funker ikke cod2 på vista?
Funker fint med meg i Vista, last ned den nyaste patchen til spel viss det ikkje funker kan du gå på egenskaper på snarveien eller på .exe fila så tekke du på "Kompatibilitet" så hakker du av for Windows XP SP2. Det hjelper fint på dei alle dei spela eg har testa ut so langt
  • 3 uker senere...
  • 5 uker senere...
I just had this error crop up while going through the Single Player and could not get the game to load.
I reinstalled the game three different times with no help.
I finely did a google search & came up and some real smart person came up with the fix for me...
I had changed some settings in my ATI atalyst control center and somehow..most likely***USER ERROR***...the check mark under 3D API Specific got taken out of: ***Support DXT texture formats***
I put the check mark back in and...Yahoo!...the game loaded just fine.
I don't know what that DXT texture does, but apparently, the game will not load with out it being checked...
hope this will help others..
Solved !
Started ATI catalyst center
in Direct 3D settings; Enabled "support DXT texture format"
Dette fikk jeg da jeg skrev feilmeldingen i google.
Endret av -sparks-
