Console commandoer i BF2?
SERVER ADMIN COMMANDS
MAPLIST COMMANDS:
- mapList.list
Every map on the server has an ID number, which is used for
voting to change maps. This command lists those numbers,
the map name, game mode and the number of players if specified.
- mapList.configFile <new location for file>
Used to specify the location of the _mapList.con
The default is \My Documents\Battlefield 2 Demo\ServerConfigs\
- mapList.load
Makes the server reload the _mapList.con
- mapList.save
Saves the current map list on the server to the file _mapList.con
- mapList.mapCount
Shows the total number of maps in the current map list
- mapList.currentMap
Shows the map list ID number of the current map being played
- mapList.clear
Clears the current map list.
Warning: If there are no maps in the map list when the server starts
loading a new map, all clients will be left on the loading screen.
- mapList.remove <map ID number>
Removes the map you specify from the map list
- mapList.append <map name> <game mode> [number of players]
Add a new map to the end of the map list.
You must specify the map name and the game mode. Number of players
is optional, if not specified will default to the current server
setting.
- mapList.insert <map ID number> <map name> <game mode> [number of players]
Exactly the same as mapList.append, but with this command you can
specify at what map ID number to insert the new map into the list at.
ADMIN COMMANDS:
- admin.listPlayers
Lists the players connected to the server.
This command lists the players ID number, their player name and if
the player is remote it also lists the players IP number.
The players ID number is also available on the Scoreboard / Manage Tab
- admin.runNextLevel
Forces the server to end the round and start the next map in the map
list.
- admin.currentLevel
Shows the map list ID number for the current map being played.
The same as mapList.currentMap.
- admin.nextLevel
Shows the map list ID number for the next map to be played.
- admin.restartMap
Restarts the current map.
- admin.banPlayer <player ID number> [timeout]
Enter the player ID number you would like to ban. Bans the player from
this server by using their IP address.
- Bans can be set on CD key hashes.
- Bans are stored as absolute times in banlist.con. Existing bans in
banlist.con will be interpreted as permanent bans.
You can choose from a selection of time outs:
- Entering 'perm' means that the ban is permanent. This is the default
if no time out is entered.
- An integral number meaning the number of seconds the ban will be
active (i.e. 3600 means one hour).
- Entering 'round' means the ban is active until the next map.
- A whole number preceded by a colon (i.e. :1234567), meaning the
epoch expiration time of the ban (number of seconds since 1 Jan 1970).
- admin.banPlayerKey <player ID number> [timeout]
this server by using their CD key hash.
You can also specify a time out. See admin.banPlayer for the time out
list.
- admin.addAddressToBanList <IP address> [timeout]
Enter the IP number you would like to ban.
list.
- admin.addKeyToBanList <CD key hash> [timeout]
Enter the CD key hash you would like to ban.
list.
- admin.removeAddressFromBanList <IP address>
Enter the IP address you would like to remove from the ban list.
- admin.removeKeyFromBanList <CD key hash>
Enter the CD key hash you would like to remove from the ban list.
- admin.clearBanList
Clears all ban lists.
- admin.listBannedAddresses
Displays a list of the currently banned IP addresses.
- admin.listBannedKeys
Displays a list of the currently banned CD keys.
- admin.kickPlayer <player ID number>
Enter the ID number of the player you would like to kick.
REMOTE CONSOLE ACCESS:
To setup remote console access to the server:
- On the server create a new plain text document in
\admin\ called default.cfg
- Enter the following text into the new file:
port=4711
password=YourPassword
- Save the file, and start the server.
Now you can access the server remotely by using the following commands
from a client:
- rcon login <YourPassword>
Use this command to login to the server.
- rcon users
This command lists all the users connected to the server.
Very similar to admin.listPlayers
- rcon exec <command name>
Replace <command name> with a console command you would like to
execute on the server.
For example: rcon exec admin.kickPlayer 3
Vet noen om noen console commandoer til BF2? Er det en liste elns?
Takker for svar!
...og alt dette står i readme-fila som følger med demoen.
