Personlige meldinger i MSN
Poldi
Hallo'n der ute...
Er det noken som veit om de går ann å fjerne de personlige meldingene folk har etter navnet i msn ?
Navet kan forandres i plus pakken , men kan ikke sjå at eg kan forandre/fjerne de personlige meldinger etter navnet.....
Sleng ned A-Patch, så kan du fjerne alt du vil av fjortiss-stoff.
The current features for the latest build (7.5.0306) are as follows:
[Contact List] - 23
Remove MSN Logo
Remove "Messenger" Title
Remove Display Picture Container
Remove Personal Message Bar
Remove E-mail Button
Remove MSN Today Button
Remove My Space Button
Remove Add Contact Button
Remove Search Bar
Remove Button Text
Remove Advertisement
Change Display Picture Link
Remove Contacts Personal Message
Remove Buttons From Contact Card
Remove Gleam Notification
Add Always On Top Button
Add Sign Out Button
Disable Song Links
Fix Add Contact Bar Position
Disable MSN Spaces Contact Card Integration
Remove Display Picture in Sign-In Window
Remove Bottom Links in Sign-In Window
Remove Microsoft Passport Network Branding
[instant Message] - 37
Remove MSN Logo
Remove Invite Button
Remove Send Files Button
Remove Web Cam Button
Remove Voice Button
Remove Activities Button
Remove Games Button
Remove Block Button
Remove Color Button
Remove Search Button
Remove Send Button
Remove My Display Picture
Remove Font Button
Remove Emoticons Button
Remove Voice Clip Button
Remove Backgrounds Button
Remove Winks Button
Remove Packs Button
Remove Nudge Button
Remove What's Hot Section
Remove Standard Toolbar Text
Remove Formatting Toolbar Text
Remove User Is Writing Message
Change Ink Tabs to Text
Remove To: Bar
Remove Web Cam Icon from To: Bar and Avatar Containers
Remove Nudge Delay
Disable Nudge Shake
Add Send Button to Handwriting Tab
Add Mess.be Custom Games
Remove Yellow Info Bar
Remove Convert Tab
Remove "says" Text
Remove "Get a Webcam" Link
Auto Hide Display Pictures
[Miscellaneous] - 8
Offline Systray Status
Polygamy (Multi-MSN)
Show Idle Status
Remove File Transfer Protection
Boost Personal Message to 500 Characters
Remove Billing Info Menus
Shorten Status Info in Info Bar
Install WinAMP Plug-in for Now Playing feature (thanks to Shane at www.myplugins.info)
Endret av Tordenflesk
