kenneth11 Skrevet 27. september 2005 Skrevet 27. september 2005 hentet fra totalbf2.com. gidder ikke oversette This Thread will explain in detail how to unlock all weapons for use in 1.02 Single Player. Click here to download Battlefield 2™ Weapon Unlocker. Go to C:\Program Files\EA GAMES\Battlefield 2\mods\bf2 You will see a file called: Objects_server.zip BACK THIS FILE UP, then copy(or unzip) this file to a new folder. Inside the Objects_server.zip file you will see a directory labeled: Kits BEFORE YOU EDIT, RIGHT CLICK THE KITS SUBDIRECTORY AND UNCHECK 'Read Only' then apply to all subdirectories, etc. Open the Kits directory, then open the subdirectory of which faction you wish to unlock: (US, MEC, CH). You will see several files with the .con extension. With a text editor (Use NOTEPAD or ULTRAEDIT, etc. DO NOT USE WORDPAD), open each .con file corresponding to each class. For US the files are: US_Assault.con US_AT.con US_Engineer.con US_Medic.con US_Sniper.con US_Specops.con US_Support.con At the end of each file you will see the following text: ObjectTemplate.unlockLevel 1 Change this to: ObjectTemplate.unlockLevel 0 Click File->Save, then repeat for all files, then repack the Kits subdirectory into the Objects_server.zip file.(after saving files you can drag the folder back into the .zip file to repack it automatically, or manually rezip the files back) (Using winzip, winrar, etc. WINDOWS XP/2k ZIP Program will NOT work for rearchiving files as far as I know!) MAKE SURE YOU KEEP THIS EDITED .ZIP SEPERATE FROM THE ORIGINAL, you do NOT want to lose your original, as the modified will probably not work, and/or get you banned from multiplayer. (Since EA likes to suck) In my case, I made a new folder called 'UNLOCKS' and stuck my edited zip inside, then when I want to play singleplayer I rename the original: Objects_server.zip.ORIG and stick the edited Objects_server.zip from my UNLOCKS folder into the C:\Program Files\EA GAMES\Battlefield 2\mods\bf2 folder, then when i want to play multi, I move the edited .zip back to the UNLOCKS folder, and rename the Objects_server.zip.ORIG back to Objects_server.zip. PLEASE NOTE: ALL WEAPONS WILL SHOW AS NORMAL WHEN YOU JOIN A SINGLEPLAYER GAME, you will also notice there is NO up/down arrow to select an unlock like there usually is, this is because ALL weapons are now unlocked, and you HAVE to use the upgraded weapon, there is no option to use the normal weapons with this mod. This HOW TO was written so even an idiot could understand it, I'm sure 99% of you didn't need half of the detailed explanation, so hold your flame posts. -Cekken
E-wok Skrevet 27. september 2005 Skrevet 27. september 2005 Skjønte det ikke helt, siden det sto 1.02 Singel Player..
kenneth11 Skrevet 27. september 2005 Forfatter Skrevet 27. september 2005 Skjønte det ikke helt, siden det sto 1.02 Singel Player.. ok for å forklare...før patch 1.02 kunne man unlocke våpen til bruk i Single Player med litt diverse edits. DICE trodde de hadde fikset dette i 1.02, men det har de ikke ja det bør gå i vanilla BF2
kenneth11 Skrevet 27. september 2005 Forfatter Skrevet 27. september 2005 Funker detta på krækka spill? tror'kke det, men HOLD KJEFT OM DET FØR MODERATOR KOMMER!
minialeks Skrevet 30. september 2005 Skrevet 30. september 2005 hentet fra totalbf2.com. gidder ikke oversette This Thread will explain in detail how to unlock all weapons for use in 1.02 Single Player. Click here to download Battlefield 2™ Weapon Unlocker ............. Ja, vi må vel laste ned det der?
kenneth11 Skrevet 30. september 2005 Forfatter Skrevet 30. september 2005 hentet fra totalbf2.com. gidder ikke oversette This Thread will explain in detail how to unlock all weapons for use in 1.02 Single Player. Click here to download Battlefield 2™ Weapon Unlocker ............. Ja, vi må vel laste ned det der? må nok det ja
