Reputation: Cenarion Hold, Rewards?
Gjest Slettet-uVTr2vDm
Jeg har nå grindet meg opp til et stykke over revered med
cenarion hold som befinner seg i silithus.
Så ser jeg folk som på dø og liv skal komme seg opp i exalted...
hvorfor? hva er rewards? ble dritskuffa da jeg nesten ikke fikk en dritt selv på revered, bare masse leatherworkinggreier som jeg ikke engang kan bruke.
Jeg er priest og grinder pages for rep med roguen min...
Noen som vet hva som er rewards i cenarion hold?
Vi har allerede spawnet en god del epicbosser og funnet noen fine items.
Takker for all hjelp.
Så snart AQ-porten åpnes vil det bli langt flere quests tilgjengelig, samt at AQ20 gir rewards avhengig av den Cenarion Hold-faction.
--Posted by Demetrius--
The "Field Duty" quests requirements that I have learned so far are shown below. Please add any additions or corrections by replying to this message and I will keep list below current.
You obtain the Field Duty quest at the Cenarion Hold in Silithus. It gives you an unsigned letter and you must travel to a new camp outside Hive Zora and get the papers signed by Captain Blackanvil. You then return to the quest giver and you choose one of the following: Logtistics Assignment, Combat Assignment, or Tactical Assignment. I simply ran back and forth and obtained to obtain multiple assignment and you can have as many assignments as your quest log will allow.
Logistics Quests (collect and turn in this stuff)
1 4 Globes of Water, 4 Power Anti-venom, 4 Smoked Desert Dumplings
2 3 Ornate Mithril Boots
3 10 Heavy Grinding Stones, 10 Solid Grinding Stones, 10 Dense Grinding Stones
4 A: 6 Oils of Immolations, 5 Goblin Rocket Fuel, 10 Dense Blasting Powder
4 H: 6 Powerful Mofo, 6 Big Mojo, 8 Oil or Immolation
5 1 Large Brilliant Shard, 1 Large Radiant Shard, 1 Huge Emerald
6 A: 2 Moonsteel Broadswords
6 H: 3 Massive Iron Axes
7 8 Rugged Armor kits, 8 Heavy Armor Kits
8
9 2 Enchanted Thorium, 2 Enchanted Leather
10 30 Heavy Runecloth bandages, Heavy Silk Bandages, Heavy Wool Bandages
11 3 Abomination stitchings, 1 Skin of Shadow, 1 Twilight Cultist Robe ... yields 1 Mark of Romulus (needed for revered reward)
Combat Quests (kill these things)
1 40 Hive'Ashi Defenders
2 40 Hive Sand Stalers
3 40 Hive Ashi Workers
4 40 Hive Zora Reavers
5 40 Hive Zora Sisters
6
7 40 Hive Zora Tunnelers
8
9 40 Hive’Regal Spitfires
10
11 40 Hive'Regal Burrowers
Note - some of these quests can be solo'd possibly and some need a small group.
Tactical Quests (kill or do these commands)
1 Kill Azure Templar
2 Kill Crimson Templar
3 Kill Earthen Templar
4 Kill Hoary Templar
5 Kill 4 Dukes, receive Mark of Cenarius (needed for exalted reward)
6 Sneak into Hive Zora, obtain Scout report from Azenal
7 Sneak into Hive Regal, obtain scout report from Landion
8
9 Kill Morna and 5 Twilight Marauders
10 Obtain twilight orders from the Twilight Prophet
Again, you can have at multiple assignments at the same time. When you complete an assignment you typically get 650xp and 50 CC rep. You simply turn in the scoll that gave you the assignment and then you are give a new assignment. You cannot repeat the same assignment but you may/may not get the same assignment again as you are given new assignments.
These assignments may/may not be involved in the opening of the AQ gates. My guess is that we will have to gather a certain number of badges as one of many prerequisites to opening the gates.
Here are the quest rewards for turning in the badges from this quest line:
The first reward quest is called “Cenarion Battlegear†and requires friendly reputation, 5 combat badges, 3 logistics badges, and 7 tactical badges. Once you collect the various badges you can choose between:
1. Gloves of Earthen Power – leather AC 109 Int 9 +27 damage/heals
2. Band of Earthen Wrath – ring +8 int +1 spell crit +3 mana/5 secs
3. Earthweave Cloak – cloak AC 44 Agi 15 +1 hit
The second reward quest is called “Veterans Battlegear†and requires honored reputation (note – this may be honored and a bug), 7 combat badges, 4 logistics badges, and 4 tactical badges. Once you collect the various badges you can choose between:
1. ? of Earth – trinket reduces threat
2. Band of Earthen Might – ring +6 str +1 crit +1 hit
3. Earthen Power Vest – cloth chest AC 93 Int 22 +1 spell crit + 25 damage/heals
The third quest is called “Stalwarts Battlegear†and requires revered reputation, 15 combat badges, 20 logistics badges, 17 tactical badges, and a Mark of Romulus. Once you collect the various badges you can choose between:
1. Deeprock Bracers (epic) – AC 309 10 str 10 agi 8 sta
2. Earthcalm Orb – offhand 10 int 8 mana/5 sec +18 heals
3. Rockfury bracers – cloth wrist AC 42 7 fire resist +27 damage/heals +1 hit spells
4. Might of Cenarius – ring +8 sta + 4 wep damage + 1 hit
The fourth quest is called “Champions Battlegear†and requires exalted reputation, 20 combat badges, 15 logistics badges, 20 tactical badges, and a Mark of Cenarius. Once you collect the various badges you can choose between:
1. Fist of Cenarius (epic) – 62.6 Mace 3.5 spd +40 damage/heals +2 crit spells
2. Wrath of Cenarius (epic) – ring Use: Increase +132 damage for 10 secs
3. Earthstrike (epic) – trinket Use: Increase AP by 280 for 20 secs
Perhaps the 4 Epics above are the "casual" epics that people have been asking for?
Demetrius
Some other guy quoted:
"Two sets of quests I know of. Both have faction requirements.
One set of quests is class specific and will require running AQ20. These are similar to the ZG quests.
The other set is geared for non-raiders; they can be done outside of AQ. There is some starter quest (defend an NPC against attackers) that will result in you being given battle orders. The battle orders are various kill and collect quests (e.g. bring 8 rugged and heavy armor kits or kill 40 of the elite bugs in Silithus). Completing the quest will give a badge and another set of orders.
There are 3 different types of badges. At each faction level you will have the option of turning in the badges for items.
Some of the items available:
http://www.wowguru.com/db/items/band-of-ea...n-might-id21182
http://www.wowguru.com/db/items/fist-of-cenarius-id21188
http://www.wowguru.com/db/items/earthstrike-id21180"
Yet another one:
Cenarion Hold has non-raid quests that can be done in portions for rare and epic items. These rewards require Cenarion Circle reputation.
There are a 3-piece set of equipment for the 20-man side; the 3rd piece is a weapon geared for your class and epic. These rewards require Cenarion Circle reputation.
There is a 5-piece set of equipment for the 40-man side; All pieces are armor and epic. The quests are (to my knowledge) attained inside the Temple of Ahn'Qiraj itself. These rewards require Brood of Nozdormu reputation, which is earned inside the instance.
HER ser du i tillegg noen av de "3-piece"-settene nevnt ovenfor, hvor siste del av settet er et epic våpen; det er visst våpenet som krever exalted reputation.
