TanglewoodD Skrevet 2. november 2005 Skrevet 2. november 2005 Det med overskriften er bare litt overdramatisk, det er selvsagt person til person om spellet er det mektigste, men fra spøk til alvor. Patchen til SH3, den seneste, hva er det den retter på ? Er det noe nye missions , ubåter osv ? Har bare prøvd det orginale for 1mnds tid, men vil gjerne vite mer om patchene ;D
Opus Skrevet 2. november 2005 Skrevet 2. november 2005 Med spillet fulgte et program som heter Gameshadow, bruk det og du finner nyeste patch. Er kommet en exspansion pack, men jeg tror ikke det er noen nye ubåter der. Er en haug med nye missions og mye annet småfiks. Dårlig emnetittel btw. Please fix it.
Amnio Skrevet 3. november 2005 Skrevet 3. november 2005 I patch 1.4 er følgende forandret: * Campaign radio messages improved so that a message can have "from" and "to"fields * Multiplayer version changed to 1.4. * Fixed the bug concerning sonar ping for clients * Added new buildings in German bases (harbors) * UZO view by night was improved; * Navigator tells when the last waypoint was reached; * Customizable values for storm parameters for each U-Boat (see StormConditions entry for each uboat.cfg file); * Depth report only when diving (from 10 to 10 meters); Time compression will drop to 1 (if greater) when critical depth was reached; * Sonar new contacts are identified as merchants or warships (not as unknown contacts as in the previous patch); * Sonar indicator will move faster when the player is at sonar station (and clicks on the sonar dial); and now it can be dragged with the mouse; * Some shortcut keys will toggle between current view and the next view: radio messages (M), captain's log (K), hydrophone station (H) and radio station ®; * A new option was added on "Merchant/Warship/... spotted" popup window. By checking this check box (called "Set as default action") the selected action will be always performed when the situation occurs. This default action will be saved from a game to other and can be reset, during the game (when press ESC) by choosing "Options/Reset default action" from Game options; * Corrected several torpedo descriptions errors within the game * Added the P38 fighter bomber to the inventory of American forces and the campaign * Added the Wellington bomber to the inventory of British forces and the campaign * Corrected the damage model for the German Armed Merchant Cruiser * Increased the detonation range of star shells to 1800m * Changed Torpedo Momber aircraft type designation to Bomber * Improved the rough waters behavior of Small and Coastal Merchants * Sonar man - Fixed a bug where "Report on nearest contact" was not function properly * Sonar man - Fixed a bug where "Follow nearest contact" was not function properly * Dynamic campaign - Add new harbor ships and traffic, including merchants, minefields and patrols * Dynamic campaign - Corrected some data in the naval rooster Full liste over forandringer (også tidligere patcher) kan f. eks. finnes her.
