Den store Nintendo Revolution tråden!
Hva er dere mest spent på angående Revolution?
211 stemmer
  1. 1. Hva er dere mest spent på angående Revolution?
    • Kontrollen
      121
    • Maskinvaren
      17
    • Lanseringstitlene
      22
    • Onlinesystemet
      10
    • Mulige medier
      2
    • 3. part bakoverkompabilitet
      21
    • Andre muligheter og spesifikasjoner
      17
too late :p
prebo...når du linker med img til det, så vil det automatisk endres ovenfor i de andre bildene også...?
Endret av AciD18
too late :p
:tease:
Men postet du URL'n til bildet? Da vil det nemlig opptatere seg selv..
You know, I didn't get a chance to see the Sony and Microsoft presentations for myself, but from what I've heard from people it sounds like they are going to be using cutting-edge technology, as are we. However, the way that they are planning on implementing that technology is obviously very different from the route that we're going to be taking.
IGNcube: Do we have to wait until E3 2006 for more Revolution info, or do you have a new Space World coming later this year?
Shigeru Miyamoto: That hasn't been determined. We haven't decided yet. I'm sure that there will be information that we'll get out somewhere, somehow, through developers or something. I'm sure there will be some leaks. But next year at E3, everything will be public as far as Revolution is concerned. It will all be out there, which should tell you that we're well into it. It's not that we don't have anything. So next year you'll get it all.
Nintendo=E1D!
Endret av Fanta Boy
Of course. It's set in stone. It has been determined. I'd love to show it to you. I'd love to be able to show you the features of the Revolution controller and tell you about them. However, unfortunately if we do that too early those ideas would be stolen. We know that from past history. Analog stick. Boom - gone. Rumble Pak. We bring it out and everybody has to have rumble. We got the wireless out first and now there's wireless everywhere. So we have to keep it under wraps
You know, in regard to the power of the Nintendo Revolution versus, say, the Xbox 360, we're looking at making a small, quiet, affordable console. If you look at trying to incorporate all that, of course we might not have the horsepower that some other companies have, but if you look at the numbers that they're throwing out, are those numbers going to be used in-game? I mean, those are just numbers that somebody just crunched up on a calculator. We could throw out a bunch of numbers, too, but what we're going to do is wait until our chips are done and we're going to find out how everything in the game is running, what its peak performance is, and those are the numbers that we're going to release because those are the numbers that really count.
I do think it's very irresponsible for people to say, "This is what we're running out. This is the power of our machine," when they're not even running on final boards. I think the professional's job is to not believe those numbers.
So for example, you might bring you DS home, turn it on, sit down next to the Revolution and there is some connectivity that allows you to play something that's better than it was with separate components. Our goal really is to build a system that appeals to everybody.
jepp...ser slik ut....reklamevegg som nylig ble skrudd på riktignok...men alikevel ikke noe spesielt :(
Tror ikke vi får se en dritt før noe blir leaked.
Nei dessverre blir det nok slik....
Er veldig spent på hva som kommer fra nintendo i kveld eller senere i e3 :huh:
Da fikk vi bekreftet hva det såkalte ''ON'' som ble vist på reklameveggen er...
Nintendo
Nintendo
eller...
Nintendo Online
Endret av Prebo
Nintendo eid?
lett å skjønne
Hvordan det?
Virker som det bare var ville spekulasjoner. E3 er ikke over da men.. kanskje vi får vite litt mer i morgen, hvem vet!?
Nintendo=E1D!
Hva skal det bety?
Nintendo= Eid=Genitiv=Eieform=eid=slang=e1d=ord med tall i=uforstårlig=Nintendo er tøff
:roll:
Endret av Fanta Boy
