Moff Skrevet 13. mai 2006 Skrevet 13. mai 2006 Finnes det en kode til indiana jones and the Emperors Tomb der man enten skrur ned intelligensen på fienden eller skrur den helt av ? Og finnes det en kode slik at man kan få panzerschrecken eller Pa Chengen ? Btw : Har runna spillet. Vil nå prøve komboer m.m Vet at cheats er lack of men er litt gøy å f. eks prøve den såkalte panzerschrecken ^^
SkyMarshall Arts Skrevet 15. mai 2006 Skrevet 15. mai 2006 God mode: Hold L + R and press Up(2), Down, Up, A, X, A, B, Up, Down, Y, Start at the "Press Start" screen. Note: Use the D-pad. A song will confirm correct code entry. You will become invincible with unlimited ammunition. Glitch: Unlimited grenade capacity: Get two grenades and you will find out that this is all you can normally hold in your pack. However, if you jump into water while holding a third grenade, you will put it in your pack. Repeat this as often as desired for unlimited grenade capacity. Cheat mode: Note: This procedure involves editing a game file; create a backup copy of the file before proceeding. Use a text editor to edit the "default.cfg" file in the "\lucasarts\indiana jones and the emperor's tomb\gamedata\indy" folder. Add the following line to the existing content of the file: cheats:1 This unlocks unlimited air when swimming, unlimited ammunition, and unlimited health. These options do no seem to be individually selectable. Information in this section was contributed by BeLGaRaTh. To unlock more cheat effects, add the following lines to the file. You will get a few more weapons including a Panzerschreck, Luger, Mauser, spear gun, crossbow, Tommy gun, MP-40 SMG and the art galley. cheats:1 cheats:12 To get just a Panzerschreck weapon, add the following line to the file: cheats:2 To get all weapons, but not the art gallery, add the following line to the file: cheats:3 To get the Pa Cheng (throwable weapon) at the beginning of the game, add the following line to the file: cheats:5 To be invincible and have all weapons, add the following lines to the file: cheats:1 cheats:13 To continue from the beginning of the level after Indy dies, without the whole reload process, add the following line to the file: cheats:100 ----------- Det var alt jeg hadde!
