Problemer med SW: Jedi Knight Jedi Academy
Hei !
Jeg har fått et problem med spillet nevnt i emnetittelen og kunne trengt litteranne hjelp.
Har litt på følelsen at det er noe galt med grafikkortet mitt.
Jeg har ferdig installert spillet og har kjørt troubleshooting og analysen som følger med. Begge deler sier at spillet skal funke.
Jeg starter spiller og får følgende feilmelding
JA: v1.0.0.0 win-x86 Jul 22 2003
Initialising zone memory .....
----- FS_Startup -----
Current search path:
C:\Program Files\LucasArts\Star Wars Jedi Knight Jedi Academy\GameData\base\assets2.pk3 (62 files)
C:\Program Files\LucasArts\Star Wars Jedi Knight Jedi Academy\GameData\base\assets1.pk3 (8320 files)
C:\Program Files\LucasArts\Star Wars Jedi Knight Jedi Academy\GameData\base\assets0.pk3 (15346 files)
C:\Program Files\LucasArts\Star Wars Jedi Knight Jedi Academy\GameData/base
23728 files in pk3 files
execing default.cfg
couldn't exec jaconfig.cfg
couldn't exec autoexec.cfg
...detecting CPU, found Intel Pentium IV
------- Input Initialization -------
Skipping check for DirectInput
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Working directory: C:\Program Files\LucasArts\Star Wars Jedi Knight Jedi Academy\GameData
Initializing OpenGL subsystem
...initializing QGL
succeeded
...setting mode 4: 800 600 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (4)
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...created window@0,0 (640x480)
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
----- CL_Shutdown -----
GLW_StartOpenGL() - could not load OpenGL subsystem
Mitt grafikkort er : Ati mobility radeon x1400.
Fikk den feilen der før på gamle PC-en min, er ikke helt sikker på hva det er men tror pappa fiksa noen drivere eller noe til skjermkortet og så funka det.
