55f9bffb8f8\msvcr80.dll adistres 8.1.0.137 412,00 kB (421 888 byte) 08.02.2008 16:36 Adobe Systems Incorporated. c:\program files\adobe\acrobat 8.0\acrobat\adistres.dll msonpmon 0.3.4518.1014 31,83 kB (32 592 byte) 07.02.2008 21:40 Microsoft Corporation c:\windows\system32\msonpmon.dll tcpmon 6.0.6000.16386 127,00 kB (130 048 byte) 02.11.2006 10:15 Microsoft Corporation c:\windows\system32\tcpmon.dll snmpapi 6.0.6000.16386 22,00 kB (22 528 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\snmpapi.dll wsnmp32 6.0.6000.16386 50,00 kB (51 200 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\wsnmp32.dll tcpmib 6.0.6000.16386 27,50 kB (28 160 byte) 02.11.2006 10:15 Microsoft Corporation c:\windows\system32\tcpmib.dll mgmtapi 6.0.6000.16386 18,50 kB (18 944 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\mgmtapi.dll usbmon 6.0.6000.16386 31,00 kB (31 744 byte) 02.11.2006 10:15 Microsoft Corporation c:\windows\system32\usbmon.dll wls0wndh 6.0.6000.16386 8,00 kB (8 192 byte) 02.11.2006 09:44 Microsoft Corporation c:\windows\system32\wls0wndh.dll wsdmon 6.0.6000.16386 146,50 kB (150 016 byte) 02.11.2006 10:15 Microsoft Corporation c:\windows\system32\wsdmon.dll msonpppr 0.3.4518.1014 32,33 kB (33 104 byte) 07.02.2008 21:40 Microsoft Corporation c:\windows\system32\spool\prtprocs\w32x86\msonpppr.dll win32spl 6.0.6000.16386 429,50 kB (439 808 byte) 02.11.2006 10:15 Microsoft Corporation c:\windows\system32\win32spl.dll netrap 6.0.6000.16386 14,50 kB (14 848 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\netrap.dll printcom 6.0.6000.16386 36,50 kB (37 376 byte) 02.11.2006 10:14 Microsoft Corporation c:\windows\system32\printcom.dll sensapi 6.0.6000.16386 8,50 kB (8 704 byte) 02.11.2006 09:50 Microsoft Corporation c:\windows\system32\sensapi.dll inetpp 6.0.6000.16386 118,00 kB (120 832 byte) 02.11.2006 13:36 Microsoft Corporation c:\windows\system32\inetpp.dll bfe 6.0.6000.16386 310,00 kB (317 440 byte) 02.11.2006 09:57 Microsoft Corporation c:\windows\system32\bfe.dll mpssvc 6.0.6000.16501 387,50 kB (396 800 byte) 07.02.2008 16:55 Microsoft Corporation c:\windows\system32\mpssvc.dll wfapigp 6.0.6000.16501 16,50 kB (16 896 byte) 07.02.2008 16:55 Microsoft Corporation c:\windows\system32\wfapigp.dll dps 6.0.6000.16515 131,50 kB (134 656 byte) 14.02.2008 15:38 Microsoft Corporation c:\windows\system32\dps.dll taskschd 6.0.6000.16386 347,50 kB (355 840 byte) 02.11.2006 09:41 Microsoft Corporation c:\windows\system32\taskschd.dll diagperf 6.0.6000.16386 1,03 MB (1 075 712 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\diagperf.dll taskeng 6.0.6000.16386 162,50 kB (166 400 byte) 02.11.2006 09:41 Microsoft Corporation c:\windows\system32\taskeng.exe playsndsrv 6.0.6000.16386 17,50 kB (17 920 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\playsndsrv.dll hotstartuseragent 6.0.6000.16386 21,00 kB (21 504 byte) 02.11.2006 13:36 Microsoft Corporation c:\windows\system32\hotstartuseragent.dll wdmaud 6.0.6000.16386 164,50 kB (168 448 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\wdmaud.drv ksuser 6.0.6000.16386 4,50 kB (4 608 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\ksuser.dll msacm32 6.0.6000.16386 21,00 kB (21 504 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\msacm32.drv msacm32 6.0.6000.16386 71,50 kB (73 216 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\msacm32.dll midimap 6.0.6000.16386 17,00 kB (17 408 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\midimap.dll tmm 6.0.6000.16386 1,24 MB (1 298 432 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\tmm.dll qagent 6.0.6000.16386 159,50 kB (163 328 byte) 02.11.2006 09:56 Microsoft Corporation c:\windows\system32\qagent.dll msctfmonitor 6.0.6000.16386 19,00 kB (19 456 byte) 02.11.2006 09:38 Microsoft Corporation c:\windows\system32\msctfmonitor.dll msutb 6.0.6000.16386 158,50 kB (162 304 byte) 02.11.2006 09:38 Microsoft Corporation c:\windows\system32\msutb.dll atitmmxx 6.14.11.17 156,00 kB (159 744 byte) 13.11.2007 10:16 c:\windows\system32\atitmmxx.dll dimsjob 6.0.6000.16386 34,50 kB (35 328 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\dimsjob.dll pautoenr 6.0.6000.16386 42,00 kB (43 008 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\pautoenr.dll certcli 6.0.6000.16386 312,50 kB (320 000 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\certcli.dll certenroll 6.0.6000.16386 1,05 MB (1 105 408 byte) 02.11.2006 09:45 Microsoft Corporation c:\windows\system32\certenroll.dll explorer 6.0.6000.16549 2,79 MB (2 923 520 byte) 14.02.2008 17:07 Microsoft Corporation c:\windows\explorer.exe shdocvw 6.0.6000.16386 1,02 MB (1 064 960 byte) 02.11.2006 09:46 Microsoft Corporation c:\windows\system32\shdocvw.dll gdiplus 5.2.6000.16386 1,66 MB (1 744 896 byte) 02.11.2006 09:39 Microsoft Corporation c:\windows\winsxs\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.6000.16386_none_9ea0ac9ec96e7127\gdiplus.dll browseui 6.0.6000.16386 1,26 MB (1 321 472 byte) 02.11.2006 09:47 Microsoft Corporation c:\windows\system32\browseui.dll duser 6.0.6000.16386 179,50 kB (183 808 byte) 02.11.2006 09:39 Microsoft Corporation c:\windows\system32\duser.dll iconcodecservice 6.0.6000.16386 9,50 kB (9 728 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\iconcodecservice.dll msiltcfg 4.0.6000.16386 15,50 kB (15 872 byte) 02.11.2006 09:42 Microsoft Corporation c:\windows\system32\msiltcfg.dll sfc_os 6.0.6000.16386 37,50 kB (38 400 byte) 02.11.2006 09:33 Microsoft Corporation c:\windows\system32\sfc_os.dll timedate 6.0.6000.16549 697,50 kB (714 240 byte) 14.02.2008 17:07 Microsoft Corporation c:\windows\system32\timedate.cpl msshsq 6.0.6000.16404 224,50 kB (229 888 byte) 14.02.2008 17:06 Microsoft Corporation c:\windows\system32\msshsq.dll naturallanguage6 6.0.6000.16386 779,00 kB (797 696 byte) 02.11.2006 10:13 Microsoft Corporation c:\windows\system32\naturallanguage6.dll authui 6.0.6000.16513 1,89 MB (1 984 512 byte) 14.02.2008 15:35 Microsoft Corporation c:\windows\system32\authui.dll linkinfo 6.0.6000.16386 21,50 kB (22 016 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\linkinfo.dll ieframe 7.0.6000.16609 5,79 MB (6 066 176 byte) 13.02.2008 22:39 Microsoft Corporation c:\windows\system32\ieframe.dll ntshrui 6.0.6000.16386 289,50 kB (296 448 byte) 02.11.2006 09:48 Microsoft Corporation c:\windows\system32\ntshrui.dll cscapi 6.0.6000.16386 27,00 kB (27 648 byte) 02.11.2006 09:31 Microsoft Corporation c:\windows\system32\cscapi.dll explorerframe 6.0.6000.16386 20,50 kB (20 992 byte) 02.11.2006 09:46 Microsoft Corporation c:\windows\system32\explorerframe.dll stobject 6.0.6000.16386 573,00 kB (586 752 byte) 02.11.2006 09:47 Microsoft Corporation c:\windows\system32\stobject.dll batmeter 6.0.6000.16386 720,50 kB (737 792 byte) 02.11.2006 09:48 Microsoft Corporation c:\windows\system32\batmeter.dll sndvolsso 6.0.6000.16386 181,50 kB (185 856 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\sndvolsso.dll ehsso 6.0.6000.16386 117,00 kB (119 808 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\ehome\ehsso.dll pnidui 6.0.6000.16386 1,74 MB (1 822 720 byte) 02.11.2006 09:56 Microsoft Corporation c:\windows\system32\pnidui.dll DreamScene 6.0.6000.16424 120,00 kB (122 880 byte) 24.04.2007 19:47 Microsoft Corporation c:\windows\system32\dreamscene.dll wlanapi 6.0.6000.16551 46,00 kB (47 104 byte) 14.02.2008 17:07 Microsoft Corporation c:\windows\system32\wlanapi.dll alttab 6.0.6000.16386 42,00 kB (43 008 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\alttab.dll wpdshserviceobj 6.0.6000.16386 128,00 kB (131 072 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\wpdshserviceobj.dll srchadmin 6.0.6000.16386 241,50 kB (247 296 byte) 02.11.2006 09:47 Microsoft Corporation c:\windows\system32\srchadmin.dll webcheck 7.0.6000.16386 227,50 kB (232 960 byte) 02.11.2006 09:50 Microsoft Corporation c:\windows\system32\webcheck.dll synccenter 6.0.6000.16386 2,10 MB (2 205 184 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\synccenter.dll wscntfy 6.0.6000.16386 218,00 kB (223 232 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\wscntfy.dll mssprxy 6.0.6000.16386 31,50 kB (32 256 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\mssprxy.dll bthprops 6.0.6000.16386 966,50 kB (989 696 byte) 02.11.2006 09:47 Microsoft Corporation c:\windows\system32\bthprops.cpl imapi2 6.0.6000.16386 309,50 kB (316 928 byte) 02.11.2006 09:51 Microsoft Corporation c:\windows\system32\imapi2.dll portabledevicetypes 6.0.6000.16386 157,00 kB (160 768 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\portabledevicetypes.dll shimeng 6.0.6000.16386 108,50 kB (111 104 byte) 02.11.2006 09:29 Microsoft Corporation c:\windows\system32\shimeng.dll aclayers 6.0.6000.16633 525,00 kB (537 600 byte) 14.02.2008 17:04 Microsoft Corporation c:\windows\apppatch\aclayers.dll acspecfc 6.0.6000.16633 439,00 kB (449 536 byte) 14.02.2008 17:04 Microsoft Corporation c:\windows\apppatch\acspecfc.dll mscms 6.0.6000.16386 382,00 kB (391 168 byte) 02.11.2006 09:38 Microsoft Corporation c:\windows\system32\mscms.dll ddraw 6.0.6000.16386 516,00 kB (528 384 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\ddraw.dll dciman32 6.0.6000.16386 10,00 kB (10 240 byte) 02.11.2006 09:38 Microsoft Corporation c:\windows\system32\dciman32.dll comdlg32 6.0.6000.16386 444,00 kB (454 656 byte) 02.11.2006 09:46 Microsoft Corporation c:\windows\system32\comdlg32.dll shunimpl 6.0.6000.16386 6,50 kB (6 656 byte) 02.11.2006 09:46 Microsoft Corporation c:\windows\system32\shunimpl.dll qedit 6.6.6000.16386 493,50 kB (505 344 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\qedit.dll msvfw32 6.0.6000.16513 121,00 kB (123 904 byte) 14.02.2008 15:35 Microsoft Corporation c:\windows\system32\msvfw32.dll quartz 6.6.6000.16587 1,27 MB (1 327 104 byte) 07.02.2008 16:54 Microsoft Corporation c:\windows\system32\quartz.dll dxva2 5.0.1.1 61,00 kB (62 464 byte) 02.11.2006 10:04 Microsoft Corporation c:\windows\system32\dxva2.dll devenum 6.6.6000.16386 62,50 kB (64 000 byte) 02.11.2006 10:04 Microsoft Corporation c:\windows\system32\devenum.dll mpg2splt 6.6.6000.16386 173,00 kB (177 152 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\mpg2splt.ax d3dim700 6.0.6000.16386 797,00 kB (816 128 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\d3dim700.dll ad2mcdsmpeg 1.0.0.75 80,00 kB (81 920 byte) 30.05.2007 03:59 MainConcept AG c:\program files\adobe\adobe premiere pro cs3\ad2mcdsmpeg.ax ad2mcmpgdec 1.1.1.40 625,50 kB (640 512 byte) 30.05.2007 03:59 MainConcept AG c:\program files\adobe\adobe premiere pro cs3\ad2mcmpgdec.dll msvcr71 7.10.3052.4 340,00 kB (348 160 byte) 30.05.2007 03:52 Microsoft Corporation c:\program files\adobe\adobe premiere pro cs3\msvcr71.dll rarext Ikke tilgjengelig 126,00 kB (129 024 byte) 07.02.2008 19:45 Ikke tilgjengelig c:\program files\winrar\rarext.dll syncui 6.0.6000.16386 171,50 kB (175 616 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\syncui.dll synceng 6.0.6000.16386 70,00 kB (71 680 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\synceng.dll ContextMenu 8.1.5.137 669,63 kB (685 696 byte) 08.02.2008 16:36 Adobe Systems Inc. c:\program files\adobe\acrobat 8.0\acrobat elements\contextmenu.dll mfc80u 8.0.50727.762 1,04 MB (1 093 120 byte) 12.02.2008 20:05 Microsoft Corporation c:\windows\winsxs\x86_microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.762_none_0c178a139ee2a7ed\mfc80u.dll msvcp80 8.0.50727.762 536,00 kB (548 864 byte) 12.02.2008 20:05 Microsoft Corporation c:\windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.762_none_10b2f55f9bffb8f8\msvcp80.dll jetflext 6.0.0.9751 156,07 kB (159 812 byte) 07.02.2008 20:54 COWON America c:\program files\jetaudio\jetflext.dll nlsdata0414 6.0.6000.16386 4,29 MB (4 493 312 byte) 02.11.2006 10:12 Microsoft Corporation c:\windows\system32\nlsdata0414.dll nlslexicons0414 6.0.6000.16386 4,40 MB (4 616 192 byte) 02.11.2006 09:22 Microsoft Corporation c:\windows\system32\nlslexicons0414.dll avifil32 6.0.6000.16513 86,50 kB (88 576 byte) 14.02.2008 15:35 Microsoft Corporation c:\windows\system32\avifil32.dll msascui 1.1.1505.0 982,68 kB (1 006 264 byte) 14.02.2008 14:39 Microsoft Corporation c:\program files\windows defender\msascui.exe msmpres 1.1.1505.0 641,18 kB (656 568 byte) 14.02.2008 14:39 Microsoft Corporation c:\program files\windows defender\msmpres.dll mprtmon 1.1.1505.0 654,68 kB (670 392 byte) 14.02.2008 14:39 Microsoft Corporation c:\program files\windows defender\mprtmon.dll msftedit 5.41.21.2507 551,50 kB (564 736 byte) 14.02.2008 15:38 Microsoft Corporation c:\windows\system32\msftedit.dll acrotray 8.0.137.0 609,62 kB (624 248 byte) 08.02.2008 16:36 Adobe Systems Inc. c:\program files\adobe\acrobat 8.0\acrobat\acrotray.exe FNP_Act_Installer 11.3.5.1 912,50 kB (934 400 byte) 15.09.2006 14:58 Macrovision Europe Ltd. c:\program files\adobe\acrobat 8.0\acrobat\fnp_act_installer.dll asneu 1.6.0.8 124,00 kB (126 976 byte) 02.08.2006 08:52 Adobe Systems Inc. c:\program files\adobe\acrobat 8.0\acrobat\asneu.dll adobe_personalization 2.0.0.37 338,00 kB (346 112 byte) 15.09.2006 00:20 Adobe Systems Incorporated c:\program files\adobe\acrobat 8.0\acrobat\adobe_personalization.dll oledlg 6.0.6000.16386 99,50 kB (101 888 byte) 02.11.2006 09:50 Microsoft Corporation c:\windows\system32\oledlg.dll adobe_epic 2.0.0.37 208,00 kB (212 992 byte) 15.09.2006 00:20 Adobe Systems Incorporated c:\program files\adobe\acrobat 8.0\acrobat\adobe_epic.dll adobe_pcd 1.0.0.0 204,00 kB (208 896 byte) 15.09.2006 00:46 Adobe Systems Incorporated c:\program files\adobe\acrobat 8.0\acrobat\adobe_pcd.dll icmp 6.0.6000.16386 3,00 kB (3 072 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\icmp.dll jusched 6.0.30.5 129,39 kB (132 496 byte) 24.02.2008 00:49 Sun Microsystems, Inc. c:\program files\java\jre1.6.0_03\bin\jusched.exe msnmsgr 8.5.1302.1018 5,46 MB (5 724 184 byte) 18.10.2007 12:34 Microsoft Corporation c:\program files\windows live\messenger\msnmsgr.exe wsock32 6.0.6000.16386 14,50 kB (14 848 byte) 02.11.2006 09:58 Microsoft Corporation c:\windows\system32\wsock32.dll msncore 8.5.1302.1018 991,02 kB (1 014 808 byte) 18.10.2007 12:32 Microsoft Corporation c:\program files\windows live\messenger\msncore.dll msidcrl40 4.100.313.1 791,33 kB (810 320 byte) 31.08.2006 21:33 Microsoft Corporation c:\program files\windows live\messenger\msidcrl40.dll contactsUX 8.5.1302.1018 331,52 kB (339 480 byte) 18.10.2007 12:32 Microsoft Corporation c:\program files\windows live\messenger\contactsux.dll cryptnet 6.0.6000.16386 91,00 kB (93 184 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\cryptnet.dll inetcomm 6.0.6000.16545 720,50 kB (737 792 byte) 07.02.2008 16:54 Microsoft Corporation c:\windows\system32\inetcomm.dll msoert2 6.0.6000.16480 85,00 kB (87 040 byte) 07.02.2008 16:56 Microsoft Corporation c:\windows\system32\msoert2.dll inetres 6.0.6000.16545 82,50 kB (84 480 byte) 07.02.2008 16:54 Microsoft Corporation c:\windows\system32\inetres.dll msgrvsta 8.5.1302.1018 145,52 kB (149 016 byte) 18.10.2007 12:32 Microsoft Corporation c:\program files\windows live\messenger\msgrvsta.thm msgslang.8.5.1302.1018 8.5.1302.1018 1,60 MB (1 679 896 byte) 18.10.2007 12:32 Microsoft Corporation c:\program files\windows live\messenger\msgslang.8.5.1302.1018.dll msgsres 8.5.1302.1018 2,38 MB (2 491 416 byte) 18.10.2007 12:33 Microsoft Corporation c:\program files\windows live\messenger\msgsres.dll lcapi 1.7.256.0 1,60 MB (1 678 600 byte) 02.10.2007 18:19 Microsoft Corporation c:\program files\windows live\messenger\lcapi.dll dsound 6.0.6000.16386 435,00 kB (445 440 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\dsound.dll msdmo 6.6.6000.16386 29,00 kB (29 696 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\msdmo.dll lcres 1.7.180.0 379,26 kB (388 360 byte) 02.10.2007 18:19 Microsoft Corporation c:\program files\windows live\messenger\lcres.dll rtmpltfm 3.0.5774.0 3,67 MB (3 851 024 byte) 02.10.2007 18:19 Microsoft Corporation c:\program files\windows live\messenger\rtmpltfm.dll msgswcam 8.5.1302.1018 654,02 kB (669 720 byte) 18.10.2007 12:32 Microsoft Corporation c:\program files\windows live\messenger\msgswcam.dll sirenacm 8.5.1302.1018 50,02 kB (51 224 byte) 18.10.2007 12:31 Microsoft Corporation c:\windows\system32\sirenacm.dll riched20 5.31.23.1227 456,50 kB (467 456 byte) 14.02.2008 15:38 Microsoft Corporation c:\windows\system32\riched20.dll lmcdata 8.5.1302.1018 472,02 kB (483 352 byte) 18.10.2007 12:32 Microsoft Corporation c:\program files\windows live\messenger\lmcdata.dll contact 8.5.1302.1018 185,02 kB (189 464 byte) 18.10.2007 12:32 Microsoft Corporation c:\program files\windows live\messenger\contact.dll custsat 9.0.3790.2428 39,87 kB (40 824 byte) 02.10.2007 18:12 Microsoft Corporation c:\program files\windows live\messenger\custsat.dll abssm 8.5.1302.1018 415,02 kB (424 984 byte) 18.10.2007 12:32 Microsoft Corporation c:\program files\windows live\messenger\abssm.dll wmvcore 11.0.6000.6324 2,32 MB (2 433 536 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\wmvcore.dll wmasf 11.0.6000.6345 218,00 kB (223 232 byte) 07.02.2008 16:54 Microsoft Corporation c:\windows\system32\wmasf.dll wmadmod 11.0.6000.6324 741,00 kB (758 784 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\wmadmod.dll mshtml 7.0.6000.16609 3,43 MB (3 592 192 byte) 13.02.2008 22:39 Microsoft Corporation c:\windows\system32\mshtml.dll msls31 3.10.349.0 152,50 kB (156 160 byte) 02.11.2006 09:38 Microsoft Corporation c:\windows\system32\msls31.dll pdm 7.0.9466.0 176,00 kB (180 224 byte) 05.01.2002 15:05 Microsoft Corporation c:\program files\common files\microsoft shared\vs7debug\pdm.dll msdbg2 7.0.9466.0 172,00 kB (176 128 byte) 05.01.2002 08:03 Microsoft Corporation c:\program files\common files\microsoft shared\vs7debug\msdbg2.dll msimtf 6.0.6000.16386 30,50 kB (31 232 byte) 02.11.2006 09:38 Microsoft Corporation c:\windows\system32\msimtf.dll jscript 5.7.0.6000 480,00 kB (491 520 byte) 02.11.2006 09:50 Microsoft Corporation c:\windows\system32\jscript.dll ddrawex 6.0.6000.16386 29,50 kB (30 208 byte) 02.11.2006 10:03 Microsoft Corporation c:\windows\system32\ddrawex.dll vbscript 5.7.0.6000 404,00 kB (413 696 byte) 02.11.2006 09:50 Microsoft Corporation c:\windows\system32\vbscript.dll jensenui 1.0.10.0 892,00 kB (913 408 byte) 07.02.2008 16:30 Jensen Scandinavia AS. c:\program files\jensen\common\jensenui.exe wlanui 6.0.6000.16386 195,00 kB (199 680 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\wlanui.dll mom 2.0.0.0 48,00 kB (49 152 byte) 01.06.2007 10:52 Ikke tilgjengelig c:\program files\ati technologies\ati.ace\core-static\mom.exe mscoree 2.0.50727.312 265,00 kB (271 360 byte) 02.11.2006 07:34 Microsoft Corporation c:\windows\system32\mscoree.dll mscorwks 2.0.50727.312 5,37 MB (5 632 512 byte) 02.11.2006 07:34 Microsoft Corporation c:\windows\microsoft.net\framework\v2.0.50727\mscorwks.dll mscorlib.ni 2.0.50727.312 11,09 MB (11 628 544 byte) 02.11.2006 13:55 Microsoft Corporation c:\windows\assembly\nativeimages_v2.0.50727_32\mscorlib\7fe79782947b85d961fd55cb5e02a129\mscorlib.ni.dll mscorjit 2.0.50727.312 319,00 kB (326 656 byte) 02.11.2006 07:34 Microsoft Corporation c:\windows\microsoft.net\framework\v2.0.50727\mscorjit.dll System.ni 2.0.50727.312 7,77 MB (8 151 040 byte) 02.11.2006 13:55 Microsoft Corporation c:\windows\assembly\nativeimages_v2.0.50727_32\system\fcc712bc5da45a672e7f1ad176dbd5a5\system.ni.dll System.Drawing.ni 2.0.50727.312 1,54 MB (1 617 920 byte) 02.11.2006 13:56 Microsoft Corporation c:\windows\assembly\nativeimages_v2.0.50727_32\system.drawing\70c145ed25af403aa899ffcb633350b1\system.drawing.ni.dll System.Windows.Forms.ni 2.0.50727.312 12,54 MB (13 148 160 byte) 02.11.2006 13:57 Microsoft Corporation c:\windows\assembly\nativeimages_v2.0.50727_32\system.windows.forms\35a9f19f21aac42b979be321f1bb5fd4\system.windows.forms.ni.dll MOM.Implementation 2.0.2768.38752 100,00 kB (102 400 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\mom.implementation\2.0.2768.38752__90ba9c70f846762e\mom.implementation.dll LOG.Foundation 2.0.2729.30174 32,00 kB (32 768 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\log.foundation\2.0.2729.30174__90ba9c70f846762e\log.foundation.dll LOG.Foundation.Private 2.0.2729.30188 32,00 kB (32 768 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\log.foundation.private\2.0.2729.30188__90ba9c70f846762e\log.foundation.private.dll LOG.Foundation.Implementation 2.0.2768.38750 60,00 kB (61 440 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\log.foundation.implementation\2.0.2768.38750__90ba9c70f846762e\log.foundation.implementation.dll MOM.Foundation 2.0.2729.30207 16,00 kB (16 384 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\mom.foundation\2.0.2729.30207__90ba9c70f846762e\mom.foundation.dll LOG.Foundation.Implementation.Private 2.0.2729.30211 20,00 kB (20 480 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\log.foundation.implementation.private\2.0.2729.30211__90ba9c70f846762e\log.foundation.implementation.private.dll System.Runtime.Remoting.ni 2.0.50727.312 796,00 kB (815 104 byte) 07.02.2008 17:04 Microsoft Corporation c:\windows\assembly\nativeimages_v2.0.50727_32\system.runtime.remo#\8fbca0140921ed343cb511595869a0ed\system.runtime.remoting.ni.dll System.Web.ni 2.0.50727.833 11,62 MB (12 185 600 byte) 07.02.2008 17:04 Microsoft Corporation c:\windows\assembly\nativeimages_v2.0.50727_32\system.web\c11c5eb32a435c14a33e62b1e150e988\system.web.ni.dll AEM.Server 2.0.2768.38458 44,00 kB (45 056 byte) 07.04.2008 14:32 Ikke tilgjengelig c:\windows\assembly\gac_msil\aem.server\2.0.2768.38458__90ba9c70f846762e\aem.server.dll NEWAEM.Foundation 2.0.2729.30184 24,00 kB (24 576 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\newaem.foundation\2.0.2729.30184__90ba9c70f846762e\newaem.foundation.dll ccc 2.0.0.0 48,00 kB (49 152 byte) 01.06.2007 10:52 Ikke tilgjengelig c:\program files\ati technologies\ati.ace\core-static\ccc.exe CCC.Implementation 2.0.2768.38751 32,00 kB (32 768 byte) 07.04.2008 14:32 Ikke tilgjengelig c:\windows\assembly\gac_msil\ccc.implementation\2.0.2768.38751__90ba9c70f846762e\ccc.implementation.dll CLI.Foundation 2.0.2729.30178 48,00 kB (49 152 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.foundation\2.0.2729.30178__90ba9c70f846762e\cli.foundation.dll CLI.Foundation.XManifest 2.0.2729.30313 28,00 kB (28 672 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.foundation.xmanifest\2.0.2729.30313__90ba9c70f846762e\cli.foundation.xmanifest.dll System.Xml.ni 2.0.50727.312 5,36 MB (5 619 712 byte) 02.11.2006 13:56 Microsoft Corporation c:\windows\assembly\nativeimages_v2.0.50727_32\system.xml\f76a7622c73e26e4d2daf54068d7ff79\system.xml.ni.dll mscorlib.resources 2.0.50727.312 284,00 kB (290 816 byte) 21.11.2006 06:13 Ikke tilgjengelig c:\windows\assembly\gac_msil\mscorlib.resources\2.0.0.0_no_b77a5c561934e089\mscorlib.resources.dll CLI.Component.Runtime 2.0.2768.38460 68,00 kB (69 632 byte) 07.04.2008 14:32 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.component.runtime\2.0.2768.38460__90ba9c70f846762e\cli.component.runtime.dll CLI.Component.Runtime.Shared.Private 2.0.2729.30209 40,00 kB (40 960 byte) 07.04.2008 14:32 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.component.runtime.shared.private\2.0.2729.30209__90ba9c70f846762e\cli.component.runtime.shared.private.dll CLI.Foundation.Private 2.0.2729.30193 40,00 kB (40 960 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.foundation.private\2.0.2729.30193__90ba9c70f846762e\cli.foundation.private.dll CLI.Component.Runtime.Shared 2.0.2729.30203 16,00 kB (16 384 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.component.runtime.shared\2.0.2729.30203__90ba9c70f846762e\cli.component.runtime.shared.dll aticccom 2.0.0.0 32,00 kB (32 768 byte) 07.04.2008 14:32 Ikke tilgjengelig c:\windows\assembly\gac_msil\aticccom\2.0.0.0__90ba9c70f846762e\aticccom.dll CLI.Component.Runtime.Extension.EEU 2.0.2768.38458 6,50 kB (6 656 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.component.runtime.extension.eeu\2.0.2768.38458__90ba9c70f846762e\cli.component.runtime.extension.eeu.dll AEM.Foundation 2.0.2729.30176 24,00 kB (24 576 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\aem.foundation\2.0.2729.30176__90ba9c70f846762e\aem.foundation.dll AEM.Server.Shared 2.0.2729.30201 16,00 kB (16 384 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\aem.server.shared\2.0.2729.30201__90ba9c70f846762e\aem.server.shared.dll AEM.Plugin.Source.Kit.Server 2.0.2768.38796 36,00 kB (36 864 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\aem.plugin.source.kit.server\2.0.2768.38796__90ba9c70f846762e\aem.plugin.source.kit.server.dll AEM.Plugin.DPPE.Shared 2.0.2729.30222 16,00 kB (16 384 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\aem.plugin.dppe.shared\2.0.2729.30222__90ba9c70f846762e\aem.plugin.dppe.shared.dll AEM.Plugin.Hotkeys.Shared 2.0.2729.30202 20,00 kB (20 480 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\aem.plugin.hotkeys.shared\2.0.2729.30202__90ba9c70f846762e\aem.plugin.hotkeys.shared.dll DEM.Graphics.I0601 2.0.2573.17685 44,00 kB (45 056 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\dem.graphics.i0601\2.0.2573.17685__90ba9c70f846762e\dem.graphics.i0601.dll DEM.Foundation 2.0.2573.17684 16,00 kB (16 384 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\dem.foundation\2.0.2573.17684__90ba9c70f846762e\dem.foundation.dll DEM.Graphics 2.0.2729.30256 16,00 kB (16 384 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\dem.graphics\2.0.2729.30256__90ba9c70f846762e\dem.graphics.dll atidemgx 2.0.2977.39911 364,00 kB (372 736 byte) 26.02.2008 04:10 Ikke tilgjengelig c:\windows\system32\atidemgx.dll AEM.Plugin.EEU.Shared 2.0.2729.30212 16,00 kB (16 384 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\aem.plugin.eeu.shared\2.0.2729.30212__90ba9c70f846762e\aem.plugin.eeu.shared.dll CLI.Caste.Graphics.Runtime 2.0.2768.38469 232,00 kB (237 568 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.caste.graphics.runtime\2.0.2768.38469__90ba9c70f846762e\cli.caste.graphics.runtime.dll CLI.Caste.Graphics.Shared 2.0.2729.30199 48,00 kB (49 152 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.caste.graphics.shared\2.0.2729.30199__90ba9c70f846762e\cli.caste.graphics.shared.dll ACE.Graphics.DisplaysManager.Shared 2.0.2573.17685 24,00 kB (24 576 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\ace.graphics.displaysmanager.shared\2.0.2573.17685__90ba9c70f846762e\ace.graphics.displaysmanager.shared.dll DEM.OS.I0602 2.0.2729.30259 20,00 kB (20 480 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\dem.os.i0602\2.0.2729.30259__90ba9c70f846762e\dem.os.i0602.dll AEM.Actions.CCAA.Shared 2.0.2729.30197 20,00 kB (20 480 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\aem.actions.ccaa.shared\2.0.2729.30197__90ba9c70f846762e\aem.actions.ccaa.shared.dll DEM.OS 2.0.2729.30242 16,00 kB (16 384 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\dem.os\2.0.2729.30242__90ba9c70f846762e\dem.os.dll atidemos 2.0.2768.38461 64,00 kB (65 536 byte) 07.04.2008 14:32 Ikke tilgjengelig c:\windows\assembly\gac_msil\atidemos\2.0.2768.38461__90ba9c70f846762e\atidemos.dll System.Management.ni 2.0.50727.312 1,01 MB (1 060 864 byte) 02.11.2006 14:08 Microsoft Corporation c:\windows\assembly\nativeimages_v2.0.50727_32\system.management\3fe3f7ba542ab78e52e49d19640a7e64\system.management.ni.dll wminet_utils 2.0.50727.312 27,50 kB (28 160 byte) 02.11.2006 07:34 Microsoft Corporation c:\windows\microsoft.net\framework\v2.0.50727\wminet_utils.dll CLI.Aspect.HotkeysHandling.Graphics.Runtime 2.0.2768.38488 20,00 kB (20 480 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.hotkeyshandling.graphics.runtime\2.0.2768.38488__90ba9c70f846762e\cli.aspect.hotkeyshandling.graphics.runtime.dll CLI.Aspect.HotkeysHandling.Graphics.Shared 2.0.2729.30216 20,00 kB (20 480 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.hotkeyshandling.graphics.shared\2.0.2729.30216__90ba9c70f846762e\cli.aspect.hotkeyshandling.graphics.shared.dll CLI.Aspect.DeviceCV.Graphics.Runtime 2.0.2768.38688 64,00 kB (65 536 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.devicecv.graphics.runtime\2.0.2768.38688__90ba9c70f846762e\cli.aspect.devicecv.graphics.runtime.dll CLI.Caste.Graphics.Runtime.Shared.Private 2.0.2729.30243 20,00 kB (20 480 byte) 07.04.2008 14:32 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.caste.graphics.runtime.shared.private\2.0.2729.30243__90ba9c70f846762e\cli.caste.graphics.runtime.shared.private.dll CLI.Aspect.DeviceCV.Graphics.Shared 2.0.2729.30230 40,00 kB (40 960 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.devicecv.graphics.shared\2.0.2729.30230__90ba9c70f846762e\cli.aspect.devicecv.graphics.shared.dll CLI.Aspect.DeviceProperty.Graphics.Runtime 2.0.2768.38625 32,00 kB (32 768 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.deviceproperty.graphics.runtime\2.0.2768.38625__90ba9c70f846762e\cli.aspect.deviceproperty.graphics.runtime.dll CLI.Aspect.CustomFormats.Graphics.Shared 2.0.2729.30212 24,00 kB (24 576 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.customformats.graphics.shared\2.0.2729.30212__90ba9c70f846762e\cli.aspect.customformats.graphics.shared.dll DEM.Graphics.I0703 2.0.2651.18802 20,00 kB (20 480 byte) 02.05.2007 17:44 Ikke tilgjengelig c:\program files\ati technologies\ati.ace\core-static\dem.graphics.i0703.dll CLI.Aspect.DeviceProperty.Graphics.Shared 2.0.2729.30213 32,00 kB (32 768 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.deviceproperty.graphics.shared\2.0.2729.30213__90ba9c70f846762e\cli.aspect.deviceproperty.graphics.shared.dll CLI.Aspect.DeviceTV.Graphics.Runtime 2.0.2768.38729 76,00 kB (77 824 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.devicetv.graphics.runtime\2.0.2768.38729__90ba9c70f846762e\cli.aspect.devicetv.graphics.runtime.dll CLI.Aspect.DeviceTV.Graphics.Shared 2.0.2729.30231 64,00 kB (65 536 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.devicetv.graphics.shared\2.0.2729.30231__90ba9c70f846762e\cli.aspect.devicetv.graphics.shared.dll AEM.Plugin.GD.Shared 2.0.2729.30224 16,00 kB (16 384 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\aem.plugin.gd.shared\2.0.2729.30224__90ba9c70f846762e\aem.plugin.gd.shared.dll CLI.Aspect.InfoCentre.Graphics.Runtime 2.0.2768.38523 32,00 kB (32 768 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.infocentre.graphics.runtime\2.0.2768.38523__90ba9c70f846762e\cli.aspect.infocentre.graphics.runtime.dll CLI.Aspect.InfoCentre.Graphics.Shared 2.0.2729.30219 52,00 kB (53 248 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.infocentre.graphics.shared\2.0.2729.30219__90ba9c70f846762e\cli.aspect.infocentre.graphics.shared.dll CLI.Aspect.DisplaysColour2.Graphics.Runtime 2.0.2768.38542 40,00 kB (40 960 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.displayscolour2.graphics.runtime\2.0.2768.38542__90ba9c70f846762e\cli.aspect.displayscolour2.graphics.runtime.dll CLI.Aspect.DisplaysColour2.Graphics.Shared 2.0.2729.30219 28,00 kB (28 672 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.displayscolour2.graphics.shared\2.0.2729.30219__90ba9c70f846762e\cli.aspect.displayscolour2.graphics.shared.dll CLI.Aspect.DisplaysOptions.Graphics.Runtime 2.0.2768.38653 32,00 kB (32 768 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.displaysoptions.graphics.runtime\2.0.2768.38653__90ba9c70f846762e\cli.aspect.displaysoptions.graphics.runtime.dll CLI.Aspect.DisplaysOptions.Graphics.Shared 2.0.2729.30228 24,00 kB (24 576 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.displaysoptions.graphics.shared\2.0.2729.30228__90ba9c70f846762e\cli.aspect.displaysoptions.graphics.shared.dll CLI.Aspect.DeviceCRT.Graphics.Runtime 2.0.2768.38632 40,00 kB (40 960 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.devicecrt.graphics.runtime\2.0.2768.38632__90ba9c70f846762e\cli.aspect.devicecrt.graphics.runtime.dll CLI.Aspect.DeviceCRT.Graphics.Shared 2.0.2729.30226 52,00 kB (53 248 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.devicecrt.graphics.shared\2.0.2729.30226__90ba9c70f846762e\cli.aspect.devicecrt.graphics.shared.dll CLI.Aspect.DeviceLCD.Graphics.Runtime 2.0.2768.38674 32,00 kB (32 768 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.devicelcd.graphics.runtime\2.0.2768.38674__90ba9c70f846762e\cli.aspect.devicelcd.graphics.runtime.dll CLI.Aspect.DeviceLCD.Graphics.Shared 2.0.2729.30259 28,00 kB (28 672 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.devicelcd.graphics.shared\2.0.2729.30259__90ba9c70f846762e\cli.aspect.devicelcd.graphics.shared.dll CLI.Aspect.DeviceDFP.Graphics.Runtime 2.0.2768.38625 56,00 kB (57 344 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.devicedfp.graphics.runtime\2.0.2768.38625__90ba9c70f846762e\cli.aspect.devicedfp.graphics.runtime.dll CLI.Aspect.DeviceDFP.Graphics.Shared 2.0.2729.30225 40,00 kB (40 960 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.devicedfp.graphics.shared\2.0.2729.30225__90ba9c70f846762e\cli.aspect.devicedfp.graphics.shared.dll CLI.Aspect.OverDrive5.Graphics.Runtime 2.0.2768.38810 64,00 kB (65 536 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.overdrive5.graphics.runtime\2.0.2768.38810__90ba9c70f846762e\cli.aspect.overdrive5.graphics.runtime.dll CLI.Aspect.OverDrive5.Graphics.Shared 2.0.2729.30255 56,00 kB (57 344 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.overdrive5.graphics.shared\2.0.2729.30255__90ba9c70f846762e\cli.aspect.overdrive5.graphics.shared.dll CLI.Aspect.Radeon3D.Graphics.Runtime 2.0.2768.38695 60,00 kB (61 440 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.radeon3d.graphics.runtime\2.0.2768.38695__90ba9c70f846762e\cli.aspect.radeon3d.graphics.runtime.dll CLI.Aspect.Radeon3D.Graphics.Shared 2.0.2729.30231 48,00 kB (49 152 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.radeon3d.graphics.shared\2.0.2729.30231__90ba9c70f846762e\cli.aspect.radeon3d.graphics.shared.dll CLI.Aspect.MMVideo.Graphics.Runtime 2.0.2768.38632 64,00 kB (65 536 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.mmvideo.graphics.runtime\2.0.2768.38632__90ba9c70f846762e\cli.aspect.mmvideo.graphics.runtime.dll CLI.Aspect.MMVideo.Graphics.Shared 2.0.2729.30227 44,00 kB (45 056 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.mmvideo.graphics.shared\2.0.2729.30227__90ba9c70f846762e\cli.aspect.mmvideo.graphics.shared.dll CLI.Aspect.PowerPlayDPPE.Graphics.Runtime 2.0.2768.38760 40,00 kB (40 960 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.powerplaydppe.graphics.runtime\2.0.2768.38760__90ba9c70f846762e\cli.aspect.powerplaydppe.graphics.runtime.dll CLI.Aspect.PowerPlayDPPE.Graphics.Shared 2.0.2729.30262 24,00 kB (24 576 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.powerplaydppe.graphics.shared\2.0.2729.30262__90ba9c70f846762e\cli.aspect.powerplaydppe.graphics.shared.dll APM.Server 2.0.2768.38460 44,00 kB (45 056 byte) 07.04.2008 14:32 Ikke tilgjengelig c:\windows\assembly\gac_msil\apm.server\2.0.2768.38460__90ba9c70f846762e\apm.server.dll APM.Foundation 2.0.2729.30208 20,00 kB (20 480 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\apm.foundation\2.0.2729.30208__90ba9c70f846762e\apm.foundation.dll System.Configuration.ni 2.0.50727.312 980,00 kB (1 003 520 byte) 02.11.2006 13:56 Microsoft Corporation c:\windows\assembly\nativeimages_v2.0.50727_32\system.configuration\d7b63c1d2ab17ac3cc24881c4ff78b63\system.configuration.ni.dll System.Windows.Forms.resources 2.0.50727.312 392,00 kB (401 408 byte) 21.11.2006 06:13 Ikke tilgjengelig c:\windows\assembly\gac_msil\system.windows.forms.resources\2.0.0.0_no_b77a5c561934e089\system.windows.forms.resources.dll CLI.Component.Systemtray 2.0.2768.38744 436,00 kB (446 464 byte) 07.04.2008 14:32 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.component.systemtray\2.0.2768.38744__90ba9c70f846762e\cli.component.systemtray.dll CLI.Component.Client.Shared.Private 2.0.2729.30205 40,00 kB (40 960 byte) 07.04.2008 14:32 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.component.client.shared.private\2.0.2729.30205__90ba9c70f846762e\cli.component.client.shared.private.dll CLI.Component.Wizard 2.0.2768.38497 460,00 kB (471 040 byte) 07.04.2008 14:32 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.component.wizard\2.0.2768.38497__90ba9c70f846762e\cli.component.wizard.dll CLI.Component.Client.Shared 2.0.2729.30185 20,00 kB (20 480 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.component.client.shared\2.0.2729.30185__90ba9c70f846762e\cli.component.client.shared.dll CLI.Component.Wizard.Shared 2.0.2729.30211 20,00 kB (20 480 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.component.wizard.shared\2.0.2729.30211__90ba9c70f846762e\cli.component.wizard.shared.dll CLI.Component.Wizard.Shared.Private 2.0.2729.30258 24,00 kB (24 576 byte) 07.04.2008 14:32 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.component.wizard.shared.private\2.0.2729.30258__90ba9c70f846762e\cli.component.wizard.shared.private.dll CLI.Caste.Graphics.Wizard 2.0.2768.38502 40,00 kB (40 960 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.caste.graphics.wizard\2.0.2768.38502__90ba9c70f846762e\cli.caste.graphics.wizard.dll CLI.Caste.Graphics.Wizard.Shared 2.0.2729.30216 16,00 kB (16 384 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.caste.graphics.wizard.shared\2.0.2729.30216__90ba9c70f846762e\cli.caste.graphics.wizard.shared.dll CLI.Aspect.TransCode.Graphics.Wizard 2.0.2768.38767 472,00 kB (483 328 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.transcode.graphics.wizard\2.0.2768.38767__90ba9c70f846762e\cli.aspect.transcode.graphics.wizard.dll CLI.Aspect.Radeon3D.Graphics.Wizard 2.0.2768.38701 88,00 kB (90 112 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.radeon3d.graphics.wizard\2.0.2768.38701__90ba9c70f846762e\cli.aspect.radeon3d.graphics.wizard.dll CLI.Aspect.DisplaysManager.Graphics.Wizard 2.0.2768.38511 1,60 MB (1 675 264 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.displaysmanager.graphics.wizard\2.0.2768.38511__90ba9c70f846762e\cli.aspect.displaysmanager.graphics.wizard.dll CLI.Aspect.TransCode.Graphics.Shared 2.0.2729.30264 40,00 kB (40 960 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.transcode.graphics.shared\2.0.2729.30264__90ba9c70f846762e\cli.aspect.transcode.graphics.shared.dll atixclib 1.0.0.0 6,50 kB (6 656 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\atixclib\1.0.0.0__90ba9c70f846762e\atixclib.dll CLI.Aspect.MMVideo.Graphics.Wizard 2.0.2768.38715 392,00 kB (401 408 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.mmvideo.graphics.wizard\2.0.2768.38715__90ba9c70f846762e\cli.aspect.mmvideo.graphics.wizard.dll CLI.Aspect.InfoCentre.Graphics.Wizard 2.0.2768.38524 180,00 kB (184 320 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.infocentre.graphics.wizard\2.0.2768.38524__90ba9c70f846762e\cli.aspect.infocentre.graphics.wizard.dll CLI.Aspect.DeviceTV.Graphics.Wizard 2.0.2768.38737 352,00 kB (360 448 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.devicetv.graphics.wizard\2.0.2768.38737__90ba9c70f846762e\cli.aspect.devicetv.graphics.wizard.dll CLI.Aspect.DeviceCV.Graphics.Wizard 2.0.2768.38708 668,00 kB (684 032 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.devicecv.graphics.wizard\2.0.2768.38708__90ba9c70f846762e\cli.aspect.devicecv.graphics.wizard.dll CLI.Component.Dashboard 2.0.2768.38477 1,44 MB (1 507 328 byte) 07.04.2008 14:32 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.component.dashboard\2.0.2768.38477__90ba9c70f846762e\cli.component.dashboard.dll CLI.Component.Dashboard.Shared 2.0.2729.30199 20,00 kB (20 480 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.component.dashboard.shared\2.0.2729.30199__90ba9c70f846762e\cli.component.dashboard.shared.dll CLI.Component.Dashboard.Shared.Private 2.0.2729.30214 20,00 kB (20 480 byte) 07.04.2008 14:32 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.component.dashboard.shared.private\2.0.2729.30214__90ba9c70f846762e\cli.component.dashboard.shared.private.dll CLI.Caste.Graphics.Dashboard 2.0.2768.38482 72,00 kB (73 728 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.caste.graphics.dashboard\2.0.2768.38482__90ba9c70f846762e\cli.caste.graphics.dashboard.dll CLI.Caste.Graphics.Dashboard.Shared 2.0.2729.30241 16,00 kB (16 384 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.caste.graphics.dashboard.shared\2.0.2729.30241__90ba9c70f846762e\cli.caste.graphics.dashboard.shared.dll CLI.Aspect.Welcome.Graphics.Dashboard 2.0.2768.38773 132,00 kB (135 168 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.welcome.graphics.dashboard\2.0.2768.38773__90ba9c70f846762e\cli.aspect.welcome.graphics.dashboard.dll CLI.Aspect.DisplaysManager.Graphics.Dashboard 2.0.2768.38489 428,00 kB (438 272 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.displaysmanager.graphics.dashboard\2.0.2768.38489__90ba9c70f846762e\cli.aspect.displaysmanager.graphics.dashboard.dll CLI.Aspect.InfoCentre.Graphics.Dashboard 2.0.2768.38530 204,00 kB (208 896 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.infocentre.graphics.dashboard\2.0.2768.38530__90ba9c70f846762e\cli.aspect.infocentre.graphics.dashboard.dll CLI.Aspect.DisplaysOptions.Graphics.Dashboard 2.0.2768.38654 116,00 kB (118 784 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.displaysoptions.graphics.dashboard\2.0.2768.38654__90ba9c70f846762e\cli.aspect.displaysoptions.graphics.dashboard.dll CLI.Aspect.DeviceCRT.Graphics.Dashboard 2.0.2768.38626 464,00 kB (475 136 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.devicecrt.graphics.dashboard\2.0.2768.38626__90ba9c70f846762e\cli.aspect.devicecrt.graphics.dashboard.dll CLI.Aspect.DeviceCV.Graphics.Dashboard 2.0.2768.38689 644,00 kB (659 456 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.devicecv.graphics.dashboard\2.0.2768.38689__90ba9c70f846762e\cli.aspect.devicecv.graphics.dashboard.dll CLI.Aspect.DeviceTV.Graphics.Dashboard 2.0.2768.38730 876,00 kB (897 024 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.devicetv.graphics.dashboard\2.0.2768.38730__90ba9c70f846762e\cli.aspect.devicetv.graphics.dashboard.dll CLI.Aspect.DeviceDFP.Graphics.Dashboard 2.0.2768.38619 320,00 kB (327 680 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.devicedfp.graphics.dashboard\2.0.2768.38619__90ba9c70f846762e\cli.aspect.devicedfp.graphics.dashboard.dll CLI.Aspect.Radeon3D.Graphics.Dashboard 2.0.2768.38696 324,00 kB (331 776 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.radeon3d.graphics.dashboard\2.0.2768.38696__90ba9c70f846762e\cli.aspect.radeon3d.graphics.dashboard.dll CLI.Aspect.DisplaysColour2.Graphics.Dashboard 2.0.2768.38536 576,00 kB (589 824 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.displayscolour2.graphics.dashboard\2.0.2768.38536__90ba9c70f846762e\cli.aspect.displayscolour2.graphics.dashboard.dll CLI.Aspect.MMVideo.Graphics.Dashboard 2.0.2768.38633 772,00 kB (790 528 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.mmvideo.graphics.dashboard\2.0.2768.38633__90ba9c70f846762e\cli.aspect.mmvideo.graphics.dashboard.dll CLI.Aspect.OverDrive5.Graphics.Dashboard 2.0.2768.38810 416,00 kB (425 984 byte) 07.04.2008 14:33 Ikke tilgjengelig c:\windows\assembly\gac_msil\cli.aspect.overdrive5.graphics.dashboard\2.0.2768.38810__90ba9c70f846762e\cli.aspect.overdrive5.graphics.dashboard.dll mdm 7.0.9466.0 314,57 kB (322 120 byte) 20.06.2003 00:25 Microsoft Corporation c:\program files\common files\microsoft shared\vs7debug\mdm.exe ipsecsvc 6.0.6000.16386 353,50 kB (361 984 byte) 02.11.2006 09:56 Microsoft Corporation c:\windows\system32\ipsecsvc.dll fwremotesvr 6.0.6000.16386 28,00 kB (28 672 byte) 02.11.2006 09:56 Microsoft Corporation c:\windows\system32\fwremotesvr.dll wiaservc 6.0.6000.16386 441,00 kB (451 584 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\wiaservc.dll wiatrace 6.0.6000.16386 12,50 kB (12 800 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\wiatrace.dll wsdchngr 6.0.6000.16386 20,50 kB (20 992 byte) 02.11.2006 10:16 Microsoft Corporation c:\windows\system32\wsdchngr.dll wersvc 6.0.6000.16386 124,50 kB (127 488 byte) 02.11.2006 09:40 Microsoft Corporation c:\windows\system32\wersvc.dll wer 6.0.6000.16386 869,00 kB (889 856 byte) 02.11.2006 09:40 Microsoft Corporation c:\windows\system32\wer.dll searchindexer 6.0.6000.16386 281,00 kB (287 744 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\searchindexer.exe tquery 6.0.6000.16386 1,43 MB (1 499 136 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\tquery.dll query 6.0.6000.16386 1,32 MB (1 380 864 byte) 02.11.2006 10:11 Microsoft Corporation c:\windows\system32\query.dll msstrc 6.0.6000.16386 51,00 kB (52 224 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\msstrc.dll mssrch 6.0.6000.16386 1,33 MB (1 398 272 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\mssrch.dll msidle 6.0.6000.16386 8,50 kB (8 704 byte) 02.11.2006 09:46 Microsoft Corporation c:\windows\system32\msidle.dll propdefs 6.0.6000.16386 64,00 kB (65 536 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\propdefs.dll msscb 6.0.6000.16386 23,00 kB (23 552 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\msscb.dll wudfhost 6.0.6000.16386 140,00 kB (143 360 byte) 02.11.2006 09:54 Microsoft Corporation c:\windows\system32\wudfhost.exe wudfx 6.0.6000.16386 302,50 kB (309 760 byte) 02.11.2006 09:54 Microsoft Corporation c:\windows\system32\wudfx.dll wpdfs 6.0.6000.16386 214,50 kB (219 648 byte) 02.11.2006 11:25 Microsoft Corporation c:\windows\system32\drivers\umdf\wpdfs.dll portabledeviceclassextension 6.0.6000.16386 93,00 kB (95 232 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\portabledeviceclassextension.dll FNPLicensingService 11.3.5.1 639,50 kB (654 848 byte) 08.02.2008 16:16 Macrovision Europe Ltd. c:\program files\common files\macrovision shared\flexnet publisher\fnplicensingservice.exe wmpnetwk 11.0.6000.6324 874,50 kB (895 488 byte) 02.11.2006 13:36 Microsoft Corporation c:\program files\windows media player\wmpnetwk.exe wmpmde 11.0.6000.6324 1,24 MB (1 304 576 byte) 02.11.2006 13:36 Microsoft Corporation c:\windows\system32\wmpmde.dll mf 11.0.6000.6324 2,72 MB (2 855 424 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\mf.dll evr 5.0.1.1 463,00 kB (474 112 byte) 02.11.2006 10:04 Microsoft Corporation c:\windows\system32\evr.dll wmdrmsdk 11.0.6000.6324 517,50 kB (529 920 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\wmdrmsdk.dll wmp 11.0.6000.6344 10,13 MB (10 617 344 byte) 14.02.2008 17:06 Microsoft Corporation c:\windows\system32\wmp.dll wmploc 11.0.6000.6344 7,77 MB (8 147 968 byte) 14.02.2008 17:06 Microsoft Corporation c:\windows\system32\wmploc.dll thumbcache 6.0.6000.16386 63,50 kB (65 024 byte) 02.11.2006 09:47 Microsoft Corporation c:\windows\system32\thumbcache.dll wmpps 11.0.6000.6324 128,00 kB (131 072 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\wmpps.dll wmdrmdev 11.0.6000.6324 408,50 kB (418 304 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\wmdrmdev.dll drmv2clt 11.0.6000.6324 955,50 kB (978 432 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\drmv2clt.dll blackbox 11.0.6000.6324 530,00 kB (542 720 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\blackbox.dll wmdrmnet 11.0.6000.6324 339,50 kB (347 648 byte) 02.11.2006 13:35 Microsoft Corporation c:\windows\system32\wmdrmnet.dll wmpnscfg 11.0.6000.6324 197,00 kB (201 728 byte) 02.11.2006 13:36 Microsoft Corporation c:\program files\windows media player\wmpnscfg.exe wmpnssci 11.0.6000.6324 190,00 kB (194 560 byte) 02.11.2006 13:36 Microsoft Corporation c:\program files\windows media player\wmpnssci.dll prime95 24.14.1.0 4,13 MB (4 333 568 byte) 07.04.2008 15:16 Ikke tilgjengelig c:\users\tanz\downloads\p95v2414\prime95.exe firefox 1.8.20080.31114 7,31 MB (7 660 656 byte) 07.02.2008 18:20 Mozilla Corporation c:\program files\mozilla firefox\firefox.exe js3250 4.0.0.0 448,10 kB (458 856 byte) 07.02.2008 18:20 Netscape Communications Corporation c:\program files\mozilla firefox\js3250.dll nspr4 4.6.8.0 157,61 kB (161 392 byte) 07.02.2008 18:20 Netscape Communications Corporation c:\program files\mozilla firefox\nspr4.dll xpcom_core 1.8.20080.31114 412,11 kB (422 000 byte) 07.02.2008 18:20 Mozilla Foundation c:\program files\mozilla firefox\xpcom_core.dll plc4 4.6.8.0 33,62 kB (34 424 byte) 07.02.2008 18:20 Netscape Communications Corporation c:\program files\mozilla firefox\plc4.dll plds4 4.6.8.0 29,61 kB (30 320 byte) 07.02.2008 18:20 Netscape Communications Corporation c:\program files\mozilla firefox\plds4.dll smime3 3.11.5.0 109,60 kB (112 232 byte) 07.02.2008 18:20 Mozilla Foundation c:\program files\mozilla firefox\smime3.dll nss3 3.11.5.0 369,60 kB (378 472 byte) 07.02.2008 18:20 Mozilla Foundation c:\program files\mozilla firefox\nss3.dll softokn3 3.11.4.0 248,11 kB (254 060 byte) 07.02.2008 18:20 Mozilla Foundation c:\program files\mozilla firefox\softokn3.dll ssl3 3.11.5.0 129,60 kB (132 712 byte) 07.02.2008 18:20 Mozilla Foundation c:\program files\mozilla firefox\ssl3.dll xpcom_compat 1.8.20080.31114 72,12 kB (73 848 byte) 07.02.2008 18:20 Mozilla Foundation c:\program files\mozilla firefox\xpcom_compat.dll myspell 1.8.20080.31114 34,13 kB (34 952 byte) 07.02.2008 18:20 Mozilla Foundation c:\program files\mozilla firefox\components\myspell.dll jar50 1.8.20080.31114 66,11 kB (67 696 byte) 07.02.2008 18:20 Mozilla Foundation c:\program files\mozilla firefox\components\jar50.dll freebl3 3.11.4.0 196,12 kB (200 829 byte) 07.02.2008 18:20 Mozilla Foundation c:\program files\mozilla firefox\freebl3.dll nssckbi 1.65.0.0 269,61 kB (276 080 byte) 07.02.2008 18:20 Mozilla Foundation c:\program files\mozilla firefox\nssckbi.dll spellchk 1.8.20080.31114 45,63 kB (46 720 byte) 07.02.2008 18:20 Mozilla Foundation c:\program files\mozilla firefox\components\spellchk.dll npswf32 9.0.115.0 2,75 MB (2 884 992 byte) 21.11.2007 01:52 Adobe Systems, Inc. c:\windows\system32\macromed\flash\npswf32.dll SwSupport 10.3.0.24 52,00 kB (53 248 byte) 07.02.2008 20:01 Adobe Systems, Inc. c:\windows\system32\macromed\common\swsupport.dll wmiprvse 6.0.6000.16386 239,50 kB (245 248 byte) 02.11.2006 09:41 Microsoft Corporation c:\windows\system32\wbem\wmiprvse.exe cimwin32 6.0.6000.16386 1,30 MB (1 362 944 byte) 02.11.2006 09:42 Microsoft Corporation c:\windows\system32\wbem\cimwin32.dll framedynos 6.0.6000.16386 199,50 kB (204 288 byte) 02.11.2006 09:42 Microsoft Corporation c:\windows\system32\wbem\framedynos.dll perfos 6.0.6000.16386 28,00 kB (28 672 byte) 02.11.2006 09:35 Microsoft Corporation c:\windows\system32\perfos.dll dskquota 6.0.6000.16386 84,50 kB (86 528 byte) 02.11.2006 09:48 Microsoft Corporation c:\windows\system32\dskquota.dll ntevt 6.0.6000.16386 168,50 kB (172 544 byte) 02.11.2006 09:41 Microsoft Corporation c:\windows\system32\wbem\ntevt.dll provthrd 6.0.6000.16386 187,00 kB (191 488 byte) 02.11.2006 09:41 Microsoft Corporation c:\windows\system32\wbem\provthrd.dll msvcirt 7.0.6000.16386 57,00 kB (58 368 byte) 02.11.2006 09:29 Microsoft Corporation c:\windows\system32\msvcirt.dll security 6.0.6000.16386 5,00 kB (5 120 byte) 02.11.2006 09:43 Microsoft Corporation c:\windows\system32\security.dll msonpui 0.3.4518.1014 65,83 kB (67 408 byte) 07.02.2008 21:40 Microsoft Corporation c:\windows\system32\spool\drivers\w32x86\3\msonpui.dll unidrvui 0.3.6000.16386 723,50 kB (740 864 byte) 02.11.2006 11:25 Microsoft Corporation c:\windows\system32\spool\drivers\w32x86\3\unidrvui.dll ps5ui 0.3.6000.16386 711,50 kB (728 576 byte) 02.11.2006 11:25 Microsoft Corporation c:\windows\system32\spool\drivers\w32x86\3\ps5ui.dll signdrv 6.0.6000.16386 41,00 kB (41 984 byte) 02.11.2006 09:35 Microsoft Corporation c:\windows\system32\signdrv.dll mfc42u 6.6.8063.0 1,11 MB (1 162 752 byte) 02.11.2006 10:14 Microsoft Corporation c:\windows\system32\mfc42u.dll odbc32 6.0.6000.16386 400,00 kB (409 600 byte) 02.11.2006 10:11 Microsoft Corporation c:\windows\system32\odbc32.dll odbcint 6.0.6000.16386 224,00 kB (229 376 byte) 02.11.2006 09:11 Microsoft Corporation c:\windows\system32\odbcint.dll riched32 6.0.6000.16517 8,00 kB (8 192 byte) 14.02.2008 15:38 Microsoft Corporation c:\windows\system32\riched32.dll ntlanman 6.0.6000.16386 60,00 kB (61 440 byte) 02.11.2006 09:42 Microsoft Corporation c:\windows\system32\ntlanman.dll drprov 6.0.6000.16386 17,50 kB (17 920 byte) 02.11.2006 10:02 Microsoft Corporation c:\windows\system32\drprov.dll davclnt 6.0.6000.16386 47,50 kB (48 640 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\davclnt.dll searchprotocolhost 6.0.6000.16386 199,50 kB (204 288 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\searchprotocolhost.exe mssph 6.0.6000.16386 323,50 kB (331 264 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\mssph.dll mapi32 1.0.2536.0 65,00 kB (66 560 byte) 02.11.2006 10:11 Microsoft Corporation c:\windows\system32\mapi32.dll mssvp 6.0.6000.16386 1,62 MB (1 695 232 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\mssvp.dll onfilter 12.0.4518.1014 70,80 kB (72 504 byte) 26.10.2006 21:24 Microsoft Corporation c:\progra~1\micros~2\office12\onfilter.dll mediametadatahandler 6.0.6000.16557 348,50 kB (356 864 byte) 14.02.2008 17:06 Microsoft Corporation c:\windows\system32\mediametadatahandler.dll wab32 6.0.6000.16480 690,50 kB (707 072 byte) 07.02.2008 16:56 Microsoft Corporation c:\program files\common files\system\wab32.dll cryptdlg 6.0.6000.16386 24,00 kB (24 576 byte) 02.11.2006 09:48 Microsoft Corporation c:\windows\system32\cryptdlg.dll wab32res 6.0.6000.16480 1,05 MB (1 098 752 byte) 07.02.2008 16:56 Microsoft Corporation c:\program files\common files\system\wab32res.dll searchfilterhost 6.0.6000.16386 74,50 kB (76 288 byte) 02.11.2006 13:34 Microsoft Corporation c:\windows\system32\searchfilterhost.exe msinfo32 6.0.6000.16386 398,00 kB (407 552 byte) 02.11.2006 09:35 Microsoft Corporation c:\windows\system32\msinfo32.exe tiptsf 6.0.6000.16386 371,00 kB (379 904 byte) 02.11.2006 13:35 Microsoft Corporation c:\program files\common files\microsoft shared\ink\tiptsf.dll wmiperfclass 6.0.6000.16386 88,50 kB (90 624 byte) 02.11.2006 09:35 Microsoft Corporation c:\windows\system32\wbem\wmiperfclass.dll pdh 6.0.6000.16386 237,00 kB (242 688 byte) 02.11.2006 09:35 Microsoft Corporation c:\windows\system32\pdh.dll [Tjenester] Visningsnavn Navn Tilstand Startmodus Tjenestetype Bane Feilkontroll Startnavn Tagg-ID Adobe Version Cue CS3 Adobe Version Cue CS3 Stopped Manual Own Process "c:\program files\common files\adobe\adobe version cue cs3\server\bin\versioncuecs3.exe" -win32service Normal NT AUTHORITY\LocalService 0 Application Experience AeLookupSvc Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Normal localSystem 0 Application Layer Gateway Service ALG Stopped Manual Own Process c:\windows\system32\alg.exe Normal NT AUTHORITY\LocalService 0 Application Information Appinfo Stopped Manual Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 Ati External Event Utility Ati External Event Utility Running Auto Own Process c:\windows\system32\ati2evxx.exe Normal LocalSystem 0 Windows Audio Endpoint Builder AudioEndpointBuilder Running Auto Share Process c:\windows\system32\svchost.exe -k localsystemnetworkrestricted Normal LocalSystem 0 Windows Audio Audiosrv Running Auto Share Process c:\windows\system32\svchost.exe -k localservicenetworkrestricted Normal NT AUTHORITY\LocalService 0 Base Filtering Engine BFE Running Auto Share Process c:\windows\system32\svchost.exe -k localservicenonetwork Normal NT AUTHORITY\LocalService 0 Background Intelligent Transfer Service BITS Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 Bonjour-tjeneste Bonjour Service Stopped Auto Own Process "c:\program files\bonjour\mdnsresponder.exe" Normal LocalSystem 0 Computer Browser Browser Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 Certificate Propagation CertPropSvc Stopped Manual Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 Microsoft .NET Framework NGEN v2.0.50727_X86 clr_optimization_v2.0.50727_32 Stopped Manual Own Process c:\windows\microsoft.net\framework\v2.0.50727\mscorsvw.exe Ignore LocalSystem 0 COM+ System Application COMSysApp Stopped Manual Own Process c:\windows\system32\dllhost.exe /processid:{02d4b3f1-fd88-11d1-960d-00805fc79235} Normal LocalSystem 0 Cryptographic Services CryptSvc Running Auto Share Process c:\windows\system32\svchost.exe -k networkservice Normal NT Authority\NetworkService 0 DCOM Server Process Launcher DcomLaunch Running Auto Share Process c:\windows\system32\svchost.exe -k dcomlaunch Normal LocalSystem 0 DFS Replication DFSR Stopped Manual Own Process c:\windows\system32\dfsr.exe Normal LocalSystem 0 DHCP Client Dhcp Running Auto Share Process c:\windows\system32\svchost.exe -k localservicenetworkrestricted Normal NT Authority\LocalService 0 DNS Client Dnscache Running Auto Share Process c:\windows\system32\svchost.exe -k networkservice Normal NT AUTHORITY\NetworkService 0 Wired AutoConfig dot3svc Stopped Manual Share Process c:\windows\system32\svchost.exe -k localsystemnetworkrestricted Normal localSystem 0 Diagnostic Policy Service DPS Running Auto Share Process c:\windows\system32\svchost.exe -k localservicenonetwork Normal NT AUTHORITY\LocalService 0 Extensible Authentication Protocol EapHost Running Manual Share Process c:\windows\system32\svchost.exe -k netsvcs Normal localSystem 0 Windows Media Center Receiver Service ehRecvr Stopped Manual Own Process c:\windows\ehome\ehrecvr.exe Ignore NT AUTHORITY\networkService 0 Windows Media Center Scheduler Service ehSched Stopped Manual Own Process c:\windows\ehome\ehsched.exe Ignore NT AUTHORITY\networkService 0 Windows Media Center Service Launcher ehstart Stopped Auto Share Process c:\windows\system32\svchost.exe -k localservicenonetwork Ignore NT AUTHORITY\LocalService 0 ReadyBoost EMDMgmt Running Auto Share Process c:\windows\system32\svchost.exe -k localsystemnetworkrestricted Ignore LocalSystem 0 Windows Event Log Eventlog Running Auto Share Process c:\windows\system32\svchost.exe -k localservicenetworkrestricted Normal NT AUTHORITY\LocalService 0 COM+ Event System EventSystem Running Auto Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 Function Discovery Provider Host fdPHost Running Manual Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 Function Discovery Resource Publication FDResPub Running Auto Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 FLEXnet Licensing Service FLEXnet Licensing Service Running Manual Own Process "c:\program files\common files\macrovision shared\flexnet publisher\fnplicensingservice.exe" Normal LocalSystem 0 Windows Presentation Foundation Font Cache 3.0.0.0 FontCache3.0.0.0 Stopped Manual Own Process c:\windows\microsoft.net\framework\v3.0\wpf\presentationfontcache.exe Normal NT Authority\LocalService 0 Group Policy Client gpsvc Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 Human Interface Device Access hidserv Stopped Manual Share Process c:\windows\system32\svchost.exe -k localsystemnetworkrestricted Normal LocalSystem 0 Health Key and Certificate Management hkmsvc Stopped Manual Share Process c:\windows\system32\svchost.exe -k netsvcs Normal localSystem 0 InstallDriver Table Manager IDriverT Stopped Manual Own Process "c:\program files\roxio\roxio mydvd de\installshield\driver\1050\intel 32\idrivert.exe" Ignore LocalSystem 0 Windows CardSpace idsvc Stopped Manual Share Process "c:\windows\microsoft.net\framework\v3.0\windows communication foundation\infocard.exe" Normal LocalSystem 0 IKE and AuthIP IPsec Keying Modules IKEEXT Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 PnP-X IP Bus Enumerator IPBusEnum Stopped Manual Share Process c:\windows\system32\svchost.exe -k localsystemnetworkrestricted Normal LocalSystem 0 IP Helper iphlpsvc Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 CNG Key Isolation KeyIso Running Manual Share Process c:\windows\system32\lsass.exe Normal LocalSystem 0 KtmRm for Distributed Transaction Coordinator KtmRm Running Auto Share Process c:\windows\system32\svchost.exe -k networkservice Normal NT AUTHORITY\NetworkService 0 Server LanmanServer Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 Workstation LanmanWorkstation Running Auto Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 Link-Layer Topology Discovery Mapper lltdsvc Stopped Manual Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 TCP/IP NetBIOS Helper lmhosts Running Auto Share Process c:\windows\system32\svchost.exe -k localservicenetworkrestricted Normal NT AUTHORITY\LocalService 0 Windows Media Center Extender Service Mcx2Svc Stopped Disabled Share Process c:\windows\system32\svchost.exe -k localservice Normal NT Authority\LocalService 0 Machine Debug Manager MDM Running Auto Own Process "c:\program files\common files\microsoft shared\vs7debug\mdm.exe" Normal LocalSystem 0 Multimedia Class Scheduler MMCSS Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 Windows Firewall MpsSvc Running Auto Share Process c:\windows\system32\svchost.exe -k localservicenonetwork Normal NT Authority\LocalService 0 Distributed Transaction Coordinator MSDTC Stopped Manual Own Process c:\windows\system32\msdtc.exe Normal NT AUTHORITY\NetworkService 0 Microsoft iSCSI Initiator Service MSiSCSI Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 Windows Installer msiserver Stopped Manual Own Process c:\windows\system32\msiexec /v Normal LocalSystem 0 Network Access Protection Agent napagent Stopped Manual Share Process c:\windows\system32\svchost.exe -k networkservice Normal NT AUTHORITY\NetworkService 0 Netlogon Netlogon Stopped Manual Share Process c:\windows\system32\lsass.exe Normal LocalSystem 0 Network Connections Netman Running Manual Share Process c:\windows\system32\svchost.exe -k localsystemnetworkrestricted Normal LocalSystem 0 Network List Service netprofm Running Auto Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 Tjenesten Net.Tcp Port Sharing NetTcpPortSharing Stopped Disabled Share Process "c:\windows\microsoft.net\framework\v3.0\windows communication foundation\smsvchost.exe" Normal NT AUTHORITY\LocalService 0 Network Location Awareness NlaSvc Running Auto Share Process c:\windows\system32\svchost.exe -k networkservice Normal NT AUTHORITY\NetworkService 0 Network Store Interface Service nsi Running Auto Share Process c:\windows\system32\svchost.exe -k localservice Normal NT Authority\LocalService 0 Microsoft Office Diagnostics Service odserv Stopped Manual Own Process "c:\program files\common files\microsoft shared\office12\odserv.exe" Normal LocalSystem 0 Office Source Engine ose Stopped Manual Own Process "c:\program files\common files\microsoft shared\source engine\ose.exe" Normal LocalSystem 0 Peer Networking Identity Manager p2pimsvc Stopped Manual Share Process c:\windows\system32\svchost.exe -k localservicenetworkrestricted Normal NT AUTHORITY\LocalService 0 Peer Networking Grouping p2psvc Stopped Manual Share Process c:\windows\system32\svchost.exe -k localservicenetworkrestricted Normal NT AUTHORITY\LocalService 0 Program Compatibility Assistant Service PcaSvc Running Auto Share Process c:\windows\system32\svchost.exe -k localsystemnetworkrestricted Normal LocalSystem 0 Performance Logs & Alerts pla Stopped Manual Share Process c:\windows\system32\svchost.exe -k localservicenonetwork Normal NT AUTHORITY\LocalService 0 Plug and Play PlugPlay Running Auto Share Process c:\windows\system32\svchost.exe -k dcomlaunch Normal LocalSystem 0 PNRP Machine Name Publication Service PNRPAutoReg Stopped Manual Share Process c:\windows\system32\svchost.exe -k localservicenetworkrestricted Normal NT AUTHORITY\LocalService 0 Peer Name Resolution Protocol PNRPsvc Stopped Manual Share Process c:\windows\system32\svchost.exe -k localservicenetworkrestricted Normal NT AUTHORITY\LocalService 0 IPsec Policy Agent PolicyAgent Running Auto Share Process c:\windows\system32\svchost.exe -k networkservicenetworkrestricted Normal NT Authority\NetworkService 0 User Profile Service ProfSvc Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 Protected Storage ProtectedStorage Stopped Manual Share Process c:\windows\system32\lsass.exe Normal LocalSystem 0 Quality Windows Audio Video Experience QWAVE Stopped Manual Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 Remote Access Auto Connection Manager RasAuto Stopped Manual Share Process c:\windows\system32\svchost.exe -k netsvcs Normal localSystem 0 Remote Access Connection Manager RasMan Running Manual Share Process c:\windows\system32\svchost.exe -k netsvcs Normal localSystem 0 Routing and Remote Access RemoteAccess Stopped Disabled Share Process c:\windows\system32\svchost.exe -k netsvcs Normal localSystem 0 Remote Registry RemoteRegistry Stopped Manual Share Process c:\windows\system32\svchost.exe -k regsvc Normal NT AUTHORITY\LocalService 0 Remote Procedure Call (RPC) Locator RpcLocator Stopped Manual Own Process c:\windows\system32\locator.exe Normal NT AUTHORITY\NetworkService 0 Remote Procedure Call (RPC) RpcSs Running Auto Share Process c:\windows\system32\svchost.exe -k rpcss Normal NT AUTHORITY\NetworkService 0 Security Accounts Manager SamSs Running Auto Share Process c:\windows\system32\lsass.exe Normal LocalSystem 0 Smart Card SCardSvr Stopped Manual Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 Task Scheduler Schedule Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 Smart Card Removal Policy SCPolicySvc Stopped Manual Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 Windows Backup SDRSVC Stopped Manual Own Process c:\windows\system32\svchost.exe -k sdrsvc Normal localSystem 0 Secondary Logon seclogon Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 System Event Notification Service SENS Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 Terminal Services Configuration SessionEnv Stopped Manual Share Process c:\windows\system32\svchost.exe -k netsvcs Normal localSystem 0 Internet Connection Sharing (ICS) SharedAccess Stopped Manual Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 Shell Hardware Detection ShellHWDetection Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Ignore LocalSystem 0 Software Licensing slsvc Running Auto Own Process c:\windows\system32\slsvc.exe Normal NT AUTHORITY\NetworkService 0 SL UI Notification Service SLUINotify Stopped Manual Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 SNMP Trap SNMPTRAP Stopped Manual Own Process c:\windows\system32\snmptrap.exe Normal NT AUTHORITY\LocalService 0 Print Spooler Spooler Running Auto Own Process c:\windows\system32\spoolsv.exe Normal LocalSystem 0 SSDP Discovery SSDPSRV Running Manual Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 Windows Image Acquisition (WIA) stisvc Running Auto Own Process c:\windows\system32\svchost.exe -k imgsvc Normal NT Authority\LocalService 0 Microsoft Software Shadow Copy Provider swprv Stopped Manual Own Process c:\windows\system32\svchost.exe -k swprv Normal LocalSystem 0 Superfetch SysMain Running Auto Share Process c:\windows\system32\svchost.exe -k localsystemnetworkrestricted Ignore LocalSystem 0 Tablet PC Input Service TabletInputService Running Auto Share Process c:\windows\system32\svchost.exe -k localsystemnetworkrestricted Normal LocalSystem 0 Telephony TapiSrv Running Manual Share Process c:\windows\system32\svchost.exe -k networkservice Normal NT AUTHORITY\NetworkService 0 TPM Base Services TBS Stopped Manual Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 Terminal Services TermService Running Auto Share Process c:\windows\system32\svchost.exe -k networkservice Normal NT Authority\NetworkService 0 Themes Themes Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 Thread Ordering Server THREADORDER Stopped Manual Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 Distributed Link Tracking Client TrkWks Running Auto Share Process c:\windows\system32\svchost.exe -k localsystemnetworkrestricted Normal LocalSystem 0 Windows Modules Installer TrustedInstaller Stopped Manual Own Process c:\windows\servicing\trustedinstaller.exe Normal localSystem 0 Interactive Services Detection UI0Detect Stopped Manual Own Process c:\windows\system32\ui0detect.exe Normal LocalSystem 0 UPnP Device Host upnphost Running Manual Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 Messenger Sharing Folders USN Journal Reader service usnjsvc Stopped Manual Own Process "c:\program files\windows live\messenger\usnsvc.exe" Normal LocalSystem 0 Desktop Window Manager Session Manager UxSms Running Auto Share Process c:\windows\system32\svchost.exe -k localsystemnetworkrestricted Normal localSystem 0 Virtual Disk vds Stopped Manual Own Process c:\windows\system32\vds.exe Normal LocalSystem 0 Volume Shadow Copy VSS Stopped Manual Own Process c:\windows\system32\vssvc.exe Normal LocalSystem 0 Windows Time W32Time Running Auto Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 Windows Connect Now - Config Registrar wcncsvc Stopped Manual Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 Windows Color System WcsPlugInService Stopped Manual Share Process c:\windows\system32\svchost.exe -k wcssvc Normal NT AUTHORITY\LocalService 0 Diagnostic Service Host WdiServiceHost Stopped Manual Share Process c:\windows\system32\svchost.exe -k wdisvc Normal NT AUTHORITY\LocalService 0 Diagnostic System Host WdiSystemHost Running Manual Share Process c:\windows\system32\svchost.exe -k localsystemnetworkrestricted Normal LocalSystem 0 WebClient WebClient Running Auto Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 Windows Event Collector Wecsvc Stopped Manual Share Process c:\windows\system32\svchost.exe -k networkservice Normal NT AUTHORITY\NetworkService 0 Problem Reports and Solutions Control Panel Support wercplsupport Stopped Manual Share Process c:\windows\system32\svchost.exe -k netsvcs Normal localSystem 0 Windows Error Reporting Service WerSvc Running Auto Share Process c:\windows\system32\svchost.exe -k wersvcgroup Ignore localSystem 0 Windows Defender WinDefend Running Auto Share Process c:\windows\system32\svchost.exe -k secsvcs Normal LocalSystem 0 WinHTTP Web Proxy Auto-Discovery Service WinHttpAutoProxySvc Stopped Manual Share Process c:\windows\system32\svchost.exe -k localservice Normal NT AUTHORITY\LocalService 0 Windows Management Instrumentation Winmgmt Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Ignore localSystem 0 Windows Remote Management (WS-Management) WinRM Stopped Manual Share Process c:\windows\system32\svchost.exe -k networkservice Normal NT AUTHORITY\NetworkService 0 WLAN AutoConfig Wlansvc Running Auto Share Process c:\windows\system32\svchost.exe -k localsystemnetworkrestricted Normal LocalSystem 0 Windows Live Setup Service WLSetupSvc Stopped Manual Own Process "c:\program files\windows live\installer\wlsetupsvc.exe" Normal LocalSystem 0 WMI Performance Adapter wmiApSrv Stopped Manual Own Process c:\windows\system32\wbem\wmiapsrv.exe Normal localSystem 0 Windows Media Player Network Sharing Service WMPNetworkSvc Running Auto Own Process "c:\program files\windows media player\wmpnetwk.exe" Normal NT AUTHORITY\NetworkService 0 Parental Controls WPCSvc Stopped Manual Share Process c:\windows\system32\svchost.exe -k localservicenetworkrestricted Normal NT Authority\LocalService 0 Portable Device Enumerator Service WPDBusEnum Running Auto Share Process c:\windows\system32\svchost.exe -k localsystemnetworkrestricted Normal LocalSystem 0 Security Center wscsvc Running Auto Share Process c:\windows\system32\svchost.exe -k localservicenetworkrestricted Normal NT AUTHORITY\LocalService 0 Windows Search WSearch Running Auto Own Process c:\windows\system32\searchindexer.exe /embedding Normal LocalSystem 0 Windows Update wuauserv Running Auto Share Process c:\windows\system32\svchost.exe -k netsvcs Normal LocalSystem 0 Windows Driver Foundation - driverrammeverk for brukermodus wudfsvc Running Auto Share Process c:\windows\system32\svchost.exe -k localsystemnetworkrestricted Normal LocalSystem 0 [Programgrupper] Gruppenavn Navn Brukernavn Start Menu Default:Start Menu Default Start Menu\Programmer Default:Start Menu\Programmer Default Start Menu\Programs Default:Start Menu\Programs Default Start Menu\Programs\Accessories Default:Start Menu\Programs\Accessories Default Start Menu\Programs\Accessories\Accessibility Default:Start Menu\Programs\Accessories\Accessibility Default Start Menu\Programs\Accessories\System Tools Default:Start Menu\Programs\Accessories\System Tools Default Start Menu\Programs\Maintenance Default:Start Menu\Programs\Maintenance Default Start Menu Public:Start Menu Public Start Menu\Programmer Public:Start Menu\Programmer Public Start Menu\Programs Public:Start Menu\Programs Public Start Menu\Programs\Accessories Public:Start Menu\Programs\Accessories Public Start Menu\Programs\Accessories\Accessibility Public:Start Menu\Programs\Accessories\Accessibility Public Start Menu\Programs\Accessories\System Tools Public:Start Menu\Programs\Accessories\System Tools Public Start Menu\Programs\Accessories\Tablet PC Public:Start Menu\Programs\Accessories\Tablet PC Public Start Menu\Programs\Administrative Tools Public:Start Menu\Programs\Administrative Tools Public Start Menu\Programs\Adobe Master Collection CS3 Public:Start Menu\Programs\Adobe Master Collection CS3 Public Start Menu\Programs\Catalyst Control Center Public:Start Menu\Programs\Catalyst Control Center Public Start Menu\Programs\Catalyst Install Manager Public:Start Menu\Programs\Catalyst Install Manager Public Start Menu\Programs\COWON Media Center - jetAudio Public:Start Menu\Programs\COWON Media Center - jetAudio Public Start Menu\Programs\COWON Media Center - jetAudio\jetToys Public:Start Menu\Programs\COWON Media Center - jetAudio\jetToys Public Start Menu\Programs\EA GAMES Public:Start Menu\Programs\EA GAMES Public Start Menu\Programs\EA GAMES\Need for Speed™ Most Wanted Public:Start Menu\Programs\EA GAMES\Need for Speed™ Most Wanted Public Start Menu\Programs\Elkjøp Fotoservice Public:Start Menu\Programs\Elkjøp Fotoservice Public Start Menu\Programs\Extras and Upgrades Public:Start Menu\Programs\Extras and Upgrades Public Start Menu\Programs\Fraps Public:Start Menu\Programs\Fraps Public Start Menu\Programs\FrostWire Public:Start Menu\Programs\FrostWire Public Start Menu\Programs\Games Public:Start Menu\Programs\Games Public Start Menu\Programs\Jensen AirLink Public:Start Menu\Programs\Jensen AirLink Public Start Menu\Programs\L&H Voice Xpress Tools Public:Start Menu\Programs\L&H Voice Xpress Tools Public Start Menu\Programs\LingSpeak 0.9 Public:Start Menu\Programs\LingSpeak 0.9 Public Start Menu\Programs\MagicISO Public:Start Menu\Programs\MagicISO Public Start Menu\Programs\Maintenance Public:Start Menu\Programs\Maintenance Public Start Menu\Programs\Microsoft Expression Public:Start Menu\Programs\Microsoft Expression Public Start Menu\Programs\Microsoft Office Public:Start Menu\Programs\Microsoft Office Public Start Menu\Programs\Microsoft Office\Microsoft Office Tools Public:Start Menu\Programs\Microsoft Office\Microsoft Office Tools Public Start Menu\Programs\Mozilla Firefox Public:Start Menu\Programs\Mozilla Firefox Public Start Menu\Programs\PCSX2 0.9 R3 Public:Start Menu\Programs\PCSX2 0.9 R3 Public Start Menu\Programs\Pcsx2_0.9.4 Public:Start Menu\Programs\Pcsx2_0.9.4 Public Start Menu\Programs\Roxio Creator DE Public:Start Menu\Programs\Roxio Creator DE Public Start Menu\Programs\Roxio Creator DE\Projects Public:Start Menu\Programs\Roxio Creator DE\Projects Public Start Menu\Programs\Startup Public:Start Menu\Programs\Startup Public Start Menu\Programs\Tablet PC Public:Start Menu\Programs\Tablet PC Public Start Menu\Programs\VideoLAN Public:Start Menu\Programs\VideoLAN Public Start Menu\Programs\VideoLAN\Quick Settings Public:Start Menu\Programs\VideoLAN\Quick Settings Public Start Menu\Programs\VideoLAN\Quick Settings\Audio Public:Start Menu\Programs\VideoLAN\Quick Settings\Audio Public Start Menu\Programs\VideoLAN\Quick Settings\Interface Public:Start Menu\Programs\VideoLAN\Quick Settings\Interface Public Start Menu\Programs\VideoLAN\Quick Settings\Video Public:Start Menu\Programs\VideoLAN\Quick Settings\Video Public Start Menu\Programs\Windows Live Public:Start Menu\Programs\Windows Live Public Start Menu\Programs\WinRAR Public:Start Menu\Programs\WinRAR Public Start Menu\Programs\World of Warcraft Public:Start Menu\Programs\World of Warcraft Public Start Menu\Programs\xpad Public:Start Menu\Programs\xpad Public Start Menu TANZ\Tanz:Start Menu TANZ\Tanz Start Menu\Programmer TANZ\Tanz:Start Menu\Programmer TANZ\Tanz Start Menu\Programs TANZ\Tanz:Start Menu\Programs TANZ\Tanz Start Menu\Programs\Accessories TANZ\Tanz:Start Menu\Programs\Accessories TANZ\Tanz Start Menu\Programs\Accessories\Accessibility TANZ\Tanz:Start Menu\Programs\Accessories\Accessibility TANZ\Tanz Start Menu\Programs\Accessories\System Tools TANZ\Tanz:Start Menu\Programs\Accessories\System Tools TANZ\Tanz Start Menu\Programs\Administrative Tools TANZ\Tanz:Start Menu\Programs\Administrative Tools TANZ\Tanz Start Menu\Programs\Fraps TANZ\Tanz:Start Menu\Programs\Fraps TANZ\Tanz Start Menu\Programs\Maintenance TANZ\Tanz:Start Menu\Programs\Maintenance TANZ\Tanz Start Menu\Programs\PCSX2 0.9 R3 TANZ\Tanz:Start Menu\Programs\PCSX2 0.9 R3 TANZ\Tanz Start Menu\Programs\Startup TANZ\Tanz:Start Menu\Programs\Startup TANZ\Tanz Start Menu\Programs\WinRAR TANZ\Tanz:Start Menu\Programs\WinRAR TANZ\Tanz Start Menu\Programs\xpad TANZ\Tanz:Start Menu\Programs\xpad TANZ\Tanz [Oppstartsprogrammer] Program Kommando Brukernavn Plassering Sidebar %programfiles%\windows sidebar\sidebar.exe /detectmem NT-MYNDIGHET\LOKAL TJENESTE HKU\S-1-5-19\SOFTWARE\Microsoft\Windows\CurrentVersion\Run WindowsWelcomeCenter rundll32.exe oobefldr.dll,showwelcomecenter NT-MYNDIGHET\LOKAL TJENESTE HKU\S-1-5-19\SOFTWARE\Microsoft\Windows\CurrentVersion\Run Sidebar %programfiles%\windows sidebar\sidebar.exe /detectmem NT-MYNDIGHET\NETTVERKSTJENESTE HKU\S-1-5-20\SOFTWARE\Microsoft\Windows\CurrentVersion\Run WindowsWelcomeCenter rundll32.exe oobefldr.dll,showwelcomecenter NT-MYNDIGHET\NETTVERKSTJENESTE HKU\S-1-5-20\SOFTWARE\Microsoft\Windows\CurrentVersion\Run OneNote 2007 Screen Clipper og Launcher onenote 2007 screen clipper og launcher.lnk TANZ\Tanz Startup msnmsgr "c:\program files\windows live\messenger\msnmsgr.exe" /background TANZ\Tanz HKU\S-1-5-21-931364956-3371024472-1513575373-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Run DAEMON Tools Pro Agent "c:\windows.old\program files\daemon tools pro\dtproagent.exe" TANZ\Tanz HKU\S-1-5-21-931364956-3371024472-1513575373-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Run IndxStoreSvr_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA} "c:\program files\common files\nero\lib\nmindexstoresvr.exe" aso-616b5711-6dae-4795-a05f-39a1e5104020 TANZ\Tanz HKU\S-1-5-21-931364956-3371024472-1513575373-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Run Jensen AirLink Utility c:\progra~1\jensen\common\jensenui.exe -s Public Common Startup Windows Defender %programfiles%\windows defender\msascui.exe -hide Public HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run Acrobat Assistant 8.0 "c:\program files\adobe\acrobat 8.0\acrobat\acrotray.exe" Public HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run Adobe_ID0EYTHM c:\progra~1\common~1\adobe\adobev~1\server\bin\versio~2.exe Public HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run NBKeyScan "c:\program files\nero\nero8\nero backitup\nbkeyscan.exe" Public HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run SunJavaUpdateSched "c:\program files\java\jre1.6.0_03\bin\jusched.exe" Public HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run StartCCC c:\program files\ati technologies\ati.ace\core-static\clistart.exe Public HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [OLE-registrering] Objekt Lokal server Microsoft Graph Chart c:\progra~1\micros~2\office12\graph.exe Microsoft Office Excel 95 Worksheet Ikke tilgjengelig Microsoft Office Excel Chart Ikke tilgjengelig Microsoft Office Excel 97-2003 Worksheet c:\progra~1\micros~2\office12\excel.exe Microsoft Office Excel Chart c:\progra~1\micros~2\office12\excel.exe Microsoft Office Excel Worksheet c:\progra~1\micros~2\office12\excel.exe Microsoft Office Excel Macro-Enabled Worksheet c:\progra~1\micros~2\office12\excel.exe Microsoft Office Excel Binary Worksheet c:\progra~1\micros~2\office12\excel.exe Microsoft Word 6.0 - 7.0 Document Ikke tilgjengelig Microsoft Word 6.0 - 7.0 Picture Ikke tilgjengelig Microsoft Office Word 97 - 2003 Document c:\progra~1\micros~2\office12\winword.exe VISIO 2 Drawing Ikke tilgjengelig VISIO 3 Drawing Ikke tilgjengelig VISIO 4 Drawing Ikke tilgjengelig VISIO 5 Drawing Ikke tilgjengelig Microsoft Visio 2000/2002 Drawing Ikke tilgjengelig Microsoft Office Visio Drawing c:\progra~1\micros~2\office12\visio.exe Microsoft Formelredigering 3.0 c:\progra~1\common~1\micros~1\equation\eqnedt32.exe Microsoft Office Excel Chart Ikke tilgjengelig Microsoft Excel 4.0 Macro Ikke tilgjengelig Microsoft Office PowerPoint Slide c:\progra~1\micros~2\office12\powerpnt.exe Microsoft Office Word Macro-Enabled Document c:\progra~1\micros~2\office12\winword.exe Microsoft Office PowerPoint Macro-Enabled Slide c:\progra~1\micros~2\office12\powerpnt.exe Flash Document c:\progra~1\adobe\adobef~3\flash.exe Microsoft Office PowerPoint 97-2003 Presentation c:\progra~1\micros~2\office12\powerpnt.exe Microsoft Office PowerPoint 97-2003 Slide c:\progra~1\micros~2\office12\powerpnt.exe WordPad Document "%programfiles%\windows nt\accessories\wordpad.exe" Microsoft Office Project Document c:\progra~1\micros~2\office12\winproj.exe Adobe Photoshop Image c:\program files\adobe\adobe photoshop cs3\photoshop.exe /automation Microsoft Office Word Macro-Enabled Template c:\progra~1\micros~2\office12\winword.exe Microsoft Office Word Template c:\progra~1\micros~2\office12\winword.exe Adobe Acrobat Document c:\program files\adobe\acrobat 8.0\acrobat\acrobat.exe Microsoft Office PowerPoint Presentation c:\progra~1\micros~2\office12\powerpnt.exe Adobe Illustrator Artwork 13.0 c:\program files\adobe\adobe illustrator cs3\support files\contents\windows\illustrator.exe Microsoft Office PowerPoint Macro-Enabled Presentation c:\progra~1\micros~2\office12\powerpnt.exe Drawing Ikke tilgjengelig Package Ikke tilgjengelig Microsoft Office Word Document c:\progra~1\micros~2\office12\winword.exe Microsoft PenInputPanel Control Ikke tilgjengelig [Windows-feilrapportering] Klokkeslett Type Detaljer 07.02.2008 15:35 Application Error Program med feil Firefox Setup 2.0.0.11.exe, versjon 4.42.0.0, tidsangivelse 0x44e24a66, modul med feil Firefox Setup 2.0.0.11.exe, versjon 4.42.0.0, tidsangivelse 0x44e24a66, unntakskode 0xc0000005, feilforskyvning 0x00003d84, prosess-ID 0x750, starttid for program 0x01c8699f04a1bc20. 07.02.2008 15:35 Application Error Program med feil Firefox Setup 2.0.0.11.exe, versjon 4.42.0.0, tidsangivelse 0x44e24a66, modul med feil Firefox Setup 2.0.0.11.exe, versjon 4.42.0.0, tidsangivelse 0x44e24a66, unntakskode 0xc0000005, feilforskyvning 0x00003d84, prosess-ID 0x840, starttid for program 0x01c8699f0df362b0. 07.02.2008 17:08 Application Error Program med feil R154092.EXE, versjon 1.3.2.6557, tidsangivelse 0x4550b439, modul med feil R154092.EXE, versjon 1.3.2.6557, tidsangivelse 0x4550b439, unntakskode 0xc0000005, feilforskyvning 0x00001f29, prosess-ID 0xd74, starttid for program 0x01c869ac108b2e88. 07.02.2008 17:08 Application Error Program med feil R154079.EXE, versjon 1.3.2.6557, tidsangivelse 0x4550b439, modul med feil R154079.EXE, versjon 1.3.2.6557, tidsangivelse 0x4550b439, unntakskode 0xc0000005, feilforskyvning 0x00001ed0, prosess-ID 0xc20, starttid for program 0x01c869ac160ce158. 07.02.2008 17:09 Application Error Program med feil msnmsgr.exe, versjon 8.5.1302.1018, tidsangivelse 0x4717a53b, modul med feil kernel32.dll, versjon 6.0.6000.16386, tidsangivelse 0x4549bd80, unntakskode 0xc06d007e, feilforskyvning 0x0001b09e, prosess-ID 0xca4, starttid for program 0x01c869ac2f3eec48. 07.02.2008 17:32 Application Error Program med feil msnmsgr.exe, versjon 8.5.1302.1018, tidsangivelse 0x4717a53b, modul med feil kernel32.dll, versjon 6.0.6000.16386, tidsangivelse 0x4549bd80, unntakskode 0xc06d007e, feilforskyvning 0x0001b09e, prosess-ID 0x548, starttid for program 0x01c869af68fb74d7. 07.02.2008 21:09 Application Error Program med feil FRONTPG.EXE, versjon 11.0.5516.0, tidsangivelse 0x3f1f5d5f, modul med feil kernel32.dll, versjon 6.0.6000.16386, tidsangivelse 0x4549bd80, unntakskode 0xc06d007e, feilforskyvning 0x0001b09e, prosess-ID 0x9c8, starttid for program 0x01c869cdbe16cc1a. 08.02.2008 17:29 Application Error Program med feil FRONTPG.EXE, versjon 11.0.5516.0, tidsangivelse 0x3f1f5d5f, modul med feil ntdll.dll, versjon 6.0.6000.16386, tidsangivelse 0x4549bdc9, unntakskode 0xc0000005, feilforskyvning 0x00067036, prosess-ID 0xa7c, starttid for program 0x01c86a7516e28068. 10.02.2008 09:37 Application Error Program med feil rundll32.exe, versjon 6.0.6000.16386, tidsangivelse 0x4549b0e1, modul med feil Xpadcpl.dll, versjon 0.0.0.0, tidsangivelse 0x43c10d0e, unntakskode 0xc0000005, feilforskyvning 0x00002671, prosess-ID 0xfd4, starttid for program 0x01c86bc861db7a26. 20.02.2008 11:54 Application Error Program med feil vlc.exe, versjon 0.8.6.0, tidsangivelse 0x474fd420, modul med feil libffmpeg_plugin.dll, versjon 0.0.0.0, tidsangivelse 0x474fd421, unntakskode 0xc0000005, feilforskyvning 0x000f0b9e, prosess-ID 0xd10, starttid for program 0x01c873b3b505684e. 20.02.2008 11:55 Application Error Program med feil vlc.exe, versjon 0.8.6.0, tidsangivelse 0x474fd420, modul med feil libffmpeg_plugin.dll, versjon 0.0.0.0, tidsangivelse 0x474fd421, unntakskode 0xc0000005, feilforskyvning 0x000f0b9e, prosess-ID 0xbd8, starttid for program 0x01c873b75d88821e. 20.02.2008 11:55 Application Error Program med feil vlc.exe, versjon 0.8.6.0, tidsangivelse 0x474fd420, modul med feil libffmpeg_plugin.dll, versjon 0.0.0.0, tidsangivelse 0x474fd421, unntakskode 0xc0000005, feilforskyvning 0x000f0b9e, prosess-ID 0x29c, starttid for program 0x01c873b774799dbe. 20.02.2008 17:02 Application Error Program med feil installer.exe, versjon 0.0.0.0, tidsangivelse 0x477af76a, modul med feil libeay32.dll, versjon 6.0.6000.16386, tidsangivelse 0x4549bdc9, unntakskode 0xc0000135, feilforskyvning 0x00008fc7, prosess-ID 0xac0, starttid for program 0x01c873e2582d4ab7. 20.02.2008 18:39 Application Error Program med feil iPodWizard.exe, versjon 1.3.0.7, tidsangivelse 0x46b2d9e4, modul med feil iPodWizard.exe, versjon 1.3.0.7, tidsangivelse 0x46b2d9e4, unntakskode 0xc0000005, feilforskyvning 0x00044a6f, prosess-ID 0xe20, starttid for program 0x01c873ee53f8d257. 23.02.2008 18:36 Application Error Program med feil gh3.exe, versjon 0.0.0.0, tidsangivelse 0x471045c8, modul med feil fmodex.dll, versjon 0.4.6.27, tidsangivelse 0x46e0ec1d, unntakskode 0xc0000005, feilforskyvning 0x0003d434, prosess-ID 0xda0, starttid for program 0x01c876473e8fb34f. 26.02.2008 18:18 Application Error Program med feil rundll32.exe, versjon 6.0.6000.16386, tidsangivelse 0x4549b0e1, modul med feil Xpadcpl.dll, versjon 0.0.0.0, tidsangivelse 0x43c10d0e, unntakskode 0xc0000005, feilforskyvning 0x00002671, prosess-ID 0x7c0, starttid for program 0x01c878a349ee17bc. 02.03.2008 21:37 Application Error Program med feil MyWarCraftStudio.exe, versjon 1.0.0.2716, tidsangivelse 0x43239dc3, modul med feil RealtimeRender.dll, versjon 0.1.0.2704, tidsangivelse 0x433c13e9, unntakskode 0xc0000005, feilforskyvning 0x00066e74, prosess-ID 0xf70, starttid for program 0x01c87cad991350fc. 02.03.2008 21:37 Application Error Program med feil MyWarCraftStudio.exe, versjon 1.0.0.2716, tidsangivelse 0x43239dc3, modul med feil RealtimeRender.dll, versjon 0.1.0.2704, tidsangivelse 0x433c13e9, unntakskode 0xc0000005, feilforskyvning 0x00066e74, prosess-ID 0x49c, starttid for program 0x01c87cad9ab986ec. 02.03.2008 21:39 Application Error Program med feil MyWarCraftStudio.exe, versjon 1.0.0.2716, tidsangivelse 0x43239dc3, modul med feil RealtimeRender.dll, versjon 0.1.0.2704, tidsangivelse 0x433c13e9, unntakskode 0xc0000005, feilforskyvning 0x00066e74, prosess-ID 0xa6c, starttid for program 0x01c87cadeefa487c. 02.03.2008 21:39 Application Error Program med feil MyWarCraftStudio.exe, versjon 1.0.0.2716, tidsangivelse 0x43239dc3, modul med feil RealtimeRender.dll, versjon 0.1.0.2704, tidsangivelse 0x433c13e9, unntakskode 0xc0000005, feilforskyvning 0x00066e74, prosess-ID 0xc80, starttid for program 0x01c87cadf123b82c. 16.03.2008 21:58 Application Error Program med feil vlc.exe, versjon 0.8.6.0, tidsangivelse 0x474fd420, modul med feil libvlc.dll, versjon 0.0.0.0, tidsangivelse 0x474fd420, unntakskode 0xc0000005, feilforskyvning 0x0001179f, prosess-ID 0xad0, starttid for program 0x01c887b0cddc7aee. 11.02.2008 16:11 Application Hang Programmet UltraISO.exe versjon 8.6.6.2180 sluttet å samhandle med Windows og ble lukket. Hvis du vil se om det finnes mer informasjon tilgjengelig om problemet, ser du i problemhistorikken i kontrollpanelet for Problemrapportering og -løsninger. Prosess-ID: a60 Starttidspunkt: 01c86cc87dc593b6 Avslutningstidspunkt: 113 12.02.2008 07:00 Application Hang Programmet Launcher.exe versjon 0.0.0.0 sluttet å samhandle med Windows og ble lukket. Hvis du vil se om det finnes mer informasjon tilgjengelig om problemet, ser du i problemhistorikken i kontrollpanelet for Problemrapportering og -løsninger. Prosess-ID: 848 Starttidspunkt: 01c86d44b0d676cf Avslutningstidspunkt: 45 24.02.2008 12:52 Application Hang Programmet Dreamweaver.exe versjon 9.0.0.3481 sluttet å samhandle med Windows og ble lukket. Hvis du vil se om det finnes mer informasjon tilgjengelig om problemet, ser du i problemhistorikken i kontrollpanelet for Problemrapportering og -løsninger. Prosess-ID: 514 Starttidspunkt: 01c876e3da8e0f40 Avslutningstidspunkt: 5 26.02.2008 19:46 Application Hang Programmet Explorer.EXE versjon 6.0.6000.16549 sluttet å samhandle med Windows og ble lukket. Hvis du vil se om det finnes mer informasjon tilgjengelig om problemet, ser du i problemhistorikken i kontrollpanelet for Problemrapportering og -løsninger. Prosess-ID: 6e8 Starttidspunkt: 01c87899af38b5dc Avslutningstidspunkt: 31 19.03.2008 19:04 Application Hang Programmet Acrobat.exe versjon 8.1.0.137 sluttet å samhandle med Windows og ble lukket. Hvis du vil se om det finnes mer informasjon tilgjengelig om problemet, ser du i problemhistorikken i kontrollpanelet for Problemrapportering og -løsninger. Prosess-ID: b08 Starttidspunkt: 01c889f23114eec0 Avslutningstidspunkt: 15 19.03.2008 19:21 Application Hang Programmet Acrobat.exe versjon 8.1.0.137 sluttet å samhandle med Windows og ble lukket. Hvis du vil se om det finnes mer informasjon tilgjengelig om problemet, ser du i problemhistorikken i kontrollpanelet for Problemrapportering og -løsninger. Prosess-ID: 6d0 Starttidspunkt: 01c889f4f6bd72d0 Avslutningstidspunkt: 18 Lenke til kommentar https://www.diskusjon.no/topic/938708-trenger-hjelp-til-%C3%A5-skj%C3%B8nne-en-hjelpemail/
fenderebest Skrevet 13. april 2008 Del Skrevet 13. april 2008 Vel om du søker på Dell's egne sider til den modellen du bruker burde da de gi deg de driverne du trenger. Lenke til kommentar https://www.diskusjon.no/topic/938708-trenger-hjelp-til-%C3%A5-skj%C3%B8nne-en-hjelpemail/#findComment-10949311
mamobr Skrevet 13. april 2008 Del Skrevet 13. april 2008 http://support.euro.dell.com/support/downl...tid=&impid= her tror jeg Lenke til kommentar https://www.diskusjon.no/topic/938708-trenger-hjelp-til-%C3%A5-skj%C3%B8nne-en-hjelpemail/#findComment-10949340
