mEhE` Skrevet 19. desember 2006 Skrevet 19. desember 2006 (endret) kjøpte nettopp noen nye sony dvd-r plater. men nero vil ikke brenne . har en nec 8x dvd brenner som støtter både + og - aldri hatt dette problemet før og jeg har hatt brenneren i ca 2 år... her er loggen fra nero 7 om noen skjønner noe av den da. edit: glemte og si at jeg brente cd-r plater uten problemer senest i går. Klikk for å se/fjerne innholdet nedenfor Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02.11.2004 12:54:32 NT-SPTI used Nero Version: 7.2.0.3 Internal Version: 7, 2, 0, 3 Recorder: <_NEC DVD_RW ND-2500A> Version: 1.05 - HA 1 TA 0 - 7.2.0.3 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: <MY3569A ASM861P >Version: 1.0 - HA 1 TA 1 - 7.2.0.3 Adapter driver: <SCSI> HA 1 === Scsi-Device-Map === DiskPeripheral : WDC WD3200JD-00KLB0 08.0 SI3112r Port 0 ID 0 DMA: Off DiskPeripheral : Maxtor 6Y120M0 YAR5 SI3112r Port 0 ID 0 DMA: Off DiskPeripheral : Maxtor 6Y080P0 YAR4 nvidesm Port 1 ID 0 DMA: Off CdRomPeripheral : _NEC DVD_RW ND-2500A 1.05 nvidesm Port 1 ID 0 DMA: Off CdRomPeripheral : MY3569A ASM861P 1.0 dtscsi Port 2 ID 0 DMA: Off CdRomPeripheral : MY3569A ASM861P 1.0 dtscsi Port 2 ID 1 DMA: Off CdRomPeripheral : MY3569A ASM861P 1.0 dtscsi Port 2 ID 2 DMA: Off === CDRom-Device-Map === _NEC DVD_RW ND-2500A E: CDRom0 MY3569A ASM861P F: CDRom1 MY3569A ASM861P G: CDRom3 MY3569A ASM861P M: CDRom2 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte BUFE : 0 Physical memory : 767MB (785904kB) Free physical memory: 175MB (179480kB) Memory in use : 77 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 19.12.2006 Burn DVD Image 13:25:23 #1 Text 0 File ThreadedTransfer.cpp, Line 531 ReadBuffer-Pipe got 262144KB of Memory 13:25:23 #2 Text 0 File Reader.cpp, Line 124 Reader running 13:25:23 #3 Text 0 File Burncd.cpp, Line 3365 Turn on Disc-At-Once, using DVD media 13:25:24 #4 Text 0 File DlgWaitCD.cpp, Line 289 Last possible write address on media: 2298495 (510:46.45, 4489MB) Last address to be written: 2292669 (509:28.69, 4477MB) ... change CloseDisc-Flag to 1 as capacity is exhaused 13:25:24 #5 Text 0 File DlgWaitCD.cpp, Line 301 Write in overburning mode: NO (enabled: CD) 13:25:24 #6 Text 0 File DlgWaitCD.cpp, Line 2715 Recorder: _NEC DVD_RW ND-2500A, Media type: DVD-R Disc Manufacturer: SONY16 - D1 Disc Application Code: 64, Disc Physical Code: 193 13:25:24 #7 Text 0 File DlgWaitCD.cpp, Line 473 >>> Protocol of DlgWaitCD activities: <<< ========================================= 13:25:24 #8 Text 0 File ThreadedTransferInterface.cpp, Line 847 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660) 2 indices, index0 (150) not provided original disc pos #0 + 2292670 (2292670) = #2292670/509:28.70 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2292670 blocks [E: _NEC DVD_RW ND-2500A] -------------------------------------------------------------- 13:25:24 #9 Text 0 File ThreadedTransferInterface.cpp, Line 1059 Prepare recorder [E: _NEC DVD_RW ND-2500A] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4695388160, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 2292670 | lead-out | 1 | 0x41 | 0x00 13:25:24 #10 Text 0 File SCSIPassThrough.cpp, Line 39 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 13:25:24 #11 Text 0 File SCSIPassThrough.cpp, Line 84 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 13:25:24 #12 Phase 24 File dlgbrnst.cpp, Line 1730 Caching of files started 13:25:24 #13 Text 0 File Burncd.cpp, Line 4199 Cache writing successful. 13:25:24 #14 Phase 25 File dlgbrnst.cpp, Line 1730 Caching of files completed 13:25:24 #15 Phase 36 File dlgbrnst.cpp, Line 1730 Burn process started at 2.4x (3 324 KB/s) 13:25:24 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2707 Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0 13:25:24 #17 Text 0 File DVDR.cpp, Line 2786 Recording mode: Sequential Recording Mode 13:25:24 #18 Text 0 File DVDR.cpp, Line 2942 Start write address at LBA 0 DVD high compatibility mode: Yes 13:25:24 #19 Text 0 File Cdrdrv.cpp, Line 8914 ---- DVD Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33) Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26127F h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Start sector number of the current Border-Out: 2FE10 h Start sector number of the next Border-In: 2FFA0 h Media Specific [16..63]: 00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!.... 00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 13:25:24 #20 SPTI -1046 File SCSIPassThrough.cpp, Line 290 E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x30 Sense Qual: 0x05 CDB Data: 0x53 00 00 00 00 00 22 FB C0 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 05 13:25:24 #21 CDR -1046 File ThreadedTransferInterface.cpp, Line 1799 Illegal disc E: _NEC DVD_RW ND-2500A 13:25:24 #22 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1799 Could not perform start of Disc-at-once 13:25:24 #23 Phase 38 File dlgbrnst.cpp, Line 1730 Burn process failed at 2.4x (3 324 KB/s) Existing drivers: File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 19.05.2006 22:16:24 File 'Drivers\PXHELP20.SYS': Ver=3.00.11B, size=46080 bytes, created 16.05.2006 21:23:54 (Prassi/Veritas driver for win 2K) File 'Drivers\scsiport.sys': Ver=5.1.2600.2562 (xpsp.040919-1030), size=96384 bytes, created 15.10.2005 16:11:00 (Adapter driver for src) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) Endret 19. desember 2006 av mEhE`
griped Skrevet 19. desember 2006 Skrevet 19. desember 2006 kjøpte nettopp noen nye sony dvd-r plater.men nero vil ikke brenne . har en nec 8x dvd brenner som støtter både + og - aldri hatt dette problemet før og jeg har hatt brenneren i ca 2 år... her er loggen fra nero 7 om noen skjønner noe av den da. edit: glemte og si at jeg brente cd-r plater uten problemer senest i går. Klikk for å se/fjerne innholdet nedenfor Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02.11.2004 12:54:32 NT-SPTI used Nero Version: 7.2.0.3 Internal Version: 7, 2, 0, 3 Recorder: <_NEC DVD_RW ND-2500A> Version: 1.05 - HA 1 TA 0 - 7.2.0.3 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: <MY3569A ASM861P >Version: 1.0 - HA 1 TA 1 - 7.2.0.3 Adapter driver: <SCSI> HA 1 === Scsi-Device-Map === DiskPeripheral : WDC WD3200JD-00KLB0 08.0 SI3112r Port 0 ID 0 DMA: Off DiskPeripheral : Maxtor 6Y120M0 YAR5 SI3112r Port 0 ID 0 DMA: Off DiskPeripheral : Maxtor 6Y080P0 YAR4 nvidesm Port 1 ID 0 DMA: Off CdRomPeripheral : _NEC DVD_RW ND-2500A 1.05 nvidesm Port 1 ID 0 DMA: Off CdRomPeripheral : MY3569A ASM861P 1.0 dtscsi Port 2 ID 0 DMA: Off CdRomPeripheral : MY3569A ASM861P 1.0 dtscsi Port 2 ID 1 DMA: Off CdRomPeripheral : MY3569A ASM861P 1.0 dtscsi Port 2 ID 2 DMA: Off === CDRom-Device-Map === _NEC DVD_RW ND-2500A E: CDRom0 MY3569A ASM861P F: CDRom1 MY3569A ASM861P G: CDRom3 MY3569A ASM861P M: CDRom2 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte BUFE : 0 Physical memory : 767MB (785904kB) Free physical memory: 175MB (179480kB) Memory in use : 77 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 19.12.2006 Burn DVD Image 13:25:23 #1 Text 0 File ThreadedTransfer.cpp, Line 531 ReadBuffer-Pipe got 262144KB of Memory 13:25:23 #2 Text 0 File Reader.cpp, Line 124 Reader running 13:25:23 #3 Text 0 File Burncd.cpp, Line 3365 Turn on Disc-At-Once, using DVD media 13:25:24 #4 Text 0 File DlgWaitCD.cpp, Line 289 Last possible write address on media: 2298495 (510:46.45, 4489MB) Last address to be written: 2292669 (509:28.69, 4477MB) ... change CloseDisc-Flag to 1 as capacity is exhaused 13:25:24 #5 Text 0 File DlgWaitCD.cpp, Line 301 Write in overburning mode: NO (enabled: CD) 13:25:24 #6 Text 0 File DlgWaitCD.cpp, Line 2715 Recorder: _NEC DVD_RW ND-2500A, Media type: DVD-R Disc Manufacturer: SONY16 - D1 Disc Application Code: 64, Disc Physical Code: 193 13:25:24 #7 Text 0 File DlgWaitCD.cpp, Line 473 >>> Protocol of DlgWaitCD activities: <<< ========================================= 13:25:24 #8 Text 0 File ThreadedTransferInterface.cpp, Line 847 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, ISO 9660) 2 indices, index0 (150) not provided original disc pos #0 + 2292670 (2292670) = #2292670/509:28.70 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2292670 blocks [E: _NEC DVD_RW ND-2500A] -------------------------------------------------------------- 13:25:24 #9 Text 0 File ThreadedTransferInterface.cpp, Line 1059 Prepare recorder [E: _NEC DVD_RW ND-2500A] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4695388160, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 2292670 | lead-out | 1 | 0x41 | 0x00 13:25:24 #10 Text 0 File SCSIPassThrough.cpp, Line 39 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 13:25:24 #11 Text 0 File SCSIPassThrough.cpp, Line 84 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 13:25:24 #12 Phase 24 File dlgbrnst.cpp, Line 1730 Caching of files started 13:25:24 #13 Text 0 File Burncd.cpp, Line 4199 Cache writing successful. 13:25:24 #14 Phase 25 File dlgbrnst.cpp, Line 1730 Caching of files completed 13:25:24 #15 Phase 36 File dlgbrnst.cpp, Line 1730 Burn process started at 2.4x (3 324 KB/s) 13:25:24 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2707 Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0 13:25:24 #17 Text 0 File DVDR.cpp, Line 2786 Recording mode: Sequential Recording Mode 13:25:24 #18 Text 0 File DVDR.cpp, Line 2942 Start write address at LBA 0 DVD high compatibility mode: Yes 13:25:24 #19 Text 0 File Cdrdrv.cpp, Line 8914 ---- DVD Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33) Disc Size: 120 mm, Maximum Rate: <not specified> (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26127F h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Start sector number of the current Border-Out: 2FE10 h Start sector number of the next Border-In: 2FFA0 h Media Specific [16..63]: 00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!.... 00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 13:25:24 #20 SPTI -1046 File SCSIPassThrough.cpp, Line 290 E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x30 Sense Qual: 0x05 CDB Data: 0x53 00 00 00 00 00 22 FB C0 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 05 13:25:24 #21 CDR -1046 File ThreadedTransferInterface.cpp, Line 1799 Illegal disc E: _NEC DVD_RW ND-2500A 13:25:24 #22 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1799 Could not perform start of Disc-at-once 13:25:24 #23 Phase 38 File dlgbrnst.cpp, Line 1730 Burn process failed at 2.4x (3 324 KB/s) Existing drivers: File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 19.05.2006 22:16:24 File 'Drivers\PXHELP20.SYS': Ver=3.00.11B, size=46080 bytes, created 16.05.2006 21:23:54 (Prassi/Veritas driver for win 2K) File 'Drivers\scsiport.sys': Ver=5.1.2600.2562 (xpsp.040919-1030), size=96384 bytes, created 15.10.2005 16:11:00 (Adapter driver for src) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) 7534539[/snapback] hadde også problemer i begynnelsen med å brenne dvd, men nå vet jeg ikke om du har samme feilen men når du skal brenne en dvd så bruker du "lag din egen dvd-plate ikkesant? deretter klikker du mye neste helt til slutten der du skal trykke "brenn" der må du gå inn på instillingene som er i margen til høyre og så må du huke av for "bur at once eller noe sånt
TSP Skrevet 19. desember 2006 Skrevet 19. desember 2006 (endret) Vet ikke om det er så mye til hjelp; men har du husket å velge "DVD" i stedet for "CD" oppe i hjørnet? Ellers vil jeg anbefale å prøve det griped sier, og ellers prøve å se nøye etter om de er andre innstillinger det virker logisk å endre eller huke av for. Endret 19. desember 2006 av The Strategy-player
mEhE` Skrevet 19. desember 2006 Forfatter Skrevet 19. desember 2006 Vet ikke om det er så mye til hjelp; men har du husket å velge "DVD" i stedet for "CD" oppe i hjørnet? Ellers vil jeg anbefale å prøve det griped sier, og ellers prøve å se nøye etter om de er andre innstillinger det virker logisk å endre eller huke av for. 7535282[/snapback] dobbelklikket bare på en isofil og trykket burn.dette har jeg aldri hatt problemer med før.. prøvde flere isofiler også.. virker som det er platene det er noe i veien med?
