iw3sp.exe og iw3mp.exe CoD4 ERROR
Gjest Slettet-UUbruw
Problemet kan være at du kjører 64 bit... Mange spill takler ikke det...
Hadde det problemet på MP. Måtte bare plugge inn en mic så funka det.
det samme gjorde jeg, må ha minijack plugg i mic inn da fungerer det
Prøv en no-cd crack du.
Siden du eier spillet kan jeg anbefale www.gamecopyworld.com.
Dette skal vel ikke være i strid med retningslinjene, men hvis det er det, si fra så skal jeg fjerne linken.
Jeg fant noe her... #
For Windows Vista
1) Right-click on your desktop and select Personalize.
2) Click on Display Settings
3) Set the resolution slider to 800X600
4) Set the colors to Highest (32 bit).
5) Click Apply and OK.
# All background applications must be shutdown prior to running the game.
If you have Windows Vista do the following:
# Set the compatibility mode for the game:
-Right click on the shortcut you use to launch the game
-Select properties
-Select the Compatibility tab
-Place a check in the checkbox next to "Run this program in compatibility mode for:" and select Windows XP SP 2 from the dropdown.
If you do not have Windows Vista, or do and are still having problems, it is possible your monitor does not support the resolution or refresh rate the game is trying to display in, please refer to the following for directions on how to change refresh rate and resolution.
To change resolution for the game:
- Locate the shortcut you use to launch the game (not the game executable)
- Right click on the shortcut and select properties
- Make sure you are on the shortcut tab
- Locate the target line
- Add the following text to the target line after all the text that is normally there
+seta r_mode "1024x768" (you can replace the resolution 1024x768 with any resolution you want) please note the spacing and punctuation.
- When you are done the line should look something like:
"C:\Program Files\Activision\Call of Duty 4 - Modern Warfare\iw3sp.exe" +seta r_mode "800x600"
- Hit ok, the next time you launch the game make sure you use this shortcut
Prøvde det ut men det står at jeg må sette inn den riktige CD/DVD... Har prøvd med crack før, det gikk ikke. Skal prøve å laste ned en til da.
Du kjører selvfølgelig spillet som administrator ? Eventuellt slå av brukerkontroll i kontrollpanelet . Høyreklikk på exefila og kjør spillet som administrator , dette MÅ gjørs på de fleste spill man kjører på 64bit vista. Jeg har slått det av så jeg slipper å gjøre det vær gang jeg skal spille .
Jeg kjører spillet som admin, men har ikke slått av noe brukerkontroll nei. Hvor finner jeg det?
Kontrollpanel , brukerkontoer
er det "Turn User Account Control On or Off"? Har gjort det nå og restartet, men det hjelper ikke... er det noe annet jeg må gjøre?
bruker du nod32 antivirus?
Jeg gjør det, men det funker greit..
plugg inn mikrofon å sjekk, funka for meg, men på pcen min funka ikke mp så kan jo alltid prøve ;)
