Group til å drepe azuregos
10-40, Trenger en tank. et par healers. resten dps.
Om du er på en high pop pvp server vil du antakeligvis trenge ganske mange fler ;)
Vil anbefale mer en 2 tanks, dersom azuregos resister taunt, vil mange DPS players bli slaktet ned. Ellers er azuregos en enkel fight, zerg til teleport pause, og zerg igjen...
Endret av alex503
Strategy
Once Azuregos has been aggroed, all the dps and healers stand at his sides WITHIN teleport range. Melee attack on his sides to avoid his breath and other frontal attacks. The MT keeps Azuregos facing parallel to the dps/heal groups. A few healers keep the MT(s) up while the other concentrate on keeping everyone up.
It is key for everyone to be in teleport range when the teleport happens, as this clears his aggro. Each time a teleport occurs everyone runs back to their side positions. ALL DPS AND HEALING must STOP until the MT has aggro again; it is usually sufficient to give the MT 5 seconds before the rest of the raid unloads. DPS resumes until the teleport happens again. Obviously use potions and bandages as necessary after teleports. Rinse and repeat until Azuregos goes down.
If any casters need to drink, wait until the next teleport and then run away from the raid. Otherwise you will be the only person on Azuregos' aggro table and he will come after you.
Mages should keep themselves buffed with Frost Ward and use Scorch. Fireballs are not allowed, for three reasons: 1) When the magic shield goes up, it hurts a lot less 2) The scorch debuff does not stack up like the fireball one does 3) Quick casting time lets you get more in between teleports.
This fight is mana intensive. Curse of Elements and Judgement of Wisdom should be on the dragon at all times.
Greater Frost Protection Potions are very helpful in this fight. They require 1 elemental water, 1 dreamfoil, and 1 crystal vial.
There are no legitamate means to remove Mark of Frost.
vi hadde "random" zerg hvor de fleste hadde 7+ deaths :wee:
5610123[/snapback]
Den taktikken fungerer heller dårlig nå siden dem innførte "Mark of Frost".
Graveyard zerg var den mest brukte taktikken i gamle dager:
Man pullet azuregos ned til graveyarden på stranda i Azshara og drepte han der, om noen døde resset de bare med en gang.
5610123[/snapback]
5610234[/snapback]
nåja, det var etter mark of frost ble innført. var litt på sparket raid da, men likevel morro :)
Mages kan ice blocke bort mark of frost. Kunne i alle fall. begynner å bli en stund siden jeg spilte på magen min. Paladins kan fjerne den med devine shield.
