Your CD-key is not valid! Med 1.41 patch!
Har spilt BF2 med 1.0 online mens jeg lastet ned 1.41, det funket FETT!
Men nå oppdaterte jeg min BF2 versjon til 1.41 og nå får jeg Your CD-key is not valid, har installert 4 ganger nå, og det skjer når jeg har installert 1.41 patchen.
Blir så frustrert, har lyst til å spille *argh*.
Har prøvd å sjekke i registeret, alt er helt OK, noen som kan noen solutions :ermm::cry:
Nei og nei, har kjøpt dette spillet for andre gang. Kunne spilt på alle servere på 1.0, fikk en venn til å prøve key'en og DEN FUNKET. Det er noe rart her :(
Skal prøve dette.
Since 1.03 onwards the CD-KEY has been encrypted in the registry. If it's still the same as the back of the manual, then it's not encrypted and will therefore give you an invalid CD-KEY error.
You can manually uninstall the game by removing the files and registry keys associated with it. Be sure to follow these steps exactly as they appear to prevent accidental file/program deletion on your system.
note: To manually uninstall the Battlefield 2: Euro Force and/or Battlefield 2: Armored Fury booster packs you must do a complete uninstall of Battlefield 2 from your system.
To delete the save files:
1. Open My Documents.
2. Right-click on the Battlefield 2 folder and choose Delete.
To delete the game files (in the default location):
1. Open My Computer.
2. Open the C drive.
3. Open the Program Files folder.
4. Open the EA GAMES folder.
5. Right-click on the Battlefield 2 folder and choose Delete.
6. Close all open windows.
7. Right-click on the Recycle Bin and choose Empty Recycle Bin.
To edit the registry and remove Battlefield 2:
1. Click on the Start button.
2. Click on Run.
3. Type regedit in the text field.
4. Click File and then choose Export.
5. Name the file Backup and make sure the Export Range is set to All.
6. Click Save; you will now be returned to the Registry Editor window.
7. Click the plus sign next to HKEY_LOCAL_MACHINE.
8. Click the plus sign next to Software.
9. Click the plus sign next to DICE.
10. Right-click on the Battlefield 2 folder and choose Delete.
11. Right-click on the Battlefield 2: Amored Fury folder (if applicable) and choose Delete.
12. Click the plus sign next to Electronic Arts.
13. Right-click and choose Delete on any Battlefield 2 folders.
14. Click the plus sign next to Microsoft.
15. Click the plus sign next to Windows.
16. Click the plus sign next to CurrentVersion.
17. Click the plus sign next to Uninstall.
18. Right-click on the key named {04858915-9F49-4B2A-AED4-DC49A7DE6A7B} andchoose Delete.
19. A Confirm Key Delete window will appear, choose Yes.
20. Close the WindowsRegistry Editor.
21. Go to the following folder: C:\Program Files\InstallShield Installation Information (If you cannot find this folder you may have to go to Tools > Folder Settings and click the setting to “SHOW hidden folders.”)
22. Find the folders with the exact same values as the registry keys above and delete them.
23. Empty the recycle bin once more.
