Hva eier mest ,Enchantment eller restoration sham?
ser dette er et hot subject.
Restoration er jo seigere da, ettersom du er bedre på healing...
Men reaper WF proccs....mmm
diskutèr:
Restoration Mastery
Improved Healing Wave
Rank 5/5
Reduces the casting time of your Healing Wave spell by 0.5 sec.
Tidal Focus
Rank 2/5
Reduces the Mana cost of your healing spells by 2%.
Improved Reincarnation
Rank 2/2
Reduces the cooldown of your Reincarnation spell by 20 min.
Ancestral Healing
Rank 5/5
Increases your target's armor value from items by 25% for 15 sec after getting a critical effect from one of your healing spells.
Combat Endurance
Rank 1/1
Allows 10% of your Health regeneration to work while in combat.
Improved Lesser Healing Wave
Rank 5/5
Gives you a 75% chance to avoid interruption caused by damage while casting Lesser Healing Wave.
Tidal Mastery
Rank 5/5
Increases the critical effect chance of your healing and lightning spells by 5%.
Nature's Swiftness
Rank 1/1
Instant 3 min cooldown
When activated, your next Nature spell with a casting time less then 10 sec. becomes an instant cast spell.
Restoration Total: 26
Enhancement Mastery
Shield Specialization
Rank 5/5
Increases your chance to block attacks with a shield by 5%.
Thundering Strikes
Rank 5/5
Improves your chance to get a critical strike with your weapon attacks by 5%.
Improved Ghost Wolf
Rank 2/2
Reduces the cast time of your Ghost Wolf spell by 2 sec.
Two-Handed Axes and Maces
Rank 1/1
Allows you to use Two-Handed Axes and Two-Handed Maces.
Anticipation
Rank 5/5
Increases your Defense skill by 10.
Flurry
Rank 5/5
Increases your attack speed by 30% for your next 3 swings after dealing a critical strike.
Improved Windfury Weapon
Rank 2/2
Increases the Attack Power bonus of your Windfury Weapon effect by 22%.
Enhancement Total: 25
Total
Total Points Spent: 51
Level Required: 60
Denne skal jeg gå for, og den er hjemmelagd.
diskutèr:
Som chokke her viser, så bør du absolutt satse på å få deg Nature's Swiftness fra Restoration-treet. En instant healing wave hvert 3. minutt kan nok være livreddende. :)
Chokke : Skjønner fortsatt ikke hvorfor du mener +10 def skill er bedre en +10 % bedre healing ? :|
Og hvorfor i svarte gå opp i shield spec vis han ikke ska bruke shield ?
Endret av lanez-nor
liker høy defense :)
EDIT:
Restoration Mastery
Rank 5/5
Tidal Focus
Rank 1/5
Reduces the Mana cost of your healing spells by 1%.
Rank 2/2
Ancestral Healing
Rank 5/5
Combat Endurance
Rank 1/1
Rank 5/5
Tidal Mastery
Rank 5/5
Nature's Swiftness
Rank 1/1
Purification
Rank 3/5
Increases the effectiveness of your healing spells by 6%.
Restoration Total: 28
Enhancement Mastery
Ancestral Knowledge
Rank 5/5
Increases your maximum Mana by 5%.
Thundering Strikes
Rank 5/5
Improved Ghost Wolf
Rank 2/2
Rank 1/1
Anticipation
Rank 3/5
Increases your Defense skill by 6.
Flurry
Rank 5/5
Rank 2/2
Enhancement Total: 23
Total
Level Required: 60
Endret av chokke
