1000 hz kjerne i Ubuntu
I've read in several forums it has something to do with the "idle"-state (or "C3") of the processor. There is a frequency called "timer interrupt" (or so mething like that). Since kernel 2.6x it is set to 1000 Hz by default (compared to 100 Hz in Kernel 2.4x). The exact reason i don't know, but it is safe to change this frequency to 100 Hz in kernel 2.6x (by the way, windows up to XP uses 100 Hz by default).
Just do the following:
In [path to kernel-sources]/include/asm-i386/param.h find the line
#define HZ 1000
and change the value of HZ to 100:
#define HZ 100
Then recompile the kernel.
In modern kernels this constant is in the kernel configuration Timer Frequency → Processor type and features (CONFIG_HZ).
Med andre ord, det Mr.Elendig sa.
Endret av huf
