Endring i mounts? :o
The Test Realm is now live with patch 1.12.1. In this patch, the cost for mounts have changed, and mounts will now only require one shared riding skill. A riding skill of 75 is required for Blue mounts, and a riding skill of 150 is required for Epic mounts. The learning cost for riding skill has been changed, and the cost for purchasing your mount has also been changed.
Mounts
Mounts now require only one, shared riding skill (blue mounts require level 75, epic mounts, level 150). Also costs of learning this skill are now significally increased. Previously, cost of learning riding skill was 20 gold for each kind of mount, without any discount. Now it will be 90 gold for level 75 and 900 for level 150. Level 150 of riding skills is required for epic mounts and will most probably include PvP mounts and all mounts that drop in instances (Tiger, Raptor, Baron mount, bug mount and maybe paladin and warlock mount too). For now I can confirm that it is required to ride Stormpike Battle Charger, rest of mounts require confirmation.
In addition to the change of riding skills, the costs of Blue and Epic faction mounts has been significally decreased. Now blue mounts costs 10 gold and epic mounts costs 100 gold.
World PvP
# Players will no longer lose the Silithus or Eastern Plaguelands PvP buffs after dying in the zone.
# Players will now port to the Crown Guard Tower graveyard if they die in Fungal Vale while their faction controls the tower.
# Players will no longer be interrupted while sitting down in Eastern Plaguelands when contested towers change ownership.
# Players will no longer be interrupted while sitting down in Silithus when a side collects 200 Silithyst and wins the event.
# In the Silithus World PVP event, the dust cloud graphic that appears on a flag carrier will now properly trail behind the character while running.
# Players will no longer receive honor if a tower in Eastern Plaguelands is captured while they are stealthed.
# Lordaeron's Blessing buff from Eastern Plaguelands is no longer dispellable.
# Players on Windows machines will now hear the victory music when their faction fully captures a tower in the Eastern Plaguelands.
Warlocks
# Players that log out of the game and back while having a pet summoned will now be properly credited a Soul Shard.
# Warlock pet sounds have now been added in all languages.
Warriors
# Canceling Bloodrage while in PvP or dueling will no longer remove you from combat.
Items
# Most enchantments on items are no longer counted against the maximum limit of effects a player can have on them, so it should be much harder for a player to exceed their max limit on effects and have one be removed involuntarily.
# Fixed a graphical error with the Dreadnaught Helmet.
# Fixed an issue in which the "Blessing of the Claw"from the 6 piece Dreamwalker set was causing players to stand up after trying to eat or drink.
# Fixed an issue where multiple armor set bonuses were not applying correctly when switching out pieces.
# Fixed an issue where the four
# piece Plagueheart set was not properly applying to corruption.
# The Blade of Eternal Darkness will now only proc when damage is done.
# Fixed a graphical error with the Dreadmist mask in which it would float above the Tauren Females' head.
# Fixed a graphical error in which enchantment glows were not updating if the same item with a different enchant or no enchant was equipped.
User Interface
# UI windows will now be positioned correctly if the right action bar is activated.
# When going from Windowed mode to Full
# Screen mode, player names will no longer be replaced with "..."
# The Quest Tracker will now properly display purchased quest items.
# The Battle Map in Outdoor PvP and in the Battlegrounds will no longer get stuck when dragging with the cursor in windowed mode.
# The Battle Map in Alterac Valley will no longer switch off whenever a graveyard,tower or mine changes ownership.
Bugs
# Players will now be able to complete the quest,"Target: Hive'Ashi Sandstalkers".
# Fixed an issue where players could be afflicted by "Withering Touch" more than once at a time.
# The Plaguewood teleporter will now teleport players to the correct location within Naxxramas.
# Fixed an issue where players were getting the message "Invalid" when trying to select flight paths.
# Fixed an issue where if the disenchant window was forced closed, a player would lose both their reagent and the item they were disenchanting.
# Fixed an issue where players could crash while fighting Anub'Rekhan.
# Fixed an issue in which players trying to disenchant an item with a full inventory and then casting a spell afterward would lose the reagent and the item.
# Fixed an issue where weapon procs will now work with instant abilities.
# Pet buffs will now apply and remove properly.
# The Priest talent Spirit Tap will no longer sometimes proc off of totems.
Mac
# Players will no longer hear any sound when they have "Enable all Sound" turned off.
http://www.curse-gaming.com/en/news-357-1-...nt-changes.html
Noen som vet mer om dette?
Endret av SilverCRX
Så nå vil man måtte betale 900g for å bruke en epic mount, samme hvilken det er? GG Blizzard, trodde dere ville minske antallet spillere som kjøper gull, ikke øke det. Blir nok ikke akkurat færre boter og chinese farmers etter dette...
6875713[/snapback]
Lære seg å lese kanskje?
Azagrath har da lest riktig? det står jo at man må betale 900g for riding skill 150, som igjen er krav for å bruke hvilken som helst epic (100%) mount..
Slik jeg forstår teksten iallefall
Forbanna dritt, visst eg tolker dette rett, so har det ingenting å sei om man er rank 3 og exalted med AV?
Exalted med darnassus, osv, må no iallefall ha noke å sei?
Forbanna tåplig dritt visst det stemmer!
Det har han selvfølgelig. Jeg svarer egentlig på noe han aldri har sagt. Sorry =( Det jeg mente var at dette er gode nyheter for dem som har lyst på mountene til andre factions. Dette vil nå bli billigere. For dem som skal kjøpe sin første epic mount, er dette langt i fra bra.
Vel, det vil jo bare bli 18g mindre å betale.
BTW: Fint for de som vil ha WS-mounten. Før måtte man jo både være exalted med de som selger mounten, og Darnassus.
Endret av Sigga
Topp :thumbup:
For en epic mount samler som meg er dette topp nyheter :p
Der står at det eneste som krever er skills. Betyr det at man kan få epic mount i level 1?
6875769[/snapback]
En mount er nok fortsatt lvl 40 req og lvl 60 req.
gg rank 11 =/ wasted time..
6875466[/snapback]
Det har det alltid vært :thumbup:
Endret av Phoenixs
Leste nettopp mer om dette på det amerikanske forumet. Fremtidige pvp mounts skal ihvertfall fortsatt være billige (kun kreve 75 skill), siden det tross alt kreves en del arbeid å skaffe de.
Riktig det, det lønner seg for de som skal ha flere epic mounts.
6876007[/snapback]
Det blir litt digg ja.
Men jeg tror ikke på dette før jeg får se Official notes!
Gjest medlem-75284
Så dette betyr at man kan få mounts fra begge factions?.. *Gnome og Kodo  :love: *
6876087[/snapback]
Hvor skal du få kjøpt kodo?
Endret av medlem-75284
