Ny ver.: BitComet 0.60 - m/preivew av nedlasting
Spragleknas
What is BitComet (A powerful C++ BitTorrent Client)?
BitComet is a p2p file-sharing freeware fully compatible with Bittorrent, which is one of the most popular p2p protocol designed for high-speed distribution of 100MB or GB sized files. BitComet is a powerful, clean, fast, and easy-to-use bittorrent client. It supports simultaneous downloads, download queue, selected downloads in torrent package, fast-resume, chatting, disk cache, speed limits, port mapping, proxy, ip-filter, etc.
Features
* Clean and free, without any adware or spyware. ( Please note: Spybot may misreport "Comet Cursor" )
* Completely new core written in C++, stable and fast, very low CPU usage. (detail)
* Multiple simultaneous downloads, ability to select download files in one torrent and set file priority. (detail)
* Ability to limit the upload speed as well as download speed.
* Support preview video file during downloading.
* Support DHT Network, download trackerless torrent!
* Intelligent Connection Optimize, Auto Optimization for different connections, runs well using all default settings.
* Intelligent Rate Control, optimize the upload distribution in order to get the max download rate.
* Intelligent Disk Cache, decrease the potential damage to the hard disk when high-speed downloading (>500KB/s) by decrease the read / write frequency, extra memory usage is the cost. (detail)
* Intelligent Disk Allocating, no long-time disk allocation, also decrease the disk fragment to almost zero.
* Intelligent Hash Scan, no time-consuming scanning when seeding / resume. (detail)
* Firewall and NAT Traversal, users behind differect NAT can now connect to each other (detail)
* Auto config ICF (Internet Connection Firewall) and ICS (Internet Connection Sharing) in Windows XP
* Auto config port mapping in router (UPnP support is required in router, Windows XP is required). (detail)
* Ability to block IP temporarily or permanently, compatiable with eMule ipfilter.dat.
* Ability to chat with other downloaders ( disabled by default )
* Compatiable with Windows XP SP2 TCP/IP restriction (detail)
* ZIP package is also provided, which runs withoust installation.
* Using only one TCP listening port. (detail)
* Support Multi-tracker, and utf-8 extension, UDP tracker Protocol v2.
* [Please Note]: It is reported that Zone Alarm 5.0 conflict with BitComet (and other p2p maybe). (discussion here)
http://www.bitcomet.com/
Go get...
ESIT: Fikk rask nedlasting via denne linken;
http://www.mirastic.com/mirrors/BitComet_0.60_setup.exe
Endret av Okay
tips til deg Okay dersom du er interessert og ikke bruker det ennå:
registrer deg på http://fileforum.betanews.com/, velg de programmer som du bruker dersom de ligger i deres database og du får epost når det kommer ny versjon av de.
fikk nettopp mail om at OpenOffice.org kom ut i versjon 2rc1 :D
Endret av modellmakt
