noe ventetid mellom char move?
Hei eg lurte på om det var noe ventetid man måtte vente mellom hver gang man har flytta spilleren sin fra server til ein anna server. fordi syns eg huska leste noe om 3mnd når eg flytta han sist men virker ikke so det står noe om det no når eg ser inpå paid character transfer.
Fra Blizzard sine sider:
Restrictions
The transferring character must be level 10 or higher.
The transferring character must not have undergone a paid character transfer within the last 3 months.
Realms launched within the last 90 days are not eligible transfer destinations. Blizzard reserves the right to prohibit the transfer to any specific realm(s) at any time.
Character transfers will be restricted to characters with specific gold limits:
Level 10-30: 300 gold limit
Level 31-50: 1000 gold limit
Level 51+: 5000 gold limit
Characters may not transfer to PvP realms where a character of the opposite faction already exists.
If an account has 10 characters on a realm, the account cannot transfer more characters to that realm.
The last name on both accounts must match in order to complete an account to account transfer.
Regarding transfer requests from one account to another account, note that you may only request character transfers from one account where you are the subscriber to another account where you are the subscriber. Any attempt to transfer a character from an account where you are not the subscriber could be considered a violation of the World of Warcraft Terms of Use and could lead to Blizzard taking disciplinary action against your account, including, but not limited to warnings, temporary account suspension, or permanent account suspension, as determined by Blizzard.
Altså. Har du overført en karakter fra en realm til en annen må det gå minimum
3.mnd før du kan overføre den til annen realm igjen. Hvis jeg forstod deg riktig og
det var dette du var ute etter å få vite.
KJ
Punktum, komma, store bokstaver og rettskrivning gjør det litt lettere å lese.
Uansett, av det jeg forsto så tror jeg det er cooldown på PCT, men er ikke sikker.
8524227[/snapback]
EDIT: Jaja :p
Off topic: Gratulerer med ny avatar.
Endret av bjorshol
8524227[/snapback]
EDIT: Jaja :p
8528795[/snapback]
Takk, den er genial!
