Irriterende virus alert...
jeg skal fikse en pc der det kommer opp en pop-up melding som heter virus alert... den legger seg på statuslinja og går ikke an å fjerne, uheldegvis vil ingen spywareprogrammer gjenkjenne denne pop-upen og heller ikke virusprogrammer.
Noen som har hatt dette problemet eller som kan hjelpe?
:hmm:
her har vi loggen
Logfile of HijackThis v1.99.1
Scan saved at 11:23:11, on 01.06.2006
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\Programfiler\Windows Defender\MsMpEng.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\System32\S24EvMon.exe
C:\WINDOWS\system32\spoolsv.exe
C:\PROGRA~1\TRENDM~1\INTERN~1\PcCtlCom.exe
C:\WINDOWS\system32\ZCfgSvc.exe
C:\PROGRA~1\TRENDM~1\INTERN~1\Tmntsrv.exe
C:\PROGRA~1\TRENDM~1\INTERN~1\tmproxy.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\dcomcfg.exe
C:\Programfiler\Trend Micro\Internet Security 14\pccguide.exe
C:\WINDOWS\SOUNDMAN.EXE
C:\PROGRA~1\LAUNCH~1\CPLBCL53.EXE
C:\WINDOWS\AGRSMMSG.exe
C:\WINDOWS\System32\igfxtray.exe
C:\WINDOWS\System32\hkcmd.exe
C:\Programfiler\Java\jre1.5.0_06\bin\jusched.exe
C:\Programfiler\Windows Defender\MSASCui.exe
C:\Programfiler\QuickTime\qttask.exe
C:\WINDOWS\system32\ctfmon.exe
D:\AV\hijackthis\HijackThis.exe
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\Programfiler\Spybot - Search & Destroy\SDHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Programfiler\Java\jre1.5.0_06\bin\ssv.dll
O2 - BHO: Nothing - {f79fd28e-36ee-4989-aa61-9dd8e30a82fa} - C:\WINDOWS\system32\hp100.tmp
O4 - HKLM\..\Run: [pccguide.exe] "C:\Programfiler\Trend Micro\Internet Security 14\pccguide.exe"
O4 - HKLM\..\Run: [soundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [LManager] C:\PROGRA~1\LAUNCH~1\CPLBCL53.EXE
O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
O4 - HKLM\..\Run: [igfxTray] C:\WINDOWS\System32\igfxtray.exe
O4 - HKLM\..\Run: [HotKeysCmds] C:\WINDOWS\System32\hkcmd.exe
O4 - HKLM\..\Run: [sunJavaUpdateSched] C:\Programfiler\Java\jre1.5.0_06\bin\jusched.exe
O4 - HKLM\..\Run: [Windows Defender] "C:\Programfiler\Windows Defender\MSASCui.exe" -hide
O4 - HKLM\..\Run: [QuickTime Task] "C:\Programfiler\QuickTime\qttask.exe" -atboottime
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Programfiler\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Programfiler\Java\jre1.5.0_06\bin\ssv.dll
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupdate/...b?1136804197844
O20 - Winlogon Notify: igfxcui - C:\WINDOWS\SYSTEM32\igfxsrvc.dll
O20 - Winlogon Notify: Sebring - C:\WINDOWS\System32\LgNotify.dll
O20 - Winlogon Notify: WgaLogon - C:\WINDOWS\
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Programfiler\Fellesfiler\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: Kortveksling (IntelRoam) - Intel Corporation - C:\Programfiler\Intel\Switching\User\RoamSvc.exe
O23 - Service: Intel NCS NetService (NetSvc) - Intel® Corporation - C:\Programfiler\Intel\NCS\Sync\NetSvc.exe
O23 - Service: Trend Micro Central Control Component (PcCtlCom) - Trend Micro Incorporated. - C:\PROGRA~1\TRENDM~1\INTERN~1\PcCtlCom.exe
O23 - Service: Spectrum24 Event Monitor (S24EventMonitor) - Intel Corporation - C:\WINDOWS\System32\S24EvMon.exe
O23 - Service: Trend Micro Real-time Service (Tmntsrv) - Trend Micro Incorporated. - C:\PROGRA~1\TRENDM~1\INTERN~1\Tmntsrv.exe
O23 - Service: Trend Micro Personal Firewall (TmPfw) - Trend Micro Inc. - C:\PROGRA~1\TRENDM~1\INTERN~1\TmPfw.exe
O23 - Service: Trend Micro Proxy Service (tmproxy) - Trend Micro Inc. - C:\PROGRA~1\TRENDM~1\INTERN~1\tmproxy.exe
men tror ikke den ligger der.. derfor er det vanskelig å slette den :ermm:
La meg først si (ikke uventet?) at du nok skulle ha postet en siste HJT-logg i den forrige tråden. For dette ser veldig ut som den samme maskinen altså. :roll:
Her er spor etter SpywareQuake:
http://www.processlibrary.com/directory/files/dcomcfg/
Prøv denne siden:
http://www.bleepingcomputer.com/forums/topic47826.html
Riktig det.. har prøvd å fjerne den fra registeret, men det gikk ikke bra.. =) skal sjekke nettsidene nå
Prøv denne siden:
6220777[/snapback]
vil helst ikke laste ned noe nytt.. det er en viss risiko å laste ned ukjente programmer =) :nei:
Da kan jeg ikke hjelpe deg dessverre.
Merk at bleepingcomputer er et av de aller beste utgangspunktene for å bli kvitt SpywareQuake/SpyFalcon/SpyAxe. Man behøver ikke være skeptisk til det fastlegen gir fordi om man har vært uheldig med medisin kjøpt på Ebay...
Sa ikke du at du hadde kjørt SmitFraudFix? Den må du kjøre i safe mode, og velge aternativ 2:
Clean:
Reboot your computer in Safe Mode (before the Windows icon appears, tap the F8 key continually)
Double-click smitfraudfix.cmd
Select 2 and hit Enter to delete infect files.
You will be prompted: Do you want to clean the registry ? answer Y (yes) and hit Enter in order to remove the Desktop background and clean registry keys associated with the infection.
The tool will now check if wininet.dll is infected. You may be prompted to replace the infected file (if found): Replace infected file ? answer Y (yes) and hit Enter to restore a clean file.
A reboot may be needed to finish the cleaning process. The report can be found at the root of the system drive, usually at C:\rapport.txt
Dette tar Spyfalcon/Axe/osv.
Bleepingcomputer er en kjempesite, men så vidt jeg husker ber de deg om å bruke SmitRem, og det er ikke oppdatert på noen tid, slik at SmitFraudFix i dag er sterkere. Jeg har ikke hørt om noen tilfeller der SFF ikke har tatt denne typen infeksjon hvis kjørt riktig.
Bernt K
Clean:
Bernt K
6220993[/snapback]
det var vist smitrem jeg kjørte, og såklart kjørte jeg det i sikker modus :thumbup:
